INNESL
A Critical Error has occurred while running the virtual machine
I took my time when following the DYI install steps to be sure everything was correct. I go to click start to run the VM OS Siera and it starts to run then it immediately starts to error. I didn't see anything that stood out to me as the problem as Im not that code savy looking at the logs.
log 1mac OS Sierra-2018-07-03-14-02-50
0 answers to this question
VirtualBox VM 5.2.14 r123301 win.amd64 (Jun 29 2018 11:35:31) release log
00:00:02.372970 Log opened 2018-07-03T04:36:13.247995200Z
00:00:02.372972 Build Type: release
00:00:02.372979 OS Product: Windows 10
00:00:02.372980 OS Release: 10.0.17134
00:00:02.372981 OS Service Pack:
00:00:02.457101 DMI Product Name: Inspiron 5765
00:00:02.466430 DMI Product Version: 1.1.1
00:00:02.466448 Host RAM: 15830MB (15.4GB) total, 10334MB (10.0GB) available
00:00:02.466451 Executable: C:\Program Files\Oracle\VirtualBox\VirtualBox.exe
00:00:02.466451 Process ID: 16356
00:00:02.466452 Package type: WINDOWS_64BITS_GENERIC
00:00:02.469282 Installed Extension Packs:
00:00:02.469391 None installed!
00:00:02.470995 Console: Machine state changed to 'Starting'
00:00:02.485854 Qt version: 5.6.2
00:00:02.490398 GUI: UIMediumEnumerator: Medium-enumeration finished!
00:00:02.683979 SUP: Loaded VMMR0.r0 (C:\Program Files\Oracle\VirtualBox\VMMR0.r0) at 0xXXXXXXXXXXXXXXXX - ModuleInit at XXXXXXXXXXXXXXXX and ModuleTerm at XXXXXXXXXXXXXXXX using the native ring-0 loader
00:00:02.684075 SUP: VMMR0EntryEx located at XXXXXXXXXXXXXXXX and VMMR0EntryFast at XXXXXXXXXXXXXXXX
00:00:02.684095 SUP: windbg> .reload /f C:\Program Files\Oracle\VirtualBox\VMMR0.r0=0xXXXXXXXXXXXXXXXX
00:00:02.691731 Guest OS type: 'MacOS1013_64'
00:00:02.692633 Using MWAIT extensions
00:00:02.693194 fHMForced=true - Lots of RAM
00:00:02.693212 fHMForced=true - SMP
00:00:02.693229 fHMForced=true - 64-bit guest
00:00:02.718597 File system of 'C:\Users\blust\VirtualBox VMs\mac OS Sierra\Snapshots' (snapshots) is unknown
00:00:02.718646 File system of 'C:\Users\blust\OneDrive\Desktop\macOS Sierra 10.12 Files-001\macOS Sierra 10.12 Files\macOS Sierra 10.12 by wikigain.vmdk' is ntfs
00:00:02.748048 VideoRec: Only video will be recorded
00:00:02.765552 Shared clipboard service loaded
00:00:02.765612 Shared clipboard mode: Off
00:00:02.791772 Drag and drop service loaded
00:00:02.791794 Drag and drop mode: Off
00:00:02.838991 Guest Control service loaded
00:00:02.842085 ************************* CFGM dump *************************
00:00:02.842089 [/] (level 0)
00:00:02.842094 CSAMEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842096 CpuExecutionCap <integer> = 0x0000000000000064 (100)
00:00:02.842098 EnablePAE <integer> = 0x0000000000000001 (1)
00:00:02.842100 HMEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842115 MemBalloonSize <integer> = 0x0000000000000000 (0)
00:00:02.842116 Name <string> = "mac OS Sierra" (cb=14)
00:00:02.842118 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:02.842119 PATMEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842120 PageFusionAllowed <integer> = 0x0000000000000000 (0)
00:00:02.842121 RamHoleSize <integer> = 0x0000000024000000 (603 979 776, 576 MB)
00:00:02.842123 RamSize <integer> = 0x0000000100000000 (4 294 967 296, 4 096 MB, 4.0 GB)
00:00:02.842126 RawR0Enabled <integer> = 0x0000000000000001 (1)
00:00:02.842128 RawR3Enabled <integer> = 0x0000000000000001 (1)
00:00:02.842129 TimerMillies <integer> = 0x000000000000000a (10)
00:00:02.842130 UUID <bytes> = "a2 1d d6 61 3b 6f 3f 47 83 e6 7e 1e cf 43 70 c4" (cb=16)
00:00:02.842138
00:00:02.842138 [/CPUM/] (level 1)
00:00:02.842141 GuestCpuName <string> = "host" (cb=5)
00:00:02.842142 MWaitExtensions <integer> = 0x0000000000000001 (1)
00:00:02.842143 PortableCpuIdLevel <integer> = 0x0000000000000000 (0)
00:00:02.842144 SpecCtrl <integer> = 0x0000000000000000 (0)
00:00:02.842146
00:00:02.842146 [/CPUM/HostCPUID/] (level 2)
00:00:02.842148
00:00:02.842148 [/CPUM/HostCPUID/1/] (level 3)
00:00:02.842150 eax <integer> = 0x00000000000106e5 (67 301)
00:00:02.842151 ebx <integer> = 0x0000000000100800 (1 050 624)
00:00:02.842153 ecx <integer> = 0x000000000098e3fd (10 019 837)
00:00:02.842154 edx <integer> = 0x00000000bfebfbff (3 219 913 727)
00:00:02.842156
00:00:02.842156 [/DBGC/] (level 1)
00:00:02.842157 GlobalInitScript <string> = "C:\Users\blust\.VirtualBox/dbgc-init" (cb=37)
00:00:02.842159 HistoryFile <string> = "C:\Users\blust\.VirtualBox/dbgc-history" (cb=40)
00:00:02.842160 LocalInitScript <string> = "C:\Users\blust\VirtualBox VMs\mac OS Sierra/dbgc-init" (cb=54)
00:00:02.842161
00:00:02.842162 [/DBGF/] (level 1)
00:00:02.842163 Path <string> = "C:\Users\blust\VirtualBox VMs\mac OS Sierra/debug/;C:\Users\blust\VirtualBox VMs\mac OS Sierra/;C:\Users\blust\" (cb=112)
00:00:02.842164
00:00:02.842165 [/Devices/] (level 1)
00:00:02.842166
00:00:02.842166 [/Devices/8237A/] (level 2)
00:00:02.842168
00:00:02.842168 [/Devices/8237A/0/] (level 3)
00:00:02.842170 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842171
00:00:02.842171 [/Devices/GIMDev/] (level 2)
00:00:02.842172
00:00:02.842173 [/Devices/GIMDev/0/] (level 3)
00:00:02.842174 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842176
00:00:02.842176 [/Devices/VMMDev/] (level 2)
00:00:02.842177
00:00:02.842177 [/Devices/VMMDev/0/] (level 3)
00:00:02.842179 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842181 PCIDeviceNo <integer> = 0x0000000000000004 (4)
00:00:02.842182 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:02.842183 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842184
00:00:02.842184 [/Devices/VMMDev/0/Config/] (level 4)
00:00:02.842186 GuestCoreDumpDir <string> = "C:\Users\blust\VirtualBox VMs\mac OS Sierra\Snapshots" (cb=54)
00:00:02.842187
00:00:02.842187 [/Devices/VMMDev/0/LUN#0/] (level 4)
00:00:02.842189 Driver <string> = "HGCM" (cb=5)
00:00:02.842190
00:00:02.842190 [/Devices/VMMDev/0/LUN#0/Config/] (level 5)
00:00:02.842192 Object <integer> = 0x0000000004b93670 (79 246 960)
00:00:02.842194
00:00:02.842194 [/Devices/VMMDev/0/LUN#999/] (level 4)
00:00:02.842196 Driver <string> = "MainStatus" (cb=11)
00:00:02.842197
00:00:02.842197 [/Devices/VMMDev/0/LUN#999/Config/] (level 5)
00:00:02.842199 First <integer> = 0x0000000000000000 (0)
00:00:02.842200 Last <integer> = 0x0000000000000000 (0)
00:00:02.842201 papLeds <integer> = 0x0000000001d0df30 (30 465 840)
00:00:02.842202
00:00:02.842203 [/Devices/acpi/] (level 2)
00:00:02.842204
00:00:02.842204 [/Devices/acpi/0/] (level 3)
00:00:02.842206 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842207 PCIDeviceNo <integer> = 0x0000000000000007 (7)
00:00:02.842208 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:02.842209 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842210
00:00:02.842211 [/Devices/acpi/0/Config/] (level 4)
00:00:02.842214 AudioPciAddress <integer> = 0x0000000000050000 (327 680)
00:00:02.842215 CpuHotPlug <integer> = 0x0000000000000000 (0)
00:00:02.842216 FdcEnabled <integer> = 0x0000000000000000 (0)
00:00:02.842217 HostBusPciAddress <integer> = 0x00000000001e0000 (1 966 080)
00:00:02.842219 HpetEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842220 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:02.842221 IocPciAddress <integer> = 0x00000000001f0000 (2 031 616)
00:00:02.842222 McfgBase <integer> = 0x00000000dc000000 (3 690 987 520)
00:00:02.842224 McfgLength <integer> = 0x0000000004000000 (67 108 864)
00:00:02.842225 NicPciAddress <integer> = 0x0000000000110000 (1 114 112)
00:00:02.842227 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:02.842228 Parallel0IoPortBase <integer> = 0x0000000000000000 (0)
00:00:02.842229 Parallel0Irq <integer> = 0x0000000000000000 (0)
00:00:02.842230 Parallel1IoPortBase <integer> = 0x0000000000000000 (0)
00:00:02.842231 Parallel1Irq <integer> = 0x0000000000000000 (0)
00:00:02.842232 PciPref64Enabled <integer> = 0x0000000000000001 (1)
00:00:02.842233 Serial0IoPortBase <integer> = 0x0000000000000000 (0)
00:00:02.842234 Serial0Irq <integer> = 0x0000000000000000 (0)
00:00:02.842236 Serial1IoPortBase <integer> = 0x0000000000000000 (0)
00:00:02.842236 Serial1Irq <integer> = 0x0000000000000000 (0)
00:00:02.842237 ShowCpu <integer> = 0x0000000000000001 (1)
00:00:02.842239 ShowRtc <integer> = 0x0000000000000001 (1)
00:00:02.842240 SmcEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842241
00:00:02.842241 [/Devices/acpi/0/LUN#0/] (level 4)
00:00:02.842243 Driver <string> = "ACPIHost" (cb=9)
00:00:02.842244
00:00:02.842244 [/Devices/acpi/0/LUN#0/Config/] (level 5)
00:00:02.842246
00:00:02.842246 [/Devices/acpi/0/LUN#1/] (level 4)
00:00:02.842248 Driver <string> = "ACPICpu" (cb=8)
00:00:02.842249
00:00:02.842249 [/Devices/acpi/0/LUN#1/Config/] (level 5)
00:00:02.842251
00:00:02.842251 [/Devices/acpi/0/LUN#2/] (level 4)
00:00:02.842253 Driver <string> = "ACPICpu" (cb=8)
00:00:02.842253
00:00:02.842254 [/Devices/acpi/0/LUN#2/Config/] (level 5)
00:00:02.842255
00:00:02.842256 [/Devices/acpi/0/LUN#3/] (level 4)
00:00:02.842257 Driver <string> = "ACPICpu" (cb=8)
00:00:02.842258
00:00:02.842259 [/Devices/acpi/0/LUN#3/Config/] (level 5)
00:00:02.842260
00:00:02.842261 [/Devices/ahci/] (level 2)
00:00:02.842262
00:00:02.842263 [/Devices/ahci/0/] (level 3)
00:00:02.842265 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842266 PCIDeviceNo <integer> = 0x000000000000001f (31)
00:00:02.842267 PCIFunctionNo <integer> = 0x0000000000000002 (2)
00:00:02.842268 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842270
00:00:02.842270 [/Devices/ahci/0/Config/] (level 4)
00:00:02.842272 Bootable <integer> = 0x0000000000000001 (1)
00:00:02.842273 PortCount <integer> = 0x0000000000000002 (2)
00:00:02.842274
00:00:02.842275 [/Devices/ahci/0/Config/Port0/] (level 5)
00:00:02.842277 Hotpluggable <integer> = 0x0000000000000000 (0)
00:00:02.842278
00:00:02.842279 [/Devices/ahci/0/Config/Port1/] (level 5)
00:00:02.842280 Hotpluggable <integer> = 0x0000000000000000 (0)
00:00:02.842281
00:00:02.842282 [/Devices/ahci/0/LUN#0/] (level 4)
00:00:02.842284 Driver <string> = "VD" (cb=3)
00:00:02.842285
00:00:02.842285 [/Devices/ahci/0/LUN#0/Config/] (level 5)
00:00:02.842287 BlockCache <integer> = 0x0000000000000001 (1)
00:00:02.842288 Format <string> = "VMDK" (cb=5)
00:00:02.842289 Mountable <integer> = 0x0000000000000000 (0)
00:00:02.842291 Path <string> = "C:\Users\blust\OneDrive\Desktop\macOS Sierra 10.12 Files-001\macOS Sierra 10.12 Files\macOS Sierra 10.12 by wikigain.vmdk" (cb=122)
00:00:02.842292 Type <string> = "HardDisk" (cb=9)
00:00:02.842294 UseNewIo <integer> = 0x0000000000000001 (1)
00:00:02.842295
00:00:02.842295 [/Devices/ahci/0/LUN#1/] (level 4)
00:00:02.842297 Driver <string> = "SCSI" (cb=5)
00:00:02.842298
00:00:02.842299 [/Devices/ahci/0/LUN#1/AttachedDriver/] (level 5)
00:00:02.842301 Driver <string> = "VD" (cb=3)
00:00:02.842302
00:00:02.842302 [/Devices/ahci/0/LUN#1/AttachedDriver/Config/] (level 6)
00:00:02.842304 EmptyDrive <integer> = 0x0000000000000001 (1)
00:00:02.842305 Mountable <integer> = 0x0000000000000001 (1)
00:00:02.842306 Type <string> = "DVD" (cb=4)
00:00:02.842307
00:00:02.842308 [/Devices/ahci/0/LUN#999/] (level 4)
00:00:02.842310 Driver <string> = "MainStatus" (cb=11)
00:00:02.842311
00:00:02.842311 [/Devices/ahci/0/LUN#999/Config/] (level 5)
00:00:02.842314 DeviceInstance <string> = "ahci/0" (cb=7)
00:00:02.842315 First <integer> = 0x0000000000000000 (0)
00:00:02.842316 Last <integer> = 0x0000000000000001 (1)
00:00:02.842317 pConsole <integer> = 0x0000000001d0d720 (30 463 776)
00:00:02.842319 papLeds <integer> = 0x0000000001d0db30 (30 464 816)
00:00:02.842321 pmapMediumAttachments <integer> = 0x0000000001d0df50 (30 465 872)
00:00:02.842322
00:00:02.842323 [/Devices/apic/] (level 2)
00:00:02.842324
00:00:02.842324 [/Devices/apic/0/] (level 3)
00:00:02.842326 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842327
00:00:02.842327 [/Devices/apic/0/Config/] (level 4)
00:00:02.842329 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:02.842330 Mode <integer> = 0x0000000000000002 (2)
00:00:02.842331 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:02.842332
00:00:02.842333 [/Devices/e1000/] (level 2)
00:00:02.842334
00:00:02.842334 [/Devices/e1000/0/] (level 3)
00:00:02.842337 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842338 PCIDeviceNo <integer> = 0x0000000000000011 (17)
00:00:02.842339 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:02.842340 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842342
00:00:02.842342 [/Devices/e1000/0/Config/] (level 4)
00:00:02.842344 AdapterType <integer> = 0x0000000000000002 (2)
00:00:02.842346 CableConnected <integer> = 0x0000000000000001 (1)
00:00:02.842347 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:02.842348 MAC <bytes> = "08 00 27 6e 78 44" (cb=6)
00:00:02.842354
00:00:02.842354 [/Devices/e1000/0/LUN#0/] (level 4)
00:00:02.842356 Driver <string> = "NAT" (cb=4)
00:00:02.842356
00:00:02.842357 [/Devices/e1000/0/LUN#0/Config/] (level 5)
00:00:02.842359 AliasMode <integer> = 0x0000000000000000 (0)
00:00:02.842360 BootFile <string> = "mac OS Sierra.pxe" (cb=18)
00:00:02.842362 DNSProxy <integer> = 0x0000000000000000 (0)
00:00:02.842363 Network <string> = "10.0.2.0/24" (cb=12)
00:00:02.842364 PassDomain <integer> = 0x0000000000000001 (1)
00:00:02.842365 TFTPPrefix <string> = "C:\Users\blust\.VirtualBox\TFTP" (cb=32)
00:00:02.842367 UseHostResolver <integer> = 0x0000000000000000 (0)
00:00:02.842368
00:00:02.842368 [/Devices/e1000/0/LUN#999/] (level 4)
00:00:02.842370 Driver <string> = "MainStatus" (cb=11)
00:00:02.842371
00:00:02.842371 [/Devices/e1000/0/LUN#999/Config/] (level 5)
00:00:02.842373 First <integer> = 0x0000000000000000 (0)
00:00:02.842374 Last <integer> = 0x0000000000000000 (0)
00:00:02.842375 papLeds <integer> = 0x0000000001d0de10 (30 465 552)
00:00:02.842377
00:00:02.842377 [/Devices/efi/] (level 2)
00:00:02.842378
00:00:02.842379 [/Devices/efi/0/] (level 3)
00:00:02.842380 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842381
00:00:02.842381 [/Devices/efi/0/Config/] (level 4)
00:00:02.842384 64BitEntry <integer> = 0x0000000000000001 (1)
00:00:02.842385 APIC <integer> = 0x0000000000000001 (1)
00:00:02.842387 BootArgs <string> = "" (cb=1)
00:00:02.842388 DeviceProps <string> = "" (cb=1)
00:00:02.842389 DmiBoardProduct <string> = "Iloveapple" (cb=11)
00:00:02.842390 DmiExposeMemoryTable <integer> = 0x0000000000000001 (1)
00:00:02.842391 DmiSystemProduct <string> = "iMac11,3" (cb=9)
00:00:02.842392 DmiSystemVersion <string> = "1.0" (cb=4)
00:00:02.842393 DmiUseHostInfo <integer> = 0x0000000000000001 (1)
00:00:02.842395 EfiRom <string> = "C:\Program Files\Oracle\VirtualBox\VBoxEFI64.fd" (cb=48)
00:00:02.842396 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:02.842397 McfgBase <integer> = 0x00000000dc000000 (3 690 987 520)
00:00:02.842399 McfgLength <integer> = 0x0000000004000000 (67 108 864)
00:00:02.842401 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:02.842402 UUID <bytes> = "a2 1d d6 61 3b 6f 3f 47 83 e6 7e 1e cf 43 70 c4" (cb=16)
00:00:02.842405
00:00:02.842406 [/Devices/efi/0/LUN#0/] (level 4)
00:00:02.842408 Driver <string> = "NvramStorage" (cb=13)
00:00:02.842409
00:00:02.842409 [/Devices/efi/0/LUN#0/Config/] (level 5)
00:00:02.842411 Object <integer> = 0x0000000001d147b0 (30 492 592)
00:00:02.842412
00:00:02.842413 [/Devices/hda/] (level 2)
00:00:02.842414
00:00:02.842414 [/Devices/hda/0/] (level 3)
00:00:02.842416 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842417 PCIDeviceNo <integer> = 0x0000000000000005 (5)
00:00:02.842418 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:02.842419 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842420
00:00:02.842421 [/Devices/hda/0/AudioConfig/] (level 4)
00:00:02.842422
00:00:02.842423 [/Devices/hda/0/Config/] (level 4)
00:00:02.842424 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:02.842425 DebugPathOut <string> = "" (cb=1)
00:00:02.842426
00:00:02.842427 [/Devices/hda/0/LUN#0/] (level 4)
00:00:02.842429 Driver <string> = "AUDIO" (cb=6)
00:00:02.842430
00:00:02.842430 [/Devices/hda/0/LUN#0/AttachedDriver/] (level 5)
00:00:02.842432 Driver <string> = "DSoundAudio" (cb=12)
00:00:02.842433
00:00:02.842434 [/Devices/hda/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:02.842436 StreamName <string> = "mac OS Sierra" (cb=14)
00:00:02.842437
00:00:02.842437 [/Devices/hda/0/LUN#0/Config/] (level 5)
00:00:02.842440 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:02.842441 DebugPathOut <string> = "" (cb=1)
00:00:02.842442 DriverName <string> = "DSoundAudio" (cb=12)
00:00:02.842443 InputEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842444 OutputEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842445
00:00:02.842445 [/Devices/hda/0/LUN#1/] (level 4)
00:00:02.842447 Driver <string> = "AUDIO" (cb=6)
00:00:02.842448
00:00:02.842448 [/Devices/hda/0/LUN#1/AttachedDriver/] (level 5)
00:00:02.842450 Driver <string> = "AudioVRDE" (cb=10)
00:00:02.842451
00:00:02.842452 [/Devices/hda/0/LUN#1/AttachedDriver/Config/] (level 6)
00:00:02.842454 Object <integer> = 0x0000000001d14950 (30 493 008)
00:00:02.842455 ObjectVRDPServer <integer> = 0x0000000001d18e60 (30 510 688)
00:00:02.842457 StreamName <string> = "mac OS Sierra" (cb=14)
00:00:02.842458
00:00:02.842459 [/Devices/hda/0/LUN#1/Config/] (level 5)
00:00:02.842461 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:02.842462 DebugPathOut <string> = "" (cb=1)
00:00:02.842463 DriverName <string> = "AudioVRDE" (cb=10)
00:00:02.842464 InputEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842465 OutputEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842466
00:00:02.842466 [/Devices/hpet/] (level 2)
00:00:02.842468
00:00:02.842468 [/Devices/hpet/0/] (level 3)
00:00:02.842470 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842471
00:00:02.842471 [/Devices/hpet/0/Config/] (level 4)
00:00:02.842473 ICH9 <integer> = 0x0000000000000001 (1)
00:00:02.842474
00:00:02.842474 [/Devices/i8254/] (level 2)
00:00:02.842476
00:00:02.842476 [/Devices/i8254/0/] (level 3)
00:00:02.842477
00:00:02.842478 [/Devices/i8254/0/Config/] (level 4)
00:00:02.842479
00:00:02.842480 [/Devices/i8259/] (level 2)
00:00:02.842481
00:00:02.842481 [/Devices/i8259/0/] (level 3)
00:00:02.842483 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842484
00:00:02.842484 [/Devices/i8259/0/Config/] (level 4)
00:00:02.842485
00:00:02.842486 [/Devices/ich9pci/] (level 2)
00:00:02.842487
00:00:02.842487 [/Devices/ich9pci/0/] (level 3)
00:00:02.842489 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842490
00:00:02.842490 [/Devices/ich9pci/0/Config/] (level 4)
00:00:02.842492 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:02.842493 McfgBase <integer> = 0x00000000dc000000 (3 690 987 520)
00:00:02.842495 McfgLength <integer> = 0x0000000004000000 (67 108 864)
00:00:02.842496
00:00:02.842496 [/Devices/ich9pcibridge/] (level 2)
00:00:02.842498
00:00:02.842498 [/Devices/ioapic/] (level 2)
00:00:02.842499
00:00:02.842500 [/Devices/ioapic/0/] (level 3)
00:00:02.842501 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842502
00:00:02.842503 [/Devices/ioapic/0/Config/] (level 4)
00:00:02.842504 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:02.842505
00:00:02.842506 [/Devices/lpc/] (level 2)
00:00:02.842507
00:00:02.842507 [/Devices/lpc/0/] (level 3)
00:00:02.842509 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842510 PCIDeviceNo <integer> = 0x000000000000001f (31)
00:00:02.842511 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:02.842512 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842513
00:00:02.842514 [/Devices/mc146818/] (level 2)
00:00:02.842515
00:00:02.842516 [/Devices/mc146818/0/] (level 3)
00:00:02.842517
00:00:02.842518 [/Devices/mc146818/0/Config/] (level 4)
00:00:02.842520 UseUTC <integer> = 0x0000000000000001 (1)
00:00:02.842520
00:00:02.842521 [/Devices/parallel/] (level 2)
00:00:02.842522
00:00:02.842523 [/Devices/pcarch/] (level 2)
00:00:02.842524
00:00:02.842524 [/Devices/pcarch/0/] (level 3)
00:00:02.842526 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842527
00:00:02.842528 [/Devices/pcarch/0/Config/] (level 4)
00:00:02.842529
00:00:02.842530 [/Devices/pckbd/] (level 2)
00:00:02.842532
00:00:02.842532 [/Devices/pckbd/0/] (level 3)
00:00:02.842534 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842535
00:00:02.842535 [/Devices/pckbd/0/Config/] (level 4)
00:00:02.842537
00:00:02.842537 [/Devices/pckbd/0/LUN#0/] (level 4)
00:00:02.842539 Driver <string> = "KeyboardQueue" (cb=14)
00:00:02.842540
00:00:02.842541 [/Devices/pckbd/0/LUN#0/AttachedDriver/] (level 5)
00:00:02.842542 Driver <string> = "MainKeyboard" (cb=13)
00:00:02.842544
00:00:02.842544 [/Devices/pckbd/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:02.842546 Object <integer> = 0x0000000001cd4c10 (30 231 568)
00:00:02.842547
00:00:02.842548 [/Devices/pckbd/0/LUN#0/Config/] (level 5)
00:00:02.842550 QueueSize <integer> = 0x0000000000000040 (64)
00:00:02.842551
00:00:02.842551 [/Devices/pckbd/0/LUN#1/] (level 4)
00:00:02.842553 Driver <string> = "MouseQueue" (cb=11)
00:00:02.842554
00:00:02.842554 [/Devices/pckbd/0/LUN#1/AttachedDriver/] (level 5)
00:00:02.842556 Driver <string> = "MainMouse" (cb=10)
00:00:02.842557
00:00:02.842558 [/Devices/pckbd/0/LUN#1/AttachedDriver/Config/] (level 6)
00:00:02.842560 Object <integer> = 0x0000000001d12d50 (30 485 840)
00:00:02.842561
00:00:02.842561 [/Devices/pckbd/0/LUN#1/Config/] (level 5)
00:00:02.842563 QueueSize <integer> = 0x0000000000000080 (128)
00:00:02.842565
00:00:02.842565 [/Devices/pcnet/] (level 2)
00:00:02.842566
00:00:02.842567 [/Devices/serial/] (level 2)
00:00:02.842568
00:00:02.842568 [/Devices/smc/] (level 2)
00:00:02.842570
00:00:02.842570 [/Devices/smc/0/] (level 3)
00:00:02.842572 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842573
00:00:02.842573 [/Devices/smc/0/Config/] (level 4)
00:00:02.842575 DeviceKey <string> = "ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc" (cb=65)
00:00:02.842577 GetKeyFromRealSMC <integer> = 0x0000000000000001 (1)
00:00:02.842578
00:00:02.842578 [/Devices/usb-ohci/] (level 2)
00:00:02.842579
00:00:02.842580 [/Devices/usb-ohci/0/] (level 3)
00:00:02.842582 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842583 PCIDeviceNo <integer> = 0x000000000000001f (31)
00:00:02.842584 PCIFunctionNo <integer> = 0x0000000000000004 (4)
00:00:02.842585 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842586
00:00:02.842587 [/Devices/usb-ohci/0/Config/] (level 4)
00:00:02.842588
00:00:02.842588 [/Devices/usb-ohci/0/LUN#0/] (level 4)
00:00:02.842590 Driver <string> = "VUSBRootHub" (cb=12)
00:00:02.842591
00:00:02.842592 [/Devices/usb-ohci/0/LUN#0/Config/] (level 5)
00:00:02.842594
00:00:02.842594 [/Devices/usb-ohci/0/LUN#999/] (level 4)
00:00:02.842596 Driver <string> = "MainStatus" (cb=11)
00:00:02.842597
00:00:02.842597 [/Devices/usb-ohci/0/LUN#999/Config/] (level 5)
00:00:02.842599 First <integer> = 0x0000000000000000 (0)
00:00:02.842600 Last <integer> = 0x0000000000000000 (0)
00:00:02.842601 papLeds <integer> = 0x0000000001d0df38 (30 465 848)
00:00:02.842602
00:00:02.842603 [/Devices/vga/] (level 2)
00:00:02.842604
00:00:02.842604 [/Devices/vga/0/] (level 3)
00:00:02.842606 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:02.842607 PCIDeviceNo <integer> = 0x0000000000000002 (2)
00:00:02.842608 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:02.842609 Trusted <integer> = 0x0000000000000001 (1)
00:00:02.842610
00:00:02.842610 [/Devices/vga/0/Config/] (level 4)
00:00:02.842613 CustomVideoModes <integer> = 0x0000000000000000 (0)
00:00:02.842614 FadeIn <integer> = 0x0000000000000001 (1)
00:00:02.842615 FadeOut <integer> = 0x0000000000000001 (1)
00:00:02.842616 HeightReduction <integer> = 0x0000000000000000 (0)
00:00:02.842617 LogoFile <string> = "" (cb=1)
00:00:02.842618 LogoTime <integer> = 0x0000000000000000 (0)
00:00:02.842620 MonitorCount <integer> = 0x0000000000000001 (1)
00:00:02.842621 ShowBootMenu <integer> = 0x0000000000000002 (2)
00:00:02.842622 VRamSize <integer> = 0x0000000008000000 (134 217 728, 128 MB)
00:00:02.842624
00:00:02.842624 [/Devices/vga/0/LUN#0/] (level 4)
00:00:02.842626 Driver <string> = "MainDisplay" (cb=12)
00:00:02.842627
00:00:02.842627 [/Devices/vga/0/LUN#0/Config/] (level 5)
00:00:02.842629 Object <integer> = 0x0000000001d15d10 (30 498 064)
00:00:02.842630
00:00:02.842631 [/Devices/vga/0/LUN#999/] (level 4)
00:00:02.842632 Driver <string> = "MainStatus" (cb=11)
00:00:02.842633
00:00:02.842634 [/Devices/vga/0/LUN#999/Config/] (level 5)
00:00:02.842636 First <integer> = 0x0000000000000000 (0)
00:00:02.842637 Last <integer> = 0x0000000000000000 (0)
00:00:02.842638 papLeds <integer> = 0x0000000001d0df48 (30 465 864)
00:00:02.842639
00:00:02.842639 [/Devices/virtio-net/] (level 2)
00:00:02.842641
00:00:02.842641 [/EM/] (level 1)
00:00:02.842642 TripleFaultReset <integer> = 0x0000000000000000 (0)
00:00:02.842644
00:00:02.842644 [/GIM/] (level 1)
00:00:02.842645 Provider <string> = "Minimal" (cb=8)
00:00:02.842646
00:00:02.842647 [/HM/] (level 1)
00:00:02.842649 64bitEnabled <integer> = 0x0000000000000001 (1)
00:00:02.842650 EnableLargePages <integer> = 0x0000000000000001 (1)
00:00:02.842651 EnableNestedPaging <integer> = 0x0000000000000001 (1)
00:00:02.842652 EnableUX <integer> = 0x0000000000000001 (1)
00:00:02.842653 EnableVPID <integer> = 0x0000000000000001 (1)
00:00:02.842655 Exclusive <integer> = 0x0000000000000000 (0)
00:00:02.842656 HMForced <integer> = 0x0000000000000001 (1)
00:00:02.842657 IBPBOnVMEntry <integer> = 0x0000000000000000 (0)
00:00:02.842658 IBPBOnVMExit <integer> = 0x0000000000000000 (0)
00:00:02.842659 SpecCtrlByHost <integer> = 0x0000000000000000 (0)
00:00:02.842660
00:00:02.842661 [/MM/] (level 1)
00:00:02.842662 CanUseLargerHeap <integer> = 0x0000000000000001 (1)
00:00:02.842663
00:00:02.842663 [/PDM/] (level 1)
00:00:02.842665
00:00:02.842665 [/PDM/AsyncCompletion/] (level 2)
00:00:02.842666
00:00:02.842667 [/PDM/AsyncCompletion/File/] (level 3)
00:00:02.842668
00:00:02.842669 [/PDM/AsyncCompletion/File/BwGroups/] (level 4)
00:00:02.842670
00:00:02.842671 [/PDM/BlkCache/] (level 2)
00:00:02.842672 CacheSize <integer> = 0x0000000000500000 (5 242 880, 5 MB)
00:00:02.842674
00:00:02.842674 [/PDM/Devices/] (level 2)
00:00:02.842676
00:00:02.842676 [/PDM/Drivers/] (level 2)
00:00:02.842677
00:00:02.842677 [/PDM/Drivers/VBoxC/] (level 3)
00:00:02.842679 Path <string> = "VBoxC" (cb=6)
00:00:02.842680
00:00:02.842680 [/PDM/NetworkShaper/] (level 2)
00:00:02.842682
00:00:02.842682 [/PDM/NetworkShaper/BwGroups/] (level 3)
00:00:02.842684
00:00:02.842684 [/TM/] (level 1)
00:00:02.842685 UTCOffset <integer> = 0x0000000000000000 (0)
00:00:02.842686
00:00:02.842686 [/USB/] (level 1)
00:00:02.842687
00:00:02.842688 [/USB/HidKeyboard/] (level 2)
00:00:02.842689
00:00:02.842689 [/USB/HidKeyboard/0/] (level 3)
00:00:02.842691
00:00:02.842691 [/USB/HidKeyboard/0/Config/] (level 4)
00:00:02.842693
00:00:02.842694 [/USB/HidKeyboard/0/LUN#0/] (level 4)
00:00:02.842695 Driver <string> = "KeyboardQueue" (cb=14)
00:00:02.842696
00:00:02.842697 [/USB/HidKeyboard/0/LUN#0/AttachedDriver/] (level 5)
00:00:02.842699 Driver <string> = "MainKeyboard" (cb=13)
00:00:02.842700
00:00:02.842700 [/USB/HidKeyboard/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:02.842702 Object <integer> = 0x0000000001cd4c10 (30 231 568)
00:00:02.842704
00:00:02.842704 [/USB/HidKeyboard/0/LUN#0/Config/] (level 5)
00:00:02.842706 QueueSize <integer> = 0x0000000000000040 (64)
00:00:02.842707
00:00:02.842708 [/USB/HidMouse/] (level 2)
00:00:02.842709
00:00:02.842709 [/USB/HidMouse/0/] (level 3)
00:00:02.842711
00:00:02.842711 [/USB/HidMouse/0/Config/] (level 4)
00:00:02.842713 Mode <string> = "absolute" (cb=9)
00:00:02.842714
00:00:02.842714 [/USB/HidMouse/0/LUN#0/] (level 4)
00:00:02.842716 Driver <string> = "MouseQueue" (cb=11)
00:00:02.842717
00:00:02.842717 [/USB/HidMouse/0/LUN#0/AttachedDriver/] (level 5)
00:00:02.842719 Driver <string> = "MainMouse" (cb=10)
00:00:02.842720
00:00:02.842721 [/USB/HidMouse/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:02.842723 Object <integer> = 0x0000000001d12d50 (30 485 840)
00:00:02.842724
00:00:02.842724 [/USB/HidMouse/0/LUN#0/Config/] (level 5)
00:00:02.842726 QueueSize <integer> = 0x0000000000000080 (128)
00:00:02.842728
00:00:02.842728 [/USB/USBProxy/] (level 2)
00:00:02.842729
00:00:02.842729 [/USB/USBProxy/GlobalConfig/] (level 3)
00:00:02.842731
00:00:02.842732 ********************* End of CFGM dump **********************
00:00:02.842749 VM: fHMEnabled=true (configured) fRecompileUser=false fRecompileSupervisor=false
00:00:02.842751 VM: fRawRing1Enabled=false CSAM=true PATM=true
00:00:02.843333 HM: HMR3Init: AMD-V w/ nested paging
00:00:02.843522 MM: cbHyperHeap=0x240000 (2359296)
00:00:02.845537 CPUM: fXStateHostMask=0x7; initial: 0x7; host XCR0=0x7
00:00:02.849407 Warning: /CPUM/MWaitExtensions is deprecated, use /CPUM/IsaExts/MWaitExtensions instead.
