TheAak
Help! I get a black screen after installing OSX!
I choose to install iAtkos ML2 on my computer. I successfully installed it but when I reboot into OSX I get greeted with some music and a BLACK SCREEN and the monitor lost signal. I am assuming this is a problem with my video card, so I reboot back into my Windows partition and use TransMac to navigate my OSX drive. I find a kext file for the video card I am using and decide to drop that into the System/Library/Extentions folder. I deleted all of the cached kext files and rebooted to no avail. Of course I tried all kinds of boot flags without any success. Single user mode wont start neither will safe mode.
Because my mobo is Dual UEFI I decide to use iAtkos ML3. I install OSX and get the same problem after the installation. I had no idea how to use the Clover boot loader at all so I could not try any bootloader flags.sad.png
Here are my system specs:
Motherboard: Gigabyte GA-B75M-HD3
Processor: 3rd Gen Intel Core i5 3570 4 cores - 3.50Ghz & 3.80Ghz Turbo Broken Integrated Graphics
Graphics Card: Nvidia GeForce GT 630 (MSI brand)
RAM: 16GB of DDR3 Ram distributed into two slots
Network: Realtek PCIe GBE Family controller
Display: Samsung Syncmaster 2494HM and Syncmaster SA450
Sound: Realtek Card
Storage: I am planning to install OSX on a 750 GB HDD
(I have Windows 7 on a ssd and a 2tb storage drive)
I have changed a few BIOS settings
enabled AHCI Sata
disabled Intel Vt-d
Hopefully somebody can help me with this, I want to run Mountain Lion encouragement.png
also I have access to another PC running OSX
I am going to use MyHack
I have installed it and I found out that the system folders are already extracted, this means I can install my kext files with no problem!?victorious.png?(Hopefully)
The Chat Moderator DUBZeeD recommended a kext file for my PC. Hopefully that is the only kext I will need to add to get OSX booting.?
I installed the N{censored} distribution. After the install has finished I boot back up to the spinny wheel and then a black screen.
I took a video of my installation and post installation
I would not call it a "good" video but it shows my problem in great detail
In this video I install OSX Mountain Lion 10.8.5 and I get a black screen while trying to boot up post install.
I really want to use Mountain Lion or Mavericks but I always end up with the same problem.
Yes I am.
I going to stick with N{censored} or iAtkos just because of system compatibility, but of course I end up with the notorious black screen after installing it.
Saurav252525?asked me to try verbose mode to capture the error I am facing?
As far as your system goes it would be fine with Myhack & Pandora box.Distro works in pre installation .but give you problems in post installations.check your bios try to work with Intel HD.
Post pic for errors
Good luck
