Clover Successful Builds
Hi to all,
If you have succeeded to build with Clover.Then post your Hardware Spec,Patches,Bios settings & Config.plist here.Post pictures if you like(Only clover config & installation settings)
Sample:
  • OSX version: Mac osx you are using.
  • Clover version:Clover version you are using.
  • Theme: Theme using for Clover GUI.
  • Clover installations:The options you click for installation.(Like UEFI boot only or ESP or Lagecy Bios )
  • CPU:Model,GHz etc.
  • RAM:Brand,MHz
  • Motherboard:Brand & Model Number(Laptop Model).
  • Audio-Onboard: Chip Name.if used Clover layout injector & patched( if not just put chip name).
  • GPU 1:Onboard or PCI-E(injector,EDID,Properties Add,Activation method)
  • GPU 2:Onboard or PCI-E(injector,EDID,Properties Add,Activation method)
  • HDMI Audio 1:Onboard or PCI-E(using-Yes/No,Working status)
  • HDMI Audio 2:Onboard or PCI-E(using-Yes/No,Working status)
  • Mac Model(Smbios):The smbios you are using.
  • Boot flags(Arguments): Your boot flags under Arguments.
  • Patches:Custom DSDT,Custom SSDT.AICPUPM & Others Patches.(Post DSDT & SSDT if you like )
  • Config.plist:Post your complete clover config.plist( Zip,spoiler or copy/paste,)and without Serial Number.
  • Sample plist: Just give you idea,so do not?copy into your post.
Spoiler
?? ?<key>ACPI</key>
?? ?<dict>
?? ??? ?<key>DSDT</key>
?? ??? ?<dict>
?? ??? ??? ?<key>Debug</key>
?? ??? ??? ?<false/>
?? ??? ??? ?<key>DropOEM_DSM</key>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<key>ATI</key>
?? ??? ??? ??? ?<true/>
?? ??? ??? ??? ?<key>Firewire</key>
?? ??? ??? ??? ?<key>HDA</key>
?? ??? ??? ??? ?<key>HDMI</key>
?? ??? ??? ??? ?<key>IDE</key>
?? ??? ??? ??? ?<key>IntelGFX</key>
?? ??? ??? ??? ?<key>LAN</key>
?? ??? ??? ??? ?<key>LPC</key>
?? ??? ??? ??? ?<false/>
?? ??? ??? ??? ?<key>NVidia</key>
?? ??? ??? ??? ?<key>SATA</key>
?? ??? ??? ??? ?<key>SmBUS</key>
?? ??? ??? ??? ?<key>USB</key>
?? ??? ??? ??? ?<key>WIFI</key>
?? ??? ??? ?</dict>
?? ??? ??? ?<key>FixMask</key>
?? ??? ??? ?<string>0xFFDF</string>
?? ??? ??? ?<key>Fixes</key>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<key>AddDTGP_0001</key>
?? ??? ??? ??? ?<key>AddMCHC_0008</key>
?? ??? ??? ??? ?<key>FakeLPC_0020</key>
?? ??? ??? ??? ?<key>FixAirport_4000</key>
?? ??? ??? ??? ?<key>FixDarwin_0002</key>
?? ??? ??? ??? ?<key>FixDisplay_0100</key>
?? ??? ??? ??? ?<key>FixFirewire_0800</key>
?? ??? ??? ??? ?<key>FixHDA_8000</key>
?? ??? ??? ??? ?<key>FixHPET_0010</key>
?? ??? ??? ??? ?<key>FixIDE_0200</key>
?? ??? ??? ??? ?<key>FixIPIC_0040</key>
?? ??? ??? ??? ?<key>FixLAN_2000</key>
?? ??? ??? ??? ?<key>FixSATA_0400</key>
?? ??? ??? ??? ?<key>FixSBUS_0080</key>
?? ??? ??? ??? ?<key>FixShutdown_0004</key>
?? ??? ??? ??? ?<key>FixUSB_1000</key>
?? ??? ??? ??? ?<key>NewWay_80000000</key>
?? ??? ??? ??? ?<key>FIX_RTC_20000</key>
?? ??? ??? ??? ?<key>FIX_TMR_40000</key>
?? ??? ??? ??? ?<key>AddIMEI_80000</key>
?? ??? ??? ??? ?<key>FIX_INTELGFX_100000</key>
?? ??? ??? ??? ?<key>FIX_WAK_200000</key>
?? ??? ??? ??? ?<key>DeleteUnused_400000</key>
?? ??? ??? ??? ?<key>FIX_ADP1_800000</key>
?? ??? ??? ??? ?<key>AddPNLF_1000000</key>
?? ??? ??? ??? ?<key>FIX_S3D_2000000</key>
?? ??? ??? ??? ?<key>FIX_ACST_4000000</key>
?? ??? ??? ??? ?<key>AddHDMI_8000000</key>
?? ??? ??? ??? ?<key>FixRegions_10000000</key>
?? ??? ??? ?</dict>
?? ??? ??? ?<key>Name</key>
?? ??? ??? ?<string>DSDT.aml</string>
?? ??? ??? ?<key>Patches</key>
?? ??? ??? ?<array>