00:00:02.849793 CPUM: Matched host CPU AMD 0x15/0x65/0x1 AMD_15h_Unknown with CPU DB entry 'AMD FX-8150 Eight-Core' (AMD 0x15/0x1/0x2 AMD_15h_Bulldozer)
00:00:02.849920 CPUM: MXCSR_MASK=0x2ffff (host: 0x2ffff)
00:00:02.849960 CPUM: Microcode revision 0x06006118
00:00:02.849996 CPUM: MSR fudge: 0x00000017 IA32_PLATFORM_ID
00:00:02.850014 CPUM: MSR fudge: 0x000001a0 IA32_MISC_ENABLE
00:00:02.850065 CPUM: SetGuestCpuIdFeature: Enabled PAE
00:00:02.855199 PGM: HCPhysInterPD=00000000bd79f000 HCPhysInterPaePDPT=00000000bd7a2000 HCPhysInterPaePML4=00000000bd7a4000
00:00:02.855258 PGM: apInterPTs={00000000bd7a0000,00000000bd7a1000} apInterPaePTs={00000000926ee000,0000000332fef000} apInterPaePDs={000000026d4f0000,000000018e4f1000,00000001f4bf2000,0000000259ef3000} pInterPaePDPT64=00000000bd7a3000
00:00:02.855276 PGM: Host paging mode: AMD64+PGE+NX
00:00:02.855303 PGM: PGMPool: cMaxPages=2096 (u64MaxPages=2084)
00:00:02.855318 PGM: pgmR3PoolInit: cMaxPages=0x830 cMaxUsers=0x1060 cMaxPhysExts=0x1060 fCacheEnable=true
00:00:02.936859 TM: GIP - u32Mode=3 (Invariant) u32UpdateHz=93 u32UpdateIntervalNS=10734900 enmUseTscDelta=2 (Pratically Zero) fGetGipCpu=0xb cCpus=4
00:00:02.936945 TM: GIP - u64CpuHz=2 694 935 365 (0xa0a17345) SUPGetCpuHzFromGip => 2 694 935 365
00:00:02.936965 TM: GIP - CPU: iCpuSet=0x0 idCpu=0x0 idApic=0x0 iGipCpu=0x3 i64TSCDelta=0 enmState=3 u64CpuHz=2694931550(*) cErrors=0
00:00:02.936985 TM: GIP - CPU: iCpuSet=0x1 idCpu=0x1 idApic=0x1 iGipCpu=0x2 i64TSCDelta=0 enmState=3 u64CpuHz=2694926536(*) cErrors=0
00:00:02.937004 TM: GIP - CPU: iCpuSet=0x2 idCpu=0x2 idApic=0x2 iGipCpu=0x1 i64TSCDelta=0 enmState=3 u64CpuHz=2694973750(*) cErrors=0
00:00:02.937021 TM: GIP - CPU: iCpuSet=0x3 idCpu=0x3 idApic=0x3 iGipCpu=0x0 i64TSCDelta=0 enmState=3 u64CpuHz=2694935365(*) cErrors=0
00:00:02.937126 TM: cTSCTicksPerSecond=2 694 935 365 (0xa0a17345) enmTSCMode=1 (VirtTscEmulated)
00:00:02.937129 TM: TSCTiedToExecution=false TSCNotTiedToHalt=false
00:00:02.939090 VMM: CoreCode: R3=00000000062e0000 R0=XXXXXXXXXXXXXXXX RC=a10c1000 Phys=00000000bd7f7000 cb=0x1000
00:00:02.939874 IEM: TargetCpu=CURRENT, Microarch=AMD_K7_Unknown
00:00:02.940249 GIM: Using provider 'Minimal' (Implementation version: 0)
00:00:02.940287 CPUM: SetGuestCpuIdFeature: Enabled Hypervisor Present bit
00:00:02.940476 AIOMgr: Default manager type is 'Async'
00:00:02.940495 AIOMgr: Default file backend is 'NonBuffered'
00:00:02.941188 BlkCache: Cache successfully initialized. Cache size is 5242880 bytes
00:00:02.941208 BlkCache: Cache commit interval is 10000 ms
00:00:02.941224 BlkCache: Cache commit threshold is 2621440 bytes
00:00:03.315495 SUP: Loaded VBoxDDR0.r0 (C:\Program Files\Oracle\VirtualBox\VBoxDDR0.r0) at 0xXXXXXXXXXXXXXXXX - ModuleInit at XXXXXXXXXXXXXXXX and ModuleTerm at XXXXXXXXXXXXXXXX using the native ring-0 loader
00:00:03.315539 SUP: windbg> .reload /f C:\Program Files\Oracle\VirtualBox\VBoxDDR0.r0=0xXXXXXXXXXXXXXXXX
00:00:03.447747 SMC: Successfully retrieved the SMC key from hardware
00:00:03.447964 EFI: boot args =
00:00:03.447981 EFI: device props =
00:00:03.451313 Found EFI FW Volume, 131072 bytes (32 4096-byte blocks)
00:00:03.463157 DMI: Using DmiSystemProduct from host: Inspiron 5765
00:00:03.470765 DMI: Using DmiSystemVersion from host: 1.1.1
00:00:03.474410 CPUM: SetGuestCpuIdFeature: Enabled xAPIC
00:00:03.475262 IOAPIC: Using implementation 2.0!
00:00:03.475495 PIT: mode=3 count=0x10000 (65536) - 18.20 Hz (ch=0)
00:00:03.495886 Shared Folders service loaded
00:00:03.595922 VGA: Using the 386+ BIOS image.
00:00:03.597746 DrvVD: Flushes will be ignored
00:00:03.597796 DrvVD: Async flushes will be passed to the disk
00:00:03.602744 VD: VDInit finished with VINF_SUCCESS
00:00:03.623949 AIOMgr: Endpoint for file 'C:\Users\blust\OneDrive\Desktop\macOS Sierra 10.12 Files-001\macOS Sierra 10.12 Files\macOS Sierra 10.12 by wikigain.vmdk' (flags 000c0723) created successfully
00:00:03.758304 AIOMgr: Async flushes not supported
00:00:03.758398 VD: Opening the disk took 156570377 ns
00:00:03.758598 AHCI: LUN#0: disk, PCHS=16383/16/63, total number of sectors 209715200
00:00:03.759129 DrvVD: Flushes will be ignored
00:00:03.759155 DrvVD: Async flushes will be passed to the disk
00:00:03.763766 SCSI#0: Enabled UNMAP support
00:00:03.763856 AHCI: LUN#1: CD/DVD
00:00:03.764379 AHCI#0: Reset the HBA
00:00:03.764416 VD#0: Cancelling all active requests
00:00:03.764507 E1000#0 Chip=82545EM LinkUpDelay=3000ms EthernetCRC=on GSO=enabled Itr=disabled ItrRx=enabled TID=disabled R0=enabled GC=enabled
00:00:03.796989 NAT: Guest address guess set to 10.0.2.15 by initialization
00:00:03.816562 NAT: DNS#0: 192.168.1.1
00:00:03.818772 HDA: Asynchronous I/O enabled
00:00:03.818848 Audio: Initializing DirectSound audio driver
00:00:03.986226 DSound: Output: GUID: {817C9931-E7A6-49B7-AEE9-2FAE19AF5888} [Speakers / Headphones (Realtek Audio)] (Module: {0.0.0.00000000}.{817c9931-e7a6-49b7-aee9-2fae19af5888})
00:00:04.160930 DSound: Input: GUID: {C0279A15-F296-4493-8716-97B73AC05E1E} [Microphone (Realtek Audio)] (Module: {0.0.1.00000000}.{c0279a15-f296-4493-8716-97b73ac05e1e})
00:00:04.162299 Audio: Initializing VRDE driver
00:00:04.162509 HDA: Codec reset
00:00:04.162540 HDA: Reset
00:00:04.162823 ACPI: enabling 64-bit prefetch root bus resource 0x0000000124000000..0x0000000fffffffff
00:00:04.163862 VUSB: Attached 'HidKeyboard' to port 1 on RootHub#0 (FullSpeed)
00:00:04.164737 VUSB: Attached 'HidMouse' to port 2 on RootHub#0 (FullSpeed)
00:00:04.165249 PGM: The CPU physical address width is 48 bits
00:00:04.165330 PGM: PGMR3InitFinalize: 4 MB PSE mask 0000ffffffffffff
00:00:04.165431 TM: TMR3InitFinalize: fTSCModeSwitchAllowed=true
00:00:04.169678 ACPI: enabling 64-bit prefetch root bus resource 0x0000000124000000..0x0000000fffffffff
00:00:04.187597 VMM: Thread-context hooks unavailable
00:00:04.189980 HM: fWorldSwitcher=0x0 (fIbpbOnVmExit=0 fIbpbOnVmEntry=0)
00:00:04.190022 HM: Using AMD-V implementation 2.0
00:00:04.190024 HM: Max resume loops = 1024
00:00:04.190025 HM: CPUID 0x80000001.u32AMDFeatureECX = 0x2fabbfff
00:00:04.190028 HM: CPUID 0x80000001.u32AMDFeatureEDX = 0x2fd3fbff
00:00:04.190029 HM: AMD HWCR MSR = 0x19001011
00:00:04.190030 HM: AMD-V revision = 0x1
00:00:04.190031 HM: AMD-V max ASID = 32768
00:00:04.190032 HM: AMD-V features = 0x1bcff
00:00:04.190033 HM: NESTED_PAGING
00:00:04.190034 HM: LBR_VIRT
00:00:04.190035 HM: SVM_LOCK
00:00:04.190035 HM: NRIP_SAVE
00:00:04.190036 HM: TSC_RATE_MSR
00:00:04.190036 HM: VMCB_CLEAN
00:00:04.190037 HM: FLUSH_BY_ASID
00:00:04.190038 HM: DECODE_ASSIST
00:00:04.190038 HM: PAUSE_FILTER
00:00:04.190039 HM: PAUSE_FILTER_THRESHOLD
00:00:04.190039 HM: AVIC
00:00:04.190040 HM: VIRT_VMSAVE_VMLOAD
00:00:04.190040 HM: VGIF
00:00:04.190041 HM: Reserved bit 11
00:00:04.190053 HM: Enabled SVM
00:00:04.190054 HM: Enabled nested paging
00:00:04.190055 HM: Enabled large page support
00:00:04.190061 CPUM: SetGuestCpuIdFeature: Enabled SYSENTER/EXIT
00:00:04.190062 CPUM: SetGuestCpuIdFeature: Enabled SYSCALL/RET
00:00:04.190063 CPUM: SetGuestCpuIdFeature: Enabled PAE
00:00:04.190064 CPUM: SetGuestCpuIdFeature: Enabled LONG MODE
00:00:04.190065 CPUM: SetGuestCpuIdFeature: Enabled NX
00:00:04.190065 CPUM: SetGuestCpuIdFeature: Enabled LAHF/SAHF
00:00:04.190066 HM: Disabled TPR patching
00:00:04.190066 HM: Guest support: 32-bit and 64-bit
00:00:04.190067 HM: VT-x/AMD-V init method: LOCAL
00:00:04.190069 VMM: fUsePeriodicPreemptionTimers=false
00:00:04.190192 CPUM: Logical host processors: 4 present, 4 max, 4 online, online mask: 000000000000000f
00:00:04.190194 CPUM: Physical host cores: 4
00:00:04.190195 ************************* CPUID dump ************************
00:00:04.190207 Raw Standard CPUID Leaves
00:00:04.190207 Leaf/sub-leaf eax ebx ecx edx
00:00:04.190211 Gst: 00000000/0000 0000000d 68747541 444d4163 69746e65
00:00:04.190213 Hst: 0000000d 68747541 444d4163 69746e65
00:00:04.190214 Gst: 00000001/0000 000106e5 00040800 80982201 178bfbff
00:00:04.190216 Hst: 00660f51 01040800 7ed8320b 178bfbff
00:00:04.190218 Gst: 00000002/0000 00000000 00000000 00000000 00000000
00:00:04.190219 Hst: 00000000 00000000 00000000 00000000
00:00:04.190220 Gst: 00000003/0000 00000000 00000000 00000000 00000000
00:00:04.190221 Hst: 00000000 00000000 00000000 00000000
00:00:04.190222 Gst: 00000004/0000 00000000 00000000 00000000 00000000
00:00:04.190223 Hst: 00000000 00000000 00000000 00000000
00:00:04.190224 Gst: 00000005/0000 00000000 00000000 00000003 00000000
00:00:04.190225 Hst: 00000040 00000040 00000003 00000000
00:00:04.190226 Gst: 00000006/0000 00000000 00000000 00000000 00000000
00:00:04.190227 Hst: 00000004 00000000 00000001 00000000
00:00:04.190228 Gst: 00000007/0000 00000000 00000021 00000000 00000000
00:00:04.190229 Hst: 00000000 000001a9 00000000 00000000
00:00:04.190257 Gst: 00000007/0001 00000000 00000000 00000000 00000000
00:00:04.190258 Hst: 00000000 00000000 00000000 00000000
00:00:04.190258 Gst: 00000008/0000 00000000 00000000 00000000 00000000
00:00:04.190259 Hst: 00000000 00000000 00000000 00000000
00:00:04.190260 Gst: 00000009/0000 00000000 00000000 00000000 00000000
00:00:04.190260 Hst: 00000000 00000000 00000000 00000000
00:00:04.190261 Gst: 0000000a/0000 00000000 00000000 00000000 00000000
00:00:04.190262 Hst: 00000000 00000000 00000000 00000000
00:00:04.190263 Gst: 0000000b/0000 00000000 00000000 00000000 00000000
00:00:04.190264 Hst: 00000000 00000000 00000000 00000000
00:00:04.190264 Gst: 0000000c/0000 00000000 00000000 00000000 00000000
00:00:04.190265 Hst: 00000000 00000000 00000000 00000000
00:00:04.190266 Gst: 0000000d/0000 00000000 00000000 00000000 00000000
00:00:04.190266 Hst: 00000007 00000340 000003c0 40000000
00:00:04.190267 Gst: 0000000d/0001 00000000 00000000 00000000 00000000
00:00:04.190268 Hst: 00000001 00000000 00000000 00000000
00:00:04.190269 Gst: 0000000d/0002 00000000 00000000 00000000 00000000
00:00:04.190269 Hst: 00000100 00000240 00000000 00000000
00:00:04.190270 Gst: 0000000d/0003 00000000 00000000 00000000 00000000
00:00:04.190271 Hst: 00000000 00000000 00000000 00000000
00:00:04.190271 Gst: 0000000d/0004 00000000 00000000 00000000 00000000
00:00:04.190272 Hst: 00000000 00000000 00000000 00000000
00:00:04.190273 Gst: 0000000d/0005 00000000 00000000 00000000 00000000
00:00:04.190273 Hst: 00000000 00000000 00000000 00000000
00:00:04.190274 Gst: 0000000d/0006 00000000 00000000 00000000 00000000
00:00:04.190275 Hst: 00000000 00000000 00000000 00000000
00:00:04.190276 Gst: 0000000d/0007 00000000 00000000 00000000 00000000
00:00:04.190276 Hst: 00000000 00000000 00000000 00000000
00:00:04.190277 Gst: 0000000d/0008 00000000 00000000 00000000 00000000
00:00:04.190278 Hst: 00000000 00000000 00000000 00000000
00:00:04.190278 Gst: 0000000d/0009 00000000 00000000 00000000 00000000
00:00:04.190279 Hst: 00000000 00000000 00000000 00000000
00:00:04.190280 Gst: 0000000d/000a 00000000 00000000 00000000 00000000
00:00:04.190280 Hst: 00000000 00000000 00000000 00000000
00:00:04.190281 Gst: 0000000d/000b 00000000 00000000 00000000 00000000
00:00:04.190282 Hst: 00000000 00000000 00000000 00000000
00:00:04.190282 Gst: 0000000d/000c 00000000 00000000 00000000 00000000
00:00:04.190283 Hst: 00000000 00000000 00000000 00000000
00:00:04.190284 Gst: 0000000d/000d 00000000 00000000 00000000 00000000
00:00:04.190284 Hst: 00000000 00000000 00000000 00000000
00:00:04.190285 Gst: 0000000d/000e 00000000 00000000 00000000 00000000
00:00:04.190286 Hst: 00000000 00000000 00000000 00000000
00:00:04.190286 Gst: 0000000d/000f 00000000 00000000 00000000 00000000
00:00:04.190287 Hst: 00000000 00000000 00000000 00000000
00:00:04.190288 Gst: 0000000d/0010 00000000 00000000 00000000 00000000
00:00:04.190289 Hst: 00000000 00000000 00000000 00000000
00:00:04.190289 Gst: 0000000d/0011 00000000 00000000 00000000 00000000
00:00:04.190290 Hst: 00000000 00000000 00000000 00000000
00:00:04.190291 Gst: 0000000d/0012 00000000 00000000 00000000 00000000
00:00:04.190291 Hst: 00000000 00000000 00000000 00000000
00:00:04.190292 Gst: 0000000d/0013 00000000 00000000 00000000 00000000
00:00:04.190293 Hst: 00000000 00000000 00000000 00000000
00:00:04.190293 Gst: 0000000d/0014 00000000 00000000 00000000 00000000
00:00:04.190294 Hst: 00000000 00000000 00000000 00000000
00:00:04.190295 Gst: 0000000d/0015 00000000 00000000 00000000 00000000
00:00:04.190295 Hst: 00000000 00000000 00000000 00000000
00:00:04.190296 Gst: 0000000d/0016 00000000 00000000 00000000 00000000
00:00:04.190297 Hst: 00000000 00000000 00000000 00000000
00:00:04.190297 Gst: 0000000d/0017 00000000 00000000 00000000 00000000
00:00:04.190298 Hst: 00000000 00000000 00000000 00000000
00:00:04.190299 Gst: 0000000d/0018 00000000 00000000 00000000 00000000
00:00:04.190299 Hst: 00000000 00000000 00000000 00000000
00:00:04.190300 Gst: 0000000d/0019 00000000 00000000 00000000 00000000
00:00:04.190301 Hst: 00000000 00000000 00000000 00000000
00:00:04.190301 Gst: 0000000d/001a 00000000 00000000 00000000 00000000
00:00:04.190302 Hst: 00000000 00000000 00000000 00000000
00:00:04.190303 Gst: 0000000d/001b 00000000 00000000 00000000 00000000
00:00:04.190303 Hst: 00000000 00000000 00000000 00000000
00:00:04.190304 Gst: 0000000d/001c 00000000 00000000 00000000 00000000
00:00:04.190305 Hst: 00000000 00000000 00000000 00000000
00:00:04.190306 Gst: 0000000d/001d 00000000 00000000 00000000 00000000
00:00:04.190306 Hst: 00000000 00000000 00000000 00000000
00:00:04.190307 Gst: 0000000d/001e 00000000 00000000 00000000 00000000
00:00:04.190308 Hst: 00000000 00000000 00000000 00000000
00:00:04.190308 Gst: 0000000d/001f 00000000 00000000 00000000 00000000
00:00:04.190309 Hst: 00000000 00000000 00000000 00000000
00:00:04.190310 Gst: 0000000d/0020 00000000 00000000 00000000 00000000
00:00:04.190310 Hst: 00000000 00000000 00000000 00000000
00:00:04.190311 Gst: 0000000d/0021 00000000 00000000 00000000 00000000
00:00:04.190312 Hst: 00000000 00000000 00000000 00000000
00:00:04.190312 Gst: 0000000d/0022 00000000 00000000 00000000 00000000
00:00:04.190313 Hst: 00000000 00000000 00000000 00000000
00:00:04.190314 Gst: 0000000d/0023 00000000 00000000 00000000 00000000
00:00:04.190314 Hst: 00000000 00000000 00000000 00000000
00:00:04.190315 Gst: 0000000d/0024 00000000 00000000 00000000 00000000
00:00:04.190316 Hst: 00000000 00000000 00000000 00000000
00:00:04.190317 Gst: 0000000d/0025 00000000 00000000 00000000 00000000
00:00:04.190317 Hst: 00000000 00000000 00000000 00000000
00:00:04.190318 Gst: 0000000d/0026 00000000 00000000 00000000 00000000
00:00:04.190319 Hst: 00000000 00000000 00000000 00000000
00:00:04.190348 Gst: 0000000d/0027 00000000 00000000 00000000 00000000
00:00:04.190349 Hst: 00000000 00000000 00000000 00000000
00:00:04.190350 Gst: 0000000d/0028 00000000 00000000 00000000 00000000
00:00:04.190351 Hst: 00000000 00000000 00000000 00000000
00:00:04.190352 Gst: 0000000d/0029 00000000 00000000 00000000 00000000
00:00:04.190353 Hst: 00000000 00000000 00000000 00000000
00:00:04.190354 Gst: 0000000d/002a 00000000 00000000 00000000 00000000
00:00:04.190354 Hst: 00000000 00000000 00000000 00000000
00:00:04.190355 Gst: 0000000d/002b 00000000 00000000 00000000 00000000
00:00:04.190356 Hst: 00000000 00000000 00000000 00000000
00:00:04.190357 Gst: 0000000d/002c 00000000 00000000 00000000 00000000
00:00:04.190358 Hst: 00000000 00000000 00000000 00000000
00:00:04.190359 Gst: 0000000d/002d 00000000 00000000 00000000 00000000
00:00:04.190360 Hst: 00000000 00000000 00000000 00000000
00:00:04.190361 Gst: 0000000d/002e 00000000 00000000 00000000 00000000
00:00:04.190361 Hst: 00000000 00000000 00000000 00000000
00:00:04.190362 Gst: 0000000d/002f 00000000 00000000 00000000 00000000
00:00:04.190363 Hst: 00000000 00000000 00000000 00000000
00:00:04.190364 Gst: 0000000d/0030 00000000 00000000 00000000 00000000
00:00:04.190365 Hst: 00000000 00000000 00000000 00000000
00:00:04.190366 Gst: 0000000d/0031 00000000 00000000 00000000 00000000
00:00:04.190367 Hst: 00000000 00000000 00000000 00000000
00:00:04.190368 Gst: 0000000d/0032 00000000 00000000 00000000 00000000
00:00:04.190368 Hst: 00000000 00000000 00000000 00000000
00:00:04.190380 Gst: 0000000d/0033 00000000 00000000 00000000 00000000
00:00:04.190381 Hst: 00000000 00000000 00000000 00000000
00:00:04.190382 Gst: 0000000d/0034 00000000 00000000 00000000 00000000
00:00:04.190383 Hst: 00000000 00000000 00000000 00000000
00:00:04.190384 Gst: 0000000d/0035 00000000 00000000 00000000 00000000
00:00:04.190385 Hst: 00000000 00000000 00000000 00000000
00:00:04.190386 Gst: 0000000d/0036 00000000 00000000 00000000 00000000
00:00:04.190387 Hst: 00000000 00000000 00000000 00000000
00:00:04.190388 Gst: 0000000d/0037 00000000 00000000 00000000 00000000
00:00:04.190389 Hst: 00000000 00000000 00000000 00000000
00:00:04.190390 Gst: 0000000d/0038 00000000 00000000 00000000 00000000
00:00:04.190390 Hst: 00000000 00000000 00000000 00000000
00:00:04.190391 Gst: 0000000d/0039 00000000 00000000 00000000 00000000
00:00:04.190392 Hst: 00000000 00000000 00000000 00000000
00:00:04.190393 Gst: 0000000d/003a 00000000 00000000 00000000 00000000
00:00:04.190394 Hst: 00000000 00000000 00000000 00000000
00:00:04.190395 Gst: 0000000d/003b 00000000 00000000 00000000 00000000
00:00:04.190396 Hst: 00000000 00000000 00000000 00000000
00:00:04.190397 Gst: 0000000d/003c 00000000 00000000 00000000 00000000
00:00:04.190398 Hst: 00000000 00000000 00000000 00000000
00:00:04.190399 Gst: 0000000d/003d 00000000 00000000 00000000 00000000
00:00:04.190400 Hst: 00000000 00000000 00000000 00000000
00:00:04.190401 Gst: 0000000d/003e 00000000 00000000 00000000 00000000
00:00:04.190402 Hst: 00000080 00000340 00000000 00000000
00:00:04.190403 Gst: 0000000d/003f 00000000 00000000 00000000 00000000
00:00:04.190404 Hst: 00000000 00000000 00000000 00000000
00:00:04.190405 Gst: 0000000d/0040 00000000 00000000 00000000 00000000
00:00:04.190406 Hst: 00000000 00000000 00000000 00000000
00:00:04.190422 Name: AuthenticAMD
00:00:04.190423 Supports: 0x00000000-0x0000000d
00:00:04.190428 Family: 6 Extended: 0 Effective: 6
00:00:04.190430 Model: 14 Extended: 1 Effective: 14
00:00:04.190432 Stepping: 5
00:00:04.190433 Type: 0 (primary)
00:00:04.190434 APIC ID: 0x00
00:00:04.190435 Logical CPUs: 4
00:00:04.190436 CLFLUSH Size: 8
00:00:04.190437 Brand ID: 0x00
00:00:04.190439 Features
00:00:04.190439 Mnemonic - Description = guest (host)
00:00:04.190443 FPU - x87 FPU on Chip = 1 (1)
00:00:04.190448 VME - Virtual 8086 Mode Enhancements = 1 (1)
00:00:04.190450 DE - Debugging extensions = 1 (1)
00:00:04.190452 PSE - Page Size Extension = 1 (1)
00:00:04.190453 TSC - Time Stamp Counter = 1 (1)
00:00:04.190455 MSR - Model Specific Registers = 1 (1)
00:00:04.190456 PAE - Physical Address Extension = 1 (1)
00:00:04.190458 MCE - Machine Check Exception = 1 (1)
00:00:04.190459 CX8 - CMPXCHG8B instruction = 1 (1)
00:00:04.190461 APIC - APIC On-Chip = 1 (1)
00:00:04.190462 SEP - SYSENTER and SYSEXIT Present = 1 (1)
00:00:04.190463 MTRR - Memory Type Range Registers = 1 (1)
00:00:04.190465 PGE - PTE Global Bit = 1 (1)
00:00:04.190466 MCA - Machine Check Architecture = 1 (1)
00:00:04.190468 CMOV - Conditional Move instructions = 1 (1)
00:00:04.190469 PAT - Page Attribute Table = 1 (1)
00:00:04.190476 PSE-36 - 36-bit Page Size Extension = 1 (1)
00:00:04.190477 PSN - Processor Serial Number = 0 (0)
00:00:04.190478 CLFSH - CLFLUSH instruction = 1 (1)
00:00:04.190480 DS - Debug Store = 0 (0)
00:00:04.190481 ACPI - Thermal Mon. & Soft. Clock Ctrl. = 0 (0)
00:00:04.190483 MMX - Intel MMX Technology = 1 (1)
00:00:04.190484 FXSR - FXSAVE and FXRSTOR instructions = 1 (1)
00:00:04.190485 SSE - SSE support = 1 (1)
00:00:04.190487 SSE2 - SSE2 support = 1 (1)
00:00:04.190491 SS - Self Snoop = 0 (0)
00:00:04.190493 HTT - Hyper-Threading Technology = 1 (1)
00:00:04.190494 TM - Therm. Monitor = 0 (0)
00:00:04.190496 PBE - Pending Break Enabled = 0 (0)
00:00:04.190497 SSE3 - SSE3 support = 1 (1)
00:00:04.190498 PCLMUL - PCLMULQDQ support (for AES-GCM) = 0 (1)
00:00:04.190500 DTES64 - DS Area 64-bit Layout = 0 (0)
00:00:04.190501 MONITOR - MONITOR/MWAIT instructions = 0 (1)
00:00:04.190502 CPL-DS - CPL Qualified Debug Store = 0 (0)
00:00:04.190503 VMX - Virtual Machine Extensions = 0 (0)
00:00:04.190505 SMX - Safer Mode Extensions = 0 (0)
00:00:04.190506 EST - Enhanced SpeedStep Technology = 0 (0)
00:00:04.190507 TM2 - Terminal Monitor 2 = 0 (0)
00:00:04.190508 SSSE3 - Supplemental Streaming SIMD Extensions 3 = 1 (1)
00:00:04.190509 CNTX-ID - L1 Context ID = 0 (0)
00:00:04.190511 SDBG - Silicon Debug interface = 0 (0)
00:00:04.190512 FMA - Fused Multiply Add extensions = 0 (1)
00:00:04.190513 CX16 - CMPXCHG16B instruction = 1 (1)
00:00:04.190515 TPRUPDATE - xTPR Update Control = 0 (0)
00:00:04.190516 PDCM - Perf/Debug Capability MSR = 0 (0)
00:00:04.190545 PCID - Process Context Identifiers = 0 (0)
00:00:04.190546 DCA - Direct Cache Access = 0 (0)
00:00:04.190547 SSE4_1 - SSE4_1 support = 1 (1)
00:00:04.190548 SSE4_2 - SSE4_2 support = 1 (1)
00:00:04.190549 X2APIC - x2APIC support = 0 (0)
00:00:04.190550 MOVBE - MOVBE instruction = 0 (1)
00:00:04.190551 POPCNT - POPCNT instruction = 1 (1)
00:00:04.190552 TSCDEADL - Time Stamp Counter Deadline = 0 (0)
00:00:04.190553 AES - AES instructions = 0 (1)
00:00:04.190554 XSAVE - XSAVE instruction = 0 (1)
00:00:04.190555 OSXSAVE - OSXSAVE instruction = 0 (1)
00:00:04.190556 AVX - AVX support = 0 (1)
00:00:04.190557 F16C - 16-bit floating point conversion instructions = 0 (1)
00:00:04.190558 RDRAND - RDRAND instruction = 0 (1)
00:00:04.190559 HVP - Hypervisor Present (we're a guest) = 1 (0)
00:00:04.190560 Structured Extended Feature Flags Enumeration (leaf 7):
00:00:04.190561 Mnemonic - Description = guest (host)
00:00:04.190561 FSGSBASE - RDFSBASE/RDGSBASE/WRFSBASE/WRGSBASE instr. = 1 (1)
00:00:04.190562 TSCADJUST - Supports MSR_IA32_TSC_ADJUST = 0 (0)
00:00:04.190563 SGX - Supports Software Guard Extensions = 0 (0)
00:00:04.190564 BMI1 - Advanced Bit Manipulation extension 1 = 0 (1)
00:00:04.190565 HLE - Hardware Lock Elision = 0 (0)
00:00:04.190566 AVX2 - Advanced Vector Extensions 2 = 1 (1)
00:00:04.190567 FDP_EXCPTN_ONLY - FPU DP only updated on exceptions = 0 (0)
00:00:04.190567 SMEP - Supervisor Mode Execution Prevention = 0 (1)
00:00:04.190568 BMI2 - Advanced Bit Manipulation extension 2 = 0 (1)
00:00:04.190569 ERMS - Enhanced REP MOVSB/STOSB instructions = 0 (0)
00:00:04.190570 INVPCID - INVPCID instruction = 0 (0)
00:00:04.190571 RTM - Restricted Transactional Memory = 0 (0)
00:00:04.190572 PQM - Platform Quality of Service Monitoring = 0 (0)
00:00:04.190601 DEPFPU_CS_DS - Deprecates FPU CS, FPU DS values if set = 0 (0)
00:00:04.190602 MPE - Intel Memory Protection Extensions = 0 (0)
00:00:04.190603 PQE - Platform Quality of Service Enforcement = 0 (0)
00:00:04.190604 AVX512F - AVX512 Foundation instructions = 0 (0)
00:00:04.190605 RDSEED - RDSEED instruction = 0 (0)
00:00:04.190607 ADX - ADCX/ADOX instructions = 0 (0)
00:00:04.190608 SMAP - Supervisor Mode Access Prevention = 0 (0)
00:00:04.190609 CLFLUSHOPT - CLFLUSHOPT (Cache Line Flush) instruction = 0 (0)
00:00:04.190610 INTEL_PT - Intel Processor Trace = 0 (0)
00:00:04.190612 AVX512PF - AVX512 Prefetch instructions = 0 (0)
00:00:04.190613 AVX512ER - AVX512 Exponential & Reciprocal instructions = 0 (0)
00:00:04.190614 AVX512CD - AVX512 Conflict Detection instructions = 0 (0)
00:00:04.190615 SHA - Secure Hash Algorithm extensions = 0 (0)
00:00:04.190616 PREFETCHWT1 - PREFETCHWT1 instruction = 0 (0)
00:00:04.190617 UMIP - User mode insturction prevention = 0 (0)
00:00:04.190618 PKU - Protection Key for Usermode pages = 0 (0)
00:00:04.190620 OSPKE - CR4.PKU mirror = 0 (0)
00:00:04.190621 MAWAU - Value used by BNDLDX & BNDSTX = 0x0 (0x0)
00:00:04.190633 RDPID - Read processor ID support = 0 (0)
00:00:04.190634 SGX_LC - Supports SGX Launch Configuration = 0 (0)
00:00:04.190636 Processor Extended State Enumeration (leaf 0xd):
00:00:04.190636 XSAVE area cur/max size by XCR0, guest: 0x0/0x0
00:00:04.190637 XSAVE area cur/max size by XCR0, host: 0x340/0x3c0
00:00:04.190638 Valid XCR0 bits, guest: 0x00000000`00000000
00:00:04.190640 Valid XCR0 bits, host: 0x40000000`00000007 ( x87 SSE YMM_Hi128 LWP )
00:00:04.190646 XSAVE features, guest:
00:00:04.190648 XSAVE features, host: XSAVEOPT
00:00:04.190649 XSAVE area cur size XCR0|XSS, guest: 0x0
00:00:04.190650 XSAVE area cur size XCR0|XSS, host: 0x0
00:00:04.190651 Valid IA32_XSS bits, guest: 0x00000000`00000000
00:00:04.190652 Valid IA32_XSS bits, host: 0x00000000`00000000
00:00:04.190653 State #2, host: off=0x0240, cb=0x0100 IA32_XSS-bit -- YMM_Hi128
00:00:04.190660 State #62, host: off=0x0340, cb=0x0080 IA32_XSS-bit -- LWP
00:00:04.190673 Raw Hypervisor CPUID Leaves
00:00:04.190673 Leaf/sub-leaf eax ebx ecx edx
00:00:04.190674 Gst: 40000000/0000 40000010 00000000 00000000 00000000
00:00:04.190675 Hst: 00000000 00000000 00000000 00000000
00:00:04.190677 Gst: 40000001/0000 00000000 00000000 00000000 00000000
00:00:04.190678 Hst: 00000000 00000000 00000000 00000000
00:00:04.190679 Gst: 40000002/0000 00000000 00000000 00000000 00000000
00:00:04.190680 Hst: 00000000 00000000 00000000 00000000
00:00:04.190681 Gst: 40000003/0000 00000000 00000000 00000000 00000000
00:00:04.190682 Hst: 00000000 00000000 00000000 00000000
00:00:04.190683 Gst: 40000004/0000 00000000 00000000 00000000 00000000
00:00:04.190684 Hst: 00000000 00000000 00000000 00000000
00:00:04.190685 Gst: 40000005/0000 00000000 00000000 00000000 00000000
00:00:04.190687 Hst: 00000000 00000000 00000000 00000000
00:00:04.190688 Gst: 40000006/0000 00000000 00000000 00000000 00000000
00:00:04.190689 Hst: 00000000 00000000 00000000 00000000
00:00:04.190690 Gst: 40000007/0000 00000000 00000000 00000000 00000000
00:00:04.190691 Hst: 00000000 00000000 00000000 00000000
00:00:04.190692 Gst: 40000008/0000 00000000 00000000 00000000 00000000
00:00:04.190693 Hst: 00000000 00000000 00000000 00000000
00:00:04.190694 Gst: 40000009/0000 00000000 00000000 00000000 00000000
00:00:04.190695 Hst: 00000000 00000000 00000000 00000000
00:00:04.190696 Gst: 4000000a/0000 00000000 00000000 00000000 00000000
00:00:04.190697 Hst: 00000000 00000000 00000000 00000000
00:00:04.190698 Gst: 4000000b/0000 00000000 00000000 00000000 00000000
00:00:04.190699 Hst: 00000000 00000000 00000000 00000000
00:00:04.190700 Gst: 4000000c/0000 00000000 00000000 00000000 00000000
00:00:04.190701 Hst: 00000000 00000000 00000000 00000000
00:00:04.190702 Gst: 4000000d/0000 00000000 00000000 00000000 00000000
00:00:04.190703 Hst: 00000000 00000000 00000000 00000000
00:00:04.190705 Gst: 4000000e/0000 00000000 00000000 00000000 00000000
00:00:04.190706 Hst: 00000000 00000000 00000000 00000000
00:00:04.190707 Gst: 4000000f/0000 00000000 00000000 00000000 00000000
00:00:04.190708 Hst: 00000000 00000000 00000000 00000000
00:00:04.190709 Gst: 40000010/0000 00291f17 000f4240 00000000 00000000
00:00:04.190710 Hst: 00000000 00000000 00000000 00000000
00:00:04.190712 Raw Extended CPUID Leaves
00:00:04.190712 Leaf/sub-leaf eax ebx ecx edx
00:00:04.190713 Gst: 80000000/0000 8000001e 68747541 444d4163 69746e65
00:00:04.190715 Hst: 8000001e 68747541 444d4163 69746e65
00:00:04.190717 Gst: 80000001/0000 00660f51 00000000 000001f3 2bd3fb7f
00:00:04.190718 Hst: 00660f51 00000000 2fabbfff 2fd3fbff
00:00:04.190726 Gst: 80000002/0000 20444d41 392d5846 50303038 44415220
00:00:04.190728 Hst: 20444d41 392d5846 50303038 44415220
00:00:04.190729 Gst: 80000003/0000 204e4f45 202c3752 43203231 55504d4f
00:00:04.190731 Hst: 204e4f45 202c3752 43203231 55504d4f
00:00:04.190733 Gst: 80000004/0000 43204554 5345524f 2b433420 00204738
00:00:04.190734 Hst: 43204554 5345524f 2b433420 00204738
00:00:04.190736 Gst: 80000005/0000 ff40ff18 ff40ff30 20080140 60030140
00:00:04.190737 Hst: ff40ff18 ff40ff30 20080140 60030140
00:00:04.190739 Gst: 80000006/0000 64006400 64004200 04008140 00000000
00:00:04.190740 Hst: 64006400 64004200 04008140 00000000
00:00:04.190742 Gst: 80000007/0000 00000000 00000000 00000000 00000000
00:00:04.190743 Hst: 00000000 00000005 00000400 000037d9
00:00:04.190744 Gst: 80000008/0000 00003030 00000000 00000003 00000000
00:00:04.190745 Hst: 00003030 00000000 00004003 00000000
00:00:04.190746 Gst: 80000009/0000 00000000 00000000 00000000 00000000
00:00:04.190748 Hst: 00000000 00000000 00000000 00000000
00:00:04.190749 Gst: 8000000a/0000 00000000 00000000 00000000 00000000
00:00:04.190750 Hst: 00000001 00008000 00000000 0001bcff
00:00:04.190751 Gst: 8000000b/0000 00000000 00000000 00000000 00000000
00:00:04.190752 Hst: 00000000 00000000 00000000 00000000
00:00:04.190753 Gst: 8000000c/0000 00000000 00000000 00000000 00000000
00:00:04.190754 Hst: 00000000 00000000 00000000 00000000
00:00:04.190755 Gst: 8000000d/0000 00000000 00000000 00000000 00000000
00:00:04.190756 Hst: 00000000 00000000 00000000 00000000
00:00:04.190757 Gst: 8000000e/0000 00000000 00000000 00000000 00000000
00:00:04.190758 Hst: 00000000 00000000 00000000 00000000
00:00:04.190759 Gst: 8000000f/0000 00000000 00000000 00000000 00000000
00:00:04.190760 Hst: 00000000 00000000 00000000 00000000
00:00:04.190761 Gst: 80000010/0000 00000000 00000000 00000000 00000000
00:00:04.190762 Hst: 00000000 00000000 00000000 00000000
00:00:04.190763 Gst: 80000011/0000 00000000 00000000 00000000 00000000
00:00:04.190764 Hst: 00000000 00000000 00000000 00000000
00:00:04.190765 Gst: 80000012/0000 00000000 00000000 00000000 00000000
00:00:04.190766 Hst: 00000000 00000000 00000000 00000000
00:00:04.190767 Gst: 80000013/0000 00000000 00000000 00000000 00000000
00:00:04.190818 Hst: 00000000 00000000 00000000 00000000
00:00:04.190819 Gst: 80000014/0000 00000000 00000000 00000000 00000000
00:00:04.190820 Hst: 00000000 00000000 00000000 00000000
00:00:04.190820 Gst: 80000015/0000 00000000 00000000 00000000 00000000
