DCdavid
Can't get power management/sleep to work on Yosemite
So I've tried tweaking a lot of Clover and (UEFI) BIOS settings but I still only get 5 P-states (16 and turbos 34, 35, 36, 37) and I'm unable to put my system to sleep.
When I attempt to put it to sleep: everything shuts off, a moment later the fans spin up/lights come on for a second, it shuts off again, then it boots up from the start (not waking up to where I was).
I'm using an SSDT generated with ssdtPRGen.sh which is placed in EFI/Clover/ACPI/patched/ and I currently have SSDT/DropOEM enabled and CState/PState generation disabled (I've also experimented with enabling that, without success). I stopped using a DSDT after upgrading to UEFI a while ago, though I've recently tried experimenting with using an extracted one which doesn't seem to have fixed anything. I've attached the SSDT.dsl in case someone wants to look it over.
Here are my specs and configuration:
  • OS X version: 10.10.2
  • Clover version: r3199
  • CPU: i5-2500K
  • Motherboard: Gigabyte GA-Z68-MA-D2H-B3 (U1C UEFI BIOS)
  • Mac Model(Smbios): iMac 12,2
  • Config.plist:
    <?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict>	<key>ACPI</key>	<dict>		<key>SSDT</key>		<dict>			<key>DropOem</key>			<true/>			<key>Generate</key>			<dict>				<key>CStates</key>				<false/>				<key>PStates</key>				<false/>			</dict>		</dict>	</dict>	<key>Boot</key>	<dict>		<key>Arguments</key>		<string>-v slide=0 kext-dev-mode=1</string>		<key>DefaultVolume</key>		<string>LastBootedVolume</string>		<key>Timeout</key>		<integer>3</integer>	</dict>	<key>Devices</key>	<dict>		<key>Audio</key>		<dict>			<key>Inject</key>			<integer>2</integer>		</dict>	</dict>	<key>DisableDrivers</key>	<array>		<string>Ps2MouseDxe</string>		<string>VBoxExt2</string>		<string>CsmVideoDxe</string>		<string>Ps2MouseAbsolutePointerDxe</string>		<string>Ps2KeyboardDxe</string>		<string>VBoxExt4</string>	</array>	<key>GUI</key>	<dict>		<key>Scan</key>		<dict>			<key>Entries</key>			<true/>			<key>Legacy</key>			<false/>			<key>Tool</key>			<true/>		</dict>		<key>Theme</key>		<string>Yosemite</string>	</dict>	<key>Graphics</key>	<dict>		<key>Inject</key>		<dict>			<key>ATI</key>			<false/>			<key>Intel</key>			<false/>			<key>NVidia</key>			<true/>		</dict>	</dict>	<key>KernelAndKextPatches</key>	<dict>		<key>KextsToPatch</key>		<array>			<dict>				<key>Comment</key>				<string>AppleHDA/Realtek ALC889</string>				<key>Find</key>				<data>				ixnUEQ==				</data>				<key>Name</key>				<string>AppleHDA</string>				<key>Replace</key>				<data>				iQjsEA==				</data>			</dict>			<dict>				<key>Comment</key>				<string>AppleHDA/Resources/xml->zml</string>				<key>Find</key>				<data>				eG1sLnps				</data>				<key>Name</key>				<string>AppleHDA</string>				<key>Replace</key>				<data>				em1sLnps				</data>			</dict>			<dict>				<key>Comment</key>				<string>TRIM patch</string>				<key>Find</key>				<data>				QVBQTEUgU1NE				</data>				<key>Name</key>				<string>IOAHCIBlockStorage</string>				<key>Replace</key>				<data>				AAAAAAAAAAAA				</data>			</dict>		</array>	</dict>	<key>SMBIOS</key>	<dict>		<key>BiosReleaseDate</key>		<string>10/17/11</string>		<key>BiosVendor</key>		<string>Apple Inc.</string>		<key>BiosVersion</key>		<string>IM121.88Z.0047.B1D.1110171110</string>		<key>Board-ID</key>		<string>Mac-942B59F58194171B</string>		<key>BoardManufacturer</key>		<string>Apple Inc.</string>		<key>BoardSerialNumber</key>		<string>REDACTED</string>		<key>BoardType</key>		<integer>10</integer>		<key>BoardVersion</key>		<string>iMac12,2</string>		<key>ChassisAssetTag</key>		<string>iMac-Aluminum</string>		<key>ChassisManufacturer</key>		<string>Apple Inc.</string>		<key>ChassisType</key>		<string>0x000d</string>		<key>Family</key>		<string>iMac</string>		<key>LocationInChassis</key>		<string>Part Component</string>		<key>Manufacturer</key>		<string>Apple Inc.</string>		<key>Mobile</key>		<false/>		<key>ProductName</key>		<string>iMac12,2</string>		<key>SerialNumber</key>		<string>REDACTED</string>		<key>SmUUID</key>		<string>REDACTED</string>		<key>Trust</key>		<true/>		<key>Version</key>		<string>1.0</string>	</dict>	<key>SystemParameters</key>	<dict>		<key>InjectKexts</key>		<string>YES</string>		<key>InjectSystemID</key>		<true/>	</dict></dict></plist>
So does anyone have any ideas about how I can get power management and sleep to start working properly? I read somewhere that even official iMacs (or at least iMac 12,x) only achieve 2 p-states, is that true? I've achieved more p-states in the past, but I'm pretty sure that was on a previous OS X release like Mavericks or Mountain Lion.
Any help would be greatly appreciated, and let me know if any additional information would be helpful in pinpointing the problem.
Add this ..
<key>KernelAndKextPatches</key>	<dict>		<key>AppleRTC</key>		<true/>		<key>AsusAICPUPM</key>		<true/>
Add this ..
Thanks, but still no luck unfortunately. I explicitly enabled both of those but I still can't get it to sleep/wake properly or achieve more p-states than 16, 34-37. By the way, isn't AppleRTC enabled by default? I think it's always been checked in the Clover options regardless of whether it was present in my config.plist.
Any other ideas?
Any other ideas?
Sleep is a different thing.Is your AICPUPM working now ?
http://www.hackintoshosx.com/topic/21588-sleep-hibernation-how-it-works-and-how-to-use/
Use maciASL to make SSDT also post darwin dumper reports.
