lost_loven
Yosemite on gateway but!
Been a few years since I have Hackintoshed a system and decided to get back into it.
So much has changed but I think I got something good going here..
So far I have Yosamite 10.10.5 on a seperate hard drive and the other being windows 10.
the system ... gateway dx4831-07c .- with some changes ..
graphic card is nvidia gt610. no problems there.. install? of yosamite hard drive.. no problem..
Audio is a problem.. intel series 5/3400? also i see realtek gf 11f . using the system info .. make sense?
there is a ralink wifi rt2790 wireless pcie card.. cant find kext for it, is it compatible ? temp solution is a usb wifi ebay adapter, its ok.
Booting off a usb stick using clover .. works great. I tried the latest clover package installed and doesnt work. just hangs on boot into system,
boots great if usb stick is in. ( it can boot off the hard drive if selected . seems just usb depends a dongle .. know what i mean..?? ) If i select boot off usb it works with clover and chamleon boot, Maybe there is something I can copy off usb stick over to the mac o/s to make it self dependent?
And last but not least,
?click on the app store and it says cant verify computer or id??? I tried method mentioned in some fors about deleteing the networking config and removing the netoworks cards out of prefpane and what not and no go.. is there anothe solution for this I am mising?
I am pretty tech salvay but would like some help on this one please.? here is a refenece from my last hackintosh from june 2011 ..
thanks in advance for even taking the time to look at my multi problem here
lost
ok so its safe then just to make another partition in the existing partition using disk utility? and just the carbon cloner to it then. Doesn't time machine do the same thing or its not reliable?
Yes time machine do the same thing and better,
but how u going to restore with system bricked ?
gottcha . ok so just clone it to a 20 gig drive and then if anything happens just boot it and clone it back if anything happens..? I have done the same think on pc with nortons ghost. ok and I can just re partition my installed drive 20 or 30 gigs less and do no harm to the installed system leaving it a function mac x system as is right.
Well done you :)?.you got it ,also make a ?clover USB with current settings.
Good hack?