00:00:04.190821 Hst: 00000000 00000000 00000000 00000000
00:00:04.190822 Gst: 80000016/0000 00000000 00000000 00000000 00000000
00:00:04.190823 Hst: 00000000 00000000 00000000 00000000
00:00:04.190823 Gst: 80000017/0000 00000000 00000000 00000000 00000000
00:00:04.190824 Hst: 00000000 00000000 00000000 00000000
00:00:04.190825 Gst: 80000018/0000 00000000 00000000 00000000 00000000
00:00:04.190826 Hst: 00000000 00000000 00000000 00000000
00:00:04.190826 Gst: 80000019/0000 f040f018 64006400 00000000 00000000
00:00:04.190827 Hst: f040f018 64006400 00000000 00000000
00:00:04.190828 Gst: 8000001a/0000 00000003 00000000 00000000 00000000
00:00:04.190829 Hst: 00000003 00000000 00000000 00000000
00:00:04.190830 Gst: 8000001b/0000 00000000 00000000 00000000 00000000
00:00:04.190831 Hst: 000007ff 00000000 00000000 00000000
00:00:04.190831 Gst: 8000001c/0000 00000000 00000000 00000000 00000000
00:00:04.190832 Hst: 00000000 80032013 00010200 e000000f
00:00:04.190833 Gst: 8000001d/0000 00000121 01c0003f 0000003f 00000000
00:00:04.190834 Hst: 00000121 01c0003f 0000003f 00000000
00:00:04.190835 Gst: 8000001d/0001 00004122 0080003f 000001ff 00000000
00:00:04.190836 Hst: 00004122 0080003f 000001ff 00000000
00:00:04.190837 Gst: 8000001d/0002 00004143 03c0003f 000003ff 00000001
00:00:04.190838 Hst: 00004143 03c0003f 000003ff 00000001
00:00:04.190839 Gst: 8000001d/0003 00000000 00000000 00000000 00000000
00:00:04.190840 Hst: 00000000 00000000 00000000 00000000
00:00:04.190841 Gst: 8000001e/0000 00000000 00000300 00000000 00000000
00:00:04.190842 Hst: 00000011 00000100 00000000 00000000
00:00:04.190843 Ext Name: AuthenticAMD
00:00:04.190844 Ext Supports: 0x80000000-0x8000001e
00:00:04.190844 Family: 15 Extended: 6 Effective: 21
00:00:04.190845 Model: 5 Extended: 6 Effective: 101
00:00:04.190846 Stepping: 1
00:00:04.190846 Brand ID: 0x000
00:00:04.190847 Ext Features
00:00:04.190848 Mnemonic - Description = guest (host)
00:00:04.190848 FPU - x87 FPU on Chip = 1 (1)
00:00:04.190849 VME - Virtual 8086 Mode Enhancements = 1 (1)
00:00:04.190850 DE - Debugging extensions = 1 (1)
00:00:04.190852 PSE - Page Size Extension = 1 (1)
00:00:04.190853 TSC - Time Stamp Counter = 1 (1)
00:00:04.190854 MSR - K86 Model Specific Registers = 1 (1)
00:00:04.190855 PAE - Physical Address Extension = 1 (1)
00:00:04.190856 MCE - Machine Check Exception = 0 (1)
00:00:04.190857 CX8 - CMPXCHG8B instruction = 1 (1)
00:00:04.190858 APIC - APIC On-Chip = 1 (1)
00:00:04.190859 SEP - SYSCALL/SYSRET = 1 (1)
00:00:04.190861 MTRR - Memory Type Range Registers = 1 (1)
00:00:04.190862 PGE - PTE Global Bit = 1 (1)
00:00:04.190863 MCA - Machine Check Architecture = 1 (1)
00:00:04.190864 CMOV - Conditional Move instructions = 1 (1)
00:00:04.190865 PAT - Page Attribute Table = 1 (1)
00:00:04.190866 PSE-36 - 36-bit Page Size Extension = 1 (1)
00:00:04.190867 NX - No-Execute/Execute-Disable = 1 (1)
00:00:04.190868 AXMMX - AMD Extensions to MMX instructions = 1 (1)
00:00:04.190869 MMX - Intel MMX Technology = 1 (1)
00:00:04.190870 FXSR - FXSAVE and FXRSTOR Instructions = 1 (1)
00:00:04.190871 FFXSR - AMD fast FXSAVE and FXRSTOR instructions = 1 (1)
00:00:04.190872 Page1GB - 1 GB large page = 0 (1)
00:00:04.190873 RDTSCP - RDTSCP instruction = 1 (1)
00:00:04.190874 LM - AMD64 Long Mode = 1 (1)
00:00:04.190875 3DNOWEXT - AMD Extensions to 3DNow = 0 (0)
00:00:04.190877 3DNOW - AMD 3DNow = 0 (0)
00:00:04.190878 LahfSahf - LAHF/SAHF support in 64-bit mode = 1 (1)
00:00:04.190879 CmpLegacy - Core multi-processing legacy mode = 1 (1)
00:00:04.190880 SVM - AMD Secure Virtual Machine extensions = 0 (1)
00:00:04.190881 EXTAPIC - AMD Extended APIC registers = 0 (1)
00:00:04.190882 CR8L - AMD LOCK MOV CR0 means MOV CR8 = 1 (1)
00:00:04.190883 ABM - AMD Advanced Bit Manipulation = 1 (1)
00:00:04.190884 SSE4A - SSE4A instructions = 1 (1)
00:00:04.190885 MISALIGNSSE - AMD Misaligned SSE mode = 1 (1)
00:00:04.190886 3DNOWPRF - AMD PREFETCH and PREFETCHW instructions = 1 (1)
00:00:04.190887 OSVW - AMD OS Visible Workaround = 0 (1)
00:00:04.190888 IBS - Instruct Based Sampling = 0 (1)
00:00:04.190889 XOP - Extended Operation support = 0 (1)
00:00:04.190890 SKINIT - SKINIT, STGI, and DEV support = 0 (1)
00:00:04.190891 WDT - AMD Watchdog Timer support = 0 (1)
00:00:04.190892 LWP - Lightweight Profiling support = 0 (1)
00:00:04.190893 FMA4 - Four operand FMA instruction support = 0 (1)
00:00:04.190894 17 - Reserved = 0 (1)
00:00:04.190895 NodeId - NodeId in MSR C001_100C = 0 (1)
00:00:04.190896 TBM - Trailing Bit Manipulation instructions = 0 (1)
00:00:04.190897 TOPOEXT - Topology Extensions = 0 (0)
00:00:04.190898 23 - Reserved = 0 (1)
00:00:04.190899 24 - Reserved = 0 (1)
00:00:04.190900 25 - Reserved = 0 (1)
00:00:04.190902 26 - Reserved = 0 (1)
00:00:04.190903 27 - Reserved = 0 (1)
00:00:04.190904 29 - Reserved = 0 (1)
00:00:04.190905 Full Name: "AMD FX-9800P RADEON R7, 12 COMPUTE CORES 4C+8G "
00:00:04.190906 TLB 2/4M Instr/Uni: fully 24 entries
00:00:04.190907 TLB 2/4M Data: fully 64 entries
00:00:04.190908 TLB 4K Instr/Uni: fully 48 entries
00:00:04.190908 TLB 4K Data: fully 64 entries
00:00:04.190910 L1 Instr Cache Line Size: 64 bytes
00:00:04.190910 L1 Instr Cache Lines Per Tag: 1
00:00:04.190911 L1 Instr Cache Associativity: 3 way
00:00:04.190911 L1 Instr Cache Size: 96 KB
00:00:04.190912 L1 Data Cache Line Size: 64 bytes
00:00:04.190912 L1 Data Cache Lines Per Tag: 1
00:00:04.190913 L1 Data Cache Associativity: 8 way
00:00:04.190913 L1 Data Cache Size: 32 KB
00:00:04.190914 L2 TLB 2/4M Instr/Uni: 8 way 1024 entries
00:00:04.190914 L2 TLB 2/4M Data: 8 way 1024 entries
00:00:04.190915 L2 TLB 4K Instr/Uni: 4 way 512 entries
00:00:04.190916 L2 TLB 4K Data: 8 way 1024 entries
00:00:04.190917 L2 Cache Line Size: 0 bytes
00:00:04.190917 L2 Cache Lines Per Tag: 0
00:00:04.190918 L2 Cache Associativity: off
00:00:04.190918 L2 Cache Size: 0 KB
00:00:04.190919 APM Features:
00:00:04.190920 Host Invariant-TSC support: true
00:00:04.190921 Physical Address Width: 48 bits
00:00:04.190922 Virtual Address Width: 48 bits
00:00:04.190922 Guest Physical Address Width: 0 bits
00:00:04.190923 Physical Core Count: 4
00:00:04.190924
00:00:04.190924 ******************** End of CPUID dump **********************
00:00:04.204861 APIC: fPostedIntrsEnabled=false fVirtApicRegsEnabled=false fSupportsTscDeadline=false
00:00:04.204922 TMR3UtcNow: nsNow=1 530 592 575 079 400 800 nsPrev=0 -> cNsDelta=1 530 592 575 079 400 800 (offLag=0 offVirtualSync=0 offVirtualSyncGivenUp=0, NowAgain=1 530 592 575 079 400 800)
00:00:04.204948 VMEmt: Halt method global1 (5)
00:00:04.205156 VMEmt: HaltedGlobal1 config: cNsSpinBlockThresholdCfg=50000
00:00:04.205240 Changing the VM state from 'CREATING' to 'CREATED'
00:00:04.206951 Changing the VM state from 'CREATED' to 'POWERING_ON'
00:00:04.207089 AIOMgr: Endpoints without assigned bandwidth groups:
00:00:04.207140 AIOMgr: C:\Users\blust\OneDrive\Desktop\macOS Sierra 10.12 Files-001\macOS Sierra 10.12 Files\macOS Sierra 10.12 by wikigain.vmdk
00:00:04.207286 Changing the VM state from 'POWERING_ON' to 'RUNNING'
00:00:04.207307 Console: Machine state changed to 'Running'
00:00:04.215484 EFI: debug point SEC_PREMEM
00:00:04.326879 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/Sec/SecMain/DEBUG/SecMain.efi' 0xfffcc064 LB 0x0
00:00:04.328263 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Core/Pei/PeiMain/DEBUG/PeiCore.efi' 0x2020120 LB 0x0
00:00:04.329577 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/PCD/Pei/Pcd/DEBUG/PcdPeim.efi' 0x2026080 LB 0x1f60
00:00:04.331228 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Universal/StatusCode/Pei/StatusCodePei/DEBUG/StatusCodePei.efi' 0x20280a0 LB 0x660
00:00:04.332436 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/PlatformPei/PlatformPei/DEBUG/PlatformPei.efi' 0x20287a0 LB 0x2920
00:00:04.334488 EFI: debug point SEC_POSTMEM
00:00:04.365199 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Core/Pei/PeiMain/DEBUG/PeiCore.efi' 0xdbfb9000 LB 0x5e40
00:00:04.366895 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Core/DxeIplPeim/DxeIpl/DEBUG/DxeIpl.efi' 0xdbfb7000 LB 0x15c0
00:00:04.368700 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/UefiCpuPkg/Universal/Acpi/S3Resume2Pei/S3Resume2Pei/DEBUG/S3Resume2Pei.efi' 0xdbfb5000 LB 0x1480
00:00:04.370133 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Core/Dxe/DxeMain/DEBUG/DxeCore.efi' 0xdbf9d000 LB 0x17ba0
00:00:04.370371 EFI: debug point DXE_CORE
00:00:04.387730 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Core/Dxe/DxeMain/DEBUG/DxeCore.efi' 0xdbf9d000 LB 0x0
00:00:04.403427 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/DevicePathDxe/DevicePathDxe/DEBUG/DevicePathDxe.efi' 0xdbecd000 LB 0x8b20
00:00:04.404843 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/PCD/Dxe/Pcd/DEBUG/PcdDxe.efi' 0xdbeca000 LB 0x29c0
00:00:04.406770 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Universal/StatusCode/RuntimeDxe/StatusCodeRuntimeDxe/DEBUG/StatusCodeRuntimeDxe.efi' 0xdbf05000 LB 0xce0
00:00:04.408306 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Core/RuntimeDxe/RuntimeDxe/DEBUG/RuntimeDxe.efi' 0xdbf03000 LB 0x1320
00:00:04.410040 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/SecurityStubDxe/SecurityStubDxe/DEBUG/SecurityStubDxe.efi' 0xdbec9000 LB 0xde0
00:00:04.411383 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/EbcDxe/EbcDxe/DEBUG/EbcDxe.efi' 0xdbec5000 LB 0x3720
00:00:04.708193 GUI: UIMachineViewNormal::resendSizeHint: Restoring guest size-hint for screen 0 to 800x600
00:00:04.708282 VMMDev: SetVideoModeHint: Got a video mode hint (800x600x0)@(0x0),(1;0) at 0
00:00:04.711043 GUI: 2D video acceleration is disabled
00:00:04.711104 GUI: HID LEDs sync is enabled
00:00:04.723290 GUI: UIMachineLogicNormal::sltCheckForRequestedVisualStateType: Requested-state=0, Machine-state=5
00:00:04.961308 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/8259InterruptControllerDxe/8259/DEBUG/Legacy8259.efi' 0xdbec4000 LB 0xa20
00:00:04.962632 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/UefiCpuPkg/CpuIo2Dxe/CpuIo2Dxe/DEBUG/CpuIo2Dxe.efi' 0xdbec3000 LB 0x920
00:00:04.963816 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/UefiCpuPkg/CpuDxe/CpuDxe/DEBUG/CpuDxe.efi' 0xdbebe000 LB 0x4e20
00:00:04.965195 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/KbcResetDxe/Reset/DEBUG/KbcReset.efi' 0xdbf02000 LB 0x7e0
00:00:04.966599 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Metronome/Metronome/DEBUG/Metronome.efi' 0xdbebd000 LB 0x820
00:00:04.968294 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/EmuVariableFvbRuntimeDxe/Fvb/DEBUG/EmuVariableFvbRuntimeDxe.efi' 0xdbf01000 LB 0xe00
00:00:04.970018 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Variable/EmuRuntimeDxe/EmuVariableRuntimeDxe/DEBUG/EmuVariableRuntimeDxe.efi' 0xdbeff000 LB 0x1fc0
00:00:04.970460 EFI: Adding variable e660597e-b94d-4209-9c80-1805b5d19b69::'Test0' fAttrib=0x7 cbValue=0x10
00:00:04.971379 EFI: Adding variable e660597e-b94d-4209-9c80-1805b5d19b69::'Test1' fAttrib=0x7 cbValue=0x20
00:00:04.973134 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/PrintDxe/PrintDxe/DEBUG/PrintDxe.efi' 0xdbebb000 LB 0x1aa0
00:00:04.974572 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/HiiDatabaseDxe/HiiDatabaseDxe/DEBUG/HiiDatabase.efi' 0xdbea9000 LB 0x11ec0
00:00:04.976183 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/MemoryTest/NullMemoryTestDxe/NullMemoryTestDxe/DEBUG/NullMemoryTestDxe.efi' 0xdbea8000 LB 0x7a0
00:00:04.977767 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Universal/DataHubDxe/DataHubDxe/DEBUG/DataHubDxe.efi' 0xdbea7000 LB 0xc80
00:00:04.979696 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/ReportStatusCodeRouter/RuntimeDxe/ReportStatusCodeRouterRuntimeDxe/DEBUG/ReportStatusCodeRouterRuntimeDxe.efi' 0xdbefe000 LB 0xfc0
00:00:04.981116 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/SmbiosDxe/SmbiosDxe/DEBUG/SmbiosDxe.efi' 0xdbea5000 LB 0x1320
00:00:04.982547 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Acpi/AcpiTableDxe/AcpiTableDxe/DEBUG/AcpiTableDxe.efi' 0xdbea3000 LB 0x1940
00:00:04.984020 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/DpcDxe/DpcDxe/DEBUG/DpcDxe.efi' 0xdbea2000 LB 0x9e0
00:00:04.985275 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/8254TimerDxe/8254Timer/DEBUG/Timer.efi' 0xdbea1000 LB 0x6e0
00:00:04.985329 PIT: mode=3 count=0x2e9c (11932) - 99.99 Hz (ch=0)
00:00:04.986729 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/PciHostBridgeDxe/PciHostBridgeDxe/DEBUG/PciHostBridge.efi' 0xdbe9e000 LB 0x25a0
00:00:04.988245 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/PcatRealTimeClockRuntimeDxe/PcatRealTimeClockRuntimeDxe/DEBUG/PcRtc.efi' 0xdbefb000 LB 0x20a0
00:00:04.988892 EFI: Adding variable 378d7b65-8da9-4773-b6e4-a47826a833e1::'RTC' fAttrib=0x7 cbValue=0x4
00:00:04.990948 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/MonotonicCounterRuntimeDxe/MonotonicCounterRuntimeDxe/DEBUG/MonotonicCounterRuntimeDxe.efi' 0xdbefa000 LB 0x780
00:00:04.991417 EFI: Adding variable eb704011-1402-11d3-8e77-00a0c969723b::'MTC' fAttrib=0x7 cbValue=0x4
00:00:04.993058 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/CapsuleRuntimeDxe/CapsuleRuntimeDxe/DEBUG/CapsuleRuntimeDxe.efi' 0xdbef9000 LB 0x940
00:00:04.994485 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Universal/BdsDxe/BdsDxe/DEBUG/BdsDxe.efi' 0xdbe7a000 LB 0x23c80
00:00:04.995993 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/SetupBrowserDxe/SetupBrowserDxe/DEBUG/SetupBrowser.efi' 0xdbe69000 LB 0x10600
00:00:04.997715 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/StatusCodeHandler/RuntimeDxe/StatusCodeHandlerRuntimeDxe/DEBUG/StatusCodeHandlerRuntimeDxe.efi' 0xdbef8000 LB 0xa20
00:00:04.999063 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/SmbiosPlatformDxe/SmbiosPlatformDxe/DEBUG/SmbiosPlatformDxe.efi' 0xdbe68000 LB 0xb20
00:00:05.000666 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Acpi/AcpiPlatformDxe/AcpiPlatformDxe/DEBUG/AcpiPlatform.efi' 0xdbe67000 LB 0x7c0
00:00:05.004780 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/PlatformDxe/Platform/DEBUG/PlatformDxe.efi' 0xdbe63000 LB 0x33e0
00:00:05.006501 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/WatchdogTimerDxe/WatchdogTimer/DEBUG/WatchdogTimer.efi' 0xdbe62000 LB 0x6e0
00:00:05.008010 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/DisplayEngineDxe/DisplayEngineDxe/DEBUG/DisplayEngine.efi' 0xdbe54000 LB 0xdd00
00:00:05.026185 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Pci/PciBusDxe/PciBusDxe/DEBUG/PciBusDxe.efi' 0xdbe49000 LB 0xae20
00:00:05.027673 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/BlockMmioToBlockIoDxe/BlockIo/DEBUG/BlockMmioToBlockIoDxe.efi' 0xdbe48000 LB 0xc80
00:00:05.029076 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/VirtioPciDeviceDxe/VirtioPciDeviceDxe/DEBUG/VirtioPciDeviceDxe.efi' 0xdbe47000 LB 0xf00
00:00:05.030511 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Console/ConPlatformDxe/ConPlatformDxe/DEBUG/ConPlatformDxe.efi' 0xdbe45000 LB 0x1600
00:00:05.032079 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Console/ConSplitterDxe/ConSplitterDxe/DEBUG/ConSplitterDxe.efi' 0xdbe40000 LB 0x4f20
00:00:05.033911 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Console/GraphicsConsoleDxe/GraphicsConsoleDxe/DEBUG/GraphicsConsoleDxe.efi' 0xdbe3c000 LB 0x3d60
00:00:05.035421 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Console/TerminalDxe/TerminalDxe/DEBUG/TerminalDxe.efi' 0xdbe37000 LB 0x4820
00:00:05.036815 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Disk/DiskIoDxe/DiskIoDxe/DEBUG/DiskIoDxe.efi' 0xdbe34000 LB 0x26a0
00:00:05.038289 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Disk/PartitionDxe/PartitionDxe/DEBUG/PartitionDxe.efi' 0xdbe2f000 LB 0x4200
00:00:05.039734 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Disk/UnicodeCollation/EnglishDxe/EnglishDxe/DEBUG/EnglishDxe.efi' 0xdbe2e000 LB 0xc80
00:00:05.041030 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Scsi/ScsiBusDxe/ScsiBusDxe/DEBUG/ScsiBus.efi' 0xdbe2c000 LB 0x1d20
00:00:05.042374 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Scsi/ScsiDiskDxe/ScsiDiskDxe/DEBUG/ScsiDisk.efi' 0xdbe28000 LB 0x3f40
00:00:05.043862 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/Bus/Pci/IdeControllerDxe/IdeControllerDxe/DEBUG/IdeController.efi' 0xdbe27000 LB 0xfa0
00:00:05.045371 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Ata/AtaAtapiPassThru/AtaAtapiPassThru/DEBUG/AtaAtapiPassThruDxe.efi' 0xdbe20000 LB 0x6a00
00:00:05.046839 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Ata/AtaBusDxe/AtaBusDxe/DEBUG/AtaBusDxe.efi' 0xdbe1c000 LB 0x3a60
00:00:05.048759 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Pci/NvmExpressDxe/NvmExpressDxe/DEBUG/NvmExpressDxe.efi' 0xdbe17000 LB 0x49a0
00:00:05.050541 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/VBoxPkg/VBoxVgaMiniPortDxe/VBoxVgaMiniPortDxe/DEBUG/VBoxVgaMiniPortDxe.efi' 0xdbe13000 LB 0x3580
00:00:05.052006 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/VBoxPkg/VBoxVgaDxe/VBoxVgaDxe/DEBUG/VBoxVgaDxe.efi' 0xdbe0f000 LB 0x3260
00:00:05.053407 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/VBoxPkg/VBoxFsDxe/VBoxIso9660/DEBUG/VBoxIso9600.efi' 0xdbe09000 LB 0x5280
00:00:05.054620 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/VBoxPkg/VBoxFsDxe/VBoxHfs/DEBUG/VBoxHfs.efi' 0xdbe03000 LB 0x5ea0
00:00:05.056005 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/VBoxPkg/VBoxSysTables/VBoxSysTables/DEBUG/VBoxSysTables.efi' 0xdbe02000 LB 0x9c0
00:00:05.095287 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/VBoxPkg/VBoxAppleSim/VBoxAppleSim/DEBUG/VBoxAppleSim.efi' 0xdbdff000 LB 0x2420
00:00:05.095872 EFI: Adding variable 4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14::'BackgroundClear' fAttrib=0x6 cbValue=0x4
00:00:05.096291 EFI: Adding variable 4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14::'FirmwareFeatures' fAttrib=0x7 cbValue=0x4
00:00:05.096740 EFI: Adding variable 4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14::'FirmwareFeaturesMask' fAttrib=0x7 cbValue=0x4
00:00:05.097375 EFI: Adding variable 7c436110-ab2a-4bbb-a880-fe41995c9f82::'boot-args' fAttrib=0x6 cbValue=0x24
00:00:05.099638 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Acpi/BootGraphicsResourceTableDxe/BootGraphicsResourceTableDxe/DEBUG/BootGraphicsResourceTableDxe.efi' 0xdbdfe000 LB 0xba0
00:00:05.101288 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/PcAtChipsetPkg/IsaAcpiDxe/IsaAcpi/DEBUG/IsaAcpi.efi' 0xdbdfc000 LB 0x1080
00:00:05.102822 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Bus/Isa/IsaBusDxe/IsaBusDxe/DEBUG/IsaBusDxe.efi' 0xdbdfa000 LB 0x1f60
00:00:05.104347 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Bus/Isa/IsaIoDxe/IsaIoDxe/DEBUG/IsaIoDxe.efi' 0xdbdf8000 LB 0x1c00
00:00:05.105970 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Bus/Isa/IsaSerialDxe/IsaSerialDxe/DEBUG/IsaSerialDxe.efi' 0xdbdf5000 LB 0x2ee0
00:00:05.107594 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Bus/Isa/Ps2KeyboardDxe/Ps2keyboardDxe/DEBUG/Ps2KeyboardDxe.efi' 0xdbdf1000 LB 0x3320
00:00:05.109257 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/IntelFrameworkModulePkg/Bus/Isa/IsaFloppyDxe/IsaFloppyDxe/DEBUG/IsaFloppyDxe.efi' 0xdbdee000 LB 0x2d80
00:00:05.109531 EFI: VBoxDbg> loadimage64 '.efi' 0xdbde7000 LB 0x6940
00:00:05.110987 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/SnpDxe/SnpDxe/DEBUG/SnpDxe.efi' 0xdbde1000 LB 0x5220
00:00:05.112448 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/MnpDxe/MnpDxe/DEBUG/MnpDxe.efi' 0xdbdda000 LB 0x6a00
00:00:05.114109 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/VlanConfigDxe/VlanConfigDxe/DEBUG/VlanConfigDxe.efi' 0xdbdd5000 LB 0x4c80
00:00:05.115562 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/ArpDxe/ArpDxe/DEBUG/ArpDxe.efi' 0xdbdd1000 LB 0x3680
00:00:05.117257 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/Dhcp4Dxe/Dhcp4Dxe/DEBUG/Dhcp4Dxe.efi' 0xdbdc9000 LB 0x7cc0
00:00:05.118919 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/Ip4ConfigDxe/Ip4ConfigDxe/DEBUG/Ip4ConfigDxe.efi' 0xdbdc2000 LB 0x6560
00:00:05.120423 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/Ip4Dxe/Ip4Dxe/DEBUG/Ip4Dxe.efi' 0xdbdb7000 LB 0xa6e0
00:00:05.121950 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/Mtftp4Dxe/Mtftp4Dxe/DEBUG/Mtftp4Dxe.efi' 0xdbdaf000 LB 0x75c0
00:00:05.123379 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/Tcp4Dxe/Tcp4Dxe/DEBUG/Tcp4Dxe.efi' 0xdbda4000 LB 0xae20
00:00:05.124870 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/Udp4Dxe/Udp4Dxe/DEBUG/Udp4Dxe.efi' 0xdbd9d000 LB 0x6de0
00:00:05.126634 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/UefiPxeBcDxe/UefiPxeBcDxe/DEBUG/UefiPxe4BcDxe.efi' 0xdbd94000 LB 0x88a0
00:00:05.128295 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Universal/Network/IScsiDxe/IScsiDxe/DEBUG/IScsi4Dxe.efi' 0xdbd85000 LB 0xe280
00:00:05.129784 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/OvmfPkg/VirtioNetDxe/VirtioNet/DEBUG/VirtioNetDxe.efi' 0xdbd82000 LB 0x24a0
00:00:05.131177 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Pci/EhciDxe/EhciDxe/DEBUG/EhciDxe.efi' 0xdbd7d000 LB 0x4ae0
00:00:05.132577 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Pci/XhciDxe/XhciDxe/DEBUG/XhciDxe.efi' 0xdbd75000 LB 0x70a0
00:00:05.134206 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Usb/UsbBusDxe/UsbBusDxe/DEBUG/UsbBusDxe.efi' 0xdbd70000 LB 0x4c20
00:00:05.135620 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Usb/UsbKbDxe/UsbKbDxe/DEBUG/UsbKbDxe.efi' 0xdbd6c000 LB 0x3b00
00:00:05.137202 EFI: VBoxDbg> loadimage64 'E:/tinderbox/efi2-5.2/out/win.amd64/release/obj/VBoxEfiFirmware/amd64/RELEASE_VS2010/X64/MdeModulePkg/Bus/Usb/UsbMassStorageDxe/UsbMassStorageDxe/DEBUG/UsbMassStorageDxe.efi' 0xdbd68000 LB 0x31e0
00:00:05.137714 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootOptionSupport' fAttrib=0x6 cbValue=0x4
00:00:05.145119 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'OsIndicationsSupported' fAttrib=0x6 cbValue=0x8
00:00:05.145931 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'LangCodes' fAttrib=0x6 cbValue=0xd
00:00:05.146457 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'PlatformLangCodes' fAttrib=0x6 cbValue=0x12
00:00:05.146945 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'Lang' fAttrib=0x7 cbValue=0x4
00:00:05.147677 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'PlatformLang' fAttrib=0x7 cbValue=0x6
00:00:05.202008 AHCI#0: Reset the HBA
00:00:05.202065 VD#0: Cancelling all active requests
00:00:05.360622 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConOutDev' fAttrib=0x6 cbValue=0x1e
00:00:05.361531 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConOut' fAttrib=0x7 cbValue=0x1e
00:00:05.363638 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConIn' fAttrib=0x7 cbValue=0x22
00:00:05.365578 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConOut' fAttrib=0x7 cbValue=0x67
00:00:05.366234 Display::handleDisplayResize: uScreenId=0 pvVRAM=000000000ba90000 w=1024 h=768 bpp=32 cbLine=0x1000 flags=0x0
00:00:05.366342 GUI: UIFrameBufferPrivate::NotifyChange: Screen=0, Origin=0x0, Size=1024x768, Sending to async-handler
00:00:05.366524 GUI: UIMachineView::sltHandleNotifyChange: Screen=0, Size=1024x768
00:00:05.366545 GUI: UIFrameBufferPrivate::handleNotifyChange: Size=1024x768
00:00:05.366559 GUI: UIFrameBufferPrivate::performResize: Size=1024x768, Directly using source bitmap content
00:00:05.368485 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConIn' fAttrib=0x7 cbValue=0x6b
00:00:05.370592 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ErrOut' fAttrib=0x7 cbValue=0x49
00:00:05.374755 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConOut' fAttrib=0x7 cbValue=0xb0
00:00:05.378851 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConIn' fAttrib=0x7 cbValue=0xb4
00:00:05.382682 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ErrOut' fAttrib=0x7 cbValue=0x92
00:00:05.407760 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConOut' fAttrib=0x7 cbValue=0x67
00:00:05.410858 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConOut' fAttrib=0x7 cbValue=0x1e
00:00:05.494623 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConInDev' fAttrib=0x6 cbValue=0x22
00:00:05.497768 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConIn' fAttrib=0x7 cbValue=0x6b
00:00:05.499773 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ConIn' fAttrib=0x7 cbValue=0x22
00:00:05.504365 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ErrOut' fAttrib=0x7 cbValue=0x49
00:00:05.506112 EFI: Deleting variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'ErrOut'
00:00:05.716468 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'Boot0000' fAttrib=0x7 cbValue=0xb2
00:00:05.716893 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootOrder' fAttrib=0x7 cbValue=0x2
00:00:05.724632 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootOrder' fAttrib=0x7 cbValue=0x2
00:00:05.731874 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'Boot0001' fAttrib=0x7 cbValue=0x42
00:00:05.732266 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootOrder' fAttrib=0x7 cbValue=0x4
00:00:05.742636 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'Boot0002' fAttrib=0x7 cbValue=0x44
00:00:05.743071 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootOrder' fAttrib=0x7 cbValue=0x6
00:00:05.757360 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'Boot0003' fAttrib=0x7 cbValue=0x5c
00:00:05.757859 EFI: Replacing variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootOrder' fAttrib=0x7 cbValue=0x8
00:00:05.816822 EFI: Adding variable 8be4df61-93ca-11d2-aa0d-00e098032b8c::'BootCurrent' fAttrib=0x6 cbValue=0x2
00:00:05.818607 EFI: Adding variable 4c19049f-4137-4dd3-9c10-8b97a83ffdfa::'MemoryTypeInformation' fAttrib=0x3 cbValue=0x40
00:00:05.952493 EFI: VBoxDbg> loadimage64 '.efi' 0xdadc6000 LB 0x8d000
00:00:05.955313 EFI: Adding variable 4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14::'ROM' fAttrib=0x6 cbValue=0x6
00:00:05.959658 EFI: Adding variable 4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14::'MLB' fAttrib=0x6 cbValue=0x182
00:00:09.474736 EFI: Adding variable 7c436110-ab2a-4bbb-a880-fe41995c9f82::'platform-uuid' fAttrib=0x7 cbValue=0x10
00:00:09.480764 IEM: wrmsr(0x8b,0x0`00000000) -> #GP(0)
00:00:09.480927 Changing the VM state from 'RUNNING' to 'GURU_MEDITATION'
00:00:09.480958 Console: Machine state changed to 'GuruMeditation'
00:00:09.481291 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
00:00:09.481292 !!
00:00:09.481292 !! VCPU0: Guru Meditation 1155 (VINF_EM_TRIPLE_FAULT)
00:00:09.481343 !!
00:00:09.481395 !! Skipping ring-0 registers and stack, rcErr=VINF_EM_TRIPLE_FAULT
00:00:09.481405 !!
00:00:09.481405 !! {mappings, <NULL>}
00:00:09.481407 !!
00:00:09.481418
00:00:09.481419 The mappings are DISABLED.
00:00:09.481423 00000000fd800000 - 00000000febfffff Hypervisor Memory Area
00:00:09.481431 00000000fec00000 - 00000000ffbfffff Above 4GB Base RAM
00:00:09.481439 !!
00:00:09.481439 !! {hma, <NULL>}
00:00:09.481440 !!
00:00:09.481446 Hypervisor Memory Area (HMA) Layout: Base 00000000fd800000, 0x01400000 bytes
00:00:09.481454 00000000fe9fa000-00000000fe9fb000 DYNAMIC fence
00:00:09.481490 00000000fe9eb000-00000000fe9fa000 00000000166d0000 00000000166d0000 LOCKED alloc once (PGM_MAPPINGS)
00:00:09.481512 00000000fe9ea000-00000000fe9eb000 DYNAMIC fence
00:00:09.481543 00000000fe9da000-00000000fe9ea000 DYNAMIC Dynamic mapping
00:00:09.481580 00000000fe95a000-00000000fe9da000 MMIO2 0000000000000000 VGA VRam
00:00:09.481606 00000000fe959000-00000000fe95a000 DYNAMIC fence
00:00:09.481640 00000000fe8d8000-00000000fe959000 0000000013a90000 0000000013a90000 LOCKED alloc once (PGM_PHYS)
00:00:09.481660 00000000fe8d7000-00000000fe8d8000 DYNAMIC fence
00:00:09.481864 00000000fe8c3000-00000000fe8d7000 000000000ba70000 000000000ba70000 LOCKED alloc once (PDM_DEVICE)
00:00:09.527640 00000000fe8c2000-00000000fe8c3000 DYNAMIC fence
00:00:09.527674 00000000fe8c1000-00000000fe8c2000 00000000062e0000 ffffe5811d6fc000 HCPHYS 00000000bd7f7000 Core Code
00:00:09.527688 00000000fe8c0000-00000000fe8c1000 DYNAMIC fence
00:00:09.527722 00000000fe8bf000-00000000fe8c0000 0000000000a40000 0000000000000000 HCPHYS 00000000be08f000 GIP
00:00:09.527733 00000000fe8be000-00000000fe8bf000 DYNAMIC fence
00:00:09.527761 00000000fe8b2000-00000000fe8be000 0000000003820000 0000000003820000 LOCKED alloc once (PGM_MAPPINGS)
00:00:09.527779 00000000fe8b1000-00000000fe8b2000 DYNAMIC fence
00:00:09.527811 00000000fdaf0000-00000000fe8b1000 00000000088f0000 00000000088f0000 LOCKED alloc once (PGM_PHYS)
00:00:09.527829 00000000fdaef000-00000000fdaf0000 DYNAMIC fence
00:00:09.527859 00000000fda91000-00000000fdaef000 0000000006280000 0000000006280000 LOCKED alloc once (PGM_POOL)
00:00:09.527876 00000000fda90000-00000000fda91000 DYNAMIC fence
00:00:09.527903 00000000fda8b000-00000000fda90000 DYNAMIC CR3 mapping
00:00:09.527937 00000000fda8a000-00000000fda8b000 DYNAMIC fence
00:00:09.527964 00000000fda87000-00000000fda8a000 0000000003810000 ffffd30a75dd4000 LOCKED alloc once (CPUM_CTX)
00:00:09.527982 00000000fda86000-00000000fda87000 DYNAMIC fence
00:00:09.528012 00000000fd846000-00000000fda86000 0000000006e10000 0000000006e10000 LOCKED Heap
00:00:09.528028 00000000fd845000-00000000fd846000 DYNAMIC fence
00:00:09.528057 00000000fd801000-00000000fd845000 0000000001b00000 ffffe5811ef40000 LOCKED VM
00:00:09.528074 00000000fd800000-00000000fd801000 DYNAMIC fence
00:00:09.528103 !!
00:00:09.528103 !! {cpumguest, verbose}
00:00:09.528104 !!
