Khuerustom
[Help] Display via VGA port
I want to install Yosemite on my system. My hardware has been verified as Yosemite supported. My GPU is nVidia GT 740 and my monitor has only a VGA (D-SUB) connector. I have read somewhere that installation may have problem (blank or gray screen) with the VGA connector. It is also said that VGA output does not work at all in OSx.
Is that true? if yes, what should I do? Would a DVI-VGA converter work in this case?
Please, tell me more if I am missing something..
Thank You...
2 answers to this question
Converters should work and yes we sometimes got issues with vga port.but if you use clover it should be ok.
Gt740 works with GE=Yes flage
Thank you very much for your reply.
I have done a little bit of digging and now I understand that I have to use a HDMI to VGA converter if VGA does not work. As my video card has only DVI-D ports, DVI to VGA is not going to work.
Thanks again. :eagerness:
