Tvor88
XFX r9 270 (help needed!)
Hello, this is my first post to the forums.
I am having troubles getting my R9 270 working in 10.9.1.
I have tried using this driver,
http://www.hackintoshosx.com/files/file/3711-amd-radeon-r9-270-series/
but the problem is that i cant update to 10.9.2 (like the installation for this driver says that i need).
I can boot with "GraphicsEnabler=No" but that still does not help.?
Any Help would be appreciated! I do know that some people have gotten them to work and i was just wondering how!?
I can gladly give any info that would help resolve the problem!
Thanks,
Tvor88
6 answers to this question
hi
you can add your graphics card Device-ID (0x68111002) in AMD7000Controller.kext and AMDRadeonX4000.kext
I literally just got it going now.?
Try this:?
(1) Download TextMate, Open program, and then go to File/Open, then navigate to System/Library/Extensions and find the AMD7000Controller.kext.
(2) Click on Contents folder, then highlight Info.plist file and click Open?
(3) You will now see the code, scroll down just past the IOPCIMATCH and you will see a string of Device IDs
(4) Just past 0x68101002 click and then add a space and then type 0x68111002 and then a space. It should look evenly spaced in the existing code.
(5) Click File/Save
(6) Next find the AMDRadeonX4000.kext
(7) Repeat steps 2-5, making sure you are in the correct string of Device IDs
(8) Download Kext Utility, run it to rebuild kextcache and Repair permissions
(9) Shut down Mac and restart
(10) Goto About This Mac/Click on More Info.?
(11) Should now see AMD Radeon 7xxx under graphics
I tried add this the device ID but under the?AMD7000Controller.kext there was no info.plist, but under?AMDRadeonX4000.kext there was, so i added it there but it?didn't?help do anything! Is there anything that I can do to fix this.?
share here your Info.plist from these two kexts, please...
your org.chameleon.Boot.plist also if you're using chameleon bootloader
The website wont let me put the .plist files here so his the code.
Thanks so much for helping!
7000Series:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict>	<key>BuildMachineOSBuild</key>	<string>13D58</string>	<key>CFBundleDevelopmentRegion</key>	<string>English</string>	<key>CFBundleExecutable</key>	<string>AMD7000Controller</string>	<key>CFBundleGetInfoString</key>	<string>AMD7000Controller 1.22.25 14095</string>	<key>CFBundleIdentifier</key>	<string>com.apple.kext.AMD7000Controller</string>	<key>CFBundleInfoDictionaryVersion</key>	<string>6.0</string>	<key>CFBundleName</key>	<string>Radeon HD 7000 Controller</string>	<key>CFBundlePackageType</key>	<string>KEXT</string>	<key>CFBundleShortVersionString</key>	<string>1.22.25</string>	<key>CFBundleSignature</key>	<string>????</string>	<key>CFBundleVersion</key>	<string>1.2.2</string>	<key>DTCompiler</key>	<string>com.apple.compilers.llvm.clang.1_0</string>	<key>DTPlatformBuild</key>	<string>5A2053</string>	<key>DTPlatformVersion</key>	<string>GM</string>	<key>DTSDKBuild</key>	<string>13D58</string>	<key>DTSDKName</key>	<string></string>	<key>DTXcode</key>	<string>0501</string>	<key>DTXcodeBuild</key>	<string>5A2053</string>	<key>IOKitPersonalities</key>	<dict>		<key>Controller</key>		<dict>			<key>ATY,Hamachi</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_USE_SM</key>					