theconsumer1
[GUIDE] GA-Z97-D3H - Core i5 - GTX650 - EL CAPITAN
UPDATE:  Now on MacOS Sierra - Build is Flawless! (see guide on osx86.net)
Specs:
  • GA Z97-D3H (rev 1.1, I am using F9, have used F7 and F8. F7 booted fastest)
  • Core i5 4430 Haswell 3.0 GHz
  • EVGA GTX650 1024mb
  • 8GB G.Skill 1333MHz
  • ASUS USBN13 Wireless Adapter
  • 120GB SSD
  • 750GB HDD
  • 160GB HDD
  • 10.11.1 OSX El Capitan
Working:
  • App store
  • Wifi (USB)
  • Audio (ALC1150 - Onboard)
  • Ethernet (via kext)
  • Power Mangement
  • Wake/Sleep
  • Graphics
  • Probably one of the most functional hacks out there.
Issues:
  • Random KP very rarely every (Once per 2 weeks- system restarts)... Could be related to failing hardware, not sure.
Notes:
  •  Onboard ALC1150 is used for this system
  • If struggling with enabling Audio, I recommend the    Syba USB 2.0 External Virtual 7.1 Surround Sound Card Adapter Sound Cards SD-CM-UAUD71    for a cheap solution ($9.00USD) - Works perfect (I Have two).
  • This build uses an SSDT and DSDT - (Optional)
Installation:
The best way to create a USB installer is with the tool made by an InsanelyMac user that automates the manual actions. Heres the link, otherwise there are tons of other tutorials for a USB.
http://www.insanelymac.com/forum/topic/307003-clover-os-x-el-capitan-usb/
Note:  The Installation for El Capitan requires no removing of Ram or any BS like that. Simply plug and play.
Bios Settings:
  • Disable VT-d
  • Set XHCI to Auto mode
  • Disable IGFX
  • Enable XHCI and EHCI handoff
  • Set SATA Configuration to AHCI
  • Important: Set memory mode to Enhanced Stability
Post Installation:
Follow the directions in specific, precise order for best results:
  1. After initial installation, boot into El Capitan with the Clover USB Installer.
  2. Install all network related kexts (For Ethernet, Download here:  AppleIntelE1000e.kext.zip) - Reboot.
  3. Install Clover Bootloader to MAC SSD (r3270 works nice)
           Settings for Clover Bootloader:
Screen Shot 2015-10-03 at 1.31.21 PM.pngScreen Shot 2015-10-03 at 1.31.42 PM.png
     4.  Do not reboot yet. Mount the EFI Partition that corresponds to your Mac SSD (the drive you just installed clover to). Navigate to EFI/EFI/Clover/Kexts/10.11 folder   and place the latest version of FakeSMC there. Do not reboot yet
     5.  Open Config.plist in Clover Configuration. Make sure that Rootles=0, -XCPM flags are checked. Make darkwake=no. Also make sure that SMBIOS is set to iMac 14,2. Make sure that if using the GTX650, uncheck inject nvidia or intel under graphics.
     6.  Optional: For maximum compatibility. I recommend using a DSDT and SSDT. SSDTs can be generated with Pike's tool found here:  http://www.rampagedev.com/ page_id=197
         However, if you have the same board, you can download my personal DSDT and Config file. BUT no guarantees that it will work. Should be harmless though.
          theconsumer1 - El Capitan files.zip
         DSDT and SSDT, for clover, are to be installed at EFI/Clover/ACPI/Patched folder.
    7.  If you skipped 6, then the next thing you need to install is Trim Patch in Clover Configuration (already patched in my DSDT).
          See guide here: http://www.insanelymac.com/forum/topic/298507-enable-trim-on-non-apple-ssd/
    8.   Enable onboard audio ALC1150 with this guide ONLY : https://github.com/toleda/audio_RealtekALC
         Requirements:
              - Must have NATIVE AppleHDA.kext in S/L/E
              - Must remove any HDAEnabler kexts in S/L/E
  - If using your a DSDT make sure you edit and navigate to HDEF/LayoutID/0x01, 0x00, 0x00, 0x00 and make sure that I.D. is 0x01. If not, change it to 0x01.
