speedoholic
Need help with OSX installation on HP G42 notebook
Hi
I am currently running Ubuntu 14.04 LTS on my HP G42 laptop and since the software-center got messed up while I tried to install Virtual Box, I am sharing my system details via terminal (lshw). I have highlighted the information that seems more useful. Please let me know if installation of OSX would be possible on this machine or not?
?description: Notebook
? ? product: HP G42 Notebook PC
? ? vendor: Hewlett-Packard
? ? version: 0599120000202710010010100
? ? serial: CNF03552YR
? ? width: 64 bits
? ? capabilities: smbios-2.6 dmi-2.6 vsyscall32
? ? configuration: boot=normal chassis=notebook family=103C_5335KV sku=XR689PA#ACJ uuid=434E4630-3335-3532-5952-60EB693CA004
? *-core
? ? ? ?description: Motherboard
? ? ? ?product: 1425
? ? ? ?vendor: Hewlett-Packard
? ? ? ?physical id: 0
? ? ? ?version: 54.46
? ? ? ?serial: P X120 01 1Z ZE 7AT
? ? ? ?slot: Base Board Chassis Location
? ? ?*-firmware
? ? ? ? ? description: BIOS
? ? ? ? ? vendor: Hewlett-Packard
? ? ? ? ? physical id: 0
? ? ? ? ? version: F.23
? ? ? ? ? date: 08/05/2010
? ? ? ? ? size: 1MiB
? ? ? ? ? capacity: 1472KiB
? ? ? ? ? capabilities: pci upgrade shadowing cdboot bootselect edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb biosbootspecification
? ? ?*-cpu
? ? ? ? ? description: CPU
? ? ? ? ? product: Intel? Core i3 CPU ? ? ? M 370 ?@ 2.40GHz
? ? ? ? ? vendor: Intel Corp.
? ? ? ? ? physical id: 16
? ? ? ? ? bus info: cpu@0
? ? ? ? ? version: Intel? Core i3 CPU ? ? ? M 370 ?@ 2.40GHz
? ? ? ? ? slot: CPU
? ? ? ? ? size: 933MHz
? ? ? ? ? capacity: 2400MHz
? ? ? ? ? width: 64 bits
? ? ? ? ? clock: 1066MHz
? ? ? ? ? capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 popcnt lahf_lm arat dtherm tpr_shadow vnmi flexpriority ept vpid cpufreq
? ? ? ? ? configuration: cores=2 enabledcores=2 threads=4
? ? ? ? *-cache:0
? ? ? ? ? ? ?description: L3 cache
? ? ? ? ? ? ?physical id: 17
? ? ? ? ? ? ?slot: L3 Cache
? ? ? ? ? ? ?size: 3MiB
? ? ? ? ? ? ?capacity: 3MiB
? ? ? ? ? ? ?capabilities: synchronous internal write-through unified
? ? ? ? *-cache:1
? ? ? ? ? ? ?description: L2 cache
? ? ? ? ? ? ?physical id: 19
? ? ? ? ? ? ?slot: L2 Cache
? ? ? ? ? ? ?size: 256KiB
? ? ? ? ? ? ?capacity: 256KiB
? ? ? ? *-cache:2
? ? ? ? ? ? ?description: L1 cache
? ? ? ? ? ? ?physical id: 1a
? ? ? ? ? ? ?slot: L1 Cache
? ? ? ? ? ? ?size: 32KiB
? ? ? ? ? ? ?capacity: 32KiB
? ? ? ? ? ? ?capabilities: synchronous internal write-through instruction
? ? ?*-cache
? ? ? ? ? description: L1 cache
? ? ? ? ? physical id: 18
? ? ? ? ? slot: L1 Cache
? ? ? ? ? size: 32KiB
? ? ? ? ? capacity: 32KiB
? ? ? ? ? capabilities: synchronous internal write-through data
? ? ?*-memory
? ? ? ? ? description: System Memory
? ? ? ? ? physical id: 1b
? ? ? ? ? slot: System board or motherboard
? ? ? ? ? size: 3GiB
? ? ? ? *-bank:0
? ? ? ? ? ? ?description: SODIMM DDR3 Synchronous 1067 MHz (0.9 ns)
? ? ? ? ? ? ?product: M471B5673FH0-CH9
? ? ? ? ? ? ?vendor: Samsung
? ? ? ? ? ? ?physical id: 0
? ? ? ? ? ? ?serial: 484BADA1
? ? ? ? ? ? ?slot: Bottom - Slot 1
? ? ? ? ? ? ?size: 2GiB
? ? ? ? ? ? ?width: 64 bits
? ? ? ? ? ? ?clock: 1067MHz (0.9ns)
? ? ? ? *-bank:1
? ? ? ? ? ? ?product: HMT112S6TFR8C-H9
? ? ? ? ? ? ?vendor: Hynix
? ? ? ? ? ? ?serial: 08318DCC
? ? ? ? ? ? ?slot: Bottom - Slot 2
? ? ? ? ? ? ?size: 1GiB
? ? ?*-pci:0
? ? ? ? ? description: Host bridge
? ? ? ? ? product: Core Processor DRAM Controller
? ? ? ? ? vendor: Intel Corporation
? ? ? ? ? physical id: 100
? ? ? ? ? bus info: pci@0000:00:00.0
? ? ? ? ? version: 02
? ? ? ? ? width: 32 bits
? ? ? ? ? clock: 33MHz
? ? ? ? ? configuration: driver=agpgart-intel
? ? ? ? ? resources: irq:0
? ? ? ? *-display
? ? ? ? ? ? ?description: VGA compatible controller
? ? ? ? ? ? ?product: Core Processor Integrated Graphics Controller