<true/>				</dict>			</dict>			<key>ATY,Ikura</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_PTPL2_TBL</key>					<data>					VwAAAFQAAABQAAAATAAAAEgAAABEAAAAQAAA					ADwAAAA4AAAANgAAADQAAAAyAAAAMAAAAC4A					AAAsAAAAKgAAAA==					</data>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>ATY,IkuraS</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_PTPL2_TBL</key>					<data>					VwAAAFQAAABQAAAATAAAAEgAAABEAAAAQAAA					ADwAAAA4AAAANgAAADQAAAAyAAAAMAAAAC4A					AAAsAAAAKgAAAA==					</data>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>ATY,Kani</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_PTPL2_TBL</key>					<data>					VwAAAFYAAABVAAAAVAAAAFMAAABSAAAAUQAA					AFAAAABPAAAATgAAAE0AAABMAAAASwAAAEoA					AABJAAAASAAAAA==					</data>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>ATY,KaniS</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_PTPL2_TBL</key>					<data>					VwAAAFYAAABVAAAAVAAAAFMAAABSAAAAUQAA					AFAAAABPAAAATgAAAE0AAABMAAAASwAAAEoA					AABJAAAASAAAAA==					</data>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>ATY,Maguro</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_PTPL2_TBL</key>					<data>					XQAAAEsAAABIAAAARQAAAEIAAAA/AAAAPAAA					ADYAAAAzAAAAMAAAAC0AAAAqAAAAJwAAACQA					AAAhAAAAHgAAAA==					</data>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>ATY,MaguroS</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_PTPL2_TBL</key>					<data>					XQAAAEsAAABIAAAARQAAAEIAAAA/AAAAPAAA					ADYAAAAzAAAAMAAAAC0AAAAqAAAAJwAAACQA					AAAhAAAAHgAAAA==					</data>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>ATY,Namako</key>			<dict>				<key>aty_config</key>				<dict>					<key>CFG_USE_AGDC</key>					<true/>				</dict>			</dict>			<key>CFBundleIdentifier</key>			<string>com.apple.kext.AMD7000Controller</string>			<key>IOClass</key>			<string>AMD7000Controller</string>			<key>IOMatchCategory</key>			<string>IOFramebuffer</string>			<key>IOName</key>			<string>AMD7000Controller</string>			<key>IOPCIMatch</key>			<string>0x26001002 0x22001002 0x67901002 0x67981002 0x679A1002 0x679E1002 0x67801002 0x68111002 0x68201002 0x68211002 0x68231002 0x68251002 0x68271002 0x682D1002 0x682F1002 0x68391002 0x683B1002 0x683D1002 0x683F1002 0x68001002 0x68011002 0x68061002 0x68081002 0x68101002 0x68181002 0x68191002</string>			<key>IOProbeScore</key>			<integer>65050</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>aty_config</key>			<dict>				<key>CFG_APER_MODE</key>				<integer>1</integer>				<key>CFG_CAA</key>				<integer>0</integer>				<key>CFG_FB_LIMIT</key>				<integer>0</integer>				<key>CFG_FORCE_HDMI</key>				<false/>				<key>CFG_FORCE_MAX_DPS</key>				<false/>				<key>CFG_GEN_FLAGS</key>				<integer>0</integer>				<key>CFG_INT_SSPC</key>				<integer>25</integer>				<key>CFG_NO_HDCP</key>				<false/>				<key>CFG_NO_MST</key>				<false/>				<key>CFG_NO_PP</key>				<false/>				<key>CFG_NO_SLS</key>				<false/>				<key>CFG_PTPL2_MAX</key>				<integer>70</integer>				<key>CFG_PTPL2_MIN</key>				<integer>16</integer>				<key>CFG_USE_AGDC</key>				<false/>				<key>CFG_USE_FBC</key>				<false/>				<key>CFG_USE_FEDS</key>				<true/>				<key>CFG_USE_STUTTER</key>				<false/>				<key>DALReadDelayStutterOff</key>				<integer>4</integer>				