sakoula
seeking advice for QUADRO NVS 300
Hello,
I would like to request some help and guidance on how to troubleshoot the performance issue I am facing with my GPU on a hackintosh.?
My card used to perform ok on 10.8 and 10.9. When I upgraded to 10.10 I had a big performance loss. I am not sure if this is normal or not.?
I am trying to understand if something is missing on my configuration.
My use is NOT gaming but everyday work , coding, browsing etc.
- My GPU is "NVIDIA Quadro NVS 300 with 512MB" with two monitors hooked: 1920x1200 and 1280x1024.
- I use MacPro3,1 and GraphicsEnabler=Yes on Chameleon and the stock apple drivers and my card is recognized in 'About' as (which seems right):
Chipset Model: ?NVIDIA Quadro NVS 300
? Type: GPU
? Bus: ?PCIe
? Slot: Slot-1
? PCIe Lane Width: ?x16
? VRAM (Total): 512 MB
? Vendor: NVIDIA (0x10de)
? Device ID: ?0x10d8
? Revision ID: ?0x00a2
? ROM Revision: 70.18.9F.00.0C
- LuxMark gave me 117
- Cinebench gave me 4.60
- kextstat shows the following modules:
? ?95 ? ?2 0xffffff7f8102c000 0x274000 ? 0x274000 ? com.apple.nvidia.classic.NVDAResmanTesla (10.0.0) <78 77 12 5 4 3 1>
? ?96 ? ?0 0xffffff7f81cab000 0xce000 ? ?0xce000 ? ?com.apple.GeForceTesla (10.0.0) <95 78 77 12 7 6 5 4 3 1>
? ?97 ? ?0 0xffffff7f812a0000 0x2cf000 ? 0x2cf000 ? com.apple.nvidia.classic.NVDANV50HalTesla (10.0.0) <95 12 4 3>
I am looking on some direction. Any help really appreciated.
Thanks
