YorkiesWorld
HELP! Trying to get OSX working on VirtualBox with AMD FX Processor?
Hi everyone! I've been at this for a while now and had no luck whatsoever.
I have followed multiple videos and tutorials but I can't get past the initial boot and start the installation process. Is there any chance someone can advise me what files I need to download or tools I need etc... that will work best with my system?
If you need my specs, I've attached a screenshot to this post.
I really want to be able to use Mac in VirtualBox to test it out, if anyone can give me some advice that would be great!
Thanks in advance!
post-643853-0-61310200-1413818681_thumb.
Edited by YorkiesWorld
2 answers to this question
hello ,
yes with distro (kernel AMD) ?all core CPU enable in virtualbox ;) ( SVM enable in bios) ?
Hi!
Thanks for that, where can I download Distro? I'm sort of a newbie with all this so is it done easily or are there any particular steps I need to take to make sure it works etc...?
Thanks!
