Rene
Clover Fake ID HD5450 Yosemite, El Capitan
For El Capitan you should not use "Inject ATI" because that will give you a black screen after Sleep.
The card will show in System Info as "ATI Radeon HD 5000 1024 MB" but who cares :P
@fabio8v
Where did you got this config.plist? Looks like it will never work with these settings.
I think you should first try to install Clover properly and make it working before trying to make graphics working.
http://www.osx86.net/forums/topic/21783-clover-main-discussion/
Do you have a DSDT?
If you have a DSDT you should not use the Acpi fixes.
DSDT.aml should be in
/EFI/CLOVER/ACPI/patched
You should create a SMBIOS in Clover. Without it it will not work.
SMBIOS should match your hardware as close as possible.
What CPU do you have?
well..my cpu is i7 920 2.67 Ghz, I tried as you suggested me..mac 3.1, the 0x28 and 0,67...saved and replaced the file config.plist in the usb but it didn't start, I mean..went in the loop..appeared some and restart
with your config.plist the pc stacks on the apple...as before when I tried your kexts
Edited by fabio8v
You should not use both methods. Try with your working config.plist and add only the FakeID part (see my example config.plist). Also enable bootflag "-v" to see what is happening. If the PC stacks make a photo so we can see what is the course.
