puneet malhotra
booting problem with niresh maverick and graphic card. URGENT PLZ
Hi i am new to hackintosh
my pc specs are
intel dual core @ 2.6ghz
1gb ddr2 ram
ecs mobo
asus nvidia 210 1gb silent
40gb hdd
i tried to install hackintosh with usb the installation goes fine and the installer works in full hd and even after creating the account i can log into the mac and use it without problem. in about this mac it shows my graphic card with its actual name and capacity. but when i restart my computer it starts till apple logo and that too with normal vga graphic it seems the graphic card is not working and after some time the screen goes blank. I tried to install many times both with chameleon and clover but no help. do i need to install the graphic card driver or something inspite of system showing correct graphic card name and memory? i have tried using MB{censored} and installed via easybeast. any help would be appreciated. thanks
hi...
some inputs...
--to me, seem 1GB is not enough for os x full work..
--the video 210 works  OOB only with inject nvidia..- if using clover...
other..
--don't know if the N{censored}  put  something different on config..-if using clover
c.frio