00:00:09.528136 Guest CPUM (VCPU 0) state:
00:00:09.528146 rax=00000000000003fc rbx=000000000000000e rcx=0000000000000000 rdx=ffffff800e2a9570
00:00:09.528150 rsi=0000000000000008 rdi=ffffff800e10bea0 r8 =ffffff80103c602b r9 =0000000000000000
00:00:09.528152 r10=0000000000000063 r11=ffffff800e97fc78 r12=ffffff800e10bef4 r13=ffffff800eaf6038
00:00:09.528155 r14=ffffff800e10bea0 r15=ffffff800e106f40
00:00:09.528157 rip=ffffff800e2a8e1f rsp=ffffff800e106f40 rbp=ffffff800e10bf30 iopl=0 nv up di pl nz na po nc
00:00:09.528161 cs={0008 base=0000000000000000 limit=ffffffff flags=0000a09b}
00:00:09.528162 ds={0000 base=0000000000000000 limit=ffffffff flags=00000000}
00:00:09.528164 es={0000 base=0000000000000000 limit=ffffffff flags=00000000}
00:00:09.528165 fs={0000 base=0000000000000000 limit=ffffffff flags=00000000}
00:00:09.528166 gs={0000 base=ffffff800ea09040 limit=ffffffff flags=00000000}
00:00:09.528168 ss={0000 base=0000000000000000 limit=ffffffff flags=00004000}
00:00:09.528169 cr0=00000000c0010033 cr2=00000000000003fc cr3=0000000010644000 cr4=0000000000000020
00:00:09.528172 dr0=0000000000000000 dr1=0000000000000000 dr2=0000000000000000 dr3=0000000000000000
00:00:09.528173 dr4=0000000000000000 dr5=0000000000000000 dr6=00000000ffff0ff0 dr7=0000000000000400
00:00:09.528174 gdtr=ffffff8000001000:0097 idtr=ffffff8000000000:1000 eflags=00000046
00:00:09.528177 ldtr={0030 base=ffffff800ea15000 limit=00000017 flags=00000082}
00:00:09.528179 tr ={0040 base=ffffff800ea14000 limit=00000067 flags=0000008b}
00:00:09.528180 SysEnter={cs=000b eip=000000000e2a9190 esp=000000000eb35080}
00:00:09.528266 xcr=0000000000000001 xcr1=0000000000000000 xss=0000000000000000 (fXStateMask=0000000000000000)
00:00:09.528268 FCW=037f FSW=0000 FTW=0000 FOP=0000 MXCSR=00001f80 MXCSR_MASK=0002ffff
00:00:09.528270 FPUIP=00000000 CS=0000 Rsrvd1=0000 FPUDP=00000000 DS=0000 Rsvrd2=0000
00:00:09.528272 ST(0)=FPR0={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528276 ST(1)=FPR1={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528279 ST(2)=FPR2={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528281 ST(3)=FPR3={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528283 ST(4)=FPR4={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528286 ST(5)=FPR5={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528288 ST(6)=FPR6={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528290 ST(7)=FPR7={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528293 XMM0 =00000000'0000001f'00000000'0000001f XMM1 =00000000'0000001f'00000000'0000001e
00:00:09.528296 XMM2 =00000000'00000000'00000000'00000000 XMM3 =00000000'00000000'00000000'00000000
00:00:09.528298 XMM4 =01020304'05060708'090a0b0c'0d0e0f10 XMM5 =00010001'00010001'00010001'00010001
00:00:09.528302 XMM6 =11121314'15161718'191a1b1c'1d1e1f20 XMM7 =00000000'00000000'00000000'00000000
00:00:09.528305 XMM8 =31323334'35363738'393a3b3c'3d3e3f40 XMM9 =21222324'25262728'292a2b2c'2d2e2f30
00:00:09.528308 XMM10=00000000'00000000'00000000'00000000 XMM11=00000000'00000000'00000000'00000000
00:00:09.528310 XMM12=00000000'00000000'00000000'00000000 XMM13=00000000'00000000'00000000'00000000
00:00:09.528313 XMM14=00000000'00000000'00000000'00000000 XMM15=00000000'00000000'00000000'00000000
00:00:09.528315 EFER =0000000000000d01
00:00:09.528316 PAT =0007040600070406
00:00:09.528317 STAR =001b000800000000
00:00:09.528318 CSTAR =0000000000000000
00:00:09.528319 LSTAR =ffffff800e2a9130
00:00:09.528320 SFMASK =0000000000004700
00:00:09.528320 KERNELGSBASE =ffffff800ea09040
00:00:09.528327 !!
00:00:09.528328 !! {cpumguesthwvirt, verbose}
00:00:09.528329 !!
00:00:09.528334 VCPU[0] hardware virtualization state:
00:00:09.528335 No/inactive hwvirt state
00:00:09.528338 !!
00:00:09.528338 !! {cpumguestinstr, verbose}
00:00:09.528339 !!
00:00:09.528402
00:00:09.528402 CPUM0: 0008:ffffff800e2a8e1f c7 81 fc 03 00 00 ff ff ff ff mov dword [rcx+0000003fch], 0ffffffffh
00:00:09.528403
00:00:09.528406 !!
00:00:09.528406 !! {cpumhyper, verbose}
00:00:09.528407 !!
00:00:09.528414 Hypervisor CPUM state:
00:00:09.528416 .eax=00000000 .ebx=00000000 .ecx=00000000 .edx=00000000 .esi=00000000 .edi=00000000
00:00:09.528418 .eip=00000000 .esp=fda84000 .ebp=00000000 .iopl=0 nv up di pl zr na pe nc
00:00:09.528420 .cs={0000 base=0000000000000000 limit=00000000 flags=00000000} .dr0=00000000 .dr1=00000000
00:00:09.528422 .ds={0000 base=0000000000000000 limit=00000000 flags=00000000} .dr2=00000000 .dr3=00000000
00:00:09.528424 .es={0000 base=0000000000000000 limit=00000000 flags=00000000} .dr4=00000000 .dr5=00000000
00:00:09.528426 .fs={0000 base=0000000000000000 limit=00000000 flags=00000000} .dr6=00000000 .dr7=00000400
00:00:09.528428 .gs={0000 base=0000000000000000 limit=00000000 flags=00000000} .cr0=00000000 .cr2=00000000
00:00:09.528429 .ss={0000 base=0000000000000000 limit=00000000 flags=00000000} .cr3=00000000 .cr4=00000000
00:00:09.528431 .gdtr=0000000000000000:0000 .idtr=0000000000000000:0000 .eflags=00000000
00:00:09.528433 .ldtr={0000 base=00000000 limit=00000000 flags=00000000}
00:00:09.528434 .tr ={0000 base=00000000 limit=00000000 flags=00000000}
00:00:09.528435 .SysEnter={cs=0000 eip=00000000 esp=00000000}
00:00:09.528436 .xcr=0000000000000000 .xcr1=0000000000000000 .xss=0000000000000000 (fXStateMask=0000000000000000)
00:00:09.528438 .FCW=0000 .FSW=0000 .FTW=0000 .FOP=0000 .MXCSR=00000000 .MXCSR_MASK=00000000
00:00:09.528440 .FPUIP=00000000 .CS=0000 .Rsrvd1=0000 .FPUDP=00000000 .DS=0000 .Rsvrd2=0000
00:00:09.528442 .ST(0)=.FPR0={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528445 .ST(1)=.FPR1={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528447 .ST(2)=.FPR2={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528450 .ST(3)=.FPR3={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528452 .ST(4)=.FPR4={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528454 .ST(5)=.FPR5={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528457 .ST(6)=.FPR6={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528459 .ST(7)=.FPR7={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:00:09.528461 .XMM0 =00000000'00000000'00000000'00000000 .XMM1 =00000000'00000000'00000000'00000000
00:00:09.528463 .XMM2 =00000000'00000000'00000000'00000000 .XMM3 =00000000'00000000'00000000'00000000
00:00:09.528466 .XMM4 =00000000'00000000'00000000'00000000 .XMM5 =00000000'00000000'00000000'00000000
00:00:09.528468 .XMM6 =00000000'00000000'00000000'00000000 .XMM7 =00000000'00000000'00000000'00000000
00:00:09.528470 .XMM8 =00000000'00000000'00000000'00000000 .XMM9 =00000000'00000000'00000000'00000000
00:00:09.528472 .XMM10=00000000'00000000'00000000'00000000 .XMM11=00000000'00000000'00000000'00000000
00:00:09.528475 .XMM12=00000000'00000000'00000000'00000000 .XMM13=00000000'00000000'00000000'00000000
00:00:09.528477 .XMM14=00000000'00000000'00000000'00000000 .XMM15=00000000'00000000'00000000'00000000
00:00:09.528479 .EFER =0000000000000000
00:00:09.528480 .PAT =0000000000000000
00:00:09.528481 .STAR =0000000000000000
00:00:09.528481 .CSTAR =0000000000000000
00:00:09.528482 .LSTAR =0000000000000000
00:00:09.528483 .SFMASK =0000000000000000
00:00:09.528483 .KERNELGSBASE =0000000000000000
00:00:09.528484 CR4OrMask=0x204 CR4AndMask=0x403
00:00:09.528487 !!
00:00:09.528487 !! {cpumhost, verbose}
00:00:09.528488 !!
00:00:09.528496 Host CPUM state:
00:00:09.528497 rax=xxxxxxxxxxxxxxxx rbx=0000000000000000 rcx=xxxxxxxxxxxxxxxx
00:00:09.528498 rdx=xxxxxxxxxxxxxxxx rsi=0000000000000000 rdi=0000000000000000
00:00:09.528499 rip=xxxxxxxxxxxxxxxx rsp=0000000000000000 rbp=0000000000000000
00:00:09.528500 r8=xxxxxxxxxxxxxxxx r9=xxxxxxxxxxxxxxxx r10=0000000000000000
00:00:09.528501 r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
00:00:09.528502 r14=0000000000000000 r15=0000000000000000
00:00:09.528503 iopl=0 nv up di pl zr na pe nc
00:00:09.528504 cs=0000 ds=0000 es=0000 fs=0000 gs=0000 eflags=00000000
00:00:09.528505 cr0=0000000000000000 cr2=xxxxxxxxxxxxxxxx cr3=0000000000000000
00:00:09.528506 cr4=0000000000000000 ldtr=0000 tr=0000
00:00:09.528507 dr[0]=0000000000000000 dr[1]=0000000000000000 dr[2]=0000000000000000
00:00:09.528508 dr[3]=0000000000000000 dr[6]=00000000ffff0ff0 dr[7]=0000000000000400
00:00:09.528510 gdtr=0000000000000000:0000 idtr=0000000000000000:0000
00:00:09.528511 SysEnter={cs=0000 eip=00000000 esp=00000000}
00:00:09.528512 FSbase=0000000000000000 GSbase=0000000000000000 efer=00000000
00:00:09.528514 !!
00:00:09.528515 !! {mode, all}
00:00:09.528516 !!
00:00:09.528526 Guest paging mode (VCPU #0): AMD64+NX (changed 5 times), A20 enabled (changed 0 times)
00:00:09.528528 Shadow paging mode (VCPU #0): Nested
00:00:09.528529 Host paging mode: AMD64+G+NX
00:00:09.528531 !!
00:00:09.528532 !! {cpuid, verbose}
00:00:09.528532 !!
00:00:09.528535 Raw Standard CPUID Leaves
00:00:09.528535 Leaf/sub-leaf eax ebx ecx edx
00:00:09.528536 Gst: 00000000/0000 0000000d 68747541 444d4163 69746e65
00:00:09.528538 Hst: 0000000d 68747541 444d4163 69746e65
00:00:09.528540 Gst: 00000001/0000 000106e5 00040800 80982201 178bfbff
00:00:09.528542 Hst: 00660f51 00040800 7ed8320b 178bfbff
00:00:09.528543 Gst: 00000002/0000 00000000 00000000 00000000 00000000
00:00:09.528544 Hst: 00000000 00000000 00000000 00000000
00:00:09.528546 Gst: 00000003/0000 00000000 00000000 00000000 00000000
00:00:09.528547 Hst: 00000000 00000000 00000000 00000000
00:00:09.528548 Gst: 00000004/0000 00000000 00000000 00000000 00000000
00:00:09.528549 Hst: 00000000 00000000 00000000 00000000
00:00:09.528550 Gst: 00000005/0000 00000000 00000000 00000003 00000000
00:00:09.528551 Hst: 00000040 00000040 00000003 00000000
00:00:09.528552 Gst: 00000006/0000 00000000 00000000 00000000 00000000
00:00:09.528553 Hst: 00000004 00000000 00000001 00000000
00:00:09.528555 Gst: 00000007/0000 00000000 00000021 00000000 00000000
00:00:09.528556 Hst: 00000000 000001a9 00000000 00000000
00:00:09.528557 Gst: 00000007/0001 00000000 00000000 00000000 00000000
00:00:09.528558 Hst: 00000000 00000000 00000000 00000000
00:00:09.528562 Gst: 00000008/0000 00000000 00000000 00000000 00000000
00:00:09.528563 Hst: 00000000 00000000 00000000 00000000
00:00:09.528564 Gst: 00000009/0000 00000000 00000000 00000000 00000000
00:00:09.528565 Hst: 00000000 00000000 00000000 00000000
00:00:09.528566 Gst: 0000000a/0000 00000000 00000000 00000000 00000000
00:00:09.528568 Hst: 00000000 00000000 00000000 00000000
00:00:09.528648 Gst: 0000000b/0000 00000000 00000000 00000000 00000000
00:00:09.528649 Hst: 00000000 00000000 00000000 00000000
00:00:09.528651 Gst: 0000000c/0000 00000000 00000000 00000000 00000000
00:00:09.528652 Hst: 00000000 00000000 00000000 00000000
00:00:09.528653 Gst: 0000000d/0000 00000000 00000000 00000000 00000000
00:00:09.528654 Hst: 00000007 00000340 000003c0 40000000
00:00:09.528655 Gst: 0000000d/0001 00000000 00000000 00000000 00000000
00:00:09.528656 Hst: 00000001 00000000 00000000 00000000
00:00:09.528657 Gst: 0000000d/0002 00000000 00000000 00000000 00000000
00:00:09.528658 Hst: 00000100 00000240 00000000 00000000
00:00:09.528659 Gst: 0000000d/0003 00000000 00000000 00000000 00000000
00:00:09.528660 Hst: 00000000 00000000 00000000 00000000
00:00:09.528661 Gst: 0000000d/0004 00000000 00000000 00000000 00000000
00:00:09.528662 Hst: 00000000 00000000 00000000 00000000
00:00:09.528663 Gst: 0000000d/0005 00000000 00000000 00000000 00000000
00:00:09.528664 Hst: 00000000 00000000 00000000 00000000
00:00:09.528665 Gst: 0000000d/0006 00000000 00000000 00000000 00000000
00:00:09.528666 Hst: 00000000 00000000 00000000 00000000
00:00:09.528667 Gst: 0000000d/0007 00000000 00000000 00000000 00000000
00:00:09.528669 Hst: 00000000 00000000 00000000 00000000
00:00:09.528669 Gst: 0000000d/0008 00000000 00000000 00000000 00000000
00:00:09.528670 Hst: 00000000 00000000 00000000 00000000
00:00:09.528672 Gst: 0000000d/0009 00000000 00000000 00000000 00000000
00:00:09.528673 Hst: 00000000 00000000 00000000 00000000
00:00:09.528674 Gst: 0000000d/000a 00000000 00000000 00000000 00000000
00:00:09.528675 Hst: 00000000 00000000 00000000 00000000
00:00:09.528676 Gst: 0000000d/000b 00000000 00000000 00000000 00000000
00:00:09.528677 Hst: 00000000 00000000 00000000 00000000
00:00:09.528678 Gst: 0000000d/000c 00000000 00000000 00000000 00000000
00:00:09.528679 Hst: 00000000 00000000 00000000 00000000
00:00:09.528680 Gst: 0000000d/000d 00000000 00000000 00000000 00000000
00:00:09.528681 Hst: 00000000 00000000 00000000 00000000
00:00:09.528682 Gst: 0000000d/000e 00000000 00000000 00000000 00000000
00:00:09.528683 Hst: 00000000 00000000 00000000 00000000
00:00:09.528684 Gst: 0000000d/000f 00000000 00000000 00000000 00000000
00:00:09.528685 Hst: 00000000 00000000 00000000 00000000
00:00:09.528686 Gst: 0000000d/0010 00000000 00000000 00000000 00000000
00:00:09.528687 Hst: 00000000 00000000 00000000 00000000
00:00:09.528688 Gst: 0000000d/0011 00000000 00000000 00000000 00000000
00:00:09.528689 Hst: 00000000 00000000 00000000 00000000
00:00:09.528690 Gst: 0000000d/0012 00000000 00000000 00000000 00000000
00:00:09.528691 Hst: 00000000 00000000 00000000 00000000
00:00:09.528692 Gst: 0000000d/0013 00000000 00000000 00000000 00000000
00:00:09.528693 Hst: 00000000 00000000 00000000 00000000
00:00:09.528694 Gst: 0000000d/0014 00000000 00000000 00000000 00000000
00:00:09.528695 Hst: 00000000 00000000 00000000 00000000
00:00:09.528697 Gst: 0000000d/0015 00000000 00000000 00000000 00000000
00:00:09.528698 Hst: 00000000 00000000 00000000 00000000
00:00:09.528699 Gst: 0000000d/0016 00000000 00000000 00000000 00000000
00:00:09.528700 Hst: 00000000 00000000 00000000 00000000
00:00:09.528701 Gst: 0000000d/0017 00000000 00000000 00000000 00000000
00:00:09.528702 Hst: 00000000 00000000 00000000 00000000
00:00:09.528703 Gst: 0000000d/0018 00000000 00000000 00000000 00000000
00:00:09.528704 Hst: 00000000 00000000 00000000 00000000
00:00:09.528705 Gst: 0000000d/0019 00000000 00000000 00000000 00000000
00:00:09.528706 Hst: 00000000 00000000 00000000 00000000
00:00:09.528707 Gst: 0000000d/001a 00000000 00000000 00000000 00000000
00:00:09.528708 Hst: 00000000 00000000 00000000 00000000
00:00:09.528709 Gst: 0000000d/001b 00000000 00000000 00000000 00000000
00:00:09.528710 Hst: 00000000 00000000 00000000 00000000
00:00:09.528711 Gst: 0000000d/001c 00000000 00000000 00000000 00000000
00:00:09.528712 Hst: 00000000 00000000 00000000 00000000
00:00:09.528713 Gst: 0000000d/001d 00000000 00000000 00000000 00000000
00:00:09.528714 Hst: 00000000 00000000 00000000 00000000
00:00:09.528715 Gst: 0000000d/001e 00000000 00000000 00000000 00000000
00:00:09.528716 Hst: 00000000 00000000 00000000 00000000
00:00:09.528717 Gst: 0000000d/001f 00000000 00000000 00000000 00000000
00:00:09.528718 Hst: 00000000 00000000 00000000 00000000
00:00:09.528719 Gst: 0000000d/0020 00000000 00000000 00000000 00000000
00:00:09.528720 Hst: 00000000 00000000 00000000 00000000
00:00:09.528721 Gst: 0000000d/0021 00000000 00000000 00000000 00000000
00:00:09.528722 Hst: 00000000 00000000 00000000 00000000
00:00:09.528723 Gst: 0000000d/0022 00000000 00000000 00000000 00000000
00:00:09.528724 Hst: 00000000 00000000 00000000 00000000
00:00:09.528725 Gst: 0000000d/0023 00000000 00000000 00000000 00000000
00:00:09.528726 Hst: 00000000 00000000 00000000 00000000
00:00:09.528727 Gst: 0000000d/0024 00000000 00000000 00000000 00000000
00:00:09.528728 Hst: 00000000 00000000 00000000 00000000
00:00:09.528729 Gst: 0000000d/0025 00000000 00000000 00000000 00000000
00:00:09.528730 Hst: 00000000 00000000 00000000 00000000
00:00:09.528731 Gst: 0000000d/0026 00000000 00000000 00000000 00000000
00:00:09.528732 Hst: 00000000 00000000 00000000 00000000
00:00:09.528733 Gst: 0000000d/0027 00000000 00000000 00000000 00000000
00:00:09.528734 Hst: 00000000 00000000 00000000 00000000
00:00:09.528735 Gst: 0000000d/0028 00000000 00000000 00000000 00000000
00:00:09.528736 Hst: 00000000 00000000 00000000 00000000
00:00:09.528737 Gst: 0000000d/0029 00000000 00000000 00000000 00000000
00:00:09.528738 Hst: 00000000 00000000 00000000 00000000
00:00:09.528739 Gst: 0000000d/002a 00000000 00000000 00000000 00000000
00:00:09.528740 Hst: 00000000 00000000 00000000 00000000
00:00:09.528741 Gst: 0000000d/002b 00000000 00000000 00000000 00000000
00:00:09.528742 Hst: 00000000 00000000 00000000 00000000
00:00:09.528743 Gst: 0000000d/002c 00000000 00000000 00000000 00000000
00:00:09.528744 Hst: 00000000 00000000 00000000 00000000
00:00:09.528745 Gst: 0000000d/002d 00000000 00000000 00000000 00000000
00:00:09.528746 Hst: 00000000 00000000 00000000 00000000
00:00:09.528747 Gst: 0000000d/002e 00000000 00000000 00000000 00000000
00:00:09.528748 Hst: 00000000 00000000 00000000 00000000
00:00:09.528749 Gst: 0000000d/002f 00000000 00000000 00000000 00000000
00:00:09.528750 Hst: 00000000 00000000 00000000 00000000
00:00:09.528751 Gst: 0000000d/0030 00000000 00000000 00000000 00000000
00:00:09.528752 Hst: 00000000 00000000 00000000 00000000
00:00:09.528753 Gst: 0000000d/0031 00000000 00000000 00000000 00000000
00:00:09.528754 Hst: 00000000 00000000 00000000 00000000
00:00:09.528755 Gst: 0000000d/0032 00000000 00000000 00000000 00000000
00:00:09.528756 Hst: 00000000 00000000 00000000 00000000
00:00:09.528757 Gst: 0000000d/0033 00000000 00000000 00000000 00000000
00:00:09.528758 Hst: 00000000 00000000 00000000 00000000
00:00:09.528759 Gst: 0000000d/0034 00000000 00000000 00000000 00000000
00:00:09.528760 Hst: 00000000 00000000 00000000 00000000
00:00:09.528761 Gst: 0000000d/0035 00000000 00000000 00000000 00000000
00:00:09.528762 Hst: 00000000 00000000 00000000 00000000
00:00:09.528763 Gst: 0000000d/0036 00000000 00000000 00000000 00000000
00:00:09.528764 Hst: 00000000 00000000 00000000 00000000
00:00:09.528765 Gst: 0000000d/0037 00000000 00000000 00000000 00000000
00:00:09.528766 Hst: 00000000 00000000 00000000 00000000
00:00:09.528767 Gst: 0000000d/0038 00000000 00000000 00000000 00000000
00:00:09.528768 Hst: 00000000 00000000 00000000 00000000
00:00:09.528769 Gst: 0000000d/0039 00000000 00000000 00000000 00000000
00:00:09.528770 Hst: 00000000 00000000 00000000 00000000
00:00:09.528772 Gst: 0000000d/003a 00000000 00000000 00000000 00000000
00:00:09.528772 Hst: 00000000 00000000 00000000 00000000
00:00:09.528774 Gst: 0000000d/003b 00000000 00000000 00000000 00000000
00:00:09.528774 Hst: 00000000 00000000 00000000 00000000
00:00:09.528775 Gst: 0000000d/003c 00000000 00000000 00000000 00000000
00:00:09.528776 Hst: 00000000 00000000 00000000 00000000
00:00:09.528778 Gst: 0000000d/003d 00000000 00000000 00000000 00000000
00:00:09.528779 Hst: 00000000 00000000 00000000 00000000
00:00:09.528780 Gst: 0000000d/003e 00000000 00000000 00000000 00000000
00:00:09.528781 Hst: 00000080 00000340 00000000 00000000
00:00:09.528782 Gst: 0000000d/003f 00000000 00000000 00000000 00000000
00:00:09.528783 Hst: 00000000 00000000 00000000 00000000
00:00:09.528784 Gst: 0000000d/0040 00000000 00000000 00000000 00000000
00:00:09.528785 Hst: 00000000 00000000 00000000 00000000
00:00:09.528790 Name: AuthenticAMD
00:00:09.528792 Supports: 0x00000000-0x0000000d
00:00:09.528794 Family: 6 Extended: 0 Effective: 6
00:00:09.528796 Model: 14 Extended: 1 Effective: 14
00:00:09.528797 Stepping: 5
00:00:09.528798 Type: 0 (primary)
00:00:09.528800 APIC ID: 0x00
00:00:09.528801 Logical CPUs: 4
00:00:09.528802 CLFLUSH Size: 8
00:00:09.528803 Brand ID: 0x00
00:00:09.528805 Features
00:00:09.528805 Mnemonic - Description = guest (host)
00:00:09.528806 FPU - x87 FPU on Chip = 1 (1)
00:00:09.528808 VME - Virtual 8086 Mode Enhancements = 1 (1)
00:00:09.528810 DE - Debugging extensions = 1 (1)
00:00:09.528811 PSE - Page Size Extension = 1 (1)
00:00:09.528813 TSC - Time Stamp Counter = 1 (1)
00:00:09.528815 MSR - Model Specific Registers = 1 (1)
00:00:09.528816 PAE - Physical Address Extension = 1 (1)
00:00:09.528818 MCE - Machine Check Exception = 1 (1)
00:00:09.528819 CX8 - CMPXCHG8B instruction = 1 (1)
00:00:09.528821 APIC - APIC On-Chip = 1 (1)
00:00:09.528822 SEP - SYSENTER and SYSEXIT Present = 1 (1)
00:00:09.528824 MTRR - Memory Type Range Registers = 1 (1)
00:00:09.528825 PGE - PTE Global Bit = 1 (1)
00:00:09.528827 MCA - Machine Check Architecture = 1 (1)
00:00:09.528828 CMOV - Conditional Move instructions = 1 (1)
00:00:09.528830 PAT - Page Attribute Table = 1 (1)
00:00:09.528831 PSE-36 - 36-bit Page Size Extension = 1 (1)
00:00:09.528832 PSN - Processor Serial Number = 0 (0)
00:00:09.528834 CLFSH - CLFLUSH instruction = 1 (1)
00:00:09.528835 DS - Debug Store = 0 (0)
00:00:09.528837 ACPI - Thermal Mon. & Soft. Clock Ctrl. = 0 (0)
00:00:09.528838 MMX - Intel MMX Technology = 1 (1)
00:00:09.528840 FXSR - FXSAVE and FXRSTOR instructions = 1 (1)
00:00:09.528841 SSE - SSE support = 1 (1)
00:00:09.528843 SSE2 - SSE2 support = 1 (1)
00:00:09.528845 SS - Self Snoop = 0 (0)
00:00:09.528846 HTT - Hyper-Threading Technology = 1 (1)
00:00:09.528848 TM - Therm. Monitor = 0 (0)
00:00:09.528849 PBE - Pending Break Enabled = 0 (0)
00:00:09.528851 SSE3 - SSE3 support = 1 (1)
00:00:09.528852 PCLMUL - PCLMULQDQ support (for AES-GCM) = 0 (1)
00:00:09.528854 DTES64 - DS Area 64-bit Layout = 0 (0)
00:00:09.528855 MONITOR - MONITOR/MWAIT instructions = 0 (1)
00:00:09.528857 CPL-DS - CPL Qualified Debug Store = 0 (0)
00:00:09.528858 VMX - Virtual Machine Extensions = 0 (0)
00:00:09.528859 SMX - Safer Mode Extensions = 0 (0)
00:00:09.528861 EST - Enhanced SpeedStep Technology = 0 (0)
00:00:09.528862 TM2 - Terminal Monitor 2 = 0 (0)
00:00:09.528864 SSSE3 - Supplemental Streaming SIMD Extensions 3 = 1 (1)
00:00:09.528865 CNTX-ID - L1 Context ID = 0 (0)
00:00:09.528866 SDBG - Silicon Debug interface = 0 (0)
00:00:09.528868 FMA - Fused Multiply Add extensions = 0 (1)
00:00:09.528869 CX16 - CMPXCHG16B instruction = 1 (1)
00:00:09.528871 TPRUPDATE - xTPR Update Control = 0 (0)
00:00:09.528872 PDCM - Perf/Debug Capability MSR = 0 (0)
00:00:09.528873 PCID - Process Context Identifiers = 0 (0)
00:00:09.528875 DCA - Direct Cache Access = 0 (0)
00:00:09.528876 SSE4_1 - SSE4_1 support = 1 (1)
00:00:09.528878 SSE4_2 - SSE4_2 support = 1 (1)
00:00:09.528879 X2APIC - x2APIC support = 0 (0)
00:00:09.528881 MOVBE - MOVBE instruction = 0 (1)
00:00:09.528882 POPCNT - POPCNT instruction = 1 (1)
00:00:09.528884 TSCDEADL - Time Stamp Counter Deadline = 0 (0)
00:00:09.528885 AES - AES instructions = 0 (1)
00:00:09.528887 XSAVE - XSAVE instruction = 0 (1)
00:00:09.528888 OSXSAVE - OSXSAVE instruction = 0 (1)
00:00:09.528890 AVX - AVX support = 0 (1)
00:00:09.528891 F16C - 16-bit floating point conversion instructions = 0 (1)
00:00:09.528892 RDRAND - RDRAND instruction = 0 (1)
00:00:09.528894 HVP - Hypervisor Present (we're a guest) = 1 (0)
00:00:09.528896 Structured Extended Feature Flags Enumeration (leaf 7):
00:00:09.528897 Mnemonic - Description = guest (host)
00:00:09.528897 FSGSBASE - RDFSBASE/RDGSBASE/WRFSBASE/WRGSBASE instr. = 1 (1)
00:00:09.528899 TSCADJUST - Supports MSR_IA32_TSC_ADJUST = 0 (0)
00:00:09.528900 SGX - Supports Software Guard Extensions = 0 (0)
00:00:09.528901 BMI1 - Advanced Bit Manipulation extension 1 = 0 (1)
00:00:09.528902 HLE - Hardware Lock Elision = 0 (0)
00:00:09.528904 AVX2 - Advanced Vector Extensions 2 = 1 (1)
00:00:09.528905 FDP_EXCPTN_ONLY - FPU DP only updated on exceptions = 0 (0)
00:00:09.528906 SMEP - Supervisor Mode Execution Prevention = 0 (1)
00:00:09.528908 BMI2 - Advanced Bit Manipulation extension 2 = 0 (1)
00:00:09.528909 ERMS - Enhanced REP MOVSB/STOSB instructions = 0 (0)
00:00:09.528910 INVPCID - INVPCID instruction = 0 (0)
00:00:09.528912 RTM - Restricted Transactional Memory = 0 (0)
00:00:09.528913 PQM - Platform Quality of Service Monitoring = 0 (0)
00:00:09.528914 DEPFPU_CS_DS - Deprecates FPU CS, FPU DS values if set = 0 (0)
00:00:09.528915 MPE - Intel Memory Protection Extensions = 0 (0)
00:00:09.528917 PQE - Platform Quality of Service Enforcement = 0 (0)
00:00:09.528918 AVX512F - AVX512 Foundation instructions = 0 (0)
00:00:09.528919 RDSEED - RDSEED instruction = 0 (0)
00:00:09.528921 ADX - ADCX/ADOX instructions = 0 (0)
00:00:09.528922 SMAP - Supervisor Mode Access Prevention = 0 (0)
00:00:09.528924 CLFLUSHOPT - CLFLUSHOPT (Cache Line Flush) instruction = 0 (0)
00:00:09.528925 INTEL_PT - Intel Processor Trace = 0 (0)
00:00:09.528926 AVX512PF - AVX512 Prefetch instructions = 0 (0)
00:00:09.528928 AVX512ER - AVX512 Exponential & Reciprocal instructions = 0 (0)
00:00:09.528929 AVX512CD - AVX512 Conflict Detection instructions = 0 (0)
00:00:09.528930 SHA - Secure Hash Algorithm extensions = 0 (0)
00:00:09.528931 PREFETCHWT1 - PREFETCHWT1 instruction = 0 (0)
00:00:09.528933 UMIP - User mode insturction prevention = 0 (0)
00:00:09.528934 PKU - Protection Key for Usermode pages = 0 (0)
00:00:09.528935 OSPKE - CR4.PKU mirror = 0 (0)
00:00:09.528937 MAWAU - Value used by BNDLDX & BNDSTX = 0x0 (0x0)
00:00:09.528938 RDPID - Read processor ID support = 0 (0)
00:00:09.528940 SGX_LC - Supports SGX Launch Configuration = 0 (0)
00:00:09.528941 Processor Extended State Enumeration (leaf 0xd):
00:00:09.528942 XSAVE area cur/max size by XCR0, guest: 0x0/0x0
00:00:09.528943 XSAVE area cur/max size by XCR0, host: 0x340/0x3c0
00:00:09.528945 Valid XCR0 bits, guest: 0x00000000`00000000
00:00:09.528946 Valid XCR0 bits, host: 0x40000000`00000007 ( x87 SSE YMM_Hi128 LWP )
00:00:09.528950 XSAVE features, guest:
00:00:09.528951 XSAVE features, host: XSAVEOPT
00:00:09.528952 XSAVE area cur size XCR0|XSS, guest: 0x0
00:00:09.528953 XSAVE area cur size XCR0|XSS, host: 0x0
00:00:09.528954 Valid IA32_XSS bits, guest: 0x00000000`00000000
00:00:09.528956 Valid IA32_XSS bits, host: 0x00000000`00000000
00:00:09.528957 State #2, host: off=0x0240, cb=0x0100 IA32_XSS-bit -- YMM_Hi128
00:00:09.528963 State #62, host: off=0x0340, cb=0x0080 IA32_XSS-bit -- LWP
00:00:09.528966 Raw Hypervisor CPUID Leaves
00:00:09.528967 Leaf/sub-leaf eax ebx ecx edx
00:00:09.528967 Gst: 40000000/0000 40000010 00000000 00000000 00000000
00:00:09.528969 Hst: 00000000 00000000 00000000 00000000
00:00:09.528970 Gst: 40000001/0000 00000000 00000000 00000000 00000000
00:00:09.528972 Hst: 00000000 00000000 00000000 00000000
00:00:09.528973 Gst: 40000002/0000 00000000 00000000 00000000 00000000
00:00:09.528974 Hst: 00000000 00000000 00000000 00000000
00:00:09.528975 Gst: 40000003/0000 00000000 00000000 00000000 00000000
00:00:09.528976 Hst: 00000000 00000000 00000000 00000000
00:00:09.528977 Gst: 40000004/0000 00000000 00000000 00000000 00000000
00:00:09.528978 Hst: 00000000 00000000 00000000 00000000
00:00:09.528980 Gst: 40000005/0000 00000000 00000000 00000000 00000000
00:00:09.528981 Hst: 00000000 00000000 00000000 00000000
00:00:09.528982 Gst: 40000006/0000 00000000 00000000 00000000 00000000
00:00:09.528983 Hst: 00000000 00000000 00000000 00000000
00:00:09.528984 Gst: 40000007/0000 00000000 00000000 00000000 00000000
00:00:09.528985 Hst: 00000000 00000000 00000000 00000000
00:00:09.528986 Gst: 40000008/0000 00000000 00000000 00000000 00000000
00:00:09.528987 Hst: 00000000 00000000 00000000 00000000
00:00:09.528988 Gst: 40000009/0000 00000000 00000000 00000000 00000000
00:00:09.528989 Hst: 00000000 00000000 00000000 00000000
00:00:09.528990 Gst: 4000000a/0000 00000000 00000000 00000000 00000000
00:00:09.528992 Hst: 00000000 00000000 00000000 00000000
00:00:09.528992 Gst: 4000000b/0000 00000000 00000000 00000000 00000000
00:00:09.528994 Hst: 00000000 00000000 00000000 00000000
00:00:09.528995 Gst: 4000000c/0000 00000000 00000000 00000000 00000000
00:00:09.528996 Hst: 00000000 00000000 00000000 00000000
00:00:09.528997 Gst: 4000000d/0000 00000000 00000000 00000000 00000000
00:00:09.528998 Hst: 00000000 00000000 00000000 00000000
00:00:09.528999 Gst: 4000000e/0000 00000000 00000000 00000000 00000000
00:00:09.529000 Hst: 00000000 00000000 00000000 00000000
00:00:09.529001 Gst: 4000000f/0000 00000000 00000000 00000000 00000000
00:00:09.529002 Hst: 00000000 00000000 00000000 00000000
00:00:09.529003 Gst: 40000010/0000 00291f17 000f4240 00000000 00000000
00:00:09.529005 Hst: 00000000 00000000 00000000 00000000
00:00:09.529006 Raw Extended CPUID Leaves
00:00:09.529006 Leaf/sub-leaf eax ebx ecx edx
00:00:09.529007 Gst: 80000000/0000 8000001e 68747541 444d4163 69746e65
00:00:09.529009 Hst: 8000001e 68747541 444d4163 69746e65
00:00:09.529010 Gst: 80000001/0000 00660f51 00000000 000001f3 2bd3fb7f
00:00:09.529012 Hst: 00660f51 00000000 2fabbfff 2fd3fbff
00:00:09.529013 Gst: 80000002/0000 20444d41 392d5846 50303038 44415220
00:00:09.529015 Hst: 20444d41 392d5846 50303038 44415220
00:00:09.529016 Gst: 80000003/0000 204e4f45 202c3752 43203231 55504d4f
00:00:09.529018 Hst: 204e4f45 202c3752 43203231 55504d4f
00:00:09.529019 Gst: 80000004/0000 43204554 5345524f 2b433420 00204738
00:00:09.529021 Hst: 43204554 5345524f 2b433420 00204738
00:00:09.529022 Gst: 80000005/0000 ff40ff18 ff40ff30 20080140 60030140
00:00:09.529024 Hst: ff40ff18 ff40ff30 20080140 60030140
00:00:09.529026 Gst: 80000006/0000 64006400 64004200 04008140 00000000
00:00:09.529027 Hst: 64006400 64004200 04008140 00000000
00:00:09.529029 Gst: 80000007/0000 00000000 00000000 00000000 00000000
00:00:09.529030 Hst: 00000000 00000005 00000400 000037d9
00:00:09.529031 Gst: 80000008/0000 00003030 00000000 00000003 00000000
00:00:09.529032 Hst: 00003030 00000000 00004003 00000000
00:00:09.529034 Gst: 80000009/0000 00000000 00000000 00000000 00000000
00:00:09.529035 Hst: 00000000 00000000 00000000 00000000
00:00:09.529036 Gst: 8000000a/0000 00000000 00000000 00000000 00000000
00:00:09.529037 Hst: 00000001 00008000 00000000 0001bcff
00:00:09.529038 Gst: 8000000b/0000 00000000 00000000 00000000 00000000
00:00:09.529040 Hst: 00000000 00000000 00000000 00000000
00:00:09.529041 Gst: 8000000c/0000 00000000 00000000 00000000 00000000
00:00:09.529042 Hst: 00000000 00000000 00000000 00000000
00:00:09.529043 Gst: 8000000d/0000 00000000 00000000 00000000 00000000
00:00:09.529044 Hst: 00000000 00000000 00000000 00000000
00:00:09.529045 Gst: 8000000e/0000 00000000 00000000 00000000 00000000
00:00:09.529046 Hst: 00000000 00000000 00000000 00000000
00:00:09.529047 Gst: 8000000f/0000 00000000 00000000 00000000 00000000
00:00:09.529048 Hst: 00000000 00000000 00000000 00000000
00:00:09.529049 Gst: 80000010/0000 00000000 00000000 00000000 00000000
00:00:09.529050 Hst: 00000000 00000000 00000000 00000000
00:00:09.529051 Gst: 80000011/0000 00000000 00000000 00000000 00000000
00:00:09.529052 Hst: 00000000 00000000 00000000 00000000
00:00:09.529053 Gst: 80000012/0000 00000000 00000000 00000000 00000000
00:00:09.529054 Hst: 00000000 00000000 00000000 00000000
00:00:09.529055 Gst: 80000013/0000 00000000 00000000 00000000 00000000
00:00:09.529056 Hst: 00000000 00000000 00000000 00000000
00:00:09.529057 Gst: 80000014/0000 00000000 00000000 00000000 00000000
00:00:09.529058 Hst: 00000000 00000000 00000000 00000000
00:00:09.529059 Gst: 80000015/0000 00000000 00000000 00000000 00000000
00:00:09.529060 Hst: 00000000 00000000 00000000 00000000
00:00:09.529061 Gst: 80000016/0000 00000000 00000000 00000000 00000000
00:00:09.529062 Hst: 00000000 00000000 00000000 00000000
00:00:09.529063 Gst: 80000017/0000 00000000 00000000 00000000 00000000
00:00:09.529065 Hst: 00000000 00000000 00000000 00000000
00:00:09.529066 Gst: 80000018/0000 00000000 00000000 00000000 00000000
00:00:09.529067 Hst: 00000000 00000000 00000000 00000000
00:00:09.529068 Gst: 80000019/0000 f040f018 64006400 00000000 00000000
00:00:09.529069 Hst: f040f018 64006400 00000000 00000000
00:00:09.529071 Gst: 8000001a/0000 00000003 00000000 00000000 00000000
00:00:09.529072 Hst: 00000003 00000000 00000000 00000000
00:00:09.529073 Gst: 8000001b/0000 00000000 00000000 00000000 00000000
00:00:09.529074 Hst: 000007ff 00000000 00000000 00000000
00:00:09.529075 Gst: 8000001c/0000 00000000 00000000 00000000 00000000
00:00:09.529076 Hst: 00000000 80032013 00010200 e000000f
00:00:09.529078 Gst: 8000001d/0000 00000121 01c0003f 0000003f 00000000
00:00:09.529079 Hst: 00000121 01c0003f 0000003f 00000000
00:00:09.529080 Gst: 8000001d/0001 00004122 0080003f 000001ff 00000000
00:00:09.529082 Hst: 00004122 0080003f 000001ff 00000000
00:00:09.529083 Gst: 8000001d/0002 00004143 03c0003f 000003ff 00000001
00:00:09.529085 Hst: 00004143 03c0003f 000003ff 00000001
00:00:09.529086 Gst: 8000001d/0003 00000000 00000000 00000000 00000000
00:00:09.529087 Hst: 00000000 00000000 00000000 00000000
00:00:09.529088 Gst: 8000001e/0000 00000000 00000300 00000000 00000000
00:00:09.529090 Hst: 00000010 00000100 00000000 00000000
00:00:09.529091 Ext Name: AuthenticAMD
00:00:09.529092 Ext Supports: 0x80000000-0x8000001e
00:00:09.529093 Family: 15 Extended: 6 Effective: 21
00:00:09.529094 Model: 5 Extended: 6 Effective: 101
00:00:09.529095 Stepping: 1
00:00:09.529096 Brand ID: 0x000
00:00:09.529096 Ext Features
00:00:09.529097 Mnemonic - Description = guest (host)
00:00:09.529098 FPU - x87 FPU on Chip = 1 (1)
00:00:09.529100 VME - Virtual 8086 Mode Enhancements = 1 (1)
00:00:09.529101 DE - Debugging extensions = 1 (1)
00:00:09.529103 PSE - Page Size Extension = 1 (1)
00:00:09.529105 TSC - Time Stamp Counter = 1 (1)
00:00:09.529106 MSR - K86 Model Specific Registers = 1 (1)
00:00:09.529108 PAE - Physical Address Extension = 1 (1)
00:00:09.529109 MCE - Machine Check Exception = 0 (1)
00:00:09.529110 CX8 - CMPXCHG8B instruction = 1 (1)
00:00:09.529112 APIC - APIC On-Chip = 1 (1)
00:00:09.529113 SEP - SYSCALL/SYSRET = 1 (1)
00:00:09.529115 MTRR - Memory Type Range Registers = 1 (1)
00:00:09.529116 PGE - PTE Global Bit = 1 (1)
00:00:09.529118 MCA - Machine Check Architecture = 1 (1)
00:00:09.529119 CMOV - Conditional Move instructions = 1 (1)
00:00:09.529120 PAT - Page Attribute Table = 1 (1)
00:00:09.529122 PSE-36 - 36-bit Page Size Extension = 1 (1)
00:00:09.529123 NX - No-Execute/Execute-Disable = 1 (1)
00:00:09.529125 AXMMX - AMD Extensions to MMX instructions = 1 (1)
00:00:09.529126 MMX - Intel MMX Technology = 1 (1)
00:00:09.529127 FXSR - FXSAVE and FXRSTOR Instructions = 1 (1)
00:00:09.529129 FFXSR - AMD fast FXSAVE and FXRSTOR instructions = 1 (1)
00:00:09.529130 Page1GB - 1 GB large page = 0 (1)
00:00:09.529131 RDTSCP - RDTSCP instruction = 1 (1)
00:00:09.529133 LM - AMD64 Long Mode = 1 (1)
00:00:09.529134 3DNOWEXT - AMD Extensions to 3DNow = 0 (0)
00:00:09.529136 3DNOW - AMD 3DNow = 0 (0)
00:00:09.529137 LahfSahf - LAHF/SAHF support in 64-bit mode = 1 (1)
00:00:09.529139 CmpLegacy - Core multi-processing legacy mode = 1 (1)
00:00:09.529140 SVM - AMD Secure Virtual Machine extensions = 0 (1)
00:00:09.529141 EXTAPIC - AMD Extended APIC registers = 0 (1)
00:00:09.529143 CR8L - AMD LOCK MOV CR0 means MOV CR8 = 1 (1)
00:00:09.529144 ABM - AMD Advanced Bit Manipulation = 1 (1)
00:00:09.529145 SSE4A - SSE4A instructions = 1 (1)
00:00:09.529147 MISALIGNSSE - AMD Misaligned SSE mode = 1 (1)
00:00:09.529148 3DNOWPRF - AMD PREFETCH and PREFETCHW instructions = 1 (1)
00:00:09.529149 OSVW - AMD OS Visible Workaround = 0 (1)
00:00:09.529151 IBS - Instruct Based Sampling = 0 (1)
00:00:09.529152 XOP - Extended Operation support = 0 (1)
00:00:09.529153 SKINIT - SKINIT, STGI, and DEV support = 0 (1)
00:00:09.529155 WDT - AMD Watchdog Timer support = 0 (1)
00:00:09.529156 LWP - Lightweight Profiling support = 0 (1)
00:00:09.529157 FMA4 - Four operand FMA instruction support = 0 (1)
00:00:09.529159 17 - Reserved = 0 (1)
00:00:09.529160 NodeId - NodeId in MSR C001_100C = 0 (1)
00:00:09.529162 TBM - Trailing Bit Manipulation instructions = 0 (1)
00:00:09.529163 TOPOEXT - Topology Extensions = 0 (0)
00:00:09.529164 23 - Reserved = 0 (1)
00:00:09.529166 24 - Reserved = 0 (1)
00:00:09.529168 25 - Reserved = 0 (1)
00:00:09.529169 26 - Reserved = 0 (1)
00:00:09.529171 27 - Reserved = 0 (1)
00:00:09.529172 29 - Reserved = 0 (1)
00:00:09.529175 Full Name: "AMD FX-9800P RADEON R7, 12 COMPUTE CORES 4C+8G "
00:00:09.529176 TLB 2/4M Instr/Uni: fully 24 entries
00:00:09.529177 TLB 2/4M Data: fully 64 entries
00:00:09.529178 TLB 4K Instr/Uni: fully 48 entries
00:00:09.529179 TLB 4K Data: fully 64 entries
00:00:09.529180 L1 Instr Cache Line Size: 64 bytes
00:00:09.529180 L1 Instr Cache Lines Per Tag: 1
00:00:09.529181 L1 Instr Cache Associativity: 3 way
00:00:09.529182 L1 Instr Cache Size: 96 KB
00:00:09.529183 L1 Data Cache Line Size: 64 bytes
00:00:09.529183 L1 Data Cache Lines Per Tag: 1
00:00:09.529184 L1 Data Cache Associativity: 8 way
00:00:09.529184 L1 Data Cache Size: 32 KB
00:00:09.529185 L2 TLB 2/4M Instr/Uni: 8 way 1024 entries
00:00:09.529186 L2 TLB 2/4M Data: 8 way 1024 entries
00:00:09.529187 L2 TLB 4K Instr/Uni: 4 way 512 entries
00:00:09.529188 L2 TLB 4K Data: 8 way 1024 entries
00:00:09.529189 L2 Cache Line Size: 0 bytes
00:00:09.529190 L2 Cache Lines Per Tag: 0
00:00:09.529190 L2 Cache Associativity: off
00:00:09.529315 L2 Cache Size: 0 KB
00:00:09.529317 APM Features:
00:00:09.529319 Host Invariant-TSC support: true
00:00:09.529320 Physical Address Width: 48 bits
00:00:09.529321 Virtual Address Width: 48 bits
00:00:09.529322 Guest Physical Address Width: 0 bits
00:00:09.529322 Physical Core Count: 4
00:00:09.529323 !!