              - To edit/check DSDT.aml files use DPCIManger app
              - Note: My DSDT on this thread is not updated for the 0x01 edit.
FAQ:
Do i need to update bios version
   No. Many advise that you do, but if you are behind 1 version, it is not big deal.
What about NVIDIA Web Drivers
  The web drivers are just a pain that offers no performance increase. They will give you headaches. Ignore them for now.
How do I know if CPU Power management is working
  Download Intel Power Gadget from Intel's website. If you can see that CPU Freq and Power is changing, you got it.
Appreciation:
Thanks for hackintoshosx.com, insanelymac.com, and the many other contributing members of the community, for all their hard work, research, and time. Also, a special thanks to hackintoshosx user/mod/admin Dmos and Kyndder for really helping me out with my build!
For any question, please address this thread.
Edited by theconsumer1
Also:
If you have success with this board and want to share, please do on this post. I really want to learn a lot more about this board with hackintoshing. Please post your experiences below! Thanks
post-595578-0-60521300-1444310121_thumb.
GA B75M-D3H
Core i3 3.0 GHz
Gigabyte GTX650 1024mb
4GB Corsair Vengeance 1333MHz
500GB HDD
10.11(Final) OSX El Capitan
Bootloader Enoch r2773
<key>GraphicsEnabler</key>
<string>No</string>
<key>Kernel Flags</key>
<string>-v kext-dev-mode=1 npci=0x2000 dart=0 rootless=0</string>
GA B75M-D3H
Core i3 3.0 GHz
500GB HDD
<string>No</string>
Nice. But you have a completely different chipset and board so I don't know how this applies to the thread.
This guide worked beautifully! I initially tried to follow this guide with the exception of upgrading a previous Mavericks install to El Capitan and it would install but never boot after that. I then tried doing a clean install, which worked, and then use migration assistant to move my old setting and stuff off of a Time Machine volume. After that, the machine, again, wouldn't boot. So, the third time, I stopped being stubborn and just did a clean install as this guide suggests and the machine is running great! Better than it did with Mavericks (El Capitan's performance improvements really shine here).
I just manually configured the machine like it was before and then manually migrated some of my preferences from ~/Library and /Library/Server (This is a rack mount server) and everything is working great like it was before, except now it runs faster, seems more stable, and I can finally use the newer Server.app versions.
Thanks a lot for this!
I have this same motherboard but I can't get Clover to boot into OSX Installation because of a KP.
Here are the relevant error lines from a verbose boot:
AppleACPIPlatformExpert::start failedpanic(cpu0 caller 0xffffff80008d1bc4): "Unable to find driver for this platform: \"ACPI\".\n"@/Library/Caches/com.apple.xbs/Sources/xnu/xnu-3247.1.106/iokit/Kernel/IOPlatformExpert.cpp: 1665Debugger called: <panic>Backtrace (CPU0), Frame : Return Address0xffffff81e592bdf0 : 0xfffffff80002e53570xffffff81e592be70 : 0xfffffff80008d1bc40xffffff81e592be80 : 0xfffffff800089405d0xffffff81e592bec0 : 0xfffffff8000893b660xffffff81e592bf30 : 0xfffffff800088e81a0xffffff81e592bf70 : 0xfffffff80008947fc0xffffff81e592bfb0 : 0xfffffff80003d14b7BSD process name corresponding to current thread: UnknownBoot args: kext-dev-mode=1 rootless=0 -v slide=0 container-dmg=file:///Install%20OS%20X%20El%20Capitan.app/Contents/SharedSupport/InstallESD.dmg root-dmg=file:///BaseSystem.dmgMac OS version:Not yet setKernel version:Darwin Kernel Version 15.0.0: Wed Aug 26 16:57:32 PDT 2015; root:xnu-3247.1.106-1/RELEASE_X86_64?
Tried both the linked "Clover OS X El Capitan-v6" app and the generic Clover with the settings showed in the pics.
Thanks in advance for your help
