hackintosh0505
USB 3.0 type-c 4 Port PCI Express Expansion Card 19-Pin Power
bought this USB 3.0 type-c 4 Port PCI Express Expansion Card 19-Pin Power. Cant seem to get a driver for this. Installed GenericUSBXHCI_1.2.7 with kext wizard...still nothing. Is there a way to enable this pic e card ? thanks.
Not enough information to be able to answer this ... Need to know the card ID or chipset it's using :), even with that information it still might not have an OS X driver.
Martin
Martin
Thanks for the reply. My bad for not checking on the compability.
This is what i bought http://www.lazada.com.my/usb-30-type-c-4-port-pci-express-expansion-card-19-pin-power-17506896.html?utm_source=Orderdelivered&utm_medium=Email&utm_campaign=LineItem
is there any way to use a fake id or so ?
6 hours ago, TpwUK said:
You might have some luck reading through This :) Hope it works for you
Martin
Much gracias for the prompt reply.  I am quite a noob, so dont quite get what is being said in the link..... But the word renesas makes me happy as the windows drivers which came with the pcie card did have some rensas drivers....:)
You're welcome - Try reading all the posts from 1 to #35 as they might contain little gems of information you need to know. From post #35 the guide specifically covers your chipset 20201
Martin
Martin
Can i ask how you knew that my usb card was 20201. Thanks.