00:00:09.529324 !! {handlers, phys virt hyper stats}
00:00:09.529325 !!
00:00:09.529328 Physical handlers: (PhysHandlers=-22136 (0xffffa988))
00:00:09.529329 From - To (incl) HandlerHC UserHC HandlerGC UserGC Type Description
00:00:09.529334 00000000000a0000 - 00000000000bffff 00007fff77615f50 0000000006e16b50 00000000 fd84cb50 MMIO VGA - VGA Video Buffer
00:00:09.529339 00000000000c0000 - 00000000000c8fff 00007fff77631fd0 0000000006e16d30 00000000 fd84cd30 Write VGA BIOS
00:00:09.529342 00000000000c9000 - 00000000000dffff 00007fff77615f50 0000000006e80a70 00000000 fd8b6a70 MMIO PC Arch Reserved #0
00:00:09.529345 00000000000e0000 - 00000000000e0fff 00007fff77631fd0 0000000006e7fa80 00000000 fd8b5a80 Write ACPI RSDP
00:00:09.529349 00000000000e1000 - 00000000000e1fff 00007fff77631fd0 0000000006e10e60 00000000 fd846e60 Write DMI tables
00:00:09.529351 00000000000e2000 - 00000000000effff 00007fff77615f50 0000000006e80b90 00000000 fd8b6b90 MMIO PC Arch Reserved #1
00:00:09.529355 00000000dc000000 - 00000000dfffffff 00007fff77615f50 0000000006e24130 00000000 fd85a130 MMIO MCFG ranges
00:00:09.529358 00000000e0000000 - 00000000e7ffffff 00007fff6368a050 000000000ba70100 00000000 fe8c3100 Write VGA LFB
00:00:09.529361 00000000e8400000 - 00000000e841ffff 00007fff77615f50 0000000006e81370 00000000 fd8b7370 MMIO E1000
00:00:09.529364 00000000e8424000 - 00000000e8427fff 00007fff77615f50 0000000006e81180 00000000 fd8b7180 MMIO HDA
00:00:09.529366 00000000e8428000 - 00000000e8429fff 00007fff77615f50 0000000006e80ef0 00000000 fd8b6ef0 MMIO AHCI
00:00:09.529369 00000000e842a000 - 00000000e842afff 00007fff77615f50 0000000006e817e0 00000000 fd8b77e0 MMIO USB OHCI
00:00:09.529372 00000000fec00000 - 00000000fec00fff 00007fff77615f50 0000000006e11c40 00000000 fd847c40 MMIO I/O APIC
00:00:09.529375 00000000fed00000 - 00000000fed00fff 00007fff77615f50 0000000006e12370 00000000 fd848370 MMIO HPET Memory
00:00:09.529378 00000000fed1c000 - 00000000fed1ffff 00007fff77615f50 0000000006e803a0 00000000 fd8b63a0 MMIO LPC Memory
00:00:09.529381 00000000fee00000 - 00000000fee00fff 00007fff77615f50 0000000006e11140 00000000 fd847140 MMIO APIC
00:00:09.529383 00000000ffe00000 - 00000000ffe7ffff 00007fff77631fd0 0000000006e1bdb0 00000000 fd851db0 Write EFI Firmware Volume
00:00:09.529386 00000000ffe80000 - 00000000ffefffff 00007fff77631fd0 0000000006e1daa0 00000000 fd853aa0 Write EFI Firmware Volume (Part 2)
00:00:09.529389 00000000fff00000 - 00000000fff7ffff 00007fff77631fd0 0000000006e1f790 00000000 fd855790 Write EFI Firmware Volume (Part 3)
00:00:09.529391 00000000fff80000 - 00000000ffffffff 00007fff77631fd0 0000000006e21480 00000000 fd857480 Write EFI Firmware Volume (Part 4)
00:00:09.529394 Virtual handlers:
00:00:09.529394 From - To (excl) HandlerHC HandlerGC Type Description
00:00:09.529396 Hypervisor Virtual handlers:
00:00:09.529397 From - To (excl) HandlerHC HandlerGC Type Description
00:00:09.529398 !!
00:00:09.529399 !! {timers, <NULL>}
00:00:09.529399 !!
00:00:09.529409 Timers (pVM=0000000001b00000)
00:00:09.529410 pTimerR3 offNext offPrev offSched Clock Time Expire HzHint State Description
00:00:09.529414 0000000006e809f0 00000000 00000000 00000000 Real 923717211 923713511 0 1-STOPPED EMT Yielder
00:00:09.529419 0000000006e80970 00000000 fff965f0 00000000 Real 923717211 923717858 0 2-ACTIVE CPU Load Timer
00:00:09.529423 0000000006e80610 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED USB Device Reset Timer
00:00:09.529427 0000000006e80590 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED USB Device Reset Timer
00:00:09.529430 0000000006e800b0 00000000 fff92da0 00000000 VrSy 5274283056 599932015941 0 2-ACTIVE ACPI PM Timer
00:00:09.529433 0000000006e7e380 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED USB Frame Timer
00:00:09.529436 0000000006e7c9f0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529439 0000000006e7c970 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529442 0000000006e7c8f0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529444 0000000006e7c870 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529447 0000000006e7c7f0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529449 0000000006e7c770 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529452 0000000006e7c6f0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529455 0000000006e7c670 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED
00:00:09.529457 0000000006e79d70 00000000 00000000 00000000 Virt 5274441598 3000000000 0 1-STOPPED E1000 Link Up Timer
00:00:09.529460 0000000006e17370 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED E1000 Late Interrupt Timer
00:00:09.529463 0000000006e170a0 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED AHCI CCC Timer
00:00:09.529466 0000000006e16f60 00069a10 00000000 00000000 Real 923717211 923717167 0 2-ACTIVE VGA Refresh Timer
00:00:09.529469 0000000006e16340 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED Heartbeat flatlined
00:00:09.529473 0000000006e12ed0 00000000 00000000 00000000 VrSy 5274283056 4990244140 0 1-STOPPED MC146818 RTC/CMOS - Second2
00:00:09.529476 0000000006e12e50 0006d260 fffffa20 00000000 VrSy 5274283056 5990000000 0 2-ACTIVE MC146818 RTC/CMOS - Second
00:00:09.529479 0000000006e12dd0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED MC146818 RTC/CMOS - Periodic
00:00:09.529482 0000000006e12870 000005e0 00000000 00000000 VrSy 5274283056 5277196060 99 2-ACTIVE i8254 Programmable Interval Timer
00:00:09.529485 0000000006e122f0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED HPET Timer
00:00:09.529488 0000000006e12270 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED HPET Timer
00:00:09.529490 0000000006e121f0 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED HPET Timer
00:00:09.529493 0000000006e12170 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED HPET Timer
00:00:09.529496 0000000006e11480 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED APIC Timer 3
00:00:09.529499 0000000006e11400 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED APIC Timer 2
00:00:09.529502 0000000006e11380 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED APIC Timer 1
00:00:09.529505 0000000006e11300 00000000 00000000 00000000 VrSy 5274283056 0 0 1-STOPPED APIC Timer 0
00:00:09.529508 0000000006e64ae0 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED PS2M Delay Timer
00:00:09.529511 0000000006e64a60 00000000 00000000 00000000 Real 923717211 0 0 1-STOPPED PS2M Throttle Timer
00:00:09.529514 0000000006e649e0 00000000 00000000 00000000 Virt 5274441598 1284330576 0 1-STOPPED PS2K Delay Timer
00:00:09.529517 0000000006e64960 00000000 00000000 00000000 Virt 5274441598 0 0 1-STOPPED PS2K Typematic Timer
00:00:09.529519 0000000006e648e0 00000000 00000000 00000000 Virt 5274441598 1285345833 0 1-STOPPED PS2K Throttle Timer
00:00:09.529522 0000000006e10320 00000000 00000000 00000000 Real 923717211 0 0 1-STOPPED BlkCache-Commit
00:00:09.529528 !!
00:00:09.529528 !! {activetimers, <NULL>}
00:00:09.529529 !!
00:00:09.529536 Active Timers (pVM=0000000001b00000)
00:00:09.529537 pTimerR3 offNext offPrev offSched Clock Time Expire HzHint State Description
00:00:09.529541 0000000006e16f60 00069a10 00000000 00000000 Real 923717211 923717167 0 2-ACTIVE VGA Refresh Timer
00:00:09.529545 0000000006e80970 00000000 fff965f0 00000000 Real 923717211 923717858 0 2-ACTIVE CPU Load Timer
00:00:09.529548 0000000006e12870 000005e0 00000000 00000000 VrSy 5274283056 5277196060 99 2-ACTIVE i8254 Programmable Interval Timer
00:00:09.529552 0000000006e12e50 0006d260 fffffa20 00000000 VrSy 5274283056 5990000000 0 2-ACTIVE MC146818 RTC/CMOS - Second
00:00:09.529555 0000000006e800b0 00000000 fff92da0 00000000 VrSy 5274283056 599932015941 0 2-ACTIVE ACPI PM Timer
00:00:09.529563 !!
00:00:09.529563 !! {acpi}
00:00:09.529563 !!
00:00:09.529564 timer: old=00000000, current=00000000
00:00:09.529567 !!
00:00:09.529567 !! {ahci0}
00:00:09.529568 !!
00:00:09.529569 ahci#0: mmio=00000000e8428000 ports=2 GC=true R0=true
00:00:09.529572 HbaCap=0xc8241f81
00:00:09.529572 HbaCtrl=0x80000000
00:00:09.529573 HbaIs=0x0
00:00:09.529574 HbaPi=0x3
00:00:09.529574 HbaVs=0x10100
00:00:09.529575 HbaCccCtl=0x0
00:00:09.529576 HbaCccPorts=0x0
00:00:09.529576 PortsInterrupted=0x0
00:00:09.529577 Port 0: device-attached=true
00:00:09.529578 PortClb=0xdb750000
00:00:09.529579 PortClbU=0x0
00:00:09.529579 PortFb=0xdb751000
00:00:09.529580 PortFbU=0x0
00:00:09.529581 PortIs=0x1
00:00:09.529581 PortIe=0x0
00:00:09.529582 PortCmd=0x110006
00:00:09.529582 PortTfd=0x50
00:00:09.529583 PortSig=0x101
00:00:09.529584 PortSSts=0x123
00:00:09.529584 PortSCtl=0x300
00:00:09.529585 PortSErr=0x0
00:00:09.529585 PortSAct=0x0
00:00:09.529586 PortCi=0x0
00:00:09.529586 PortPhysClb=00000000db750000
00:00:09.529587 PortPhysFb=00000000db751000
00:00:09.529588 PortActTasksActive=0
00:00:09.529589 PortPoweredOn=true
00:00:09.529590 PortSpunUp=true
00:00:09.529590 PortFirstD2HFisSent=true
00:00:09.529591 PortATAPI=false
00:00:09.529592 PortTasksFinished=0x1
00:00:09.529592 PortQueuedTasksFinished=0x0
00:00:09.529593 PortTasksNew=0x0
00:00:09.529594
00:00:09.529594 Port 1: device-attached=true
00:00:09.529595 PortClb=0xdb750000
00:00:09.529596 PortClbU=0x0
00:00:09.529596 PortFb=0xdb751100
00:00:09.529597 PortFbU=0x0
00:00:09.529598 PortIs=0x1
00:00:09.529598 PortIe=0x0
00:00:09.529599 PortCmd=0x3110006
00:00:09.529599 PortTfd=0x50
00:00:09.529600 PortSig=0xeb140101
00:00:09.529601 PortSSts=0x123
00:00:09.529601 PortSCtl=0x300
00:00:09.529602 PortSErr=0x0
00:00:09.529602 PortSAct=0x0
00:00:09.529603 PortCi=0x0
00:00:09.529603 PortPhysClb=00000000db750000
00:00:09.529604 PortPhysFb=00000000db751100
00:00:09.529605 PortActTasksActive=0
00:00:09.529606 PortPoweredOn=true
00:00:09.529607 PortSpunUp=true
00:00:09.529607 PortFirstD2HFisSent=true
00:00:09.529608 PortATAPI=true
00:00:09.529608 PortTasksFinished=0x1
00:00:09.529609 PortQueuedTasksFinished=0x0
00:00:09.529610 PortTasksNew=0x0
00:00:09.529610
00:00:09.529611 !!
00:00:09.529611 !! {apic}
00:00:09.529612 !!
00:00:09.529618 APIC0:
00:00:09.529619 APIC Base MSR = 0xfee00900 (Addr=0xfee00000)
00:00:09.529620 Mode = 2 (xAPIC)
00:00:09.529622 APIC ID = 0 (0x0)
00:00:09.529623 Version = 0x50014
00:00:09.529624 APIC Version = 0x14
00:00:09.529624 Max LVT entry index (0..N) = 5
00:00:09.529625 EOI Broadcast supression = false
00:00:09.529626 APR = 0 (0x0)
00:00:09.529627 TPR = 0 (0x0)
00:00:09.529627 Task-priority class = 0x0
00:00:09.529628 Task-priority subclass = 0x0
00:00:09.529629 PPR = 0 (0x0)
00:00:09.529629 Processor-priority class = 0x0
00:00:09.529630 Processor-priority subclass = 0x0
00:00:09.529631 RRD = 0 (0x0)
00:00:09.529631 LDR = 0x0
00:00:09.529632 Logical APIC ID = 0x0
00:00:09.529633 DFR = 0xffffffff
00:00:09.529634 Model = 0xf (Flat)
00:00:09.529634 SVR = 0x10f
00:00:09.529635 Vector = 15 (0xf)
00:00:09.529636 Software Enabled = true
00:00:09.529637 Supress EOI broadcast = false
00:00:09.529637 ISR
00:00:09.529638 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529641 Pending: None
00:00:09.529641 TMR
00:00:09.529642 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529644 Pending: None
00:00:09.529645 IRR
00:00:09.529645 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529648 Pending: None
00:00:09.529649 PIB
00:00:09.529649 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529652 Pending: None
00:00:09.529652 Level PIB
00:00:09.529653 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529655 Pending: None
00:00:09.529656 ESR Internal = 0x0
00:00:09.529656 ESR = 0x0
00:00:09.529657 Redirectable IPI = false
00:00:09.529658 Send Illegal Vector = false
00:00:09.529658 Recv Illegal Vector = false
00:00:09.529659 Illegal Register Address = false
00:00:09.529660 ICR Low = 0x0
00:00:09.529660 Vector = 0 (0x0)
00:00:09.529661 Delivery Mode = 0x0 (Fixed)
00:00:09.529662 Destination Mode = 0x0 (Physical)
00:00:09.529663 Delivery Status = 0
00:00:09.529664 Level = 0
00:00:09.529664 Trigger Mode = 0 (Edge)
00:00:09.529665 Destination shorthand = 0x0 (None)
00:00:09.529666 ICR High = 0x0
00:00:09.529667 Destination field/mask = 0x0
00:00:09.529677 APIC1:
00:00:09.529682 APIC Base MSR = 0xfee00800 (Addr=0xfee00000)
00:00:09.529686 Mode = 2 (xAPIC)
00:00:09.529688 APIC ID = 1 (0x1)
00:00:09.529689 Version = 0x50014
00:00:09.529690 APIC Version = 0x14
00:00:09.529691 Max LVT entry index (0..N) = 5
00:00:09.529692 EOI Broadcast supression = false
00:00:09.529693 APR = 0 (0x0)
00:00:09.529694 TPR = 0 (0x0)
00:00:09.529695 Task-priority class = 0x0
00:00:09.529695 Task-priority subclass = 0x0
00:00:09.529696 PPR = 0 (0x0)
00:00:09.529697 Processor-priority class = 0x0
00:00:09.529698 Processor-priority subclass = 0x0
00:00:09.529698 RRD = 0 (0x0)
00:00:09.529699 LDR = 0x0
00:00:09.529700 Logical APIC ID = 0x0
00:00:09.529700 DFR = 0xffffffff
00:00:09.529701 Model = 0xf (Flat)
00:00:09.529702 SVR = 0xff
00:00:09.529703 Vector = 255 (0xff)
00:00:09.529704 Software Enabled = false
00:00:09.529705 Supress EOI broadcast = false
00:00:09.529705 ISR
00:00:09.529707 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529709 Pending: None
00:00:09.529710 TMR
00:00:09.529711 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529713 Pending: None
00:00:09.529714 IRR
00:00:09.529714 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529716 Pending: None
00:00:09.529717 PIB
00:00:09.529718 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529720 Pending: None
00:00:09.529721 Level PIB
00:00:09.529721 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529723 Pending: None
00:00:09.529724 ESR Internal = 0x0
00:00:09.529725 ESR = 0x0
00:00:09.529725 Redirectable IPI = false
00:00:09.529726 Send Illegal Vector = false
00:00:09.529727 Recv Illegal Vector = false
00:00:09.529728 Illegal Register Address = false
00:00:09.529728 ICR Low = 0x0
00:00:09.529729 Vector = 0 (0x0)
00:00:09.529730 Delivery Mode = 0x0 (Fixed)
00:00:09.529731 Destination Mode = 0x0 (Physical)
00:00:09.529732 Delivery Status = 0
00:00:09.529733 Level = 0
00:00:09.529733 Trigger Mode = 0 (Edge)
00:00:09.529734 Destination shorthand = 0x0 (None)
00:00:09.529735 ICR High = 0x0
00:00:09.529736 Destination field/mask = 0x0
00:00:09.529750 APIC2:
00:00:09.529752 APIC Base MSR = 0xfee00800 (Addr=0xfee00000)
00:00:09.529754 Mode = 2 (xAPIC)
00:00:09.529755 APIC ID = 2 (0x2)
00:00:09.529756 Version = 0x50014
00:00:09.529757 APIC Version = 0x14
00:00:09.529758 Max LVT entry index (0..N) = 5
00:00:09.529758 EOI Broadcast supression = false
00:00:09.529759 APR = 0 (0x0)
00:00:09.529760 TPR = 0 (0x0)
00:00:09.529761 Task-priority class = 0x0
00:00:09.529761 Task-priority subclass = 0x0
00:00:09.529762 PPR = 0 (0x0)
00:00:09.529763 Processor-priority class = 0x0
00:00:09.529764 Processor-priority subclass = 0x0
00:00:09.529764 RRD = 0 (0x0)
00:00:09.529765 LDR = 0x0
00:00:09.529766 Logical APIC ID = 0x0
00:00:09.529766 DFR = 0xffffffff
00:00:09.529767 Model = 0xf (Flat)
00:00:09.529768 SVR = 0xff
00:00:09.529769 Vector = 255 (0xff)
00:00:09.529770 Software Enabled = false
00:00:09.529771 Supress EOI broadcast = false
00:00:09.529772 ISR
00:00:09.529772 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529775 Pending: None
00:00:09.529776 TMR
00:00:09.529776 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529779 Pending: None
00:00:09.529779 IRR
00:00:09.529780 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529782 Pending: None
00:00:09.529783 PIB
00:00:09.529784 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529786 Pending: None
00:00:09.529787 Level PIB
00:00:09.529788 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529790 Pending: None
00:00:09.529791 ESR Internal = 0x0
00:00:09.529792 ESR = 0x0
00:00:09.529792 Redirectable IPI = false
00:00:09.529793 Send Illegal Vector = false
00:00:09.529794 Recv Illegal Vector = false
00:00:09.529795 Illegal Register Address = false
00:00:09.529795 ICR Low = 0x0
00:00:09.529796 Vector = 0 (0x0)
00:00:09.529797 Delivery Mode = 0x0 (Fixed)
00:00:09.529798 Destination Mode = 0x0 (Physical)
00:00:09.529799 Delivery Status = 0
00:00:09.529800 Level = 0
00:00:09.529801 Trigger Mode = 0 (Edge)
00:00:09.529801 Destination shorthand = 0x0 (None)
00:00:09.529802 ICR High = 0x0
00:00:09.529803 Destination field/mask = 0x0
00:00:09.529815 APIC3:
00:00:09.529816 APIC Base MSR = 0xfee00800 (Addr=0xfee00000)
00:00:09.529818 Mode = 2 (xAPIC)
00:00:09.529819 APIC ID = 3 (0x3)
00:00:09.529820 Version = 0x50014
00:00:09.529821 APIC Version = 0x14
00:00:09.529822 Max LVT entry index (0..N) = 5
00:00:09.529822 EOI Broadcast supression = false
00:00:09.529823 APR = 0 (0x0)
00:00:09.529824 TPR = 0 (0x0)
00:00:09.529825 Task-priority class = 0x0
00:00:09.529826 Task-priority subclass = 0x0
00:00:09.529826 PPR = 0 (0x0)
00:00:09.529827 Processor-priority class = 0x0
00:00:09.529828 Processor-priority subclass = 0x0
00:00:09.529829 RRD = 0 (0x0)
00:00:09.529829 LDR = 0x0
00:00:09.529830 Logical APIC ID = 0x0
00:00:09.529831 DFR = 0xffffffff
00:00:09.529831 Model = 0xf (Flat)
00:00:09.529832 SVR = 0xff
00:00:09.529833 Vector = 255 (0xff)
00:00:09.529834 Software Enabled = false
00:00:09.529835 Supress EOI broadcast = false
00:00:09.529835 ISR
00:00:09.529836 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529838 Pending: None
00:00:09.529839 TMR
00:00:09.529839 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529841 Pending: None
00:00:09.529842 IRR
00:00:09.529842 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529844 Pending: None
00:00:09.529845 PIB
00:00:09.529846 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529848 Pending: None
00:00:09.529849 Level PIB
00:00:09.529849 0000000000000000000000000000000000000000000000000000000000000000
00:00:09.529851 Pending: None
00:00:09.529852 ESR Internal = 0x0
00:00:09.529853 ESR = 0x0
00:00:09.529853 Redirectable IPI = false
00:00:09.529854 Send Illegal Vector = false
00:00:09.529855 Recv Illegal Vector = false
00:00:09.529856 Illegal Register Address = false
00:00:09.529856 ICR Low = 0x0
00:00:09.529857 Vector = 0 (0x0)
00:00:09.529858 Delivery Mode = 0x0 (Fixed)
00:00:09.529859 Destination Mode = 0x0 (Physical)
00:00:09.529859 Delivery Status = 0
00:00:09.529860 Level = 0
00:00:09.529861 Trigger Mode = 0 (Edge)
00:00:09.529861 Destination shorthand = 0x0 (None)
00:00:09.529862 ICR High = 0x0
00:00:09.529863 Destination field/mask = 0x0
00:00:09.529875 !!
00:00:09.529876 !! {apiclvt}
00:00:09.529876 !!
00:00:09.529882 VCPU[0] APIC Local Vector Table (LVT):
00:00:09.529884 lvt timermode mask trigger rirr polarity dlvr_st dlvr_mode vector
00:00:09.529885 Timer One-shot 1 Idle 0 (0x0)
00:00:09.529887 Thermal 1 Idle Fixed 0 (0x0)
00:00:09.529889 Perf 1 Idle Fixed 0 (0x0)
00:00:09.529891 LINT0 0 Edge 0 ActiveHi Idle ExtINT 0 (0x0)
00:00:09.529893 LINT1 0 Edge 0 ActiveHi Idle NMI 0 (0x0)
00:00:09.529895 Error 1 Idle Fixed 0 (0x0)
00:00:09.529901 VCPU[1] APIC Local Vector Table (LVT):
00:00:09.529903 lvt timermode mask trigger rirr polarity dlvr_st dlvr_mode vector
00:00:09.529903 Timer One-shot 1 Idle 0 (0x0)
00:00:09.529906 Thermal 1 Idle Fixed 0 (0x0)
00:00:09.529909 Perf 1 Idle Fixed 0 (0x0)
00:00:09.529911 LINT0 1 Edge 0 ActiveHi Idle Fixed 0 (0x0)
00:00:09.529913 LINT1 1 Edge 0 ActiveHi Idle Fixed 0 (0x0)
00:00:09.529915 Error 1 Idle Fixed 0 (0x0)
00:00:09.529927 VCPU[2] APIC Local Vector Table (LVT):
00:00:09.529928 lvt timermode mask trigger rirr polarity dlvr_st dlvr_mode vector
00:00:09.529929 Timer One-shot 1 Idle 0 (0x0)
00:00:09.529931 Thermal 1 Idle Fixed 0 (0x0)
00:00:09.529933 Perf 1 Idle Fixed 0 (0x0)
00:00:09.529935 LINT0 1 Edge 0 ActiveHi Idle Fixed 0 (0x0)
00:00:09.529937 LINT1 1 Edge 0 ActiveHi Idle Fixed 0 (0x0)
00:00:09.529939 Error 1 Idle Fixed 0 (0x0)
00:00:09.529949 VCPU[3] APIC Local Vector Table (LVT):
00:00:09.529951 lvt timermode mask trigger rirr polarity dlvr_st dlvr_mode vector
00:00:09.529951 Timer One-shot 1 Idle 0 (0x0)
00:00:09.529953 Thermal 1 Idle Fixed 0 (0x0)
00:00:09.529955 Perf 1 Idle Fixed 0 (0x0)
00:00:09.529957 LINT0 1 Edge 0 ActiveHi Idle Fixed 0 (0x0)
00:00:09.529959 LINT1 1 Edge 0 ActiveHi Idle Fixed 0 (0x0)
00:00:09.529961 Error 1 Idle Fixed 0 (0x0)
00:00:09.529974 !!
00:00:09.529974 !! {apictimer}
00:00:09.529976 !!
00:00:09.529980 VCPU[0] Local APIC timer:
00:00:09.529981 ICR = 0x0
00:00:09.529982 CCR = 0x0
00:00:09.529983 DCR = 0x0
00:00:09.529984 Timer shift = 0x1
00:00:09.529984 Timer initial TS = 0
00:00:09.529985 LVT Timer = 0x10000
00:00:09.529986 Vector = 0 (0x0)
00:00:09.529987 Delivery status = 0
00:00:09.529988 Masked = true
00:00:09.529988 Timer Mode = 0x0 (One-shot)
00:00:09.529993 VCPU[1] Local APIC timer:
00:00:09.529994 ICR = 0x0
00:00:09.529995 CCR = 0x0
00:00:09.529996 DCR = 0x0
00:00:09.529997 Timer shift = 0x1
00:00:09.529998 Timer initial TS = 0
00:00:09.529999 LVT Timer = 0x10000
00:00:09.530000 Vector = 0 (0x0)
00:00:09.530001 Delivery status = 0
00:00:09.530001 Masked = true
00:00:09.530002 Timer Mode = 0x0 (One-shot)
00:00:09.530012 VCPU[2] Local APIC timer:
00:00:09.530013 ICR = 0x0
00:00:09.530014 CCR = 0x0
00:00:09.530015 DCR = 0x0
00:00:09.530016 Timer shift = 0x1
00:00:09.530017 Timer initial TS = 0
00:00:09.530017 LVT Timer = 0x10000
00:00:09.530019 Vector = 0 (0x0)
00:00:09.530020 Delivery status = 0
00:00:09.530020 Masked = true
00:00:09.530021 Timer Mode = 0x0 (One-shot)
00:00:09.530029 VCPU[3] Local APIC timer:
00:00:09.530030 ICR = 0x0
00:00:09.530031 CCR = 0x0
00:00:09.530032 DCR = 0x0
00:00:09.530033 Timer shift = 0x1
00:00:09.530034 Timer initial TS = 0
00:00:09.530035 LVT Timer = 0x10000
00:00:09.530036 Vector = 0 (0x0)
00:00:09.530036 Delivery status = 0
00:00:09.530037 Masked = true
00:00:09.530038 Timer Mode = 0x0 (One-shot)
00:00:09.530049 !!
00:00:09.530050 !! {cfgm}
00:00:09.530051 !!
