Hello everybody.
I have this problem to solve and i dont know how.
Saturday, i have shutdown my hackintosh as usually to sleep. On monday, when I start the system, I got this message: "Still waiting for root device"
I´m realy dont know what to do.
I tried -x, -f, -s, cpus=1, fd=disk0s2 (0)(1)(3),.
The first thing I thought was, i lost my HDD!.. but it recognizes on windows normally.
I have an external hdd with OsX 10.8.5 and works fine. BUT dont recognizes the internal HDD on disk utility.
I also tried to install again the OsX 10.9.2 on the internal HDD, and for my surprise, the HDD dont recognizes on disk utility too.
Anyone could help me without loses my data?
Thanks for now.
4 answers to this question
Try to change your Sata port.Maybe be you deleted some kext.
3rd_party_sata & IObackstroge or AHCIportinjector kext might help.
Boot into your 10.8.5 install kext & rebuild cache
Good luck
Good luck
Thats the problem...
im new on mac, i dont know how to do it.
im already change the sata port and nothing...
internal HDD = osx 10.9.2
external HDD = osx 10.8.5
if I boot the external HDD, it work fine, but inside de osx i cannot see the internal hdd with the osx10.9.2....
the internal hdd is plugged !
Make your internal hdd as external , then copy kext into s/l/e or check you bios setting then reset it..or copy the kext into you installer USB then boot from it