? ? ? ? ? ? ?vendor: Intel Corporation
? ? ? ? ? ? ?physical id: 2
? ? ? ? ? ? ?bus info: pci@0000:00:02.0
? ? ? ? ? ? ?version: 02
? ? ? ? ? ? ?clock: 33MHz
? ? ? ? ? ? ?capabilities: msi pm vga_controller bus_master cap_list rom
? ? ? ? ? ? ?configuration: driver=i915 latency=0
? ? ? ? ? ? ?resources: irq:43 memory:d0000000-d03fffff memory:c0000000-cfffffff ioport:4050(size=8)
? ? ? ? *-communication
? ? ? ? ? ? ?description: Communication controller
? ? ? ? ? ? ?product: 5 Series/3400 Series Chipset HECI Controller
? ? ? ? ? ? ?physical id: 16
? ? ? ? ? ? ?bus info: pci@0000:00:16.0
? ? ? ? ? ? ?version: 06
? ? ? ? ? ? ?capabilities: pm msi bus_master cap_list
? ? ? ? ? ? ?configuration: driver=mei_me latency=0
? ? ? ? ? ? ?resources: irq:42 memory:d4406100-d440610f
? ? ? ? *-multimedia
? ? ? ? ? ? ?description: Audio device
? ? ? ? ? ? ?product: 5 Series/3400 Series Chipset High Definition Audio
? ? ? ? ? ? ?physical id: 1b
? ? ? ? ? ? ?bus info: pci@0000:00:1b.0
? ? ? ? ? ? ?version: 05
? ? ? ? ? ? ?capabilities: pm msi pciexpress bus_master cap_list
? ? ? ? ? ? ?configuration: driver=snd_hda_intel latency=0
? ? ? ? ? ? ?resources: irq:44 memory:d4400000-d4403fff
? ? ? ? *-pci:0
? ? ? ? ? ? ?description: PCI bridge
? ? ? ? ? ? ?product: 5 Series/3400 Series Chipset PCI Express Root Port 1
? ? ? ? ? ? ?physical id: 1c
? ? ? ? ? ? ?bus info: pci@0000:00:1c.0
? ? ? ? ? ? ?width: 32 bits
? ? ? ? ? ? ?capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
? ? ? ? ? ? ?configuration: driver=pcieport
? ? ? ? ? ? ?resources: irq:17 ioport:3000(size=4096) memory:d3400000-d43fffff ioport:d0400000(size=16777216)
? ? ? ? ? ?*-network
? ? ? ? ? ? ? ? description: Wireless interface
? ? ? ? ? ? ? ? product: BCM4313 802.11bgn Wireless Network Adapter
? ? ? ? ? ? ? ? vendor: Broadcom Corporation
? ? ? ? ? ? ? ? physical id: 0
? ? ? ? ? ? ? ? bus info: pci@0000:02:00.0
? ? ? ? ? ? ? ? logical name: wlan0
? ? ? ? ? ? ? ? version: 01
? ? ? ? ? ? ? ? serial: --
? ? ? ? ? ? ? ? width: 64 bits
? ? ? ? ? ? ? ? clock: 33MHz
? ? ? ? ? ? ? ? capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
? ? ? ? ? ? ? ? configuration: broadcast=yes driver=wl0 driverversion=6.30.223.141 (r415941) ip=192.168.1.2 latency=0 multicast=yes wireless=IEEE 802.11abg
? ? ? ? ? ? ? ? resources: irq:16 memory:d3400000-d3403fff
? ? ? ? *-storage
? ? ? ? ? ? ?description: SATA controller
? ? ? ? ? ? ?product: 5 Series/3400 Series Chipset 4 port SATA AHCI Controller
? ? ? ? ? ? ?physical id: 1f.2
? ? ? ? ? ? ?bus info: pci@0000:00:1f.2
? ? ? ? ? ? ?clock: 66MHz
? ? ? ? ? ? ?capabilities: storage msi pm ahci_1.0 bus_master cap_list
? ? ? ? ? ? ?configuration: driver=ahci latency=0
? ? ? ? ? ? ?resources: irq:41 ioport:4048(size=8) ioport:405c(size=4) ioport:4040(size=8) ioport:4058(size=4) ioport:4020(size=32) memory:d4405000-d44057ff
? ? ? ? *-disk
? ? ? ? ? ? ?description: ATA Disk
? ? ? ? ? ? ?product: ST9320423AS
? ? ? ? ? ? ?vendor: Seagate
? ? ? ? ? ? ?physical id: 0.0.0
? ? ? ? ? ? ?bus info: scsi@0:0.0.0
? ? ? ? ? ? ?logical name: /dev/sda
? ? ? ? ? ? ?version: 0006
? ? ? ? ? ? ?serial: 5VH4BK20
? ? ? ? ? ? ?size: 298GiB (320GB)
? ? ? ? ? ? ?capabilities: partitioned partitioned:dos
? ? ? ? ? ? ?configuration: ansiversion=5 sectorsize=512 signature=000d529a
? *-battery
? ? ? ?description: Lithium Ion Battery
? ? ? ?product: MU06047
? ? ? ?vendor: SMP-SO22G6F
? ? ? ?slot: Primary
? ? ? ?capacity: 4400mWh
? ? ? ?configuration: voltage=10.8V
The 1st Gen Intel graphics will need workarounds, and your WiFi card will need this. ?I'll need more info, i.e. Dev/Ven IDs, for the audio codec.
It's definitely possible to install, but if you heavily rely on the components I just listed, and they turn out to be not supported, it simply wouldn't be worth installing.
