eternalturmoil
ASUS HD6770 HELP REQUIRED :(
Haii,
I was wondering if anyone would be able to help me with an issue ive been having. Essentially i can get OS X Yosemite installed and no kernel panics show up by default but i cannot get my graphics card working at all
Normally it shows as "Display 3mb/5mb/7mb" or "AMD Radeon HD 5000 series 7mb" etc.
My system specs are :
Motherboard : Gigabyte GA-H61M-S1 Rev3 F2a
CPU : Intel Core i3-2120
Graphics Card : Asus AMD Radeon HD6770 1GB
RAM :6GB DDR3 1333mhz
All my BIOS settings are set properly
If it is required i can install a different version of OS X but i would rather be on the newest version of Yosemite (10.10.2)
If you can help in any way , i thank you
ASUS HD6770 >? 0x68BA
Add your Device ID in: AMD5000Controller.kext and AMDRadeonX3000.kext
Search for AMDJuniperGraphicsAccelerator
Add: 0x68BA1002
Here are the 2 kexts with your Device ID added: http://cl.ly/ZaIJ
Install with Kext Wizard and repair permissions and caches.
Bootflags:
AtiConfig=Vervet
GraphicsEnabler=Yes
Thanks to Fantomas:
http://www.insanelymac.com/forum/topic/282687-radeon-hd-6770-full-qeci-mlmavericksyosemite/