?? ??? ??? ??? ?<dict>
?? ??? ??? ??? ??? ?<key>Comment</key>
?? ??? ??? ??? ??? ?<string>Remove battery device from desktop</string>
?? ??? ??? ??? ??? ?<key>Find</key>
?? ??? ??? ??? ??? ?<data>W4IeQkFUMQhfSElEDEHQDAoIX1VJRAEUCF9TVEEApAA=</data>
?? ??? ??? ??? ??? ?<key>Replace</key>
?? ??? ??? ??? ??? ?<data></data>
?? ??? ??? ??? ?</dict>
?? ??? ??? ??? ??? ?<string>Add _SUN property for GIGE</string>
?? ??? ??? ??? ??? ?<data>UFhTWAhfQURSAAhfUFJXEgYC</data>
?? ??? ??? ??? ??? ?<data>UFhTWAhfQURSAAhfU1VOCgQIX1BSVxIGAg==</data>
?? ??? ??? ??? ??? ?<string>Rename GFX0 to IGPU</string>
?? ??? ??? ??? ??? ?<data>R0ZYMA==</data>
?? ??? ??? ??? ??? ?<data>SUdQVQ==</data>
?? ??? ??? ??? ??? ?<string>Rename HDEF to AZAL</string>
?? ??? ??? ??? ??? ?<data>SERFRg==</data>
?? ??? ??? ??? ??? ?<data>QVpBTA==</data>
?? ??? ??? ?</array>
?? ??? ??? ?<key>ReuseFFFF</key>
?? ??? ??? ?<key>Rtc8Allowed</key>
?? ??? ??? ?<key>SuspendOverride</key>
?? ??? ?</dict>
?? ??? ?<key>DropMCFG</key>
?? ??? ?<false/>
?? ??? ?<key>DropTables</key>
?? ??? ?<array>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<key>Signature</key>
?? ??? ??? ??? ?<string>DMAR</string>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string>SSDT</string>
?? ??? ??? ??? ?<key>TableId</key>
?? ??? ??? ??? ?<string>CpuPm</string>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<key>Length</key>
?? ??? ??? ??? ?<integer>720</integer>
?? ??? ??? ?</dict>
?? ??? ?</array>
?? ??? ?<key>HaltEnabler</key>
?? ??? ?<false/>
?? ??? ?<key>PatchAPIC</key>
?? ??? ?<false/>
?? ??? ?<key>ResetAddress</key>
?? ??? ?<string>0x64</string>
?? ??? ?<key>ResetValue</key>
?? ??? ?<string>0xFE</string>
?? ??? ?<key>SSDT</key>
?? ??? ?<dict>
?? ??? ??? ?<key>DoubleFirstState</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>DropOem</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>Generate</key>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<key>CStates</key>
?? ??? ??? ??? ?<key>PStates</key>
?? ??? ??? ?</dict>
?? ??? ??? ?<key>MaxMultiplier</key>
?? ??? ??? ?<integer>12</integer>
?? ??? ??? ?<key>MinMultiplier</key>
?? ??? ??? ?<integer>8</integer>
?? ??? ??? ?<key>PLimitDict</key>
?? ??? ??? ?<integer>1</integer>
?? ??? ??? ?<key>PluginType</key>
?? ??? ??? ?<integer>0</integer>
?? ??? ??? ?<key>UnderVoltStep</key>
?? ??? ??? ?<key>UseSystemIO</key>
?? ??? ??? ?<key>EnableC7</key>
?? ??? ??? ?<key>EnableC6</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>EnableC4</key>
?? ??? ??? ?<key>EnableC2</key>
?? ??? ??? ?<key>C3Latency</key>
?? ??? ??? ?<string>0x03E7</string>
?? ??? ?</dict>
?? ??? ?<key>smartUPS</key>
?? ??? ?<false/>
?? ?</dict>
?? ?<key>Boot</key>
?? ?<dict>
?? ??? ?<key>Arguments</key>
?? ??? ?<string>-v arch=i386 slide=0 erase_this_please_all</string>
?? ??? ?<key>DefaultLoader</key>
?? ??? ?<string>boot.efi</string>
?? ??? ?<key>DefaultVolume</key>
?? ??? ?<string>MacHDD</string>
?? ??? ?<key>IgnoreNVRAMBoot</key>
?? ??? ?<false/>
?? ??? ?<key>NeverHibernate</key>
?? ??? ?<false/>
?? ??? ?<key>Fast</key>
?? ??? ?<false/>
?? ??? ?<key>Legacy</key>
?? ??? ?<string>PBR</string>
?? ??? ?<key>LegacyBiosDefaultEntry</key>
?? ??? ?<key>Log</key>
?? ??? ?<false/>
?? ??? ?<key>Timeout</key>
?? ??? ?<integer>5</integer>
?? ??? ?<key>XMPDetection</key>
?? ??? ?<string>-1</string>
?? ?</dict>
?? ?<key>CPU</key>
?? ?<dict>
?? ??? ?<key>BusSpeedkHz</key>
?? ??? ?<integer>133330</integer>
?? ??? ?<key>C2</key>
?? ??? ?<true/>
?? ??? ?<key>C4</key>