<key>DALUseUrgencyWaterMarkOffset</key>				<integer>0</integer>			</dict>			<key>aty_properties</key>			<dict>				<key>PP_ActivitySamplingInterval</key>				<integer>1000</integer>				<key>PP_DALPowerLevel</key>				<integer>1</integer>				<key>PP_DisableCAC</key>				<integer>0</integer>				<key>PP_DisableDTE</key>				<integer>1</integer>				<key>PP_DisablePowerContainment</key>				<integer>0</integer>				<key>PP_DisableSMUUVDHandshake</key>				<integer>0</integer>				<key>PP_DisableSQRamping</key>				<integer>0</integer>				<key>PP_DisableULV</key>				<integer>0</integer>				<key>PP_DriverCalculateCACLeakage</key>				<integer>1</integer>				<key>PP_HighSamplingInterval</key>				<integer>200000</integer>				<key>PP_MCLKStutterModeThreshold</key>				<integer>40000</integer>				<key>PP_PowerGatingDisable</key>				<integer>0</integer>				<key>PP_SISLANDSVotingRightsClients</key>				<integer>12583475</integer>				<key>PP_UserMaxClockForMultiDisplays</key>				<integer>1</integer>			</dict>		</dict>	</dict>	<key>OSBundleLibraries</key>	<dict>		<key>com.apple.iokit.IOACPIFamily</key>		<string>1.2</string>		<key>com.apple.iokit.IOGraphicsFamily</key>		<string>1.3</string>		<key>com.apple.iokit.IOPCIFamily</key>		<string>1.2</string>		<key>com.apple.kext.AMDSupport</key>		<string>1.2.2</string>		<key>com.apple.kpi.bsd</key>		<string>8.0.0</string>		<key>com.apple.kpi.iokit</key>		<string>8.0.0</string>		<key>com.apple.kpi.libkern</key>		<string>8.0.0</string>		<key>com.apple.kpi.mach</key>		<string>8.0.0</string>	</dict>	<key>OSBundleRequired</key>	<string>Safe Boot</string></dict></plist>
X4000:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict>	<key>CFBundleDevelopmentRegion</key>	<string>English</string>	<key>CFBundleExecutable</key>	<string>AMDRadeonX4000</string>	<key>CFBundleGetInfoString</key>	<string>AMDRadeonX4000 1.22.25 14095</string>	<key>CFBundleIdentifier</key>	<string>com.apple.AMDRadeonX4000</string>	<key>CFBundleInfoDictionaryVersion</key>	<string>6.0</string>	<key>CFBundleName</key>	<string>AMDRadeonX4000 Kernel Extension</string>	<key>CFBundlePackageType</key>	<string>KEXT</string>	<key>CFBundleShortVersionString</key>	<string>1.22.25</string>	<key>CFBundleSignature</key>	<string>????</string>	<key>CFBundleVersion</key>	<string>1.2.2</string>	<key>IOKitPersonalities</key>	<dict>		<key>AMDBonaireGraphicsAccelerator</key>		<dict>			<key>ATIEnableWideBlitSupport</key>			<true/>			<key>ATIUseTearingWideBlit</key>			<false/>			<key>CFBundleIdentifier</key>			<string>com.apple.AMDRadeonX4000</string>			<key>GpuDebugPolicy</key>			<integer>0</integer>			<key>IOClass</key>			<string>AMDBonaireGraphicsAccelerator</string>			<key>IODVDBundleName</key>			<string>AMDRadeonVADriver</string>			<key>IOKitDebug</key>			<integer>0</integer>			<key>IOMatchCategory</key>			<string>IOAccelerator</string>			<key>IOPCIMatch</key>			<string>0x66401002 0x66411002 0x66461002 0x66501002 0x66511002 0x665C1002 0x665D1002</string>			<key>IOProbeScore</key>			<integer>200</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>IOSourceVersion</key>			<string>0.0.0.0.0</string>			<key>IOVARendererID</key>			<integer>16908288</integer>			<key>sensor-properties</key>			<array>				<dict>					<key>device_type</key>					<data>					