00:00:09.530052 pRoot=0000000004bbfc30:{/}
00:00:09.530054 [/] (level 0)
00:00:09.530057 CSAMEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530059 CpuExecutionCap <integer> = 0x0000000000000064 (100)
00:00:09.530061 EnablePAE <integer> = 0x0000000000000001 (1)
00:00:09.530063 HMEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530065 MemBalloonSize <integer> = 0x0000000000000000 (0)
00:00:09.530066 Name <string> = "mac OS Sierra" (cb=14)
00:00:09.530068 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:09.530069 PATMEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530071 PageFusionAllowed <integer> = 0x0000000000000000 (0)
00:00:09.530072 RamHoleSize <integer> = 0x0000000024000000 (603 979 776, 576 MB)
00:00:09.530074 RamSize <integer> = 0x0000000100000000 (4 294 967 296, 4 096 MB, 4.0 GB)
00:00:09.530077 RawR0Enabled <integer> = 0x0000000000000001 (1)
00:00:09.530079 RawR3Enabled <integer> = 0x0000000000000001 (1)
00:00:09.530080 TimerMillies <integer> = 0x000000000000000a (10)
00:00:09.530081 UUID <bytes> = "a2 1d d6 61 3b 6f 3f 47 83 e6 7e 1e cf 43 70 c4" (cb=16)
00:00:09.530085
00:00:09.530086 [/CPUM/] (level 1)
00:00:09.530088 GuestCpuName <string> = "host" (cb=5)
00:00:09.530090 MWaitExtensions <integer> = 0x0000000000000001 (1)
00:00:09.530091 PortableCpuIdLevel <integer> = 0x0000000000000000 (0)
00:00:09.530092 SpecCtrl <integer> = 0x0000000000000000 (0)
00:00:09.530094
00:00:09.530094 [/CPUM/HostCPUID/] (level 2)
00:00:09.530096
00:00:09.530097 [/CPUM/HostCPUID/1/] (level 3)
00:00:09.530099 eax <integer> = 0x00000000000106e5 (67 301)
00:00:09.530101 ebx <integer> = 0x0000000000100800 (1 050 624)
00:00:09.530102 ecx <integer> = 0x000000000098e3fd (10 019 837)
00:00:09.530104 edx <integer> = 0x00000000bfebfbff (3 219 913 727)
00:00:09.530105
00:00:09.530106 [/DBGC/] (level 1)
00:00:09.530108 GlobalInitScript <string> = "C:\Users\blust\.VirtualBox/dbgc-init" (cb=37)
00:00:09.530109 HistoryFile <string> = "C:\Users\blust\.VirtualBox/dbgc-history" (cb=40)
00:00:09.530111 LocalInitScript <string> = "C:\Users\blust\VirtualBox VMs\mac OS Sierra/dbgc-init" (cb=54)
00:00:09.530112
00:00:09.530112 [/DBGF/] (level 1)
00:00:09.530114 Path <string> = "C:\Users\blust\VirtualBox VMs\mac OS Sierra/debug/;C:\Users\blust\VirtualBox VMs\mac OS Sierra/;C:\Users\blust\" (cb=112)
00:00:09.530115
00:00:09.530116 [/Devices/] (level 1)
00:00:09.530117
00:00:09.530117 [/Devices/8237A/] (level 2)
00:00:09.530119
00:00:09.530119 [/Devices/8237A/0/] (level 3)
00:00:09.530121 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530122
00:00:09.530123 [/Devices/8237A/0/Config/] (level 4) (restricted root)
00:00:09.530125
00:00:09.530125 [/Devices/GIMDev/] (level 2)
00:00:09.530127
00:00:09.530127 [/Devices/GIMDev/0/] (level 3)
00:00:09.530129 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530130
00:00:09.530131 [/Devices/GIMDev/0/Config/] (level 4) (restricted root)
00:00:09.530133
00:00:09.530133 [/Devices/VMMDev/] (level 2)
00:00:09.530135
00:00:09.530135 [/Devices/VMMDev/0/] (level 3)
00:00:09.530137 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530139 PCIDeviceNo <integer> = 0x0000000000000004 (4)
00:00:09.530140 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:09.530141 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530142
00:00:09.530142 [/Devices/VMMDev/0/Config/] (level 4) (restricted root)
00:00:09.530145 GuestCoreDumpDir <string> = "C:\Users\blust\VirtualBox VMs\mac OS Sierra\Snapshots" (cb=54)
00:00:09.530146
00:00:09.530146 [/Devices/VMMDev/0/LUN#0/] (level 4)
00:00:09.530148 Driver <string> = "HGCM" (cb=5)
00:00:09.530149
00:00:09.530150 [/Devices/VMMDev/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530152 Object <integer> = 0x0000000004b93670 (79 246 960)
00:00:09.530153
00:00:09.530154 [/Devices/VMMDev/0/LUN#999/] (level 4)
00:00:09.530155 Driver <string> = "MainStatus" (cb=11)
00:00:09.530157
00:00:09.530157 [/Devices/VMMDev/0/LUN#999/Config/] (level 5) (restricted root)
00:00:09.530159 First <integer> = 0x0000000000000000 (0)
00:00:09.530160 Last <integer> = 0x0000000000000000 (0)
00:00:09.530161 papLeds <integer> = 0x0000000001d0df30 (30 465 840)
00:00:09.530163
00:00:09.530163 [/Devices/acpi/] (level 2)
00:00:09.530165
00:00:09.530165 [/Devices/acpi/0/] (level 3)
00:00:09.530167 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530168 PCIDeviceNo <integer> = 0x0000000000000007 (7)
00:00:09.530169 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:09.530170 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530171
00:00:09.530172 [/Devices/acpi/0/Config/] (level 4) (restricted root)
00:00:09.530176 AudioPciAddress <integer> = 0x0000000000050000 (327 680)
00:00:09.530177 CpuHotPlug <integer> = 0x0000000000000000 (0)
00:00:09.530179 FdcEnabled <integer> = 0x0000000000000000 (0)
00:00:09.530180 HostBusPciAddress <integer> = 0x00000000001e0000 (1 966 080)
00:00:09.530182 HpetEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530183 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:09.530184 IocPciAddress <integer> = 0x00000000001f0000 (2 031 616)
00:00:09.530186 McfgBase <integer> = 0x00000000dc000000 (3 690 987 520)
00:00:09.530187 McfgLength <integer> = 0x0000000004000000 (67 108 864)
00:00:09.530189 NicPciAddress <integer> = 0x0000000000110000 (1 114 112)
00:00:09.530190 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:09.530192 Parallel0IoPortBase <integer> = 0x0000000000000000 (0)
00:00:09.530193 Parallel0Irq <integer> = 0x0000000000000000 (0)
00:00:09.530194 Parallel1IoPortBase <integer> = 0x0000000000000000 (0)
00:00:09.530195 Parallel1Irq <integer> = 0x0000000000000000 (0)
00:00:09.530196 PciPref64Enabled <integer> = 0x0000000000000001 (1)
00:00:09.530198 Serial0IoPortBase <integer> = 0x0000000000000000 (0)
00:00:09.530199 Serial0Irq <integer> = 0x0000000000000000 (0)
00:00:09.530200 Serial1IoPortBase <integer> = 0x0000000000000000 (0)
00:00:09.530201 Serial1Irq <integer> = 0x0000000000000000 (0)
00:00:09.530202 ShowCpu <integer> = 0x0000000000000001 (1)
00:00:09.530204 ShowRtc <integer> = 0x0000000000000001 (1)
00:00:09.530205 SmcEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530206
00:00:09.530206 [/Devices/acpi/0/LUN#0/] (level 4)
00:00:09.530208 Driver <string> = "ACPIHost" (cb=9)
00:00:09.530210
00:00:09.530210 [/Devices/acpi/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530212
00:00:09.530212 [/Devices/acpi/0/LUN#1/] (level 4)
00:00:09.530214 Driver <string> = "ACPICpu" (cb=8)
00:00:09.530215
00:00:09.530215 [/Devices/acpi/0/LUN#1/Config/] (level 5)
00:00:09.530217
00:00:09.530218 [/Devices/acpi/0/LUN#2/] (level 4)
00:00:09.530219 Driver <string> = "ACPICpu" (cb=8)
00:00:09.530220
00:00:09.530221 [/Devices/acpi/0/LUN#2/Config/] (level 5)
00:00:09.530223
00:00:09.530223 [/Devices/acpi/0/LUN#3/] (level 4)
00:00:09.530225 Driver <string> = "ACPICpu" (cb=8)
00:00:09.530226
00:00:09.530227 [/Devices/acpi/0/LUN#3/Config/] (level 5)
00:00:09.530228
00:00:09.530229 [/Devices/ahci/] (level 2)
00:00:09.530230
00:00:09.530231 [/Devices/ahci/0/] (level 3)
00:00:09.530233 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530234 PCIDeviceNo <integer> = 0x000000000000001f (31)
00:00:09.530235 PCIFunctionNo <integer> = 0x0000000000000002 (2)
00:00:09.530236 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530237
00:00:09.530238 [/Devices/ahci/0/Config/] (level 4) (restricted root)
00:00:09.530240 Bootable <integer> = 0x0000000000000001 (1)
00:00:09.530241 PortCount <integer> = 0x0000000000000002 (2)
00:00:09.530242
00:00:09.530243 [/Devices/ahci/0/Config/Port0/] (level 5)
00:00:09.530245 Hotpluggable <integer> = 0x0000000000000000 (0)
00:00:09.530246
00:00:09.530246 [/Devices/ahci/0/Config/Port1/] (level 5)
00:00:09.530248 Hotpluggable <integer> = 0x0000000000000000 (0)
00:00:09.530249
00:00:09.530250 [/Devices/ahci/0/LUN#0/] (level 4)
00:00:09.530252 Driver <string> = "VD" (cb=3)
00:00:09.530253
00:00:09.530253 [/Devices/ahci/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530256 BlockCache <integer> = 0x0000000000000001 (1)
00:00:09.530257 Format <string> = "VMDK" (cb=5)
00:00:09.530259 Mountable <integer> = 0x0000000000000000 (0)
00:00:09.530260 Path <string> = "C:\Users\blust\OneDrive\Desktop\macOS Sierra 10.12 Files-001\macOS Sierra 10.12 Files\macOS Sierra 10.12 by wikigain.vmdk" (cb=122)
00:00:09.530262 Type <string> = "HardDisk" (cb=9)
00:00:09.530263 UseNewIo <integer> = 0x0000000000000001 (1)
00:00:09.530264
00:00:09.530265 [/Devices/ahci/0/LUN#1/] (level 4)
00:00:09.530266 Driver <string> = "SCSI" (cb=5)
00:00:09.530267
00:00:09.530268 [/Devices/ahci/0/LUN#1/AttachedDriver/] (level 5)
00:00:09.530270 Driver <string> = "VD" (cb=3)
00:00:09.530271
00:00:09.530271 [/Devices/ahci/0/LUN#1/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.530274 EmptyDrive <integer> = 0x0000000000000001 (1)
00:00:09.530275 Mountable <integer> = 0x0000000000000001 (1)
00:00:09.530276 Type <string> = "DVD" (cb=4)
00:00:09.530277
00:00:09.530278 [/Devices/ahci/0/LUN#1/Config/] (level 5) (restricted root)
00:00:09.530280
00:00:09.530280 [/Devices/ahci/0/LUN#999/] (level 4)
00:00:09.530282 Driver <string> = "MainStatus" (cb=11)
00:00:09.530283
00:00:09.530284 [/Devices/ahci/0/LUN#999/Config/] (level 5) (restricted root)
00:00:09.530287 DeviceInstance <string> = "ahci/0" (cb=7)
00:00:09.530288 First <integer> = 0x0000000000000000 (0)
00:00:09.530290 Last <integer> = 0x0000000000000001 (1)
00:00:09.530291 pConsole <integer> = 0x0000000001d0d720 (30 463 776)
00:00:09.530293 papLeds <integer> = 0x0000000001d0db30 (30 464 816)
00:00:09.530294 pmapMediumAttachments <integer> = 0x0000000001d0df50 (30 465 872)
00:00:09.530296
00:00:09.530296 [/Devices/apic/] (level 2)
00:00:09.530298
00:00:09.530298 [/Devices/apic/0/] (level 3)
00:00:09.530300 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530301
00:00:09.530301 [/Devices/apic/0/Config/] (level 4) (restricted root)
00:00:09.530303 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:09.530304 Mode <integer> = 0x0000000000000002 (2)
00:00:09.530305 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:09.530307
00:00:09.530307 [/Devices/e1000/] (level 2)
00:00:09.530308
00:00:09.530309 [/Devices/e1000/0/] (level 3)
00:00:09.530311 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530312 PCIDeviceNo <integer> = 0x0000000000000011 (17)
00:00:09.530313 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:09.530314 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530315
00:00:09.530316 [/Devices/e1000/0/Config/] (level 4) (restricted root)
00:00:09.530318 AdapterType <integer> = 0x0000000000000002 (2)
00:00:09.530319 CableConnected <integer> = 0x0000000000000001 (1)
00:00:09.530320 LineSpeed <integer> = 0x0000000000000000 (0)
00:00:09.530321 MAC <bytes> = "08 00 27 6e 78 44" (cb=6)
00:00:09.530324
00:00:09.530324 [/Devices/e1000/0/LUN#0/] (level 4)
00:00:09.530326 Driver <string> = "NAT" (cb=4)
00:00:09.530327
00:00:09.530327 [/Devices/e1000/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530330 AliasMode <integer> = 0x0000000000000000 (0)
00:00:09.530332 BootFile <string> = "mac OS Sierra.pxe" (cb=18)
00:00:09.530333 DNSProxy <integer> = 0x0000000000000000 (0)
00:00:09.530334 Network <string> = "10.0.2.0/24" (cb=12)
00:00:09.530335 PassDomain <integer> = 0x0000000000000001 (1)
00:00:09.530337 TFTPPrefix <string> = "C:\Users\blust\.VirtualBox\TFTP" (cb=32)
00:00:09.530338 UseHostResolver <integer> = 0x0000000000000000 (0)
00:00:09.530339
00:00:09.530339 [/Devices/e1000/0/LUN#999/] (level 4)
00:00:09.530341 Driver <string> = "MainStatus" (cb=11)
00:00:09.530342
00:00:09.530343 [/Devices/e1000/0/LUN#999/Config/] (level 5) (restricted root)
00:00:09.530345 First <integer> = 0x0000000000000000 (0)
00:00:09.530346 Last <integer> = 0x0000000000000000 (0)
00:00:09.530347 papLeds <integer> = 0x0000000001d0de10 (30 465 552)
00:00:09.530349
00:00:09.530349 [/Devices/efi/] (level 2)
00:00:09.530350
00:00:09.530351 [/Devices/efi/0/] (level 3)
00:00:09.530352 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530353
00:00:09.530354 [/Devices/efi/0/Config/] (level 4) (restricted root)
00:00:09.530358 64BitEntry <integer> = 0x0000000000000001 (1)
00:00:09.530359 APIC <integer> = 0x0000000000000001 (1)
00:00:09.530361 BootArgs <string> = "" (cb=1)
00:00:09.530362 DeviceProps <string> = "" (cb=1)
00:00:09.530363 DmiBoardProduct <string> = "Iloveapple" (cb=11)
00:00:09.530364 DmiExposeMemoryTable <integer> = 0x0000000000000001 (1)
00:00:09.530365 DmiSystemProduct <string> = "iMac11,3" (cb=9)
00:00:09.530367 DmiSystemVersion <string> = "1.0" (cb=4)
00:00:09.530368 DmiUseHostInfo <integer> = 0x0000000000000001 (1)
00:00:09.530369 EfiRom <string> = "C:\Program Files\Oracle\VirtualBox\VBoxEFI64.fd" (cb=48)
00:00:09.530371 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:09.530372 McfgBase <integer> = 0x00000000dc000000 (3 690 987 520)
00:00:09.530374 McfgLength <integer> = 0x0000000004000000 (67 108 864)
00:00:09.530376 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:09.530377 UUID <bytes> = "a2 1d d6 61 3b 6f 3f 47 83 e6 7e 1e cf 43 70 c4" (cb=16)
00:00:09.530381
00:00:09.530381 [/Devices/efi/0/LUN#0/] (level 4)
00:00:09.530383 Driver <string> = "NvramStorage" (cb=13)
00:00:09.530384
00:00:09.530384 [/Devices/efi/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530386 Object <integer> = 0x0000000001d147b0 (30 492 592)
00:00:09.530388
00:00:09.530388 [/Devices/hda/] (level 2)
00:00:09.530390
00:00:09.530390 [/Devices/hda/0/] (level 3)
00:00:09.530392 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530393 PCIDeviceNo <integer> = 0x0000000000000005 (5)
00:00:09.530394 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:09.530395 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530396
00:00:09.530397 [/Devices/hda/0/AudioConfig/] (level 4)
00:00:09.530398
00:00:09.530399 [/Devices/hda/0/Config/] (level 4) (restricted root)
00:00:09.530401 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:09.530402 DebugPathOut <string> = "" (cb=1)
00:00:09.530403
00:00:09.530403 [/Devices/hda/0/LUN#0/] (level 4)
00:00:09.530405 Driver <string> = "AUDIO" (cb=6)
00:00:09.530406
00:00:09.530407 [/Devices/hda/0/LUN#0/AttachedDriver/] (level 5)
00:00:09.530409 Driver <string> = "DSoundAudio" (cb=12)
00:00:09.530410
00:00:09.530410 [/Devices/hda/0/LUN#0/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.530413 StreamName <string> = "mac OS Sierra" (cb=14)
00:00:09.530414
00:00:09.530415 [/Devices/hda/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530418 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:09.530419 DebugPathOut <string> = "" (cb=1)
00:00:09.530420 DriverName <string> = "DSoundAudio" (cb=12)
00:00:09.530421 InputEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530422 OutputEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530423
00:00:09.530424 [/Devices/hda/0/LUN#1/] (level 4)
00:00:09.530425 Driver <string> = "AUDIO" (cb=6)
00:00:09.530426
00:00:09.530427 [/Devices/hda/0/LUN#1/AttachedDriver/] (level 5)
00:00:09.530429 Driver <string> = "AudioVRDE" (cb=10)
00:00:09.530430
00:00:09.530430 [/Devices/hda/0/LUN#1/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.530433 Object <integer> = 0x0000000001d14950 (30 493 008)
00:00:09.530434 ObjectVRDPServer <integer> = 0x0000000001d18e60 (30 510 688)
00:00:09.530436 StreamName <string> = "mac OS Sierra" (cb=14)
00:00:09.530437
00:00:09.530437 [/Devices/hda/0/LUN#1/Config/] (level 5) (restricted root)
00:00:09.530440 DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:09.530441 DebugPathOut <string> = "" (cb=1)
00:00:09.530442 DriverName <string> = "AudioVRDE" (cb=10)
00:00:09.530444 InputEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530445 OutputEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530446
00:00:09.530446 [/Devices/hpet/] (level 2)
00:00:09.530448
00:00:09.530448 [/Devices/hpet/0/] (level 3)
00:00:09.530450 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530451
00:00:09.530451 [/Devices/hpet/0/Config/] (level 4) (restricted root)
00:00:09.530453 ICH9 <integer> = 0x0000000000000001 (1)
00:00:09.530454
00:00:09.530455 [/Devices/i8254/] (level 2)
00:00:09.530456
00:00:09.530456 [/Devices/i8254/0/] (level 3)
00:00:09.530458
00:00:09.530458 [/Devices/i8254/0/Config/] (level 4) (restricted root)
00:00:09.530460
00:00:09.530461 [/Devices/i8259/] (level 2)
00:00:09.530462
00:00:09.530463 [/Devices/i8259/0/] (level 3)
00:00:09.530464 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530465
00:00:09.530466 [/Devices/i8259/0/Config/] (level 4) (restricted root)
00:00:09.530467
00:00:09.530468 [/Devices/ich9pci/] (level 2)
00:00:09.530469
00:00:09.530470 [/Devices/ich9pci/0/] (level 3)
00:00:09.530472 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530473
00:00:09.530473 [/Devices/ich9pci/0/Config/] (level 4) (restricted root)
00:00:09.530475 IOAPIC <integer> = 0x0000000000000001 (1)
00:00:09.530476 McfgBase <integer> = 0x00000000dc000000 (3 690 987 520)
00:00:09.530478 McfgLength <integer> = 0x0000000004000000 (67 108 864)
00:00:09.530752
00:00:09.530756 [/Devices/ich9pcibridge/] (level 2)
00:00:09.530758
00:00:09.530758 [/Devices/ioapic/] (level 2)
00:00:09.530760
00:00:09.530760 [/Devices/ioapic/0/] (level 3)
00:00:09.530762 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530764
00:00:09.530764 [/Devices/ioapic/0/Config/] (level 4) (restricted root)
00:00:09.530767 NumCPUs <integer> = 0x0000000000000004 (4)
00:00:09.530768
00:00:09.530768 [/Devices/lpc/] (level 2)
00:00:09.530770
00:00:09.530770 [/Devices/lpc/0/] (level 3)
00:00:09.530772 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530774 PCIDeviceNo <integer> = 0x000000000000001f (31)
00:00:09.530775 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:09.530776 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530778
00:00:09.530778 [/Devices/lpc/0/Config/] (level 4) (restricted root)
00:00:09.530780
00:00:09.530781 [/Devices/mc146818/] (level 2)
00:00:09.530782
00:00:09.530782 [/Devices/mc146818/0/] (level 3)
00:00:09.530784
00:00:09.530784 [/Devices/mc146818/0/Config/] (level 4) (restricted root)
00:00:09.530786 UseUTC <integer> = 0x0000000000000001 (1)
00:00:09.530788
00:00:09.530788 [/Devices/parallel/] (level 2)
00:00:09.530789
00:00:09.530790 [/Devices/pcarch/] (level 2)
00:00:09.530791
00:00:09.530792 [/Devices/pcarch/0/] (level 3)
00:00:09.530793 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530794
00:00:09.530795 [/Devices/pcarch/0/Config/] (level 4) (restricted root)
00:00:09.530797
00:00:09.530797 [/Devices/pckbd/] (level 2)
00:00:09.530798
00:00:09.530799 [/Devices/pckbd/0/] (level 3)
00:00:09.530800 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530801
00:00:09.530802 [/Devices/pckbd/0/Config/] (level 4) (restricted root)
00:00:09.530804
00:00:09.530804 [/Devices/pckbd/0/LUN#0/] (level 4)
00:00:09.530806 Driver <string> = "KeyboardQueue" (cb=14)
00:00:09.530807
00:00:09.530808 [/Devices/pckbd/0/LUN#0/AttachedDriver/] (level 5)
00:00:09.530810 Driver <string> = "MainKeyboard" (cb=13)
00:00:09.530811
00:00:09.530811 [/Devices/pckbd/0/LUN#0/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.530814 Object <integer> = 0x0000000001cd4c10 (30 231 568)
00:00:09.530816
00:00:09.530816 [/Devices/pckbd/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530819 QueueSize <integer> = 0x0000000000000040 (64)
00:00:09.530820
00:00:09.530820 [/Devices/pckbd/0/LUN#1/] (level 4)
00:00:09.530822 Driver <string> = "MouseQueue" (cb=11)
00:00:09.530823
00:00:09.530823 [/Devices/pckbd/0/LUN#1/AttachedDriver/] (level 5)
00:00:09.530825 Driver <string> = "MainMouse" (cb=10)
00:00:09.530826
00:00:09.530827 [/Devices/pckbd/0/LUN#1/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.530829 Object <integer> = 0x0000000001d12d50 (30 485 840)
00:00:09.530830
00:00:09.530831 [/Devices/pckbd/0/LUN#1/Config/] (level 5) (restricted root)
00:00:09.530833 QueueSize <integer> = 0x0000000000000080 (128)
00:00:09.530834
00:00:09.530835 [/Devices/pcnet/] (level 2)
00:00:09.530836
00:00:09.530837 [/Devices/serial/] (level 2)
00:00:09.530838
00:00:09.530838 [/Devices/smc/] (level 2)
00:00:09.530840
00:00:09.530840 [/Devices/smc/0/] (level 3)
00:00:09.530841 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530843
00:00:09.530843 [/Devices/smc/0/Config/] (level 4) (restricted root)
00:00:09.530845 DeviceKey <string> = "ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc" (cb=65)
00:00:09.530847 GetKeyFromRealSMC <integer> = 0x0000000000000001 (1)
00:00:09.530849
00:00:09.530849 [/Devices/usb-ohci/] (level 2)
00:00:09.530850
00:00:09.530851 [/Devices/usb-ohci/0/] (level 3)
00:00:09.530853 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530854 PCIDeviceNo <integer> = 0x000000000000001f (31)
00:00:09.530855 PCIFunctionNo <integer> = 0x0000000000000004 (4)
00:00:09.530856 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530857
00:00:09.530858 [/Devices/usb-ohci/0/Config/] (level 4) (restricted root)
00:00:09.530859
00:00:09.530860 [/Devices/usb-ohci/0/LUN#0/] (level 4)
00:00:09.530862 Driver <string> = "VUSBRootHub" (cb=12)
00:00:09.530863
00:00:09.530863 [/Devices/usb-ohci/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530865
00:00:09.530865 [/Devices/usb-ohci/0/LUN#999/] (level 4)
00:00:09.530867 Driver <string> = "MainStatus" (cb=11)
00:00:09.530868
00:00:09.530869 [/Devices/usb-ohci/0/LUN#999/Config/] (level 5) (restricted root)
00:00:09.530871 First <integer> = 0x0000000000000000 (0)
00:00:09.530872 Last <integer> = 0x0000000000000000 (0)
00:00:09.530873 papLeds <integer> = 0x0000000001d0df38 (30 465 848)
00:00:09.530875
00:00:09.530875 [/Devices/vga/] (level 2)
00:00:09.530877
00:00:09.530877 [/Devices/vga/0/] (level 3)
00:00:09.530879 PCIBusNo <integer> = 0x0000000000000000 (0)
00:00:09.530881 PCIDeviceNo <integer> = 0x0000000000000002 (2)
00:00:09.530882 PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:09.530883 Trusted <integer> = 0x0000000000000001 (1)
00:00:09.530884
00:00:09.530884 [/Devices/vga/0/Config/] (level 4) (restricted root)
00:00:09.530887 CustomVideoModes <integer> = 0x0000000000000000 (0)
00:00:09.530888 FadeIn <integer> = 0x0000000000000001 (1)
00:00:09.530889 FadeOut <integer> = 0x0000000000000001 (1)
00:00:09.530891 HeightReduction <integer> = 0x0000000000000000 (0)
00:00:09.530892 LogoFile <string> = "" (cb=1)
00:00:09.530893 LogoTime <integer> = 0x0000000000000000 (0)
00:00:09.530894 MonitorCount <integer> = 0x0000000000000001 (1)
00:00:09.530896 ShowBootMenu <integer> = 0x0000000000000002 (2)
00:00:09.530897 VRamSize <integer> = 0x0000000008000000 (134 217 728, 128 MB)
00:00:09.530899
00:00:09.530899 [/Devices/vga/0/LUN#0/] (level 4)
00:00:09.530901 Driver <string> = "MainDisplay" (cb=12)
00:00:09.530902
00:00:09.530903 [/Devices/vga/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530905 Object <integer> = 0x0000000001d15d10 (30 498 064)
00:00:09.530906
00:00:09.530906 [/Devices/vga/0/LUN#999/] (level 4)
00:00:09.530908 Driver <string> = "MainStatus" (cb=11)
00:00:09.530909
00:00:09.530910 [/Devices/vga/0/LUN#999/Config/] (level 5) (restricted root)
00:00:09.530912 First <integer> = 0x0000000000000000 (0)
00:00:09.530913 Last <integer> = 0x0000000000000000 (0)
00:00:09.530914 papLeds <integer> = 0x0000000001d0df48 (30 465 864)
00:00:09.530915
00:00:09.530916 [/Devices/virtio-net/] (level 2)
00:00:09.530917
00:00:09.530917 [/EM/] (level 1)
00:00:09.530919 TripleFaultReset <integer> = 0x0000000000000000 (0)
00:00:09.530920
00:00:09.530921 [/GIM/] (level 1)
00:00:09.530922 Provider <string> = "Minimal" (cb=8)
00:00:09.530924
00:00:09.530924 [/HM/] (level 1)
00:00:09.530926 64bitEnabled <integer> = 0x0000000000000001 (1)
00:00:09.530927 EnableLargePages <integer> = 0x0000000000000001 (1)
00:00:09.530929 EnableNestedPaging <integer> = 0x0000000000000001 (1)
00:00:09.530930 EnableUX <integer> = 0x0000000000000001 (1)
00:00:09.530931 EnableVPID <integer> = 0x0000000000000001 (1)
00:00:09.530932 Exclusive <integer> = 0x0000000000000000 (0)
00:00:09.530934 HMForced <integer> = 0x0000000000000001 (1)
00:00:09.530935 IBPBOnVMEntry <integer> = 0x0000000000000000 (0)
00:00:09.530936 IBPBOnVMExit <integer> = 0x0000000000000000 (0)
00:00:09.530937 SpecCtrlByHost <integer> = 0x0000000000000000 (0)
00:00:09.530938
00:00:09.530939 [/MM/] (level 1)
00:00:09.530940 CanUseLargerHeap <integer> = 0x0000000000000001 (1)
00:00:09.530941
00:00:09.530941 [/PDM/] (level 1)
00:00:09.530943
00:00:09.530943 [/PDM/AsyncCompletion/] (level 2)
00:00:09.530945
00:00:09.530945 [/PDM/AsyncCompletion/File/] (level 3)
00:00:09.530947
00:00:09.530947 [/PDM/AsyncCompletion/File/BwGroups/] (level 4)
00:00:09.530949
00:00:09.530949 [/PDM/BlkCache/] (level 2)
00:00:09.530951 CacheSize <integer> = 0x0000000000500000 (5 242 880, 5 MB)
00:00:09.530952
00:00:09.530953 [/PDM/Devices/] (level 2)
00:00:09.530954
00:00:09.530955 [/PDM/Drivers/] (level 2)
00:00:09.530956
00:00:09.530956 [/PDM/Drivers/VBoxC/] (level 3)
00:00:09.530958 Path <string> = "VBoxC" (cb=6)
00:00:09.530959
00:00:09.530959 [/PDM/NetworkShaper/] (level 2)
00:00:09.530961
00:00:09.530961 [/PDM/NetworkShaper/BwGroups/] (level 3)
00:00:09.530963
00:00:09.530963 [/TM/] (level 1)
00:00:09.530964 UTCOffset <integer> = 0x0000000000000000 (0)
00:00:09.530965
00:00:09.530966 [/USB/] (level 1)
00:00:09.530967
00:00:09.530967 [/USB/HidKeyboard/] (level 2)
00:00:09.530969
00:00:09.530969 [/USB/HidKeyboard/0/] (level 3)
00:00:09.530970
00:00:09.530971 [/USB/HidKeyboard/0/Config/] (level 4) (restricted root)
00:00:09.530973
00:00:09.530973 [/USB/HidKeyboard/0/LUN#0/] (level 4)
00:00:09.530975 Driver <string> = "KeyboardQueue" (cb=14)
00:00:09.530977
00:00:09.530977 [/USB/HidKeyboard/0/LUN#0/AttachedDriver/] (level 5)
00:00:09.530979 Driver <string> = "MainKeyboard" (cb=13)
00:00:09.530980
00:00:09.530980 [/USB/HidKeyboard/0/LUN#0/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.530983 Object <integer> = 0x0000000001cd4c10 (30 231 568)
00:00:09.530984
00:00:09.530985 [/USB/HidKeyboard/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.530987 QueueSize <integer> = 0x0000000000000040 (64)
00:00:09.530988
00:00:09.530988 [/USB/HidKeyboard/GlobalConfig/] (level 3) (restricted root)
00:00:09.530990
00:00:09.530991 [/USB/HidMouse/] (level 2)
00:00:09.530992
00:00:09.530992 [/USB/HidMouse/0/] (level 3)
00:00:09.530994
00:00:09.530994 [/USB/HidMouse/0/Config/] (level 4) (restricted root)
00:00:09.530996 Mode <string> = "absolute" (cb=9)
00:00:09.530997
00:00:09.530998 [/USB/HidMouse/0/LUN#0/] (level 4)
00:00:09.531000 Driver <string> = "MouseQueue" (cb=11)
00:00:09.531001
00:00:09.531001 [/USB/HidMouse/0/LUN#0/AttachedDriver/] (level 5)
00:00:09.531003 Driver <string> = "MainMouse" (cb=10)
00:00:09.531004
00:00:09.531005 [/USB/HidMouse/0/LUN#0/AttachedDriver/Config/] (level 6) (restricted root)
00:00:09.531007 Object <integer> = 0x0000000001d12d50 (30 485 840)
00:00:09.531008
00:00:09.531009 [/USB/HidMouse/0/LUN#0/Config/] (level 5) (restricted root)
00:00:09.531011 QueueSize <integer> = 0x0000000000000080 (128)
00:00:09.531012
00:00:09.531013 [/USB/HidMouse/GlobalConfig/] (level 3) (restricted root)
00:00:09.531015
00:00:09.531015 [/USB/USBProxy/] (level 2)
00:00:09.531016
00:00:09.531017 [/USB/USBProxy/GlobalConfig/] (level 3)
00:00:09.531018
00:00:09.531020 !!
00:00:09.531020 !! {clocks}
00:00:09.531020 !!
00:00:09.531027 Cpu Tick: 14211082498 (0x0000034f0be902) 2694935365Hz paused - virtualized - virtual clock
00:00:09.531030 Cpu Tick: 14213851932 (0x0000034f362b1c) 2694935365Hz paused - virtualized - virtual clock
00:00:09.531033 Cpu Tick: 14213703924 (0x0000034f33e8f4) 2694935365Hz paused - virtualized - virtual clock
00:00:09.531036 Cpu Tick: 14213851932 (0x0000034f362b1c) 2694935365Hz paused - virtualized - virtual clock
00:00:09.531039 Virtual: 5274441598 (0x0000013a61977e) 1000000000Hz paused
00:00:09.531041 VirtSync: 5274283056 (0x0000013a5f2c30) paused
00:00:09.531042 offset 144943 catch-up rate 5 %
00:00:09.531044 Real: 923717213 (0x000000370ece5d) 1000Hz
00:00:09.531050 !!
00:00:09.531050 !! {cmos1}
00:00:09.531050 !!
00:00:09.531051 First CMOS bank, offsets 0x0E - 0x7F
00:00:09.531052 Offset 00 : --- use 'info rtc' to show CMOS clock --- 00 00
00:00:09.531053 Offset 10 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531057 Offset 20 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531061 Offset 30 : 00 00 20 00 00 db 00 20-00 00 00 00 00 00 00 00
00:00:09.531065 Offset 40 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531069 Offset 50 : 00 00 00 00 00 00 00 00-00 00 00 00 24 00 00 00
00:00:09.531073 Offset 60 : 04 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531077 Offset 70 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531081 !!
00:00:09.531081 !! {cmos2}
00:00:09.531082 !!
00:00:09.531082 Second CMOS bank, offsets 0x80 - 0xFF
00:00:09.531083 Offset 80 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531087 Offset 90 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531091 Offset a0 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531094 Offset b0 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531098 Offset c0 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531102 Offset d0 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531106 Offset e0 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531109 Offset f0 : 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00
00:00:09.531117 !!
00:00:09.531117 !! {e1k0}
00:00:09.531117 !!