?? ??? ?<true/>
?? ??? ?<key>C6</key>
?? ??? ?<true/>
?? ??? ?<key>Latency</key>
?? ??? ?<integer>250</integer>
?? ??? ?<key>QPI</key>
?? ??? ?<integer>4800</integer>
?? ??? ?<key>Type</key>
?? ??? ?<string>0x0201</string>
?? ?</dict>
?? ?<key>Devices</key>
?? ?<dict>
?? ??? ?<key>NoDefaultProperties</key>
?? ??? ?<false/>
?? ??? ?<key>AddProperties</key>
?? ??? ?<array>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<key>Device</key>
?? ??? ??? ??? ?<string>NVidia</string>
?? ??? ??? ??? ?<key>Key</key>
?? ??? ??? ??? ?<string>AAPL,HasPanel</string>
?? ??? ??? ??? ?<key>Value</key>
?? ??? ??? ??? ?<data>AQAAAA==</data>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string>AAPL,Haslid</string>
?? ??? ??? ?</dict>
?? ??? ?</array>
?? ??? ?<key>Audio</key>
?? ??? ?<dict>
?? ??? ??? ?<key>Inject</key>
?? ??? ??? ?<string>0x0887</string>
?? ??? ?</dict>
?? ??? ?<key>FakeID</key>
?? ??? ?<dict>
?? ??? ??? ?<string>0x67501002</string>
?? ??? ??? ?<string>0x01268086</string>
?? ??? ??? ?<string>0x20008086</string>
?? ??? ??? ?<string>0x0</string>
?? ??? ??? ?<string>0x25628086</string>
?? ??? ??? ?<string>0x431214e4</string>
?? ??? ??? ?<key>XHCI</key>
?? ??? ??? ?<key>IMEI</key>
?? ??? ?</dict>
?? ??? ?<key>InjectString</key>
?? ??? ?<false/>
?? ??? ?<key>UseIntelHDMI</key>
?? ??? ?<false/>
?? ??? ?<key>Properties</key>
?? ??? ?<string>7a00000001000000010000006e0000000200000002010c00d041030a0000000001010600001b7fff040028000000500069006e0043006f006e00660069006700750072006100740069006f006e00730000000800000001080100180000006c00610079006f00750074002d00690064000000080000000c000000</string>
?? ??? ?<dict>
?? ??? ??? ?<key>AddClockID</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>FixOwnership</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>HighCurrent</key>
?? ??? ??? ?<true/>
?? ??? ?</dict>
?? ?</dict>
?? ?<key>DisableDrivers</key>
?? ?<array>
?? ??? ?<string>CsmVideoDxe</string>
?? ??? ?<string>VBoxExt4</string>
?? ?</array>
?? ?<key>GUI</key>
?? ?<dict>
?? ??? ?<key>Custom</key>
?? ??? ?<dict>
?? ??? ??? ?<key>Entries</key>
?? ??? ??? ?<array>
?? ??? ??? ??? ??? ?<key>AddArguments</key>
?? ??? ??? ??? ??? ?<string>-v</string>
?? ??? ??? ??? ??? ?<key>Arguments</key>
?? ??? ??? ??? ??? ?<string>Kernel=mach_kernel</string>
?? ??? ??? ??? ??? ?<key>Disabled</key>
?? ??? ??? ??? ??? ?<true/>
?? ??? ??? ??? ??? ?<key>Hidden</key>
?? ??? ??? ??? ??? ?<false/>
?? ??? ??? ??? ??? ?<key>Hotkey</key>
?? ??? ??? ??? ??? ?<string>M</string>
?? ??? ??? ??? ??? ?<key>InjectKexts</key>
?? ??? ??? ??? ??? ?<key>NoCaches</key>
?? ??? ??? ??? ??? ?<key>Path</key>
?? ??? ??? ??? ??? ?<string>\EFI\BOOT\BOOTX64.efi</string>
?? ??? ??? ??? ??? ?<key>Title</key>
?? ??? ??? ??? ??? ?<string>MyCustomEntry</string>
?? ??? ??? ??? ??? ?<key>Type</key>
?? ??? ??? ??? ??? ?<string>OSXRecovery</string>
?? ??? ??? ??? ??? ?<key>Volume</key>
?? ??? ??? ??? ??? ?<string>D68F1885-571C-4441-8DD5-F14803EFEF54</string>
?? ??? ??? ??? ??? ?<key>SubEntries</key>
?? ??? ??? ??? ??? ?<array>
?? ??? ??? ??? ??? ??? ?<dict>
?? ??? ??? ??? ??? ??? ??? ?<key>AddArguments</key>
?? ??? ??? ??? ??? ??? ??? ?<string>-v</string>
?? ??? ??? ??? ??? ??? ??? ?<key>Title</key>
?? ??? ??? ??? ??? ??? ??? ?<string>Boot OS X 10.8.5 (12F36) Mountain Lion in Verbose Mode</string>
?? ??? ??? ??? ??? ??? ?</dict>
?? ??? ??? ??? ??? ?</array>
?? ??? ??? ??? ??? ?<string>OS X 10.8.5 (12F36) Mountain Lion</string>
?? ??? ??? ??? ??? ?<string>OSX</string>
