diras2010
(help) AppleHDA for Dell XPS 435t, OS X 10.8.5
hi guys
i'm sort of newbie around OS X, i have installed successfully installed OS X 10.8.5 and have fixed manually a pair of kext, so i can understand part of the kext 'internals'
the issue comes with the audio (as same as a lot of people out there), i have read a lot of guides around the web, and i was able to 'build' a patched AppleHDA, but it doesn't work
the audio is Realtek ALC888 but is a v100101 and generally the patched kexts that i can found are for v100202 or newer
so i'm asking for anyone with more knowledge, that can check my files, and can spot the issues in my files
i'm attaching:
DSDT.aml
codec dump.txt
codec dump dec.txt
pin config.txt
codec dump.txt.svg
codec dump dec.txt.svg
verbs.txt
verbit debug.txt
mac.diego.r.ioreg
analized verbs.txt
platforms.xml.zlib (i was unable to convert it, the Revogirl's (R.I.P.) script suddenly stops working)
layout1.xml
for more info my pc spec are
Intel i7 920 2,66MHz socket 1366
7Gb RAM DDR3
X501H Dell OEM MoBo
EVGA GTX 285 1Gb DDR3 video
500Gb HDD SATA2
if anyone can help me i'll be very gratefull
stuff mac.diego.zip
0 answers to this question
