poesel
unknown CPU model 0x3c
I get these lines during boot:
kernel[0]: WARNING: IOPlatformPluginUtil : getCPUIDInfo: this is an unknown CPU model 0x3c
kernel[0]: -- power management may be incomplete or unsupported
I have no problems with power management except one: I have no sound after sleep and this is very annoying because I have to reboot then which makes the point of sleep moot.
I've read this (twice):
http://www.hackintoshosx.com/topic/22874-power-management-for-your-hackintosh/
but I'm still confused what I actually have to do. Some or all of it? Sorry.
GA-Z97 motherboard with i5, plist attached.
Thanks!
Edit: Clover!
config.plist.zip
Edited by poesel
Intel? Core? i5-4690K CPU @ 3.50GHz
Lets start ,First of all you need to remove chameleon bootloader, just delete the files.
Then remove EmuVariableUefi-64.efi , vbox.efi? and nullCpu kext from clover.?
Use the DSDT and cpnfig.plist files from the link
https://www.dropbox.com/s/93qhqnyhopnw7qd/poesel%20files.zip?dl=0
and last verify its working or not.
Good hack
I am having the exact same issue, I have a i5 4430, my computer starts really slow and holds up on this same spot.?
I would greatly appreciate any help given.?
I tried the recommendations and was unable to boot.?
These are my specs.?
OS X 10.10.5 - Clover 3253 - CPU | i5 4430 Haswell 3-3.2GHz - 16GB 1600MHz ram ​- 250GB Samsung EVO 840 SSD - GC | ASUS NVIDIA GeForce GTX 660 - MB | Gigabyte GA-H97M-D3H - Ethernet | Realtek RTL8111F-VA - LG Blu-ray
Thank you very much in advance.?
Edited by macj29
Do you please try this config?
config.plist.zip
Edited by christ1111
