I have a ALC 887 audio chipset and it's not working right:
I used this patch: audio_cloverALC-120_v1.0a0.command
On Audio ID: 1,2: I get sound on front panel and that's it !
On Audio ID: 3: I get sound on front panel and microphone on the back panel.
if I use just AppleALC patch then:
Audio ID 1: I have audio on back panel but no mic on front or back panel
Audio ID 2: I have audio on front panel but no mic on front or back panel
Audio ID 3: No audio but mic on back panel.
How can I fix the layout so at least the back panel to be fully working ?
Thank you very much !
3 answers to this question
On 8/4/2016 at 12:47 AM, Eurofighter_Ty said:
On 1/20/2018 at 3:41 PM, HardyHu said:
I have the same problem, too
Thanks a lot to every one
DSDT patch is the way to go or use voodooHDA
On 03/08/2016 at 1:47 PM, Eurofighter_Ty said:
first of all post your specs, motherboard, cpu, gpu etc....
post your clover folder + copy of  your IOREG.
and try AppleHDA Patcher.