?? ??? ??? ??? ??? ?<string>454794AC-760D-46E8-8F77-D6EB23D2FD32</string>
?? ??? ??? ?<key>Legacy</key>
?? ??? ??? ?<array>
?? ??? ??? ??? ??? ?<string>L</string>
?? ??? ??? ??? ??? ?<string>MyLegacyEntry</string>
?? ??? ??? ??? ??? ?<string>Windows</string>
?? ??? ??? ??? ??? ?<string>89433CD3-21F2-4D3C-95FC-722C48066D3A</string>
?? ??? ??? ?<key>Tool</key>
?? ??? ??? ?<array>
?? ??? ??? ??? ??? ?<string>-b</string>
?? ??? ??? ??? ??? ?<string>S</string>
?? ??? ??? ??? ??? ?<string>\EFI\CLOVER\TOOLS\Shell64-v1.efi</string>
?? ??? ??? ??? ??? ?<string>MyCustomShell</string>
?? ??? ?</dict>
?? ??? ?<key>CustomIcons</key>
?? ??? ?<false/>
?? ??? ?<key>Hide</key>
?? ??? ?<array>
?? ??? ??? ?<string>\EFI\BOOT\BOOTX64.EFI</string>
?? ??? ?</array>
?? ??? ?<key>Language</key>
?? ??? ?<string>ru:0</string>
?? ??? ?<key>Mouse</key>
?? ??? ?<dict>
?? ??? ??? ?<key>DoubleClick</key>
?? ??? ??? ?<integer>500</integer>
?? ??? ??? ?<key>Enabled</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>Mirror</key>
?? ??? ??? ?<key>Speed</key>
?? ??? ??? ?<integer>2</integer>
?? ??? ?</dict>
?? ??? ?<key>Scan</key>
?? ??? ?<dict>
?? ??? ??? ?<true/>
?? ??? ??? ?<true/>
?? ??? ?</dict>
?? ??? ?<key>ScreenResolution</key>
?? ??? ?<string>1024x768</string>
?? ??? ?<key>ConsoleMode</key>
?? ??? ?<string>0</string>
?? ??? ?<key>TextOnly</key>
?? ??? ?<false/>
?? ??? ?<key>Theme</key>
?? ??? ?<string>metal</string>
?? ?</dict>
?? ?<key>Graphics</key>
?? ?<dict>
?? ??? ?<key>CustomEDID</key>
?? ??? ?<data>AP///////wAyDADfAAAAAAASAQOAIRV4CunVmVlTjigmUFQAAAABAQEBAQEBAQEBAQEBAQEB3iGgcFCEHzAgIFYAS88QAAAY3iGgcFCEHzAgIFYAS88QAAAAAAAA/gBXNjU3RwAxNTRXUDEKAAAA/gAjMz1IZYSq/wIBCiAgAJo=</data>
?? ??? ?<key>DualLink</key>
?? ??? ?<key>FBName</key>
?? ??? ?<string>Makakakakala</string>
?? ??? ?<dict>
?? ??? ??? ?<true/>
?? ??? ??? ?<key>Intel</key>
?? ??? ?</dict>
?? ??? ?<key>InjectEDID</key>
?? ??? ?<true/>
?? ??? ?<key>LoadVBios</key>
?? ??? ?<false/>
?? ??? ?<key>NVCAP</key>
?? ??? ?<string>04000000000003000C0000000000000A00000000</string>
?? ??? ?<key>PatchVBios</key>
?? ??? ?<true/>
?? ??? ?<key>PatchVBiosBytes</key>
?? ??? ?<array>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<data>gAeoAqAF</data>
?? ??? ??? ??? ?<data>gAeoAjgE</data>
?? ??? ??? ?</dict>
?? ??? ?</array>
?? ??? ?<key>VRAM</key>
?? ??? ?<integer>1024</integer>
?? ??? ?<key>VideoPorts</key>
?? ??? ?<key>Connectors</key>
?? ??? ?<array/>
?? ??? ?<key>display-cfg</key>
?? ??? ?<string>03010300FFFF0001</string>
?? ??? ?<key>ig-platform-id</key>
?? ??? ?<string>0x01620005</string>
?? ?</dict>
?? ?<key>KernelAndKextPatches</key>
?? ?<dict>
?? ??? ?<key>ATIConnectorsController</key>
?? ??? ?<string>6000</string>
?? ??? ?<key>ATIConnectorsData</key>
?? ??? ?<string>000400000403000000010000210302040400000014020000000100000000040310000000100000000001000000000001</string>
?? ??? ?<key>ATIConnectorsPatch</key>
?? ??? ?<string>040000001402000000010000000004040004000004030000000100001102010500000000000000000000000000000000</string>
?? ??? ?<key>AppleRTC</key>
?? ??? ?<true/>
?? ??? ?<key>AsusAICPUPM</key>
?? ??? ?<false/>
?? ??? ?<false/>
?? ??? ?<key>KernelCpu</key>
?? ??? ?<false/>
?? ??? ?<key>KernelPm</key>
?? ??? ?<false/>
?? ??? ?<key>KernelLapic</key>
?? ??? ?<false/>
?? ??? ?<key>KextsToPatch</key>
?? ??? ?<array>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<data>SGVhZHBob25lcwA=</data>
?? ??? ??? ??? ?<key>Name</key>
?? ??? ??? ??? ?<string>VoodooHDA</string>