Z3B1LXNlbnNvcg==					</data>					<key>location</key>					<string>GPU</string>					<key>name</key>					<string>gpu-sensor</string>					<key>polling-period</key>					<data>					AAAAAQAAAAA=					</data>					<key>reg</key>					<data>					AAAAAg==					</data>					<key>sample-period</key>					<data>					AAAAAACYmAA=					</data>					<key>sensor-id</key>					<data>					AAAABg==					</data>					<key>version</key>					<data>					AAAAAg==					</data>					<key>zone</key>					<data>					AAAAAg==					</data>				</dict>			</array>		</dict>		<key>AMDHawaiiGraphicsAccelerator</key>		<dict>			<key>ATIEnableWideBlitSupport</key>			<true/>			<key>ATIUseTearingWideBlit</key>			<false/>			<key>CFBundleIdentifier</key>			<string>com.apple.AMDRadeonX4000</string>			<key>GpuDebugPolicy</key>			<integer>0</integer>			<key>IOClass</key>			<string>AMDHawaiiGraphicsAccelerator</string>			<key>IODVDBundleName</key>			<string>AMDRadeonVADriver</string>			<key>IOKitDebug</key>			<integer>0</integer>			<key>IOMatchCategory</key>			<string>IOAccelerator</string>			<key>IOPCIMatch</key>			<string>0x67B01002</string>			<key>IOProbeScore</key>			<integer>200</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>IOSourceVersion</key>			<string>0.0.0.0.0</string>			<key>IOVARendererID</key>			<integer>16908288</integer>			<key>sensor-properties</key>			<array>				<dict>					<key>device_type</key>					<data>					Z3B1LXNlbnNvcg==					</data>					<key>location</key>					<string>GPU</string>					<key>name</key>					<string>gpu-sensor</string>					<key>polling-period</key>					<data>					AAAAAQAAAAA=					</data>					<key>reg</key>					<data>					AAAAAg==					</data>					<key>sample-period</key>					<data>					AAAAAACYmAA=					</data>					<key>sensor-id</key>					<data>					AAAABg==					</data>					<key>version</key>					<data>					AAAAAg==					</data>					<key>zone</key>					<data>					AAAAAg==					</data>				</dict>			</array>		</dict>		<key>AMDPitcairnGraphicsAccelerator</key>		<dict>			<key>ATIEnableWideBlitSupport</key>			<true/>			<key>ATIUseTearingWideBlit</key>			<false/>			<key>CFBundleIdentifier</key>			<string>com.apple.AMDRadeonX4000</string>			<key>GpuDebugPolicy</key>			<integer>0</integer>			<key>IOClass</key>			<string>AMDPitcairnGraphicsAccelerator</string>			<key>IODVDBundleName</key>			<string>AMDRadeonVADriver</string>			<key>IOKitDebug</key>			<integer>0</integer>			<key>IOMatchCategory</key>			<string>IOAccelerator</string>			<key>IOPCIMatch</key>			<string>0x68001002 0x68011002 0x68061002 0x68081002 0x68101002 0x68111002 0x68181002 0x68191002</string>			<key>IOProbeScore</key>			<integer>200</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>IOSourceVersion</key>			<string>0.0.0.0.0</string>			<key>IOVARendererID</key>			<integer>16908288</integer>			<key>sensor-properties</key>			<array>				<dict>					<key>device_type</key>					<data>					Z3B1LXNlbnNvcg==					</data>					<key>location</key>					<string>GPU</string>					<key>name</key>					<string>gpu-sensor</string>					<key>polling-period</key>					<data>					AAAAAQAAAAA=					</data>					<key>reg</key>					<data>					AAAAAg==					</data>					<key>sample-period</key>					<data>					AAAAAACYmAA=					</data>					<key>sensor-id</key>					<data>					AAAABg==					</data>					<key>version</key>					