Rene
Clover Fake ID HD5450 Yosemite, El Capitan
To use FakeID with Clover, you must have the following information in your config.plist.
ACPI > DSDT > Fixes > Fix_Display_0100=TRUE
Devices > FakeID > ATI=0xDeviceIDVendorID (for example 0x68E01002)
Graphics > Inject > ATI=TRUE
For El Capitan you should not use "Inject ATI" because that will give you a black screen after Sleep.
The card will show in System Info as "ATI Radeon HD 5000 1024 MB" but who cares :P
Spoiler
I had to set the frame buffer to “Shrike??? to get it working right.
Graphics > FB Name > Shrike
As you can see my Fake ID is 0x68e0. My real ID is 0x68F9.
This should work for every HD5450 with Device ID 68F9 68E5 68e1
Working on a clean install without editing/patching kexts.
No problems with sleep.
renes-Mac-Pro:~ rene$ kextstat | grep AMD
com.apple.kext.AMDSupport (1.3.0) <60 59 12 11 7 5 4 3 1>
com.apple.kext.AMD5000Controller (1.3.0) <61 59 12 11 5 4 3 1>
com.apple.AMDRadeonX3000 (1.3.0) <80 59 12 7 5 4 3 1>
com.apple.kext.AMDFramebuffer (1.3.0) <61 59 12 11 7 5 4 3 1>
More tests with other frame buffers:
renes-Mac-Pro:~ rene$ ioreg | grep ATY
    | |   |   | +-o ATY,Hoolock@0  <class AtiFbStub, id 0x1000002b6, registered, matched, active, busy 0 (5 ms), retain 8>    | |   |   | | +-o ATY_Hoolock  <class AMDFramebuffer, id 0x1000002b9, registered, matched, active, busy 0 (4 ms), retain 18>    | |   |   | +-o ATY,Hoolock@1  <class AtiFbStub, id 0x1000002b7, registered, matched, active, busy 0 (0 ms), retain 8>    | |   |   | | +-o ATY_Hoolock  <class AMDFramebuffer, id 0x1000002bf, registered, matched, active, busy 0 (0 ms), retain 15>    | |   |   | +-o ATY,Hoolock@2  <class AtiFbStub, id 0x1000002b8, registered, matched, active, busy 0 (0 ms), retain 8>    | |   |   | | +-o ATY_Hoolock  <class AMDFramebuffer, id 0x1000002c5, registered, matched, active, busy 0 (0 ms), retain 15>
Last login: Fri Jun  5 12:06:50 on consolerenes-Mac-Pro:~ rene$ ioreg | grep ATY
    | |   |   | +-o ATY,Langur@0  <class AtiFbStub, id 0x1000002b2, registered, matched, active, busy 0 (4 ms), retain 8>    | |   |   | | +-o ATY_Langur  <class AMDFramebuffer, id 0x1000002b5, registered, matched, active, busy 0 (3 ms), retain 18>    | |   |   | +-o ATY,Langur@1  <class AtiFbStub, id 0x1000002b3, registered, matched, active, busy 0 (0 ms), retain 8>    | |   |   | | +-o ATY_Langur  <class AMDFramebuffer, id 0x1000002bb, registered, matched, active, busy 0 (0 ms), retain 15>    | |   |   | +-o ATY,Langur@2  <class AtiFbStub, id 0x1000002b4, registered, matched, active, busy 0 (0 ms), retain 8>    | |   |   | | +-o ATY_Langur  <class AMDFramebuffer, id 0x1000002c1, registered, matched, active, busy 0 (0 ms), retain 15>
Shrike:Last login: Fri Jun  5 12:20:45 on consolerenes-Mac-Pro:~ rene$ ioreg | grep ATY
    | |   |   | +-o ATY,ATY,RadeonFramebuffer@0  <class AtiFbStub, id 0x1000002b0, registered, matched, active, busy 0 (5 ms), retain 8>    | |   |   | | +-o ATY_ATY,RadeonFramebuffer  <class AMDFramebuffer, id 0x1000002b3, registered, matched, active, busy 0 (4 ms), retain 18>    | |   |   | +-o ATY,ATY,RadeonFramebuffer@1  <class AtiFbStub, id 0x1000002b1, registered, matched, active, busy 0 (0 ms), retain 8>    | |   |   | | +-o ATY_ATY,RadeonFramebuffer  <class AMDFramebuffer, id 0x1000002ba, registered, matched, active, busy 0 (0 ms), retain 15>    | |   |   | +-o ATY,ATY,RadeonFramebuffer@2  <class AtiFbStub, id 0x1000002b2, registered, matched, active, busy 0 (0 ms), retain 8>    | |   |   | | +-o ATY_ATY,RadeonFramebuffer  <class AMDFramebuffer, id 0x1000002c0, registered, matched, active, busy 0 (0 ms), retain 15>
As always big thanks and credits to kyndder for teaching me this.
[Edit]
As always big thanks and credits to?kyndder?for teaching me this.
Yeah always teaches very well , i also have some unforgettable experiences?
Lets Cheers :very_drunk:? :very_drunk:? :very_drunk:? :very_drunk: ?for @Kynnder?
Edited by InsanelyDeepak
I update the config.plist (and not used the .kext files, see other thread :) but the machine hangs at reboot now (and then crashes and tries to reboot); there seems to be a kernel panic or something like that.
Without the fakeID it worked.
Any idea how to debug this?
Thanks again.
Don't forget to set RtVariables for El Capitan:
<key>RtVariables</key>
<key>BooterConfig</key>
<string>0x28</string>
<key>CsrActiveConfig</key>
<string>0x67</string>
And after cache update remove them or set to "0"
<string>0x0</string>
Works for?0x68f9 for El Capitan 10.11.2.. Followed your Clover config pix and it did the trick!?
Many many maaany thanks!! :)
Edited by brandur