?? ??? ??? ??? ?<data>VGVsZXBob25lcwA=</data>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string>Patch_to_not_load_this_driver</string>
?? ??? ??? ??? ?<string>0x04020000</string>
?? ??? ??? ??? ?<key>InfoPlistPatch</key>
?? ??? ??? ??? ?<string>AppleHDAController</string>
?? ??? ??? ??? ?<string>0x44220000</string>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<data>TA==</data>
?? ??? ??? ??? ?<string>IOBlockStorage</string>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<data>RXh0ZXJuYWw=</data>
?? ??? ??? ??? ?<string>AppleAHCIPort</string>
?? ??? ??? ??? ?<data>SW50ZXJuYWw=</data>
?? ??? ??? ?</dict>
?? ??? ?</array>
?? ?</dict>
?? ?<key>RtVariables</key>
?? ?<dict>
?? ??? ?<key>LogEveryBoot</key>
?? ??? ?<string>10</string>
?? ??? ?<key>LogLineCount</key>
?? ??? ?<integer>3000</integer>
?? ??? ?<key>MLB</key>
?? ??? ?<string>C02032109R5DC771H</string>
?? ??? ?<key>MountEFI</key>
?? ??? ?<false/>
?? ??? ?<key>ROM</key>
?? ??? ?<string>0011223344556677</string>
?? ?</dict>
?? ?<key>SMBIOS</key>
?? ?<dict>
?? ??? ?<key>BiosReleaseDate</key>
?? ??? ?<string>05/03/10</string>
?? ??? ?<key>BiosVendor</key>
?? ??? ?<string>Apple Inc.</string>
?? ??? ?<key>BiosVersion</key>
?? ??? ?<string>MB11.88Z.0061.B03.0809221748</string>
?? ??? ?<key>Board-ID</key>
?? ??? ?<string>Mac-F4208CC8</string>
?? ??? ?<key>BoardManufacturer</key>
?? ??? ?<key>BoardSerialNumber</key>
?? ??? ?<string>C02032101R5DC771H</string>
?? ??? ?<key>BoardType</key>
?? ??? ?<integer>10</integer>
?? ??? ?<key>BoardVersion</key>
?? ??? ?<string>Proto1</string>
?? ??? ?<key>ChassisAssetTag</key>
?? ??? ?<string>LatitudeD420</string>
?? ??? ?<key>ChassisManufacturer</key>
?? ??? ?<key>ChassisType</key>
?? ??? ?<integer>16</integer>
?? ??? ?<key>Family</key>
?? ??? ?<string>MacBook</string>
?? ??? ?<key>FirmwareFeatures</key>
?? ??? ?<string>0xC0001403</string>
?? ??? ?<key>LocationInChassis</key>
?? ??? ?<string>MLB</string>
?? ??? ?<key>Manufacturer</key>
?? ??? ?<key>Memory</key>
?? ??? ?<dict>
?? ??? ??? ?<key>Channels</key>
?? ??? ??? ?<key>Modules</key>
?? ??? ??? ?<array>
?? ??? ??? ??? ??? ?<key>Frequency</key>
?? ??? ??? ??? ??? ?<integer>1333</integer>
?? ??? ??? ??? ??? ?<key>Part</key>
?? ??? ??? ??? ??? ?<string>C0001403</string>
?? ??? ??? ??? ??? ?<key>Serial</key>
?? ??? ??? ??? ??? ?<string>00001001</string>
?? ??? ??? ??? ??? ?<key>Size</key>
?? ??? ??? ??? ??? ?<integer>4096</integer>
?? ??? ??? ??? ??? ?<key>Slot</key>
?? ??? ??? ??? ??? ?<integer>0</integer>
?? ??? ??? ??? ??? ?<string>DDR3</string>
?? ??? ??? ??? ??? ?<key>Vendor</key>
?? ??? ??? ??? ??? ?<string>Kingston</string>
?? ??? ??? ??? ??? ?<string>C0001404</string>
?? ??? ??? ??? ??? ?<string>00001002</string>
?? ??? ??? ??? ??? ?<integer>2</integer>
?? ??? ??? ?<key>SlotCount</key>
?? ??? ??? ?<integer>4</integer>
?? ??? ?</dict>
?? ??? ?<key>Mobile</key>
?? ??? ?<true/>
?? ??? ?<key>ProductName</key>
?? ??? ?<string>MacBook1,1</string>
?? ??? ?<key>SerialNumber</key>
?? ??? ?<string>4H629LYAU9C</string>
?? ??? ?<key>SmUUID</key>
?? ??? ?<string>00000000-0000-1000-8000-010203040506</string>
?? ??? ?<key>Trust</key>
?? ??? ?<true/>
?? ??? ?<key>Version</key>
?? ??? ?<string>1.0</string>
?? ?</dict>
?? ?<key>SystemParameters</key>
?? ?<dict>
?? ??? ?<key>BacklightLevel</key>
?? ??? ?<string>0x0501</string>
?? ??? ?<key>CustomUUID</key>
?? ??? ?<string>511CE200-1000-4000-9999-010203040506</string>
?? ??? ?<key>InjectSystemID</key>
?? ??? ?<false/>
?? ?</dict>
if you like to post more detail please do.