00:00:09.531119 E1000 #0: port=c040 mmio=00000000e8400000 mac-cfg=08:00:27:6e:78:44 82545EM GC R0
00:00:09.531123 CTRL = 00000a09
00:00:09.531125 STATUS = 00000081
00:00:09.531126 EECD = 00000100
00:00:09.531127 EERD = 00000000
00:00:09.531127 CTRL_EXT = 00000000
00:00:09.531128 FLA = 00000000
00:00:09.531129 MDIC = 00000000
00:00:09.531130 FCAL = 00000000
00:00:09.531131 FCAH = 00000000
00:00:09.531131 FCT = 00000000
00:00:09.531132 VET = 00000000
00:00:09.531133 ICR = 00000000
00:00:09.531133 ITR = 00000000
00:00:09.531134 ICS = 00000000
00:00:09.531135 IMS = 00000000
00:00:09.531136 IMC = 00000000
00:00:09.531136 RCTL = 00000000
00:00:09.531137 FCTTV = 00000000
00:00:09.531138 TXCW = 00000000
00:00:09.531138 RXCW = 00000000
00:00:09.531139 TCTL = 00000000
00:00:09.531140 TIPG = 00000000
00:00:09.531140 AIFS = 00000000
00:00:09.531141 LEDCTL = 00000000
00:00:09.531142 PBA = 00000000
00:00:09.531143 FCRTL = 00000000
00:00:09.531143 FCRTH = 00000000
00:00:09.531144 RDFH = 00000000
00:00:09.531145 RDFT = 00000000
00:00:09.531145 RDFHS = 00000000
00:00:09.531146 RDFTS = 00000000
00:00:09.531147 RDFPC = 00000000
00:00:09.531147 RDBAL = 00000000
00:00:09.531148 RDBAH = 00000000
00:00:09.531148 RDLEN = 00000000
00:00:09.531149 RDH = 00000000
00:00:09.531150 RDT = 00000000
00:00:09.531150 RDTR = 00000000
00:00:09.531151 RXDCTL = 00000000
00:00:09.531152 RADV = 00000000
00:00:09.531153 RSRPD = 00000000
00:00:09.531153 TXDMAC = 00000000
00:00:09.531154 TDFH = 00000000
00:00:09.531154 TDFT = 00000000
00:00:09.531155 TDFHS = 00000000
00:00:09.531156 TDFTS = 00000000
00:00:09.531156 TDFPC = 00000000
00:00:09.531157 TDBAL = 00000000
00:00:09.531158 TDBAH = 00000000
00:00:09.531158 TDLEN = 00000000
00:00:09.531159 TDH = 00000000
00:00:09.531160 TDT = 00000000
00:00:09.531160 TIDV = 00000000
00:00:09.531161 TXDCTL = 00000000
00:00:09.531162 TADV = 00000000
00:00:09.531162 TSPMT = 01000400
00:00:09.531163 CRCERRS = 00000000
00:00:09.531164 ALGNERRC = 00000000
00:00:09.531164 SYMERRS = 00000000
00:00:09.531165 RXERRC = 00000000
00:00:09.531166 MPC = 00000000
00:00:09.531166 SCC = 00000000
00:00:09.531167 ECOL = 00000000
00:00:09.531168 MCC = 00000000
00:00:09.531168 LATECOL = 00000000
00:00:09.531169 COLC = 00000000
00:00:09.531170 DC = 00000000
00:00:09.531171 TNCRS = 00000000
00:00:09.531171 SEC = 00000000
00:00:09.531172 CEXTERR = 00000000
00:00:09.531173 RLEC = 00000000
00:00:09.531173 XONRXC = 00000000
00:00:09.531174 XONTXC = 00000000
00:00:09.531175 XOFFRXC = 00000000
00:00:09.531175 XOFFTXC = 00000000
00:00:09.531176 FCRUC = 00000000
00:00:09.531177 PRC64 = 00000000
00:00:09.531177 PRC127 = 00000000
00:00:09.531178 PRC255 = 00000000
00:00:09.531179 PRC511 = 00000000
00:00:09.531179 PRC1023 = 00000000
00:00:09.531180 PRC1522 = 00000000
00:00:09.531180 GPRC = 00000000
00:00:09.531181 BPRC = 00000000
00:00:09.531182 MPRC = 00000000
00:00:09.531182 GPTC = 00000000
00:00:09.531183 GORCL = 00000000
00:00:09.531184 GORCH = 00000000
00:00:09.531184 GOTCL = 00000000
00:00:09.531185 GOTCH = 00000000
00:00:09.531186 RNBC = 00000000
00:00:09.531187 RUC = 00000000
00:00:09.531187 RFC = 00000000
00:00:09.531188 ROC = 00000000
00:00:09.531189 RJC = 00000000
00:00:09.531189 MGTPRC = 00000000
00:00:09.531190 MGTPDC = 00000000
00:00:09.531190 MGTPTC = 00000000
00:00:09.531191 TORL = 00000000
00:00:09.531192 TORH = 00000000
00:00:09.531204 TOTL = 00000000
00:00:09.531205 TOTH = 00000000
00:00:09.531205 TPR = 00000000
00:00:09.531206 TPT = 00000000
00:00:09.531207 PTC64 = 00000000
00:00:09.531208 PTC127 = 00000000
00:00:09.531208 PTC255 = 00000000
00:00:09.531209 PTC511 = 00000000
00:00:09.531210 PTC1023 = 00000000
00:00:09.531211 PTC1522 = 00000000
00:00:09.531211 MPTC = 00000000
00:00:09.531212 BPTC = 00000000
00:00:09.531213 TSCTC = 00000000
00:00:09.531213 TSCTFC = 00000000
00:00:09.531214 RXCSUM = 00000000
00:00:09.531215 WUC = 00000000
00:00:09.531215 WUFC = 00000000
00:00:09.531216 WUS = 00000000
00:00:09.531217 MANC = 00000000
00:00:09.531217 IPAV = 00000000
00:00:09.531218 WUPL = 00000000
00:00:09.531219 RA00: DST 08:00:27:6e:78:44
00:00:09.531221
00:00:09.531221 -- Receive Descriptors (0 total) --
00:00:09.531223
00:00:09.531223 -- Receive Descriptors in Cache (at 0 (RDH 0)/ fetched 0 / max 16) --
00:00:09.531224
00:00:09.531225 -- Transmit Descriptors (0 total) --
00:00:09.531226
00:00:09.531226 -- Transmit Descriptors in Cache (at 0 (TDH 0)/ fetched 0 / max 64) --
00:00:09.531227 Interrupt attempts: 0
00:00:09.531228 Interrupts raised : 0
00:00:09.531229 Interrupts lowered: 0
00:00:09.531229 ICR outside ISR : 0
00:00:09.531230 IMS raised ints : 0
00:00:09.531231 Interrupts skipped: 0
00:00:09.531231 Masked interrupts : 0
00:00:09.531232 Early interrupts : 0
00:00:09.531232 Late interrupts : 0
00:00:09.531233 Lost interrupts : 0
00:00:09.531233 Interrupts by RX : 0
00:00:09.531234 Interrupts by TX : 0
00:00:09.531235 Interrupts by ICS : 0
00:00:09.531235 Interrupts by RDTR: 0
00:00:09.531236 Interrupts by RDMT: 0
00:00:09.531236 Interrupts by TXQE: 0
00:00:09.531237 TX int delay asked: 0
00:00:09.531238 TX delayed: 0
00:00:09.531238 TX delayed expired: 0
00:00:09.531239 TX no report asked: 0
00:00:09.531239 TX abs timer expd : 0
00:00:09.531240 TX int timer expd : 0
00:00:09.531241 RX abs timer expd : 0
00:00:09.531241 RX int timer expd : 0
00:00:09.531242 TX CTX descriptors: 0
00:00:09.531242 TX DAT descriptors: 0
00:00:09.531243 TX LEG descriptors: 0
00:00:09.531243 Received frames : 0
00:00:09.531244 Transmitted frames: 0
00:00:09.531244 TX frames up to 1514: 0
00:00:09.531245 TX frames up to 2962: 0
00:00:09.531246 TX frames up to 4410: 0
00:00:09.531246 TX frames up to 5858: 0
00:00:09.531247 TX frames up to 7306: 0
00:00:09.531247 TX frames up to 8754: 0
00:00:09.531248 TX frames up to 16384: 0
00:00:09.531249 TX frames up to 32768: 0
00:00:09.531249 Larger TX frames : 0
00:00:09.531251 !!
00:00:09.531251 !! {exithistory}
00:00:09.531251 !!
00:00:09.531259 CPU[0]: AMD-V #VMEXIT history:
00:00:09.531260 idxExitHistoryFree = 23
00:00:09.531261 auExitHistory[ 0] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531267 auExitHistory[ 1] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531269 auExitHistory[ 2] = 0x0014 SVM_EXIT_WRITE_CR4 - 20 - Write CR4.
00:00:09.531273 auExitHistory[ 3] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531275 auExitHistory[ 4] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531276 auExitHistory[ 5] = 0x0000 SVM_EXIT_READ_CR0 - 0 - Read CR0.
00:00:09.531277 auExitHistory[ 6] = 0x0010 SVM_EXIT_WRITE_CR0 - 16 - Write CR0.
00:00:09.531278 auExitHistory[ 7] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531279 auExitHistory[ 8] = 0x006e SVM_EXIT_RDTSC - 110 - RDTSC instruction.
00:00:09.531281 auExitHistory[ 9] = 0x0060 SVM_EXIT_INTR - 96 - Physical maskable interrupt (host).
00:00:09.531282 auExitHistory[10] = 0x0400 SVM_EXIT_NPF - 1024 - Nested Page Fault.
00:00:09.531283 auExitHistory[11] = 0x006e SVM_EXIT_RDTSC - 110 - RDTSC instruction.
00:00:09.531284 auExitHistory[12] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531285 auExitHistory[13] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531286 auExitHistory[14] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531287 auExitHistory[15] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531288 auExitHistory[16] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531289 auExitHistory[17] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531290 auExitHistory[18] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531291 auExitHistory[19] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531292 auExitHistory[20] = 0x0072 SVM_EXIT_CPUID - 114 - CPUID instruction.
00:00:09.531293 auExitHistory[21] = 0x007c SVM_EXIT_MSR - 124 - RDMSR or WRMSR access to protected MSR.
00:00:09.531294 auExitHistory[22] = 0x007f SVM_EXIT_SHUTDOWN - 127 - Shutdown. <-- Latest exit
00:00:09.531295 auExitHistory[23] = 0xffff <NULL>
00:00:09.531296 auExitHistory[24] = 0x007b SVM_EXIT_IOIO - 123 - IN/OUT accessing protected port.
00:00:09.531297 auExitHistory[25] = 0x0400 SVM_EXIT_NPF - 1024 - Nested Page Fault.
00:00:09.531298 auExitHistory[26] = 0x0400 SVM_EXIT_NPF - 1024 - Nested Page Fault.
00:00:09.531299 auExitHistory[27] = 0x0400 SVM_EXIT_NPF - 1024 - Nested Page Fault.
00:00:09.531300 auExitHistory[28] = 0x0400 SVM_EXIT_NPF - 1024 - Nested Page Fault.
00:00:09.531301 auExitHistory[29] = 0x0000 SVM_EXIT_READ_CR0 - 0 - Read CR0.
00:00:09.531302 auExitHistory[30] = 0x0010 SVM_EXIT_WRITE_CR0 - 16 - Write CR0.
00:00:09.531304 HM error = 0x0 (0)
00:00:09.531308 CPU[1]: AMD-V #VMEXIT history:
00:00:09.531309 idxExitHistoryFree = 0
00:00:09.531310 auExitHistory[ 0] = 0xffff <NULL>
00:00:09.531311 auExitHistory[ 1] = 0xffff <NULL>
00:00:09.531312 auExitHistory[ 2] = 0xffff <NULL>
00:00:09.531313 auExitHistory[ 3] = 0xffff <NULL>
00:00:09.531314 auExitHistory[ 4] = 0xffff <NULL>
00:00:09.531315 auExitHistory[ 5] = 0xffff <NULL>
00:00:09.531316 auExitHistory[ 6] = 0xffff <NULL>
00:00:09.531317 auExitHistory[ 7] = 0xffff <NULL>
00:00:09.531318 auExitHistory[ 8] = 0xffff <NULL>
00:00:09.531319 auExitHistory[ 9] = 0xffff <NULL>
00:00:09.531320 auExitHistory[10] = 0xffff <NULL>
00:00:09.531321 auExitHistory[11] = 0xffff <NULL>
00:00:09.531322 auExitHistory[12] = 0xffff <NULL>
00:00:09.531323 auExitHistory[13] = 0xffff <NULL>
00:00:09.531323 auExitHistory[14] = 0xffff <NULL>
00:00:09.531324 auExitHistory[15] = 0xffff <NULL>
00:00:09.531325 auExitHistory[16] = 0xffff <NULL>
00:00:09.531326 auExitHistory[17] = 0xffff <NULL>
00:00:09.531327 auExitHistory[18] = 0xffff <NULL>
00:00:09.531328 auExitHistory[19] = 0xffff <NULL>
00:00:09.531328 auExitHistory[20] = 0xffff <NULL>
00:00:09.531329 auExitHistory[21] = 0xffff <NULL>
00:00:09.531330 auExitHistory[22] = 0xffff <NULL>
00:00:09.531331 auExitHistory[23] = 0xffff <NULL>
00:00:09.531332 auExitHistory[24] = 0xffff <NULL>
00:00:09.531333 auExitHistory[25] = 0xffff <NULL>
00:00:09.531333 auExitHistory[26] = 0xffff <NULL>
00:00:09.531334 auExitHistory[27] = 0xffff <NULL>
00:00:09.531335 auExitHistory[28] = 0xffff <NULL>
00:00:09.531336 auExitHistory[29] = 0xffff <NULL>
00:00:09.531337 auExitHistory[30] = 0xffff <NULL> <-- Latest exit
00:00:09.531338 HM error = 0x0 (0)
00:00:09.531348 CPU[2]: AMD-V #VMEXIT history:
00:00:09.531350 idxExitHistoryFree = 0
00:00:09.531351 auExitHistory[ 0] = 0xffff <NULL>
00:00:09.531353 auExitHistory[ 1] = 0xffff <NULL>
00:00:09.531354 auExitHistory[ 2] = 0xffff <NULL>
00:00:09.531355 auExitHistory[ 3] = 0xffff <NULL>
00:00:09.531356 auExitHistory[ 4] = 0xffff <NULL>
00:00:09.531357 auExitHistory[ 5] = 0xffff <NULL>
00:00:09.531358 auExitHistory[ 6] = 0xffff <NULL>
00:00:09.531359 auExitHistory[ 7] = 0xffff <NULL>
00:00:09.531360 auExitHistory[ 8] = 0xffff <NULL>
00:00:09.531361 auExitHistory[ 9] = 0xffff <NULL>
00:00:09.531362 auExitHistory[10] = 0xffff <NULL>
00:00:09.531363 auExitHistory[11] = 0xffff <NULL>
00:00:09.531364 auExitHistory[12] = 0xffff <NULL>
00:00:09.531365 auExitHistory[13] = 0xffff <NULL>
00:00:09.531366 auExitHistory[14] = 0xffff <NULL>
00:00:09.531367 auExitHistory[15] = 0xffff <NULL>
00:00:09.531368 auExitHistory[16] = 0xffff <NULL>
00:00:09.531369 auExitHistory[17] = 0xffff <NULL>
00:00:09.531370 auExitHistory[18] = 0xffff <NULL>
00:00:09.531371 auExitHistory[19] = 0xffff <NULL>
00:00:09.531372 auExitHistory[20] = 0xffff <NULL>
00:00:09.531372 auExitHistory[21] = 0xffff <NULL>
00:00:09.531373 auExitHistory[22] = 0xffff <NULL>
00:00:09.531374 auExitHistory[23] = 0xffff <NULL>
00:00:09.531375 auExitHistory[24] = 0xffff <NULL>
00:00:09.531376 auExitHistory[25] = 0xffff <NULL>
00:00:09.531377 auExitHistory[26] = 0xffff <NULL>
00:00:09.531378 auExitHistory[27] = 0xffff <NULL>
00:00:09.531379 auExitHistory[28] = 0xffff <NULL>
00:00:09.531380 auExitHistory[29] = 0xffff <NULL>
00:00:09.531381 auExitHistory[30] = 0xffff <NULL> <-- Latest exit
00:00:09.531382 HM error = 0x0 (0)
00:00:09.531509 CPU[3]: AMD-V #VMEXIT history:
00:00:09.531510 idxExitHistoryFree = 0
00:00:09.531511 auExitHistory[ 0] = 0xffff <NULL>
00:00:09.531512 auExitHistory[ 1] = 0xffff <NULL>
00:00:09.531513 auExitHistory[ 2] = 0xffff <NULL>
00:00:09.531514 auExitHistory[ 3] = 0xffff <NULL>
00:00:09.531515 auExitHistory[ 4] = 0xffff <NULL>
00:00:09.531516 auExitHistory[ 5] = 0xffff <NULL>
00:00:09.531517 auExitHistory[ 6] = 0xffff <NULL>
00:00:09.531517 auExitHistory[ 7] = 0xffff <NULL>
00:00:09.531518 auExitHistory[ 8] = 0xffff <NULL>
00:00:09.531519 auExitHistory[ 9] = 0xffff <NULL>
00:00:09.531520 auExitHistory[10] = 0xffff <NULL>
00:00:09.531521 auExitHistory[11] = 0xffff <NULL>
00:00:09.531522 auExitHistory[12] = 0xffff <NULL>
00:00:09.531523 auExitHistory[13] = 0xffff <NULL>
00:00:09.531524 auExitHistory[14] = 0xffff <NULL>
00:00:09.531525 auExitHistory[15] = 0xffff <NULL>
00:00:09.531526 auExitHistory[16] = 0xffff <NULL>
00:00:09.531526 auExitHistory[17] = 0xffff <NULL>
00:00:09.531527 auExitHistory[18] = 0xffff <NULL>
00:00:09.531528 auExitHistory[19] = 0xffff <NULL>
00:00:09.531529 auExitHistory[20] = 0xffff <NULL>
00:00:09.531530 auExitHistory[21] = 0xffff <NULL>
00:00:09.531531 auExitHistory[22] = 0xffff <NULL>
00:00:09.531532 auExitHistory[23] = 0xffff <NULL>
00:00:09.531532 auExitHistory[24] = 0xffff <NULL>
00:00:09.531533 auExitHistory[25] = 0xffff <NULL>
00:00:09.531534 auExitHistory[26] = 0xffff <NULL>
00:00:09.531535 auExitHistory[27] = 0xffff <NULL>
00:00:09.531536 auExitHistory[28] = 0xffff <NULL>
00:00:09.531537 auExitHistory[29] = 0xffff <NULL>
00:00:09.531538 auExitHistory[30] = 0xffff <NULL> <-- Latest exit
00:00:09.531539 HM error = 0x0 (0)
00:00:09.531622 !!
00:00:09.531623 !! {fflags}
00:00:09.531624 !!
00:00:09.531632 Global FFs: 0x400
00:00:09.531633 CHECK_VM_STATE
00:00:09.531634 Groups:
00:00:09.531635 EXTERNAL_SUSPENDED, EXTERNAL_HALTED, HIGH_PRIORITY_PRE, NORMAL_PRIORITY_POST, ALL_REM
00:00:09.531638 CPU 0 FFs: 0x0
00:00:09.531642 CPU 1 FFs: 0x90000
00:00:09.531643 PGM_SYNC_CR3, TLB_FLUSH
00:00:09.531645 Groups:
00:00:09.531645 HIGH_PRIORITY_PRE, HIGH_PRIORITY_PRE_RAW
00:00:09.531647 CPU 2 FFs: 0x90000
00:00:09.531648 PGM_SYNC_CR3, TLB_FLUSH
00:00:09.531649 Groups:
00:00:09.531649 HIGH_PRIORITY_PRE, HIGH_PRIORITY_PRE_RAW
00:00:09.531651 CPU 3 FFs: 0x90004
00:00:09.531652 TIMER, PGM_SYNC_CR3, TLB_FLUSH
00:00:09.531653 Groups:
00:00:09.531653 EXTERNAL_HALTED, HIGH_PRIORITY_PRE, HIGH_PRIORITY_PRE_RAW, HM_TO_R3, ALL_REM
00:00:09.531656 !!
00:00:09.531656 !! {gdtguest}
00:00:09.531656 !!
00:00:09.531658 Guest GDT (GCAddr=ffffff8000001000 limit=97):
00:00:09.531673 0010 - 0e107020 ffffff80 - base=ff800e10 limit=f7020fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531676 0020 - 0000000f 00cff200 - base=00000000 limit=f000ffff dpl=3 DataRW Present Page 32-bit
00:00:09.531679 0028 - 0000ffff 00affa00 - base=00000000 limit=ffffffff dpl=3 CodeER Present Page 16-bit
00:00:09.531682 0030 - 0e10bea0 ffffff80 - base=ff800e10 limit=fbea0fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531685 0040 - 0e2a9570 ffffff80 - base=ff800e2a limit=f9570fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531688 0050 - 103c602b ffffff80 - base=ff80103c limit=f602bfff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531691 0068 - 0e107100 ffffff80 - base=ff800e10 limit=f7100fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531694 0070 - 0e10bea0 ffffff80 - base=ff800e10 limit=fbea0fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531696 0078 - 0eaf6038 ffffff80 - base=ff800eaf limit=f6038fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531698 0080 - 0e10bef4 ffffff80 - base=ff800e10 limit=fbef4fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531700 0088 - 0e97fc78 ffffff80 - base=ff800e97 limit=ffc78fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531703 0090 - 0e10bf30 ffffff80 - base=ff800e10 limit=fbf30fff dpl=3 CodeConfER Accessed Present Page 32-bit
00:00:09.531704 !!
00:00:09.531704 !! {guestprops}
00:00:09.531705 !!
00:00:09.531708 /VirtualBox/HostInfo/GUI/LanguageID: 'en_US', 1530592575105596900 (RDONLYGUEST)
00:00:09.531711 /VirtualBox/HostInfo/VBoxVerExt: '5.2.14', 1530592573683902400 (TRANSIENT, RDONLYGUEST)
00:00:09.531713 /VirtualBox/HostGuest/SysprepExec: '', 1530592573682829800 (TRANSIENT, RDONLYGUEST)
00:00:09.531716 /VirtualBox/HostGuest/SysprepArgs: '', 1530592573682829801 (TRANSIENT, RDONLYGUEST)
00:00:09.531718 /VirtualBox/HostInfo/VBoxRev: '123301', 1530592573683902401 (TRANSIENT, RDONLYGUEST)
00:00:09.531720 /VirtualBox/HostInfo/VBoxVer: '5.2.14', 1530592573682829802 (TRANSIENT, RDONLYGUEST)
00:00:09.531724 !!
00:00:09.531724 !! {hda}
00:00:09.531725 !!
00:00:09.531730 GCAP: 0x4401
00:00:09.531731 VMIN: 0x0
00:00:09.531732 VMAJ: 0x1
00:00:09.531733 OUTPAY: 0x3c
00:00:09.531733 INPAY: 0x1d
00:00:09.531734 GCTL: 0x1
00:00:09.531735 WAKEEN: 0x0
00:00:09.531735 STATESTS: 0x1
00:00:09.531736 GSTS: 0x0
00:00:09.531736 OUTSTRMPAY: 0x0
00:00:09.531737 INSTRMPAY: 0x0
00:00:09.531738 INTCTL: 0x0
00:00:09.531738 INTSTS: 0x0
00:00:09.531739 WALCLK: 0x4401
00:00:09.531740 SSYNC: 0x0
00:00:09.531740 CORBLBASE: 0x0
00:00:09.531741 CORBUBASE: 0x0
00:00:09.531741 CORBWP: 0x0
00:00:09.531742 CORBRP: 0x0
00:00:09.531742 CORBCTL: 0x0
00:00:09.531743 CORBSTS: 0x0
00:00:09.531744 CORBSIZE: 0x42
00:00:09.531744 RIRBLBASE: 0x0
00:00:09.531745 RIRBUBASE: 0x0
00:00:09.531745 RIRBWP: 0x0
00:00:09.531746 RINTCNT: 0x1
00:00:09.531747 RIRBCTL: 0x0
00:00:09.531747 RIRBSTS: 0x0
00:00:09.531748 RIRBSIZE: 0x42
00:00:09.531748 IC: 0x0
00:00:09.531749 IR: 0x0
00:00:09.531750 IRS: 0x0
00:00:09.531750 DPLBASE: 0x0
00:00:09.531751 DPUBASE: 0x0
00:00:09.531751 SD0CTL: 0x0
00:00:09.531752 SD0STS: 0x20
00:00:09.531752 SD0LPIB: 0x0
00:00:09.531753 SD0CBL: 0x0
00:00:09.531754 SD0LVI: 0x0
00:00:09.531754 SD0FIFOW: 0x4
00:00:09.531755 SD0FIFOS: 0x77
00:00:09.531755 SD0FMT: 0x0
00:00:09.531756 SD0BDPL: 0x0
00:00:09.531757 SD0BDPU: 0x0
00:00:09.531757 SD1CTL: 0x0
00:00:09.531758 SD1STS: 0x20
00:00:09.531758 SD1LPIB: 0x0
00:00:09.531759 SD1CBL: 0x0
00:00:09.531759 SD1LVI: 0x0
00:00:09.531760 SD1FIFOW: 0x4
00:00:09.531761 SD1FIFOS: 0x77
00:00:09.531761 SD1FMT: 0x0
00:00:09.531762 SD1BDPL: 0x0
00:00:09.531762 SD1BDPU: 0x0
00:00:09.531763 SD2CTL: 0x0
00:00:09.531763 SD2STS: 0x20
00:00:09.531764 SD2LPIB: 0x0
00:00:09.531765 SD2CBL: 0x0
00:00:09.531765 SD2LVI: 0x0
00:00:09.531766 SD2FIFOW: 0x4
00:00:09.531766 SD2FIFOS: 0x77
00:00:09.531767 SD2FMT: 0x0
00:00:09.531768 SD2BDPL: 0x0
00:00:09.531768 SD2BDPU: 0x0
00:00:09.531769 SD3CTL: 0x0
00:00:09.531769 SD3STS: 0x20
00:00:09.531770 SD3LPIB: 0x0
00:00:09.531771 SD3CBL: 0x0
00:00:09.531771 SD3LVI: 0x0
00:00:09.531772 SD3FIFOW: 0x4
00:00:09.531772 SD3FIFOS: 0x77
00:00:09.531773 SD3FMT: 0x0
00:00:09.531773 SD3BDPL: 0x0
00:00:09.531774 SD3BDPU: 0x0
00:00:09.531775 SD4CTL: 0x0
00:00:09.531775 SD4STS: 0x20
00:00:09.531776 SD4LPIB: 0x0
00:00:09.531776 SD4CBL: 0x0
00:00:09.531777 SD4LVI: 0x0
00:00:09.531777 SD4FIFOW: 0x4
00:00:09.531778 SD4FIFOS: 0xbf
00:00:09.531779 SD4FMT: 0x0
00:00:09.531779 SD4BDPL: 0x0
00:00:09.531780 SD4BDPU: 0x0
00:00:09.531780 SD5CTL: 0x0
00:00:09.531781 SD5STS: 0x20
00:00:09.531781 SD5LPIB: 0x0
00:00:09.531782 SD5CBL: 0x0
00:00:09.531783 SD5LVI: 0x0
00:00:09.531783 SD5FIFOW: 0x4
00:00:09.531784 SD5FIFOS: 0xbf
00:00:09.531784 SD5FMT: 0x0
00:00:09.531785 SD5BDPL: 0x0
00:00:09.531785 SD5BDPU: 0x0
00:00:09.531786 SD6CTL: 0x0
00:00:09.531787 SD6STS: 0x20
00:00:09.531787 SD6LPIB: 0x0
00:00:09.531788 SD6CBL: 0x0
00:00:09.531788 SD6LVI: 0x0
00:00:09.531789 SD6FIFOW: 0x4
00:00:09.531789 SD6FIFOS: 0xbf
00:00:09.531790 SD6FMT: 0x0
00:00:09.531791 SD6BDPL: 0x0
00:00:09.531791 SD6BDPU: 0x0
00:00:09.531792 SD7CTL: 0x0
00:00:09.531792 SD7STS: 0x20
00:00:09.531793 SD7LPIB: 0x0
00:00:09.531793 SD7CBL: 0x0
00:00:09.531794 SD7LVI: 0x0
00:00:09.531795 SD7FIFOW: 0x4
00:00:09.531795 SD7FIFOS: 0xbf
00:00:09.531796 SD7FMT: 0x0
00:00:09.531796 SD7BDPL: 0x0
00:00:09.531797 SD7BDPU: 0x0
00:00:09.531798 !!
00:00:09.531798 !! {hdabdle}
00:00:09.531799 !!
00:00:09.531800 Stream #0 BDLE:
00:00:09.531800 Stream #1 BDLE:
00:00:09.531801 Stream #2 BDLE:
00:00:09.531802 Stream #3 BDLE:
00:00:09.531802 Stream #4 BDLE:
00:00:09.531803 Stream #5 BDLE:
00:00:09.531803 Stream #6 BDLE:
00:00:09.531804 Stream #7 BDLE:
00:00:09.531805 !!
00:00:09.531805 !! {hdamixer}
00:00:09.531806 !!
00:00:09.531807 [Master] HDA Mixer: lVol=255, rVol=255, fMuted=false
00:00:09.531809 [Sink 0] [Playback] PCM Output: lVol=255, rVol=255, fMuted=true
00:00:09.531811 [Sink 1] [Recording] Line In: lVol=1, rVol=1, fMuted=true
00:00:09.531813 !!
00:00:09.531814 !! {hdastream}
00:00:09.531814 !!
00:00:09.531815 Stream #0:
00:00:09.531815 SD0CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531820 SD0CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531822 SD0FIFOS: SDFIFOS(raw:0x77, sdfifos:120 B)
00:00:09.531824 SD0FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531826 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531829 Stream #1:
00:00:09.531829 SD1CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531832 SD1CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531834 SD1FIFOS: SDFIFOS(raw:0x77, sdfifos:120 B)
00:00:09.531835 SD1FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531837 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531839 Stream #2:
00:00:09.531840 SD2CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531842 SD2CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531844 SD2FIFOS: SDFIFOS(raw:0x77, sdfifos:120 B)
00:00:09.531845 SD2FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531846 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531849 Stream #3:
00:00:09.531849 SD3CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531852 SD3CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531853 SD3FIFOS: SDFIFOS(raw:0x77, sdfifos:120 B)
00:00:09.531855 SD3FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531856 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531858 Stream #4:
00:00:09.531858 SD4CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531861 SD4CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531863 SD4FIFOS: SDFIFOS(raw:0xbf, sdfifos:192 B)
00:00:09.531864 SD4FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531865 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531867 Stream #5:
00:00:09.531868 SD5CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531870 SD5CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531872 SD5FIFOS: SDFIFOS(raw:0xbf, sdfifos:192 B)
00:00:09.531873 SD5FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531874 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531876 Stream #6:
00:00:09.531876 SD6CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531879 SD6CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531880 SD6FIFOS: SDFIFOS(raw:0xbf, sdfifos:192 B)
00:00:09.531882 SD6FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531883 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531885 Stream #7:
00:00:09.531885 SD7CTL : SDCTL(raw:0x0, DIR:IN, TP:false, STRIPE:0, DEIE:false, FEIE:false, IOCE:false, RUN:false, RESET:false)
00:00:09.531888 SD7CTS : SDSTS(raw:0x20, fifordy:true , dese:false, fifoe:false, bcis:false)
00:00:09.531889 SD7FIFOS: SDFIFOS(raw:0xbf, sdfifos:192 B)
00:00:09.531890 SD7FIFOW: SDFIFOW(raw: 0x4, sdfifow:32 B)
00:00:09.531892 BDLE : BDLE(idx:0, off:0, fifow:0, IOC:false, DMA[0 bytes @ 0x0])
00:00:09.531894 !!
00:00:09.531894 !! {hdcnodes}
00:00:09.531895 !!
00:00:09.531896 Codec implementation doesn't provide corresponding callback
00:00:09.531897 !!
00:00:09.531897 !! {hdcselector}
00:00:09.531898 !!
00:00:09.531898 Codec implementation doesn't provide corresponding callback
00:00:09.531900 !!
00:00:09.531901 !! {hmeventpending}
00:00:09.531901 !!
00:00:09.531907 CPU[0]: HM event (fPending=false)
00:00:09.531913 CPU[1]: HM event (fPending=false)
00:00:09.531927 CPU[2]: HM event (fPending=false)
00:00:09.531936 CPU[3]: HM event (fPending=false)
00:00:09.531949 !!
00:00:09.531950 !! {hpet}
00:00:09.531950 !!
00:00:09.531957 HPET status:
00:00:09.531957 config=0000000000000000 isr=0000000000000000
00:00:09.531958 offset=0000000000000000 counter=0000000000000000 frequency=0429b17f
00:00:09.531960 legacy-mode=off timer-count=3
00:00:09.531961 Timers:
00:00:09.531962 0: comparator=ffffffffffffffff period(hidden)=0000000000000000 cfg=ffffffff00000030
00:00:09.531964 1: comparator=00000000ffffffff period(hidden)=0000000000000000 cfg=ffffffff00000000
00:00:09.531967 2: comparator=00000000ffffffff period(hidden)=0000000000000000 cfg=ffffffff00000000
00:00:09.531969 3: comparator=00000000ffffffff period(hidden)=0000000000000000 cfg=ffffffff00000000
00:00:09.531971 !!
00:00:09.531972 !! {ioapic}
00:00:09.531972 !!
00:00:09.531973 I/O APIC at 0xfec00000:
00:00:09.531974 ID = 0x0
00:00:09.531975 ID = 0x0
00:00:09.531976 Version = 0x170020
00:00:09.531977 Version = 0x20
00:00:09.531978 Pin Assert Reg. Support = false
00:00:09.531979 Max. Redirection Entry = 23
00:00:09.531979 Current index = 0x0
00:00:09.531980 I/O Redirection Table and IRR:
00:00:09.531981 idx dst_mode dst_addr mask irr trigger rirr polar dlvr_st dlvr_mode vector
00:00:09.531982 00 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531984 01 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531986 02 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531989 03 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531991 04 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531993 05 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531994 06 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531996 07 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.531998 08 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532000 09 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532002 10 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532004 11 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532005 12 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532007 13 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532009 14 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532011 15 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532012 16 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532014 17 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532016 18 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532018 19 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532019 20 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532021 21 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532023 22 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532025 23 phys 00 1 0 edge 0 acthi idle Fixed 0 (0000000000010000)
00:00:09.532027 !!
00:00:09.532027 !! {ioport}
00:00:09.532028 !!
00:00:09.532029 I/O Port R3 ranges (pVM=0000000001b00000)
00:00:09.532029 Range pDevIns In Out pvUser Description
00:00:09.532034 0000-0007 000000000782cce0 00007fff636bd8f0 00007fff636bd830 000000000782cdf0 DMA8 Address
00:00:09.532037 0008-000f 000000000782cce0 00007fff636bdab0 00007fff636bd980 000000000782cdf0 DMA8 Control
00:00:09.532039 0020-0021 0000000006e11500 00007fff6369dd00 00007fff6369ddc0 0000000000000000 i8259 PIC #0
00:00:09.532042 0040-0043 0000000006e12530 00007fff6369bc50 00007fff6369c8d0 0000000000000000 i8254 Programmable Interval Timer
00:00:09.532044 0060-0060 0000000006e642e0 00007fff63671ff0 00007fff63672090 0000000000000000 PC Keyboard - Data
00:00:09.532046 0061-0061 0000000006e12530 00007fff6369be00 00007fff6369cb60 0000000000000000 PC Speaker
00:00:09.532048 0064-0064 0000000006e642e0 00007fff636720c0 00007fff63672100 0000000000000000 PC Keyboard - Command / Status
00:00:09.532051 0070-0073 0000000006e12a10 00007fff636a42d0 00007fff636a4430 0000000000000000 MC146818 RTC/CMOS
00:00:09.532053 0080-0087 000000000782cce0 00007fff636bdbe0 00007fff636bdc40 000000000782cdf0 DMA8 Page
00:00:09.532055 0088-008f 000000000782cce0 00007fff636bdbe0 00007fff636bdc40 000000000782ce90 DMA16 Page
00:00:09.532057 0092-0092 0000000004bc0f40 00007fff636ab840 00007fff636ab880 0000000000000000 PS/2 system control port A (A20 and more)
00:00:09.532059 00a0-00a1 0000000006e11500 00007fff6369dd00 00007fff6369ddc0 0000000000000001 i8259 PIC #1
00:00:09.532061 00c0-00cf 000000000782cce0 00007fff636bd8f0 00007fff636bd830 000000000782ce90 DMA16 Address
00:00:09.532063 00d0-00df 000000000782cce0 00007fff636bdab0 00007fff636bd980 000000000782ce90 DMA16 Control
00:00:09.532065 00f0-00ff 0000000004bc0f40 00007fff636ab7c0 00007fff636ab7e0 0000000000000000 Math Co-Processor (DOS/OS2 mode)
00:00:09.532068 01ce-01ce 000000000ba70000 00007fff63689410 00007fff63689320 0000000000000000 VGA/VBE - Index
00:00:09.532070 01cf-01cf 000000000ba70000 00007fff63689380 00007fff63689290 0000000000000000 VGA/VBE - Data
00:00:09.532072 0300-031f 0000000006e10940 00007fff63682a00 00007fff63682930 0000000000000000 SMC data port
00:00:09.532075 03b0-03b3 000000000ba70000 00007fff63689550 00007fff63689470 0000000000000000 VGA - 3b0 (HGSMI host)
00:00:09.532077 03b4-03b5 000000000ba70000 00007fff636891f0 00007fff63689170 0000000000000000 VGA - 3b4
00:00:09.532079 03b6-03b6 000000000ba70000 00007fff6368a0c0 00007fff6368a0a0 0000000000000000 VBE BIOS Extra Data
00:00:09.532081 03b7-03b7 000000000ba70000 00007fff636794d0 00007fff6368a070 0000000000000000 VGA BIOS debug/panic
00:00:09.532083 03b8-03b8 000000000ba70000 00007fff6368ad20 00007fff6368aac0 0000000000000000 BIOS Logo
00:00:09.532085 03ba-03ba 000000000ba70000 00007fff636891f0 00007fff63689170 0000000000000000 VGA - 3ba
00:00:09.532087 03c0-03cf 000000000ba70000 00007fff636891f0 00007fff63689170 0000000000000000 VGA - 3c0
00:00:09.532090 03d0-03d3 000000000ba70000 00007fff63689550 00007fff63689470 0000000000000000 VGA - 3d0 (HGSMI guest)
00:00:09.532092 03d4-03d5 000000000ba70000 00007fff636891f0 00007fff63689170 0000000000000000 VGA - 3d4
00:00:09.532094 03da-03da 000000000ba70000 00007fff636891f0 00007fff63689170 0000000000000000 VGA - 3da
00:00:09.532096 0410-0410 0000000006e23170 00007fff636794d0 00007fff63680ba0 0000000000000000 ICH9 (Fake PCI BIOS trigger)
00:00:09.532098 04d0-04d0 0000000006e11500 00007fff6369de50 00007fff6369ded0 0000000006e11600 i8259 PIC #0 - elcr
00:00:09.532100 04d1-04d1 0000000006e11500 00007fff6369de50 00007fff6369ded0 0000000006e11648 i8259 PIC #1 - elcr
00:00:09.532102 0504-0504 0000000006e13250 00007fff77525fc0 00007fff636b0830 0000000000000000 VMMDev backdoor logging
00:00:09.532105 0505-0505 0000000006e13250 00007fff636b09b0 00007fff636b0980 0000000000000000 VMMDev timesync backdoor
00:00:09.532107 0cf8-0cf8 0000000006e23170 00007fff6367b340 00007fff6367b2f0 0000000000000000 ICH9 (PCI)
00:00:09.532109 0cfc-0cff 0000000006e23170 00007fff6367db60 00007fff6367da20 0000000000000000 ICH9 (PCI)
00:00:09.532111 4000-4000 0000000006e7e400 00007fff6369fc60 00007fff6369fce0 0000000006e7e500 ACPI PM1a Status
00:00:09.532113 4002-4002 0000000006e7e400 00007fff6369fb60 00007fff6369fbd0 0000000006e7e500 ACPI PM1a Enable
00:00:09.532115 4004-4004 0000000006e7e400 00007fff6369fd80 00007fff6369fe00 0000000006e7e500 ACPI PM1a Control
00:00:09.532117 4008-4008 0000000006e7e400 00007fff636a0010 00007fff775660c0 0000000006e7e500 ACPI PM Timer
00:00:09.532119 4020-4020 0000000006e7e400 00007fff636a00f0 00007fff636a0170 0000000006e7e500 ACPI GPE0 Status
00:00:09.532121 4021-4021 0000000006e7e400 00007fff636a01f0 00007fff636a0270 0000000006e7e500 ACPI GPE0 Enable
00:00:09.532124 4040-4040 0000000006e7e400 00007fff77525fc0 00007fff6369f350 0000000006e7e500 ACPI Battery status index
00:00:09.532312 4044-4044 0000000006e7e400 00007fff6369f3e0 00007fff775660c0 0000000006e7e500 ACPI Battery status data
00:00:09.532316 4048-4048 0000000006e7e400 00007fff77525fc0 00007fff6369f5c0 0000000006e7e500 ACPI system info index
00:00:09.532319 404c-404c 0000000006e7e400 00007fff6369f680 00007fff6369fa40 0000000006e7e500 ACPI system info data
00:00:09.532321 4050-4050 0000000006e7e400 00007fff77525fc0 00007fff636a0380 0000000006e7e500 ACPI Reset
00:00:09.532323 4100-410f 0000000006e7e400 00007fff636a09c0 00007fff636a0810 0000000006e7e500 SMBus
00:00:09.532326 442e-442e 0000000006e7e400 00007fff77525fc0 00007fff636a02f0 0000000006e7e500 ACPI SMI
00:00:09.532328 c000-c000 0000000006e13250 00007fff77525fc0 00007fff636b0470 0000000006e13350 VMMDev Request Handler
00:00:09.532330 c020-c02f 0000000006e6f500 00007fff6372f3e0 00007fff6372f380 0000000000000000 AHCI IDX/DATA
00:00:09.532332 c030-c037 0000000006e6f500 00007fff636cc250 00007fff636cc250 0000000000000000 AHCI Fake
00:00:09.532335 c038-c03f 0000000006e6f500 00007fff636cc250 00007fff636cc250 0000000000000000 AHCI Fake
00:00:09.532337 c040-c047 0000000006e74670 00007fff63723fb0 00007fff63724040 0000000000000000 E1000
00:00:09.532339 ef10-ef17 0000000009fde050 00007fff63745ed0 00007fff63746080 0000000000000000 EFI communication ports
00:00:09.532341 I/O Port R0 ranges (pVM=0000000001b00000)
00:00:09.532342 Range pDevIns In Out pvUser Description
00:00:09.532344 0020-0021 0000000006e11500 fffff80017e36be0 fffff80017e36ca0 0000000000000000 i8259 PIC #0
00:00:09.532347 0040-0043 0000000006e12530 fffff80017e35f60 fffff80017e36110 0000000000000000 i8254 Programmable Interval Timer
00:00:09.532350 0060-0060 0000000006e642e0 fffff80017e347a0 fffff80017e34840 0000000000000000 PC Keyboard - Data
00:00:09.532352 0064-0064 0000000006e642e0 fffff80017e34870 fffff80017e348b0 0000000000000000 PC Keyboard - Command / Status
00:00:09.532355 0070-0073 0000000006e12a10 fffff80017e37050 fffff80017e371b0 0000000000000000 MC146818 RTC/CMOS
00:00:09.532357 00a0-00a1 0000000006e11500 fffff80017e36be0 fffff80017e36ca0 0000000000000001 i8259 PIC #1
00:00:09.532359 01ce-01ce 000000000ba70000 fffff80017e33580 fffff80017e33490 0000000000000000 VGA/VBE - Index (GC)
00:00:09.532362 01cf-01cf 000000000ba70000 fffff80017e334f0 fffff80017e33400 0000000000000000 VGA/VBE - Data (GC)
00:00:09.532364 03b4-03b5 000000000ba70000 fffff80017e33360 fffff80017e332e0 0000000000000000 VGA - 3b4 (GC)
00:00:09.532367 03b7-03b7 000000000ba70000 fffff80017e34100 fffff80017e34110 0000000000000000 VGA BIOS debug/panic
00:00:09.532369 03ba-03ba 000000000ba70000 fffff80017e33360 fffff80017e332e0 0000000000000000 VGA - 3ba (GC)
00:00:09.532372 03c0-03cf 000000000ba70000 fffff80017e33360 fffff80017e332e0 0000000000000000 VGA - 3c0 (GC)
00:00:09.532374 03d4-03d5 000000000ba70000 fffff80017e33360 fffff80017e332e0 0000000000000000 VGA - 3d4 (GC)
00:00:09.532376 03da-03da 000000000ba70000 fffff80017e33360 fffff80017e332e0 0000000000000000 VGA - 3da (GC)
00:00:09.532379 04d0-04d0 0000000006e11500 fffff80017e36d30 fffff80017e36db0 0000000006e11600 i8259 PIC #0 - elcr
00:00:09.532381 04d1-04d1 0000000006e11500 fffff80017e36d30 fffff80017e36db0 0000000006e11648 i8259 PIC #1 - elcr
00:00:09.532384 0cf8-0cf8 0000000006e23170 fffff80017e31520 fffff80017e31330 0000000000000000 ICH9 (PCI)
00:00:09.532386 0cfc-0cff 0000000006e23170 fffff80017e31620 fffff80017e31580 0000000000000000 ICH9 (PCI)
00:00:09.532389 4008-4008 0000000006e7e400 fffff80017e35750 0000000000000000 0000000000000000 ACPI PM Timer
00:00:09.532391 c020-c02f 0000000006e6f500 fffff80017e44ff0 fffff80017e44f90 0000000000000000 AHCI IDX/DATA
00:00:09.532394 c030-c037 0000000006e6f500 fffff80017e428e0 fffff80017e428e0 0000000000000000 AHCI Fake
00:00:09.532396 c038-c03f 0000000006e6f500 fffff80017e428e0 fffff80017e428e0 0000000000000000 AHCI Fake
00:00:09.532399 c040-c047 0000000006e74670 fffff80017e42180 fffff80017e42210 0000000000000000 E1000
00:00:09.532401 I/O Port GC ranges (pVM=0000000001b00000)
00:00:09.532402 Range pDevIns In Out pvUser Description
00:00:09.532404 !!