<data>					AAAAAg==					</data>					<key>zone</key>					<data>					AAAAAg==					</data>				</dict>			</array>		</dict>		<key>AMDTahitiGraphicsAccelerator</key>		<dict>			<key>ATIEnableWideBlitSupport</key>			<true/>			<key>ATIUseTearingWideBlit</key>			<false/>			<key>CFBundleIdentifier</key>			<string>com.apple.AMDRadeonX4000</string>			<key>GpuDebugPolicy</key>			<integer>0</integer>			<key>IOClass</key>			<string>AMDTahitiGraphicsAccelerator</string>			<key>IODVDBundleName</key>			<string>AMDRadeonVADriver</string>			<key>IOKitDebug</key>			<integer>0</integer>			<key>IOMatchCategory</key>			<string>IOAccelerator</string>			<key>IOPCIMatch</key>			<string>0x67901002 0x67981002 0x679A1002 0x679E1002 0x67801002</string>			<key>IOProbeScore</key>			<integer>200</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>IOSourceVersion</key>			<string>0.0.0.0.0</string>			<key>IOVARendererID</key>			<integer>16908288</integer>			<key>sensor-properties</key>			<array>				<dict>					<key>device_type</key>					<data>					Z3B1LXNlbnNvcg==					</data>					<key>location</key>					<string>GPU</string>					<key>name</key>					<string>gpu-sensor</string>					<key>polling-period</key>					<data>					AAAAAQAAAAA=					</data>					<key>reg</key>					<data>					AAAAAg==					</data>					<key>sample-period</key>					<data>					AAAAAACYmAA=					</data>					<key>sensor-id</key>					<data>					AAAABg==					</data>					<key>version</key>					<data>					AAAAAg==					</data>					<key>zone</key>					<data>					AAAAAg==					</data>				</dict>			</array>		</dict>		<key>AMDTongaGraphicsAccelerator</key>		<dict>			<key>ATIEnableWideBlitSupport</key>			<true/>			<key>ATIUseTearingWideBlit</key>			<false/>			<key>CFBundleIdentifier</key>			<string>com.apple.AMDRadeonX4000</string>			<key>GpuDebugPolicy</key>			<integer>0</integer>			<key>IOClass</key>			<string>AMDTongaGraphicsAccelerator</string>			<key>IODVDBundleName</key>			<string>AMDRadeonVADriver</string>			<key>IOKitDebug</key>			<integer>0</integer>			<key>IOMatchCategory</key>			<string>IOAccelerator</string>			<key>IOPCIMatch</key>			<string>0x69201002 0x69381002</string>			<key>IOProbeScore</key>			<integer>200</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>IOSourceVersion</key>			<string>0.0.0.0.0</string>			<key>IOVARendererID</key>			<integer>16908288</integer>			<key>cail_properties</key>			<dict>				<key>CAIL_DisableAcpPowerGating</key>				<integer>0</integer>				<key>CAIL_DisableSAMUPowerGating</key>				<integer>0</integer>				<key>CAIL_DisableSysClockGating</key>				<integer>1</integer>				<key>CAIL_DisableUVDPowerGating</key>				<integer>1</integer>				<key>CAIL_DisableVCEPowerGating</key>				<integer>0</integer>			</dict>			<key>sensor-properties</key>			<array>				<dict>					<key>device_type</key>					<data>					Z3B1LXNlbnNvcg==					</data>					<key>location</key>					<string>GPU</string>					<key>name</key>					<string>gpu-sensor</string>					<key>polling-period</key>					<data>					AAAAAQAAAAA=					</data>					<key>reg</key>					<data>					AAAAAg==					</data>					<key>sample-period</key>					<data>					AAAAAACYmAA=					</data>					<key>sensor-id</key>					<data>					AAAABg==					</data>					<key>version</key>					<data>					AAAAAg==					</data>					<key>zone</key>					