Please don't bump post? in here or Ask for help.
Thanks
My Clover setup
  • Osx version: 10.9.4 & 10.10.4(test)
  • Clover version:Clover v2k_r3241.
  • Theme: BGM.
  • Clover installations:?Clover ESP,MBR & PBR sector,64-bit SATA,OsxAptioFixDrv-64,(EmuVariableUefi-64 not needed any more).
  • CPU:?Intel Core i7 2600 @ 3.4GHz
  • RAM: 16 GB DDR3 1866 MHz Corsair Vengeance black
  • Motherboard:GIGABYTE@ GA-P67-UD3-B3
  • Audio-Onboard: Realtek ALC892 & patched AppleHDA by toleda
  • GPU 1:On board (No).
  • GPU 2:PCI-E@ GTX650 OOB.
  • HDMI Audio 1:Onboard(No)
  • HDMI Audio 2:GTX 650(Yes,Working)
  • Mac Model(Smbios):Mac Pro 5,1
  • Boot flags(Arguments): -gux_defer_usb2 ( kext-dev-mode=1 for 10.10)
  • Patches: Custom DSDT,Custom SSDT,ASUSAICPUpm.
  • Config.plist: config.plist.zip
Spoiler
?? ?<key>ACPI</key>
?? ?<dict>
?? ??? ?<dict>
?? ??? ??? ?<key>SlpSmiAtWake</key>
?? ??? ??? ?<true/>
?? ??? ??? ?<true/>
?? ??? ?</dict>
?? ??? ?<array>
?? ??? ??? ?<dict>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string>BGRT</string>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string>MCFG</string>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string>Cpu0Ist</string>
?? ??? ??? ?</dict>
?? ??? ?</array>
?? ??? ?<true/>
?? ??? ?<string>0x0CF9</string>
?? ??? ?<string>0x06</string>
?? ??? ?<dict>
?? ??? ??? ?<true/>
?? ??? ??? ?<dict>
?? ??? ??? ?</dict>
?? ??? ??? ?<integer>38</integer>
?? ??? ?</dict>
?? ?</dict>
?? ?<key>Boot</key>
?? ?<dict>
?? ??? ?<string>-v -gux_defer_usb2</string>
?? ??? ?<string>Intel10.9</string>
?? ??? ?<string>LegacyBiosDefault</string>
?? ??? ?<false/>
?? ??? ?<key>Policy</key>
?? ??? ?<string>User</string>
?? ??? ?<key>Secure</key>
?? ??? ?<false/>
?? ??? ?<string>Yes</string>
?? ?</dict>
?? ?<key>CPU</key>
?? ?<dict>
?? ??? ?<true/>
?? ??? ?<true/>
?? ??? ?<true/>
?? ??? ?<string>0x03E9</string>
?? ?</dict>
?? ?<dict>
?? ??? ?<dict>
?? ??? ??? ?<string>0xC</string>
?? ??? ?</dict>
?? ??? ?<key>LpcTune</key>
?? ??? ?<true/>
?? ??? ?<dict>
?? ??? ??? ?<true/>
?? ??? ??? ?<true/>
?? ??? ??? ?<true/>
?? ??? ??? ?<true/>
?? ??? ?</dict>
?? ??? ?<false/>
?? ?</dict>
?? ?<key>GUI</key>
?? ?<dict>
?? ??? ?<string>en:0</string>
?? ??? ?<dict>
?? ??? ??? ?<true/>
?? ??? ?</dict>
?? ??? ?<true/>
?? ??? ?<string>1920x1080</string>
?? ??? ?<string>BGM</string>
?? ?</dict>
?? ?<dict>
?? ??? ?<dict>
?? ??? ?</dict>
?? ?</dict>
?? ?<dict>
?? ??? ?<true/>
?? ??? ?<true/>
?? ??? ?<true/>
?? ??? ?<array>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?<string></string>
?? ??? ??? ??? ?RXh0ZXJuYWw=
?? ??? ??? ??? ?</data>
?? ??? ??? ??? ?SW50ZXJuYWw=
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?QVBQTEUgU1NEAA==
?? ??? ??? ??? ?<string>IOAHCIBlockStorage</string>
?? ??? ??? ??? ?AAAAAAAAAAAAAA==
?? ??? ??? ?</dict>
?? ??? ??? ?<dict>
?? ??? ??? ??? ?cgoATWFjUHJvNCwxAE1hY1BybzUsMQBY
?? ??? ??? ??? ?<string>AppleTyMCEDriver</string>
?? ??? ??? ??? ?cgoAAAAAAAAAAAAAAAAAAAAAAAAAAABY
?? ??? ??? ?</dict>
?? ??? ?</array>
?? ?</dict>
?? ?<dict>
?? ??? ?<string>C02140302D5DMT31M</string>
?? ?</dict>
?? ?<dict>
?? ??? ?<string>10/07/10</string>
?? ??? ?<string>MP51.88Z.007F.B03.1010071432</string>
?? ??? ?<string>Mac-F221BEC8</string>
?? ??? ?<string>Mac Pro</string>
?? ??? ?<dict>
?? ??? ??? ?<array>
?? ??? ??? ??? ??? ?<integer>1600</integer>
?? ??? ??? ??? ??? ?<string>CMZ8GX3M2A1600C9 </string>
?? ??? ??? ??? ??? ?<string>0509050D01070600</string>
?? ??? ??? ??? ??? ?<string>Corsair</string>
?? ??? ??? ??? ??? ?<string>07000F0D01060600</string>
?? ??? ??? ??? ??? ?<integer>1</integer>
?? ??? ??? ??? ??? ?<string>805060201070600</string>
?? ??? ??? ??? ??? ?<string>905060201010600</string>
?? ??? ??? ??? ??? ?<integer>3</integer>
?? ??? ?</dict>
?? ??? ?<string>MacPro5,1</string>
?? ??? ?<string>SG311740EUH</string>
?? ??? ?<string>5B05DB02-4BD3-57A9-B1EA-35B25E1D36AC</string>
?? ??? ?<true/>
?? ?</dict>
?? ?<dict>
?? ?</dict>
My clover setup
  • Osx version: 10.9.2?
