Ashanx
DSDT Help for Asus Sabertooth 990fx
I am completely new to DSDT making.?? I am having a problem with my USB not working on wake and I figured having a DSDT would help with that.?? Is there anyone that would be able to create one for me.?? If so let me know what you need.
My set up is as follows
Mavericks 10.9.2
Amd FX -8350 Black edition 8 core at 4.33ghz
2x EVGA 560ti 2048mb
8gb Ram
Realtek ALC892
I would like to have graphics enabler no to make things easier but as it stands not I have to.?? This is what I have my boot list as
?? ?<key>EthernetBuiltIn</key>
?? ?<string>Yes</string>
?? ?<key>GraphicsEnabler</key>
?? ?<key>Kernel Flags</key>
?? ?<string>npci=0x2000 darkwake=0</string>
?? ?<key>SystemType</key>
?? ?<string>1</string>
?? ?<key>Theme</key>
?? ?<string>Blackosx_Button</string>
?? ?<key>Timeout</key>
?? ?<string>2</string>
?? ?<key>UseKernelCache</key>
any help would be greatly appreciated
Thank you for that, I tried to use the systemchk but I get this error.??? /Applications/SystemChk.app/Contents/Resources/DirectHW.kext failed to laod - (lbKern/kext) different verison/uuid already loaded; check System/Kernel logs for error or try kextutil(8).??????? I tried to look for system/kernal logs but do not see anything there.???
Its error about DirectHW.kext error.No prob smile.png .use ioreg-Explorer or darwin-dumper
