Hey guys, I am new to the whole mackintosh thing.
My problem is the following.
I have a MOBO with an ALC 889 audio codec, I have tried a lot... and I mean A LOT, patched appleHDA and HDAenabler etc and despite that I see the kexts load with -v when I go to System Preferences I get "No sound output devices found".
I have found a work-around with voodooHDA 2.7.3 (for some reason 2.7.3 is the only one that it is working but I get sound lags after some times and the quality is medium.
Every other voodooHDA gives me crackling shitty sound. Also the HDMI output is not detected even with 2.7.3 .
I am using Chameleon bootloader up to date.
My OS X version is 10.9.1 .
My specs are:
MOBO: Gigabyte 990FXA-D3 (not UD3, its D3)
CPU: Phenom II x4 960t (non-core-unlocked)
GPU: XFX Radeon HD 6870 Black Edition
SSD: Sandisk 128Gb Ultra II
Any help is greatly appreciated.?
Use dcpimanger to get your sound card ids,then go to S/L/E find voodoo hda kext.>show package content> open info.plist?
add your ids. rebuild cache & reboot.
check your voodoo pref. in system pref
Thanks for the help, I just need one more thing. My audio ids are:
Audio Device: 0x10024383
sub Device: 0x1458A002
codec ID: 0x10EC0889
and the voodooHDA info.plist the above but I do not know where to plug the numbers.
Add your Audio Device Id? after IOPCIClassMatch.
<key>IOPCIPrimeryMatch</key>
????????????<string>0x10024383</string>
post-249665-0-20549900-1402001809_thumb.
I edited the kexts both ways in that image and the result in both was that "No output devices found" in System Preferences > sound.
Anyway, thanks for all your help! I guess I will stay with what I have.
Thanks again for trying!
Strange,but np.can you take a pic of DCPIManager & upload your voodoo kext here.
Meanwhile? try this http://www.osx86.net/files/file/3599-updated-applehda-1093-alc889/
but to install Applehda you have to remove voodoo,so back up it first.
I have tried those kexts,
I delete everything that has something to do with voodooHDA (appleHDADisabler.kext, voodooHDA.kext, also in apps and preferences panel),?
since I use 10.9.1 without DSDT, I installed?HDAEnabler889.kext and appleHDA.kext (from 10.9 zip) with Kext Wizard,?
I repair permissions,
and I reboot as normal, without any changes to chameleon?bootloader and I can see in the code (I always boot with -v) that HDAEnabler is loaded
but still when I get to System Prefs > Sound I get "No device output found".
I forgot to tell you that my?back panel has 6 outs, if that has any different?approach.
Here is the DCPIManager with 2.7.3 voodooHDA.kext:?https://www.dropbox.com/s/oiwy4ngm2a1s094/DPCIManager.png?The second Audio Device ID is from HDMI output (tried that id also with the moded voodooHDA.)
Here is the original 2.8.5 voodooHDA:?https://www.dropbox.com/s/y5rl3b8uxw2ywxs/VoodooHDA.kext.zip
Here is the the?moded voodooHDA with my audio device id:?https://www.dropbox.com/s/y5pxx1w4eqssxk6/Moded%20VoodooHDA.kext.zip
Here is my Chameleon settings:?https://www.dropbox.com/s/opg6e1v7hww7kae/Chameleon%20Settings.png?There are some audio options there but I?don't know if I need to use them and how.
Here is the DPCIManager with the original voodooHDA:?https://www.dropbox.com/s/scgjwt56h598ttr/DPCIManager%20with%20original%20voodoo.png?I have tried to use the HDMI sound port in my monitor but it does not work at all, I get no?sound and the voodoo prefs panel has no options (also the sound icon in the top right corner becomes grey).?
And here is the partly working voodooHDA from 2.7.3:?https://www.dropbox.com/s/2ml0vjsc8z4qlu9/2.7.3%20partly%20working%20VoodooHDA.kext.zip?I have sound with this but without adobe flash player I get delayed video over sound. Also the only working player is MPlayerX. VLC player has... I?don't know how to call it, but has audio gaps, plays with no delay but the sound is cut off every second or so and comes back.