  • Clover version:Clover v2k_r2636.
  • Theme: mavsgreysmall.
  • Clover installations: Clover EFI -DataHubDxe-64.efi,?EmuVariableUefi-64.efi, FSInject-64.efi, HFSPlus.efi, OsxFatBinaryDrv-64.efi.
  • CPU:?Intel Core i5 3210M @ 2.5 - 3.1GHz
  • RAM: ?4?GB DDR3 1600 MHz SmartModular
  • Motherboard:Lenovo
  • Audio-Onboard:Conexant Cx20590 & patched AppleHDA by Mirone.
  • GPU 1:On board (Yes).HD 4000
  • HDMI Audio 1:Onboard(Yes) - With Framebuffer edited.
  • Mac Model(Smbios):Macbook Pro 9,2.
  • Boot flags(Arguments):-gux_defer_usb2 -gux_no_idle
  • Patches:Clover - ig-platform-id, Inject Intel,UseIntelHDMI.
I am actually quite embarrassed, because my computer specs is quite ancient. rolleyes.giflaugh.png
but I only participated..
Osx version: 10.9.2
Clover version:Clover v2k_r2652 (always update).
Theme: Shield.
Clover installations: Default installation for Legacy Bios
CPU:?Intel CoreDuo E2200 @2.2GHz
RAM: 3 GB DDR2 Mixed
Motherboard:GIGABYTE@ GCM-945-S2C
Audio-Onboard: Realtek ALC6622 (AppleHDA by Mirone)
GPU 2:PCI-E@ Geforce 8400GS.
Mac Model(Smbios):Mac Pro 3,1
Boot flags(Arguments): -v
Patches:Custom DSDT Fix by PJALM ,Custom SSDT, AppleRTC.
Config.plist:
config.plist.zip
OS X version: 10.9.2
Clover version: v2652
Theme: no theme
Clover installations: "Install for UEFI booting only", "EmuVariableUefi-64", "OsxAptioFixDrv-64"
CPU: Intel Core i5-4570 @3.2GHz
RAM: Kingston ValueRAM 8GB @1333MHz
Motherboard: Gigabyte GA-Z87M-D3H
Audio-Onboard: Realtek ALC892 with LayoutID=1 injected via Clover and also patch "ixnUEQ==" to "kgjsEA==" in AppleHDA binary.?I use this for a persistent .plist.
GPU 1: Intel 4600 (disabled in BIOS/UEFI)
GPU 2: EVGA GTX 670 (works natively but power management is a bit wonky)
HDMI Audio 1: not using
HDMI Audio 2: not using
Mac Model(Smbios): iMac14,2
Boot flags(Arguments): none
Patches: TRIM enabled via config.plist (patch IOAHCIBlockStorage from?"QVBQTEUgU1NE" to "AAAAAAAAAAAA")
Config.plist:
<xml version="1.0" encoding="UTF-8"?>
<plistversion="1.0">
<key>ACPI</key>
            <key>DSDT</key>
                    <key>Debug</key>
                    <false/>
                    <key>Fixes</key>
                            <true/>
                            <true/>
                            <true/>
                            <false/>
                            <true/>
                            <true/>
                            <true/>
                            <true/>
                            <false/>
                            <true/>
                            <true/>
                            <true/>
                            <true/>
                            <false/>
                            <true/>
                            <false/>
                            <true/>
                            <true/>
                            <true/>
                            <true/>
                            <false/>
                            <true/>
                            <true/>
                            =<true/>
                            <false/>
                            <false/>
                            <true/>
                            <false/>
                            <true/>
                    <key>Name</key>
                    <array>
                <key>TableId</key>
                <key>TableId</key>
                </array>
                <true/>
                <key>SSDT</key>
                <key>EnableC2</key>
                <false/>
                <key>EnableC4</key>
                <false/>
                <key>EnableC6</key>
                <true/>
                <key>EnableC7</key>
                <false/>
                <key>Generate</key>
                <key>CStates</key>
                <true/>
                <key>PStates</key>
                <true/>
                <key>Boot</key>
                <string>OS X</string>
                <key>Fast</key>
                <false/>
                <key>Legacy</key>
                <key>Log</key>
                <false/>
                <key>Timeout</key>
                <string>-1</string>
                <key>Devices</key>
                <key>Audio</key>
                <key>Inject</key>
                <string>1</string>
                <key>FakeID</key>
                <key>ATI</key>
                <key>IMEI</key>
                <key>IntelGFX</key>
                <key>LAN</key>
                <key>NVidia</key>
                <key>SATA</key>
                <key>WIFI</key>
                <key>XHCI</key>
                <key>Inject</key>
                <false/>
                <key>USB</key>
                <true/>
                <true/>
                <key>Inject</key>
                <true/>
                <array>
                <string>Nothing</string>
