macxuser
XFX R9 270x ( need some with DSDT )
My xfx R9 270x works just fine pretty much out of the box but for the life of me i cant get full acceleration and when i try kext injection it dont work all i get is a card showing Amd radeon R9 270x 7mb??? so i figure it must need DSTD injection but when i insert patch from? http://www.hackintoshosx.com/files/file/3711-amd-radeon-r9-270-series/ ? all i get is errors? and i havent a clue how to fix them myself
any help would be appreciated?
Thanks
acpi_dsdt.zip
My Gigabyte R9 270X works OOB with graphics injection disabled. ?To enable the DVI-D port, I added this to my Clover config.plist:
<key>KernelAndKextPatches</key>	<dict>		<key>ATIConnectorsController</key>		<string>7000</string>		<key>ATIConnectorsData</key>		<string>00040000040300000001010112040401000400000403000000010201220505020400000014020000000103000000060600080000040200000001040011020103</string>		<key>ATIConnectorsPatch</key>		<string>00040000040300000001010112040401000400000403000000010201220505020400000014020000000100001102060500080000040200000001040011020103</string>	</dict>
And added this to use the patch above:
<key>Graphics</key>	<dict>		<key>Inject</key>		<dict>			<key>ATI</key>			<true/>		</dict>		<key>FBName</key>		<string>Futomaki</string>		<key>PatchVBios</key>		<true/>	</dict>
