cleriston.martins
Audio don't work
3 answers to this question
2 hours ago, cleriston.martins said:
Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller
Hi, This is not your audio card.please post your proper audio card.
10.13 is new os so older AppleHDA might not work properly.
try voodooHDA for now if new patch available then try applehda
Which patch you are using ?
12 horas atrás, Dmos disse:
I've tried using several AppleHDA, from native to ALC1150. I've tried VoodooHDA too, and to no avail.
I noticed that the native is ALC668, so the Toledo script is not supported ..
Type an impression of my devices with Windows installed.
On 10/10/2017 at 9:16 PM, cleriston.martins said:
I thinks its just kext injection issue.lot of ppl having success using 662 but 668 has its own kexts
https://github.com/insanelydeepak/Patched-AppleHDA-for-Mac-OS-Sierra-10.12
Check you injection setting and dont try all the patches from native to ALC 1150.Sometimes its breaks the system.And for voodooHDA try the latest ver,install and update you cache.
https://sourceforge.net/projects/voodoohda/files/?source=navbar