                </array>
                <key>GUI</key>
                <key>Hide</key>
                <array>
                </array>
                <key>Language</key>
                <key>Mouse</key>
                <key>Enabled</key>
                <true/>
                <key>Speed</key>
                <key>Scan</key>
                <key>Entries</key>
                <true/>
                <key>Legacy</key>
                <true/>
                <key>Tool</key>
                <true/>
                <key>TextOnly</key>
                <false/>
                <key>Theme</key>
                <key>Graphics</key>
                <key>Inject</key>
                <key>ATI</key>
                <false/>
                <key>Intel</key>
                <true/>
                <key>NVidia</key>
                <false/>
                <false/>
                <array>
                <key>Comment</key>
                <string>AppleHDA Patch</string>
                <key>Find</key>
                <data>ixnUEQ==</data>
                <key>Name</key>
                <string>AppleHDA</string>
                <key>Replace</key>
                <data>kgjsEA==</data>
                <key>Comment</key>
                <string>Enable TRIM</string>
                <key>Find</key>
                <data>QVBQTEUgU1NE</data>
                <key>Name</key>
                <key>Replace</key>
                <data>AAAAAAAAAAAA</data>
                </array>
                <string>10</string>
                <key>MountEFI</key>
                <false/>
                <true/>
My SandyBridge Mobile
Clover Status: better
OS X version: 10.10.2
Clover version: v2960
Theme: Bootcamp style
Clover installations: ESP of HDD
CPU: Intel SandyBridge i3 2330M?2.2GHz
RAM: Nanya 1333MHz 2G
Motherboard: Laptop Dell Inspiron N4050
Audio-Onboard: IDT92HD87B1 loaded by VoodooHDA v2.8.7
HDMI Audio: For now not needed
GPU: Intel HD Graphics 3000 | SwitchResX: 2560x1440p @60Hz | Backlight: natively loaded AppleBacklight | Brightness slider enabled
Mac Model: Macbook Pro 8.1, 8.2 or 8.3
Boot flags: -v kext-dev-mode=1 timeout=0
Kext Patches: AICPUPM patched loaded
DSDT:  auto-generated by clover
SSDT: C States / P- auto-generated by clover
Config.plist:
Spoiler
< xml version="1.0" encoding="UTF-8" >
    <key>ACPI</key>
        <key>DSDT</key>
            <key>Debug</key>
            <false/>
            <key>Fixes</key>
                <true/>
                <true/>
                <true/>
                <true/>
                <true/>
                <true/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <true/>
            <key>Name</key>
        <array>
                <key>TableId</key>
                <key>TableId</key>
        </array>
        <false/>
        <key>SSDT</key>
            <key>DropOem</key>
            <false/>
            <key>EnableC2</key>
            <false/>
            <key>EnableC4</key>
            <false/>
            <key>EnableC6</key>
            <true/>
            <key>EnableC7</key>
            <false/>
            <key>Generate</key>
                <key>CStates</key>
                <true/>
                <key>PStates</key>
                <true/>
    <key>Boot</key>
        <string>-v</string>
        <string>˙</string>
        <key>Fast</key>
        <false/>
        <key>Legacy</key>
        <key>Log</key>
        <false/>
        <key>Timeout</key>
        <true/>
    <key>Devices</key>
        <key>Audio</key>
            <key>Inject</key>
            <string>12</string>
        <key>FakeID</key>
            <key>IMEI</key>
            <key>IntelGFX</key>
            <key>LAN</key>
            <key>SATA</key>
            <key>WIFI</key>
            <key>XHCI</key>
        <key>Inject</key>
        <false/>
        <key>USB</key>
            <true/>
            <false/>
            <key>Inject</key>
            <false/>
        <false/>
    <array>
    </array>
    <key>GUI</key>
        <key>Hide</key>
        <array>
        </array>
        <key>Language</key>
        <key>Mouse</key>
            <key>Enabled</key>
            <false/>
            <key>Speed</key>
        <key>Scan</key>
            <key>Entries</key>
            <true/>
            <key>Legacy</key>
            <true/>
            <key>Tool</key>
            <true/>
        <string>1366x768</string>
        <key>TextOnly</key>
        <false/>
        <key>Theme</key>
        <string>bootcamp</string>
    <key>Graphics</key>
        <key>Inject</key>
            <key>Intel</key>
            <false/>
        <key>AppleRTC</key>
        <false/>
        <true/>
        <key>Debug</key>
        <false/>
        <false/>
        <array>
        </array>
        <string>10</string>
        <key>MountEFI</key>
        <true/>
        <true/>
        <true/>
