diras2010
Help required, AppleHDA in Dell XPS 345t (ALC1200/888 v100101)
hi guys!!
i REALLY ned help...
i'm an average user of OS X, i have read tons of guides and downloaded a huge amount of audio kexts and nothing seems to working
i have read CAREFULLY how to manually patch the AppleHDA and all the stuff, i have done all, and have ended with a supposedly working audio kext, but in the end it doesn't work
now i'm very frustrated because i don't know what else i can do
so i'm requesting help of any that can understand more and can help me...
i'm attaching all my related stuff:
DSDT.aml
codec dump.txt
codec dump dec.txt
pin config.txt
codec dump.txt.svg
codec dump dec.txt.svg
verbs.txt
verbit debug.txt
mac.diego.r.ioreg
analized verbs.txt
platforms.xml.zlib (i was unable to convert it, the Revogirl's (R.I.P.) script suddenly stops working)
layout1.xml
for more info my pc spec are
Intel i7 920 2,66MHz socket 1366
7Gb RAM DDR3
X501H Dell OEM MoBo
EVGA GTX 285 1Gb DDR3 video
500Gb HDD SATA2
if anyone can help me i'll be very gratefull
stuff mac.diego.zip
0 answers to this question
