jonealex
[HELP] Yosemite in my AMD PC?
Hi guys, I have an AMD A8-7600 and an Gigabyte GTX 960 OC 4GB Windforce, and my question is... ¿it will boot? ¿it will work?
Thank you.
I've installed Yosemite but grpahics are so bad (animations, toolbars...). What I can do?
Looks like u are not a fan of reading.The ?guide has answer to usr question.but anyway u have issue with ur GPU ,its not running with QE/CI.
so u need to install web driver
http://www.hackintoshosx.com/topic/22774-nvidia-graphics-web-drivers-installation-guide/
I've been reading and testing some things. And had the driver installed , but when you start with nvda_drv = 1 screen appears disconnected. About this problem I didn't found nothing...
I need to know more about ur system information,boot loader ,settings u using?
sp post darwin dumper reports so i can take a look.
My system information is :?
AMD A8-7600 APU Processor with Radeon R7 Graphics (integrated 4 Cores CPU + 6 Cores GPU)
MSI Motherboard A78M-E35
2x 4Gb Crucial RAM DDR3 1600 Mhz
Gigabyte GeForce GTX 960 OC 4GB
I'm not using a boot loader, I've installed the N i r e s h 's ISO for AMD and Intel. This is because I'm spanish and I'm not really good translating your guide and changing the kernel, etc...?
For boot my hackintosh Yosemite 10.10 I'm using the USB Installer and selecting the hard disk with the OS and put in to te command line "ncda_drv=1" but?screen appears disconnected. Without it, the system boots but it shows an alert that says I've shutdown my PC incorrectly and I had apps running ("Cancel" or "Open again") and I can't choose anyone it looks like frozen.
Thank you, and sorry for being irritating.
Edited by jonealex
