UnDeaD_AmP
My Hackintosh freezes when I unplug/plug in USB devices sometimes...
:( I was watching a video in chrome, and i plug in my iPhone, the whole system just froze. it also occurs when i unplug a USB device like my webcam. Any ideas? I tried USBBusFix and no luck.?
Running on OS X Yosemite 10.10.2
GA-Z97M-DS3H
IOGear Bluetooth 4.0 USB
TP-Link TL-WDN4800 ?for wifi
Logitech C510 Webcam
AULA backlight led keyboard
Logitech mouse
Kingston 120GB V3 SSD
Intel Core i3 4360
ThermalTake 550w PSU
Using Chameleon.
Video of it freezing while watching a video. Sorry Waj. :c Just so happened to be your video, love your videos though.?
Edited by UnDeaD_AmP
Hi, I have a similar problem, I have 4G wimax usb internet and when it's signal is blocked and gives kernel panic with backtrace in iousbfamily.kext and then restarts. Iousbfamily problem is probably a bug, do not know exactly who know better to explain and us.
78
Edited by ovidoi
78
As for the USB wifi problem, i ordered a wifi card, the TP-Link TL-WDN4800 PCI-e wifi card and have no regrets. it works amazing in OS X. i recommend that you get one.
As i told you before it time for you change chameleon to? Clover .
You might have USB bus issue.It can be fixed by dsdt patch.
or you also can have issue with CPUpm try -xcpm bootflag
KP occurs when the signal falls suddenly, any place on the usb works correctly only 4g wimax this trouble.
@UnDeaD_AmP thx, but 4G wimax not same wifi, is wireless long distance radio.
60
Edited by ovidoi
:( Hm.... Is it possible to just reinstall clover bootloader over my current install or no??
and as for the CPUpm thingy, not sure what that does... i'll try that bootflag anyway.
EDIT ~ I used the -xcpm bootflag and so far...
After 20 or so usb plugs/unplugs, no freezes, i tried rebooting with the same bootflag, no problems, i tried sleeping, then waking from sleep. plug in USB no problems. :) Will report back by monday if all is well, or sooner if anything goes wrong.
EDIT: one time it froze... any way to find and post the log for it freezing, tried again and thats the only time it froze.
