Rene
Clover Fake ID HD5450 Yosemite, El Capitan
no..no...I used just a method per time...the stack happens when try to change from the text mode to the graphic mode...in a while I load a photo
Hi to all,
sorry because I am very new here only 2 week in hackingtosh, but I is not running on my computer. It detects HD5450, but only 7mb ram. My card is 1Gb ram. What can I do to fix it. Running on "El Capitan 10.11.3
Are you using disable SIP when updating cache?
Read here.
To see which kext doesn't load, type in terminal:
renes-Mac-Pro:~ rene$ kextstat | grep AMD
Output should be something like this (4 kexts loaded):
com.apple.kext.AMDSupport (1.3.0)
com.apple.kext.AMD5000Controller
com.apple.AMDRadeonX3000
com.apple.kext.AMDFramebuffer
On 28 de marzo de 2016 at 20:41, Rene dijo:
Read here.
thank you very much  for your help. I do not know how to disable SIP maybe it is the problem. I will try to learn. After typing the line i get this:
75    0 0xffffff7f8230d000 0x125000   0x125000   com.apple.kext.AMDSupport (1.4.0) B69BD872-3C05-30D5-B319-1429C14816A0 <74 73 12 11 7 5 4 3 1>
but nothing regarding to hd 5450 or and support. What do you recommend me to do? thanks
Are you using Clover? Then read my link and add those values in your config.plist.
Are you using the FakeID??
Read here.
Thanks a lot for your help. I do. To know how to disable  sip maybe it's the problem. After typing your command only get this :
hace 3 horas, Rene dijo:
Yes use Fake ID 68E01002 but I said not working. Y read your post, I understand what do you want, but sorry I don't know how to add these RT values . Do I have to do it by clover configuration or when starting system I have to add them. And I must update cache? Sorry for my low level
Edited by abelg
