<Bluet00th>
[GUIDE] ATI Radeon HD 5450
ATI Radeon HD 5450?
Used this method to activate my Sapphire Radeon HD 5450 after installing OS X 10.6.3 and updating to 10.6.8 on the GA-G31M-ES2C.
Everything works (QE/CI included) except for DVD Player.app?.?
Install the ATI5000Injector.kext in /Extra/Extentions (use Kext Wizard if you used myHack).
Install the ATIFramebuffer.kext in /System/Library/Extensions with Kext Wizard.
Repair permissions+rebuild mkext for Extra and Repair permissions+Rebuild cache for /System/Library/Extensions after both installs.
Edit your org.chameleon.Boot.plist in /Extra/ to set GraphicsEnabler=Yes and ATIConfig=Eulemur. You can also do this with Chameleon Wizard.
Restart! And you're done. Enjoy QE/CI! I know how hard it can get to activate it.
Find the kexts here.
If, for some reason, this does not work for you, please tell me. I'll help.
On 2 Mar 2014 at 2:50 PM, said:
ATI Radeon HD 5450?
Doesn't work for me
