HCD2015
System Uptime In Nanoseconds...
Hi there pretty new at working with a hackintosh and working on my first install created the USB installation via the AIO guide and was advised to install with the bootflags -f -v. Using those I only made it a certain amount of the way before an error so I tried more boot flags and got it to load a little further however this about the extent of how far I can get it to go. Anyone have advice on what I should do from here help!
http://imgur.com/j8U7NpP is where i got stuck
used boot flags -v npci=0x200 GraphicsEnabler=Yes maxmem=8192
System does use an AMD phenom II X4 945
and an Nvidia GPU 680 GTX
Edited by HCD2015
2 answers to this question
I also get a Kernel CPU caller 1, 2 or 3 Kernel trap?
I get that error for just about any combination of bootflags that I put in.