<data>					AAAAAg==					</data>				</dict>			</array>		</dict>		<key>AMDVerdeGraphicsAccelerator</key>		<dict>			<key>ATIEnableWideBlitSupport</key>			<true/>			<key>ATIUseTearingWideBlit</key>			<false/>			<key>CFBundleIdentifier</key>			<string>com.apple.AMDRadeonX4000</string>			<key>GpuDebugPolicy</key>			<integer>0</integer>			<key>IOClass</key>			<string>AMDVerdeGraphicsAccelerator</string>			<key>IODVDBundleName</key>			<string>AMDRadeonVADriver</string>			<key>IOKitDebug</key>			<integer>0</integer>			<key>IOMatchCategory</key>			<string>IOAccelerator</string>			<key>IOPCIMatch</key>			<string>0x68201002 0x68211002 0x68231002 0x68251002 0x68271002 0x682D1002 0x682F1002 0x68391002 0x683B1002 0x683D1002 0x683F1002</string>			<key>IOProbeScore</key>			<integer>200</integer>			<key>IOProviderClass</key>			<string>IOPCIDevice</string>			<key>IOSourceVersion</key>			<string>0.0.0.0.0</string>			<key>IOVARendererID</key>			<integer>16908288</integer>			<key>cail_properties</key>			<dict>				<key>CAIL_DisableDrmdmaPowerGating</key>				<integer>1</integer>				<key>CAIL_DisableDynamicGfxMGPowerGating</key>				<integer>1</integer>				<key>CAIL_DisableGfxCGPowerGating</key>				<integer>1</integer>				<key>CAIL_DisableGmcPowerGating</key>				<integer>1</integer>				<key>CAIL_DisableStaticGfxMGPowerGating</key>				<integer>1</integer>				<key>CAIL_DisableUVDPowerGating</key>				<integer>0</integer>				<key>CAIL_DisableVCEPowerGating</key>				<integer>0</integer>			</dict>			<key>sensor-properties</key>			<array>				<dict>					<key>device_type</key>					<data>					Z3B1LXNlbnNvcg==					</data>					<key>location</key>					<string>GPU</string>					<key>name</key>					<string>gpu-sensor</string>					<key>polling-period</key>					<data>					AAAAAQAAAAA=					</data>					<key>reg</key>					<data>					AAAAAg==					</data>					<key>sample-period</key>					<data>					AAAAAACYmAA=					</data>					<key>sensor-id</key>					<data>					AAAABg==					</data>					<key>version</key>					<data>					AAAAAg==					</data>					<key>zone</key>					<data>					AAAAAg==					</data>				</dict>			</array>		</dict>	</dict>	<key>NSHumanReadableCopyright</key>	<string>Copyright © 2005-2012 Apple Inc. All rights reserved.</string>	<key>OSBundleLibraries</key>	<dict>		<key>com.apple.iokit.IOAcceleratorFamily</key>		<string>2.0.0</string>		<key>com.apple.iokit.IOGraphicsFamily</key>		<string>1.0.0b1</string>		<key>com.apple.iokit.IOPCIFamily</key>		<string>1.0.0b1</string>		<key>com.apple.kpi.bsd</key>		<string>8.0.0</string>		<key>com.apple.kpi.iokit</key>		<string>8.0.0</string>		<key>com.apple.kpi.libkern</key>		<string>8.0.0</string>		<key>com.apple.kpi.mach</key>		<string>8.0.0</string>		<key>com.apple.kpi.unsupported</key>		<string>8.0.0</string>	</dict></dict></plist>
pfff, I'm really sorry? :(
I thought we were talking about Yosemite?? :anonymous:
there's no support for R9 graphics cards in Mavericks
however you can try this experimental driver made by netkas:http://forum.netkas.org/index.php/topic,8489.0.html but I can't guarantee that it will work
you have to install Yosemite to have native support: http://www.insanelymac.com/forum/topic/298413-r9-and-r7-support-in-1010-finally/
Its ok i really appreciate the help so much!!! :eagerness:
Edited by Tvor88
