sep8001
Sleep and Trim on HP8200
Hi?
I have a HP8200 with GT210 which was running 10.10.4 fine without any issues. I upgraded to 10.11 via the upgrade option as I use Clover and now have the following two issues:
1. When I try and check if Trim is enabled under system prefs I get a message as: There was an error while scanning for Serial-ATA devices.
2. When I put the PC to sleep it wakes up by itself after a minute or two, the message I get is: Wake Reason: BR20 GBE1 EUSB.
I am not using a?DSDT.aml?as it was working fine on 10.10.4 without one. Any pointers on how I could resolve the above two issues.
Thank you
Hi?
Thanks for your time. I have managed to get it to sleep with the attached amended dsdt, just hd issue and iMessage. All files are uploaded below.
Thank you for your help.
Did you set SATA configuration in BIOS to AHCI?
check in Bios if you boot with UEFI or Legacy or UEFI+Legacy
Try installing Clover UEFI only on USB stick or Clover Legacy?
I think its a Clover bug because you boot your system normally from HD ?
you can also check disk read/write speed?
if you have experience with Chameleon you can boot from USB stick with the same .kext's from clover and determent if its kext related or bootloader bug?
Try changing SMbios to MacMini thats most similar to your configuration?
About iMessage i think you can fix it with Clover Configurator?
I use Chameleon because clover can't load Envy24.kext properly and i have iMessage on my phone and MacBook Pro so i don't need it?
Chameleon can't enable iMessage for now only Clover can?
Hi
Thanks, it is set to boot ahci, need to check bios but when I installed clover I did select uefi.
Will check the other bits and post back.
Thanks for the suggestions.