00:00:09.532405 !! {ldtguest}
00:00:09.532405 !!
00:00:09.532406 Guest LDT (Sel=30 GCAddr=ffffff800ea15000 limit=17):
00:00:09.532415 000c - 0000ffff 00cff200 - base=00000000 limit=ffffffff dpl=3 DataRW Present Page 32-bit
00:00:09.532417 !!
00:00:09.532417 !! {lpc}
00:00:09.532418 !!
00:00:09.532419 APIC backdoor closed: 00 00
00:00:09.532420 PIRQA -> IRQ11
00:00:09.532421 PIRQB -> IRQ9
00:00:09.532422 PIRQC -> IRQ11
00:00:09.532422 PIRQD -> IRQ9
00:00:09.532423 PIRQE disabled
00:00:09.532424 PIRQF disabled
00:00:09.532424 PIRQG disabled
00:00:09.532425 PIRQH disabled
00:00:09.532426 !!
00:00:09.532427 !! {mmio}
00:00:09.532427 !!
00:00:09.532428 MMIO ranges (pVM=0000000001b00000)
00:00:09.532429 GC Phys Range pDevIns Read Write Fill pvUser Description
00:00:09.532432 00000000000a0000-00000000000bffff 000000000ba70000 00007fff63689c30 00007fff63689df0 00007fff63689c00 0000000000000000 VGA - VGA Video Buffer
00:00:09.532436 R0 000000000ba70000 fffff80017e33c50 fffff80017e33e10 fffff80017e33c20 0000000000000000
00:00:09.532440 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532443 00000000000c9000-00000000000dffff 0000000004bc0f40 00007fff636ab910 00007fff636cc250 0000000000000000 0000000000000000 PC Arch Reserved #0
00:00:09.532446 R0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
00:00:09.532449 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532451 00000000000e2000-00000000000effff 0000000004bc0f40 00007fff636ab910 00007fff636cc250 0000000000000000 0000000000000000 PC Arch Reserved #1
00:00:09.532454 R0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
00:00:09.532456 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532466 00000000dc000000-00000000dfffffff 0000000006e23170 00007fff6367dd80 00007fff6367dcc0 0000000000000000 0000000000000000 MCFG ranges
00:00:09.532469 R0 0000000006e23170 fffff80017e31970 fffff80017e318e0 0000000000000000 0000000000000000
00:00:09.532473 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532475 00000000e8400000-00000000e841ffff 0000000006e74670 00007fff63723f10 00007fff63723f30 0000000000000000 0000000000000000 E1000
00:00:09.532478 R0 0000000006e74670 fffff80017e420e0 fffff80017e42100 0000000000000000 0000000000000000
00:00:09.532481 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532483 00000000e8424000-00000000e8427fff 0000000006e79df0 00007fff63751a10 00007fff63751d10 0000000000000000 0000000000000000 HDA
00:00:09.532486 R0 0000000006e79df0 fffff80017e3e770 fffff80017e3e9d0 0000000000000000 0000000000000000
00:00:09.532489 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532492 00000000e8428000-00000000e8429fff 0000000006e6f500 00007fff6372f2b0 00007fff6372f2d0 0000000000000000 0000000000000000 AHCI
00:00:09.532495 R0 0000000006e6f500 fffff80017e44ec0 fffff80017e44ee0 0000000000000000 0000000000000000
00:00:09.532498 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532500 00000000e842a000-00000000e842afff 0000000006e7ca70 00007fff637060d0 00007fff63706130 0000000000000000 0000000000000000 USB OHCI
00:00:09.532503 R0 0000000006e7ca70 fffff80017e44520 fffff80017e44580 0000000000000000 0000000000000000
00:00:09.532506 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532508 00000000fec00000-00000000fec00fff 0000000006e119d0 00007fff636c0e10 00007fff636c0e50 0000000000000000 0000000006e11ad0 I/O APIC
00:00:09.532511 R0 0000000006e119d0 fffff80017e35ba0 fffff80017e35c50 0000000000000000 0000000000000000
00:00:09.532515 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532517 00000000fed00000-00000000fed00fff 0000000006e11e00 00007fff636bf900 00007fff636bfad0 0000000000000000 0000000006e11f00 HPET Memory
00:00:09.532520 R0 0000000006e11e00 fffff80017e38100 fffff80017e382d0 0000000000000000 0000000000000000
00:00:09.532523 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532526 00000000fed1c000-00000000fed1ffff 000000000784d580 00007fff89e71080 00007fff89e710b0 0000000000000000 000000000784d680 LPC Memory
00:00:09.532528 R0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
00:00:09.532531 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532533 00000000fee00000-00000000fee00fff 0000000006e64ce0 00007fff775acc00 00007fff775ae190 0000000000000000 0000000000000000 APIC
00:00:09.532536 R0 0000000006e64ce0 fffff80017d186e0 fffff80017d19ca0 0000000000000000 0000000000000000
00:00:09.532539 RC 00000000 00000000 00000000 00000000 00000000
00:00:09.532542 !!
00:00:09.532543 !! {nat0}
00:00:09.532543 !!
00:00:09.532544 NAT parameters: MTU=1500
00:00:09.532545 NAT TCP ports:
00:00:09.532546 NAT UDP ports:
00:00:09.532546 NAT ARP cache:
00:00:09.532547 NAT rules:
00:00:09.532548 !!
00:00:09.532548 !! {nvram}
00:00:09.532549 !!
00:00:09.532550 NVRAM variables: 28
00:00:09.532552 Variable - fAttr=0x07 - '378d7b65-8da9-4773-b6e4-a47826a833e1:RTC' - cb=0x04
00:00:09.532557 0000000004be7d60 0000: ff 07 00 00 ....
00:00:09.532568 Variable - fAttr=0x03 - '4c19049f-4137-4dd3-9c10-8b97a83ffdfa:MemoryTypeInformation' - cb=0x40
00:00:09.532571 0000000004c0a190 0000: 0a 00 00 00 04 00 00 00-09 00 00 00 0d 00 00 00 ................
00:00:09.532575 0000000004c0a1a0 0010: 00 00 00 00 04 00 00 00-06 00 00 00 24 00 00 00 ............$...
00:00:09.532579 0000000004c0a1b0 0020: 05 00 00 00 30 00 00 00-03 00 00 00 80 01 00 00 ....0...........
00:00:09.532582 0000000004c0a1c0 0030: 04 00 00 00 00 0f 00 00-0f 00 00 00 00 00 00 00 ................
00:00:09.532586 Variable - fAttr=0x06 - '4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14:BackgroundClear' - cb=0x04
00:00:09.532589 0000000004bfcf40 0000: 00 00 00 00 ....
00:00:09.532591 Variable - fAttr=0x07 - '4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14:FirmwareFeatures' - cb=0x04
00:00:09.532594 0000000004bfd780 0000: 15 00 00 80 ....
00:00:09.532596 Variable - fAttr=0x07 - '4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14:FirmwareFeaturesMask' - cb=0x04
00:00:09.532599 0000000004bfdfc0 0000: ff 03 00 80 ....
00:00:09.532601 Variable - fAttr=0x06 - '4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14:MLB' - cb=0x182
00:00:09.532604 0000000004c065a0 0000: bb 00 f0 8e db bb 74 ff-2e 66 0f 01 17 66 b8 23 ......t..f...f.#
00:00:09.532607 0000000004c065b0 0010: 00 00 80 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532610 0000000004c065c0 0020: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532614 0000000004c065d0 0030: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532617 0000000004c065e0 0040: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532620 0000000004c065f0 0050: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532623 0000000004c06600 0060: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532626 0000000004c06610 0070: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532629 0000000004c06620 0080: 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532632 0000000004c06630 0090: 00 00 00 00 00 00 00 00-00 00 30 e1 f9 db 00 00 ..........0.....
00:00:09.532636 0000000004c06640 00a0: 00 00 00 00 00 00 00 00-00 00 18 56 76 db 00 00 ...........Vv...
00:00:09.532639 0000000004c06650 00b0: 00 00 c0 cd f9 db 00 00-00 00 b8 cd f9 db 00 00 ................
00:00:09.532642 0000000004c06660 00c0: 00 00 ee 00 00 00 00 00-00 00 01 00 00 00 00 00 ................
00:00:09.532645 0000000004c06670 00d0: 00 00 b8 cd f9 db 00 00-00 00 18 f4 14 db 00 00 ................
00:00:09.532648 0000000004c06680 00e0: 00 00 0a 0b fa db 00 00-00 00 01 00 00 00 00 00 ................
00:00:09.532652 0000000004c06690 00f0: 00 00 40 56 76 db 00 00-00 00 00 00 00 00 00 00 ..@Vv...........
00:00:09.532655 0000000004c066a0 0100: 00 00 18 07 15 db 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532658 0000000004c066b0 0110: 00 00 00 00 00 00 00 00-00 00 01 00 00 00 00 00 ................
00:00:09.532661 0000000004c066c0 0120: 00 00 e6 4f e9 db 00 00-00 00 18 04 15 db 00 00 ...O............
00:00:09.532665 0000000004c066d0 0130: 00 00 a9 cc f9 db 00 00-00 00 18 07 15 db 00 00 ................
00:00:09.532668 0000000004c066e0 0140: 00 00 01 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532671 0000000004c066f0 0150: 00 00 10 cd f9 db 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532674 0000000004c06700 0160: 00 00 e1 45 e8 db 00 00-00 00 18 02 15 db 00 00 ...E............
00:00:09.532677 0000000004c06710 0170: 00 00 d0 cc f9 db 00 00-00 00 00 00 00 00 00 00 ................
00:00:09.532681 0000000004c06720 0180: 00 00 ..
00:00:09.532682 Variable - fAttr=0x06 - '4d1ede05-38c7-4a6a-9cc6-4bcca8b38c14:ROM' - cb=0x06
00:00:09.532685 0000000004c087e0 0000: 00 02 c7 05 10 10 ......
00:00:09.532687 Variable - fAttr=0x06 - '7c436110-ab2a-4bbb-a880-fe41995c9f82:boot-args' - cb=0x24
00:00:09.532690 String value (UTF-8): "usb=0x800 keepsyms=1 -v -serial=0x1"
00:00:09.532691 Variable - fAttr=0x07 - '7c436110-ab2a-4bbb-a880-fe41995c9f82:platform-uuid' - cb=0x10
00:00:09.532694 String value (UTF-8,nz): "a��o;G?��~�Cp�"
00:00:09.532695 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:Boot0000' - cb=0xb2
00:00:09.532698 0000000004c076c0 0000: 01 00 00 00 9a 00 4d 00-61 00 63 00 20 00 42 00 ......M.a.c. .B.
00:00:09.532701 0000000004c076d0 0010: 6f 00 6f 00 74 00 00 00-02 01 0c 00 d0 41 03 0a o.o.t........A..
00:00:09.532704 0000000004c076e0 0020: 00 00 00 00 01 01 06 00-02 1f 03 12 0a 00 00 00 ................
00:00:09.532708 0000000004c076f0 0030: 00 00 00 00 04 01 2a 00-02 00 00 00 28 40 06 00 ......*.....(@..
00:00:09.532711 0000000004c07700 0040: 00 00 00 00 90 60 66 0c-00 00 00 00 0c 1d 24 e5 .....`f.......$.
00:00:09.532714 0000000004c07710 0050: 0e 1d d3 45 aa 15 32 5c-f9 44 ff 50 02 02 04 04 ...E..2\.D.P....
00:00:09.532718 0000000004c07720 0060: 50 00 5c 00 53 00 79 00-73 00 74 00 65 00 6d 00 P.\.S.y.s.t.e.m.
00:00:09.532721 0000000004c07730 0070: 5c 00 4c 00 69 00 62 00-72 00 61 00 72 00 79 00 \.L.i.b.r.a.r.y.
00:00:09.532724 0000000004c07740 0080: 5c 00 43 00 6f 00 72 00-65 00 53 00 65 00 72 00 \.C.o.r.e.S.e.r.
00:00:09.532727 0000000004c07750 0090: 76 00 69 00 63 00 65 00-73 00 5c 00 62 00 6f 00 v.i.c.e.s.\.b.o.
00:00:09.532730 0000000004c07760 00a0: 6f 00 74 00 2e 00 65 00-66 00 69 00 00 00 7f ff o.t...e.f.i.....
00:00:09.532734 0000000004c07770 00b0: 04 00 ..
00:00:09.532736 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:Boot0001' - cb=0x42
00:00:09.532739 0000000004c04bf0 0000: 01 00 00 00 20 00 45 00-46 00 49 00 20 00 44 00 .... .E.F.I. .D.
00:00:09.532742 0000000004c04c00 0010: 56 00 44 00 2f 00 43 00-44 00 52 00 4f 00 4d 00 V.D./.C.D.R.O.M.
00:00:09.532745 0000000004c04c10 0020: 00 00 02 01 0c 00 d0 41-03 0a 00 00 00 00 01 01 .......A........
00:00:09.532748 0000000004c04c20 0030: 06 00 02 1f 03 12 0a 00-01 00 00 00 00 00 7f ff ................
00:00:09.532752 0000000004c04c30 0040: 04 00 ..
00:00:09.532753 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:Boot0002' - cb=0x44
00:00:09.532756 0000000004c07f50 0000: 01 00 00 00 20 00 45 00-46 00 49 00 20 00 48 00 .... .E.F.I. .H.
00:00:09.532759 0000000004c07f60 0010: 61 00 72 00 64 00 20 00-44 00 72 00 69 00 76 00 a.r.d. .D.r.i.v.
00:00:09.532762 0000000004c07f70 0020: 65 00 00 00 02 01 0c 00-d0 41 03 0a 00 00 00 00 e........A......
00:00:09.532765 0000000004c07f80 0030: 01 01 06 00 02 1f 03 12-0a 00 00 00 00 00 00 00 ................
00:00:09.532768 0000000004c07f90 0040: 7f ff 04 00 ....
00:00:09.532770 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:Boot0003' - cb=0x5c
00:00:09.532773 0000000004c05480 0000: 01 00 00 00 30 00 45 00-46 00 49 00 20 00 49 00 ....0.E.F.I. .I.
00:00:09.532776 0000000004c05490 0010: 6e 00 74 00 65 00 72 00-6e 00 61 00 6c 00 20 00 n.t.e.r.n.a.l. .
00:00:09.532779 0000000004c054a0 0020: 53 00 68 00 65 00 6c 00-6c 00 00 00 01 03 18 00 S.h.e.l.l.......
00:00:09.532782 0000000004c054b0 0030: 0b 00 00 00 00 00 10 02-00 00 00 00 ff ff 8f 02 ................
00:00:09.532785 0000000004c054c0 0040: 00 00 00 00 04 06 14 00-83 a5 04 7c 3e 9e 1c 4f ...........|>..O
00:00:09.532788 0000000004c054d0 0050: ad 65 e0 52 68 d0 b4 d1-7f ff 04 00 .e.Rh.......
00:00:09.532791 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:BootCurrent' - cb=0x02
00:00:09.532794 0000000004c09070 0000: 00 00 ..
00:00:09.532796 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:BootOptionSupport' - cb=0x04
00:00:09.532799 0000000004bff040 0000: 03 03 00 00 ....
00:00:09.532801 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:BootOrder' - cb=0x08
00:00:09.532804 0000000004c09900 0000: 00 00 01 00 02 00 03 00 ........
00:00:09.532807 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:ConIn' - cb=0x22
00:00:09.532810 0000000004c03240 0000: 02 01 0c 00 d0 41 03 0a-00 00 00 00 01 01 06 00 .....A..........
00:00:09.532813 0000000004c03250 0010: 00 1f 02 01 0c 00 d0 41-03 03 00 00 00 00 7f ff .......A........
00:00:09.532816 0000000004c03260 0020: 04 00 ..
00:00:09.532818 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:ConInDev' - cb=0x22
00:00:09.532820 0000000004c04360 0000: 02 01 0c 00 d0 41 03 0a-00 00 00 00 01 01 06 00 .....A..........
00:00:09.532824 0000000004c04370 0010: 00 1f 02 01 0c 00 d0 41-03 03 00 00 00 00 7f ff .......A........
00:00:09.532827 0000000004c04380 0020: 04 00 ..
00:00:09.533368 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:ConOut' - cb=0x1e
00:00:09.533386 0000000004c02a00 0000: 02 01 0c 00 d0 41 03 0a-00 00 00 00 01 01 06 00 .....A..........
00:00:09.533389 0000000004c02a10 0010: 00 02 02 03 08 00 00 01-01 80 7f ff 04 00 ..............
00:00:09.533394 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:ConOutDev' - cb=0x1e
00:00:09.533397 0000000004c021c0 0000: 02 01 0c 00 d0 41 03 0a-00 00 00 00 01 01 06 00 .....A..........
00:00:09.533408 0000000004c021d0 0010: 00 02 02 03 08 00 00 01-01 80 7f ff 04 00 ..............
00:00:09.533412 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:Lang' - cb=0x04
00:00:09.533415 String value (UTF-8): "eng"
00:00:09.533419 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:LangCodes' - cb=0x0d
00:00:09.533429 String value (UTF-8): "engfraengfra"
00:00:09.533431 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:OsIndicationsSupported' - cb=0x08
00:00:09.533439 0000000004bff880 0000: 09 00 00 00 00 00 00 00 ........
00:00:09.533442 Variable - fAttr=0x07 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:PlatformLang' - cb=0x06
00:00:09.533444 String value (UTF-8): "en-US"
00:00:09.533453 Variable - fAttr=0x06 - '8be4df61-93ca-11d2-aa0d-00e098032b8c:PlatformLangCodes' - cb=0x12
00:00:09.533456 String value (UTF-8): "en;fr;en-US;fr-FR"
00:00:09.533457 Variable - fAttr=0x07 - 'e660597e-b94d-4209-9c80-1805b5d19b69:Test0' - cb=0x10
00:00:09.533460 String value (UTF-8): "This is test!!!"
00:00:09.533461 Variable - fAttr=0x07 - 'e660597e-b94d-4209-9c80-1805b5d19b69:Test1' - cb=0x20
00:00:09.533464 String value (UTF-16): "This is test!!!"
00:00:09.533466 Variable - fAttr=0x07 - 'eb704011-1402-11d3-8e77-00a0c969723b:MTC' - cb=0x04
00:00:09.533482 0000000004bfc700 0000: 01 00 00 00 ....
00:00:09.533486 !!
00:00:09.533487 !! {ohci}
00:00:09.533487 !!
00:00:09.533489 HcControl: 00000200 - CBSR=0 PLE=0 IE=0 CLE=0 BLE=0 HCFS=0x0 IR=0 RWC=1 RWE=0
00:00:09.533492 HcCommandStatus: 00000000 - HCR=0 CLF=0 BLF=0 OCR=0 SOC=0
00:00:09.533493 HcInterruptStatus: 00000040 - SO=0 WDH=0 SF=0 RD=0 UE=0 FNO=0 RHSC=1 OC=0
00:00:09.533496 HcInterruptEnable: 00000000 - SO=0 WDH=0 SF=0 RD=0 UE=0 FNO=0 RHSC=0 OC=0 MIE=0
00:00:09.533498 HcHCCA: 00000000
00:00:09.533498 HcPeriodCurrentED: 00000000
00:00:09.533499 HcControlHeadED: 00000000
00:00:09.533500 HcControlCurrentED: 00000000
00:00:09.533501 HcBulkHeadED: 00000000
00:00:09.533501 HcBulkCurrentED: 00000000
00:00:09.533502 HcDoneHead: 00000000
00:00:09.533503 HcDoneHead: 00000000
00:00:09.533504 HcRhDescriptorA: 0000020c - NDP=12 PSM=0 NPS=1 DT=0 OCPM=0 NOCP=0 POTPGT=0
00:00:09.533506 HcRhDescriptorB: 00000000 - DR=0x00 PPCM=0x00
00:00:09.533507 HcRhStatus: 00000000 - LPS=0 OCI=0 DRWE=0 LPSC=0 OCIC=0 CRWE=0
00:00:09.533509
00:00:09.533510 HcRhPortStatus00: CCS=1 PES =0 PSS =0 POCI=0 PRS =0 PPS=1 LSDA=0
00:00:09.533511 00010101 - CSC=1 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533513 HcRhPortStatus01: CCS=1 PES =0 PSS =0 POCI=0 PRS =0 PPS=1 LSDA=0
00:00:09.533514 00010101 - CSC=1 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533515 HcRhPortStatus02: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533517 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533518 HcRhPortStatus03: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533519 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533520 HcRhPortStatus04: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533521 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533523 HcRhPortStatus05: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533524 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533525 HcRhPortStatus06: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533526 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533527 HcRhPortStatus07: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533528 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533530 HcRhPortStatus08: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533531 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533532 HcRhPortStatus09: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533533 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533534 HcRhPortStatus10: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533535 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533537 HcRhPortStatus11: CCS=0 PES =0 PSS =0 POCI=0 PRS =0 PPS=0 LSDA=0
00:00:09.533538 00000000 - CSC=0 PESC=0 PSSC=0 OCIC=0 PRSC=0
00:00:09.533540 !!
00:00:09.533540 !! {pci}
00:00:09.533541 !!
00:00:09.533556 00:02.0 vga: 80ee-beef ICH9 IRQ0 (INTA#->IRQ18)
00:00:09.533559 Class base/sub: 0300 (display controller)
00:00:09.533562 MMIO32 PREFETCH region #0: e0000000..e7ffffff
00:00:09.533565 Command: 0017, Status: 0000
00:00:09.533566 Bus master: Yes
00:00:09.533567 00:04.0 VMMDev: 80ee-cafe ICH9 IRQ255 (INTA#->IRQ20)
00:00:09.533570 Class base/sub: 0880 (base system peripherals)
00:00:09.533572 IO region #0: c000..c01f
00:00:09.533574 MMIO32 region #1: e8000000..e83fffff
00:00:09.533576 MMIO32 PREFETCH region #2: e8420000..e8423fff
00:00:09.533578 Command: 0017, Status: 0000
00:00:09.533579 Bus master: Yes
00:00:09.533580 00:05.0 hda: 8086-2668 ICH9 MSI IRQ11 (INTA#->IRQ21)
00:00:09.533583 Class base/sub: 0403 (multimedia controller)
00:00:09.533584 MSI: off
00:00:09.533586 MMIO32 region #0: e8424000..e8427fff
00:00:09.533588 Command: 0017, Status: 0010
00:00:09.533589 Bus master: Yes
00:00:09.533591 00:07.0 acpi: 8086-7113 ICH9 IRQ9 (INTA#->IRQ23)
00:00:09.533593 Class base/sub: 0680 (bridge device)
00:00:09.533594 Command: 0017, Status: 0280
00:00:09.533596 Bus master: Yes
00:00:09.533597 00:11.0 e1000: 8086-100f ICH9 IRQ255 (INTA#->IRQ17)
00:00:09.533600 Class base/sub: 0200 (network controller)
00:00:09.533601 MMIO32 region #0: e8400000..e841ffff
00:00:09.533603 IO region #2: c040..c047
00:00:09.533604 Command: 0017, Status: 0230
00:00:09.533606 Bus master: Yes
00:00:09.533607 00:1f.0 lpc: 8086-27b9 ICH9
00:00:09.533609 Class base/sub: 0601 (bridge device)
00:00:09.533610 Command: 0017, Status: 0200
00:00:09.533611 Bus master: Yes
00:00:09.533613 00:1f.2 ahci: 8086-2829 ICH9 MSI IRQ255 (INTA#->IRQ23)
00:00:09.533615 Class base/sub: 0106 (mass storage controller)
00:00:09.533616 MSI: off
00:00:09.533617 IO region #0: c038..c03f
00:00:09.533619 IO region #1: c04c..c04c
00:00:09.533620 IO region #2: c030..c037
00:00:09.533622 IO region #3: c048..c048
00:00:09.533623 IO region #4: c020..c02f
00:00:09.533624 MMIO32 region #5: e8428000..e8429fff
00:00:09.533626 Command: 0017, Status: 0010
00:00:09.533627 Bus master: Yes
00:00:09.533628 00:1f.4 usb-ohci: 106b-003f ICH9 MSI IRQ255 (INTA#->IRQ23)
00:00:09.533631 Class base/sub: 0c03 (serial bus controllers)
00:00:09.533632 MSI: off
00:00:09.533633 MMIO32 region #0: e842a000..e842afff
00:00:09.533635 Command: 0017, Status: 0010
00:00:09.533637 Bus master: Yes
00:00:09.533638 !!
00:00:09.533638 !! {pciirq}
00:00:09.533639 !!
00:00:09.533640 PCI I/O APIC IRQ levels:
00:00:09.533640 IRQ16: 0
00:00:09.533641 IRQ17: 0
00:00:09.533642 IRQ18: 0
00:00:09.533642 IRQ19: 0
00:00:09.533643 IRQ20: 0
00:00:09.533644 IRQ21: 0
00:00:09.533644 IRQ22: 0
00:00:09.533645 IRQ23: 0
00:00:09.533646 !!
00:00:09.533647 !! {pdmtracingids}
00:00:09.533647 !!
00:00:09.533648 Device tracing IDs:
00:00:09.533649 00001 pcarch
00:00:09.533650 00002 smc
00:00:09.533651 00003 efi
00:00:09.533652 00004 ich9pci
00:00:09.533653 00005 pckbd
00:00:09.533654 00006 apic
00:00:09.533655 00007 i8259
00:00:09.533656 00008 ioapic
00:00:09.533657 00009 hpet
00:00:09.533658 00010 i8254
00:00:09.533659 00011 mc146818
00:00:09.533660 00012 8237A
00:00:09.533661 00013 VMMDev
00:00:09.533662 00014 vga
00:00:09.533663 00015 ahci
00:00:09.533664 00016 e1000
00:00:09.533664 00017 hda
00:00:09.533665 00018 usb-ohci
00:00:09.533666 00019 acpi
00:00:09.533667 00020 GIMDev
00:00:09.533668 00021 lpc
00:00:09.533669 USB device tracing IDs:
00:00:09.533670 01047 HidKeyboard
00:00:09.533671 01050 HidMouse
00:00:09.533672 Driver tracing IDs:
00:00:09.533673 01025 NvramStorage (level 0, lun 0, dev efi)
00:00:09.533675 01026 KeyboardQueue (level 0, lun 0, dev pckbd)
00:00:09.533677 01027 MainKeyboard (level 1, lun 0, dev pckbd)
00:00:09.533678 01028 MouseQueue (level 0, lun 1, dev pckbd)
00:00:09.533680 01029 MainMouse (level 1, lun 1, dev pckbd)
00:00:09.533682 01030 HGCM (level 0, lun 0, dev VMMDev)
00:00:09.533683 01031 MainStatus (level 0, lun 999, dev VMMDev)
00:00:09.533685 01032 MainDisplay (level 0, lun 0, dev vga)
00:00:09.533687 01033 MainStatus (level 0, lun 999, dev vga)
00:00:09.533688 01034 VD (level 0, lun 0, dev ahci)
00:00:09.533690 01035 SCSI (level 0, lun 1, dev ahci)
00:00:09.533691 01036 VD (level 1, lun 1, dev ahci)
00:00:09.533692 01037 MainStatus (level 0, lun 999, dev ahci)
00:00:09.533694 01038 MainStatus (level 0, lun 999, dev e1000)
00:00:09.533695 01039 NAT (level 0, lun 0, dev e1000)
00:00:09.533697 01040 AUDIO (level 0, lun 0, dev hda)
00:00:09.533698 01041 DSoundAudio (level 1, lun 0, dev hda)
00:00:09.533700 01042 AUDIO (level 0, lun 1, dev hda)
00:00:09.533701 01043 AudioVRDE (level 1, lun 1, dev hda)
00:00:09.533703 01044 VUSBRootHub (level 0, lun 0, dev usb-ohci)
00:00:09.533704 01045 MainStatus (level 0, lun 999, dev usb-ohci)
00:00:09.533706 01046 ACPIHost (level 0, lun 0, dev acpi)
00:00:09.533708 01048 KeyboardQueue (level 0, lun 0, dev HidKeyboard)
00:00:09.533709 01049 MainKeyboard (level 1, lun 0, dev HidKeyboard)
00:00:09.533711 01051 MouseQueue (level 0, lun 0, dev HidMouse)
00:00:09.533712 01052 MainMouse (level 1, lun 0, dev HidMouse)
00:00:09.533714 !!
00:00:09.533715 !! {phys}
00:00:09.533715 !!
00:00:09.533716 RAM ranges (pVM=0000000001b00000)
00:00:09.533717 GC Phys Range pvHC
00:00:09.533719 0000000000000000-00000000dbffffff 0000000000000000 Base RAM
00:00:09.533722 00000000dc000000-00000000dfffffff 0000000000000000 MCFG ranges
00:00:09.533724 00000000e0000000-00000000e7ffffff 000000000ba90000 VRam
00:00:09.533726 00000000e8000000-00000000e83fffff 000000000b560000 VMMDev
00:00:09.533728 00000000e8400000-00000000e841ffff 0000000000000000 E1000
00:00:09.533730 00000000e8420000-00000000e8423fff 000000000b960000 VMMDev Heap
00:00:09.533732 00000000e8424000-00000000e8427fff 0000000000000000 HDA
00:00:09.533733 00000000e8428000-00000000e8429fff 0000000000000000 AHCI
00:00:09.533735 00000000e842a000-00000000e842afff 0000000000000000 USB OHCI
00:00:09.533736 00000000fec00000-00000000fec00fff 0000000000000000 I/O APIC
00:00:09.533738 00000000fed00000-00000000fed00fff 0000000000000000 HPET Memory
00:00:09.533740 00000000fed1c000-00000000fed1ffff 0000000000000000 LPC Memory
00:00:09.533742 00000000fee00000-00000000fee00fff 0000000000000000 APIC
00:00:09.533744 00000000ffe00000-00000000ffe7ffff 0000000000000000 EFI Firmware Volume
00:00:09.533746 00000000ffe80000-00000000ffefffff 0000000000000000 EFI Firmware Volume (Part 2)
00:00:09.533748 00000000fff00000-00000000fff7ffff 0000000000000000 EFI Firmware Volume (Part 3)
00:00:09.533749 00000000fff80000-00000000ffffffff 0000000000000000 EFI Firmware Volume (Part 4)
00:00:09.533752 0000000100000000-0000000123ffffff 0000000000000000 Above 4GB Base RAM
00:00:09.533754 !!
00:00:09.533755 !! {pic}
00:00:09.533755 !!
00:00:09.533756 PIC0:
00:00:09.533756 IMR :ff ISR :00 IRR :00 LIRR:00
00:00:09.533758 Base:68 PriAdd:00 RegSel:00
00:00:09.533759 Poll:00 SpMask:00 IState:00
00:00:09.533760 AEOI:00 Rotate:00 FNest :00 Ini4:01
00:00:09.533761 ELCR:00 ELMask:f8
00:00:09.533762 PIC1:
00:00:09.533762 IMR :ff ISR :00 IRR :00 LIRR:00
00:00:09.533763 Base:70 PriAdd:00 RegSel:00
00:00:09.533764 Poll:00 SpMask:00 IState:00
00:00:09.533765 AEOI:00 Rotate:00 FNest :00 Ini4:01
00:00:09.533766 ELCR:00 ELMask:de
00:00:09.533767 !!
00:00:09.533768 !! {pit}
00:00:09.533768 !!
00:00:09.533769 PIT (i8254) channel 0 status: irq=0x0
00:00:09.533770 count=00002e9c latched_count=0000 count_latched=00
00:00:09.533809 status=00 status_latched=00 read_state=03
00:00:09.533811 write_state=03 write_latch=9c rw_mode=03
00:00:09.533812 mode=03 bcd=00 gate=01
00:00:09.533813 count_load_time=000000002e5208ee next_transition_time=000000013a8b9f1c
00:00:09.533815 u64ReloadTS=0000000139f30805 u64NextTS=000000013a8b9f1c
00:00:09.533817 PIT (i8254) channel 1 status: irq=0x0
00:00:09.533818 count=00010000 latched_count=0000 count_latched=00
00:00:09.533819 status=00 status_latched=00 read_state=00
00:00:09.533820 write_state=00 write_latch=00 rw_mode=00
00:00:09.533821 mode=03 bcd=00 gate=01
00:00:09.533822 count_load_time=0000000000000000 next_transition_time=0000000000000000
00:00:09.533823 u64ReloadTS=0000000000000000 u64NextTS=ffffffffffffffff
00:00:09.533825 PIT (i8254) channel 2 status: irq=0x0
00:00:09.533825 count=00010000 latched_count=0000 count_latched=00
00:00:09.533827 status=00 status_latched=00 read_state=00
00:00:09.533827 write_state=00 write_latch=00 rw_mode=00
00:00:09.533828 mode=03 bcd=00 gate=00
00:00:09.533829 count_load_time=0000000000000000 next_transition_time=0000000000000000
00:00:09.533830 u64ReloadTS=0000000000000000 u64NextTS=ffffffffffffffff
00:00:09.533832 speaker_data_on=0x0
00:00:09.533834 !!
00:00:09.533834 !! {plugins}
00:00:09.533835 !!
00:00:09.533836 No plug-ins loaded
00:00:09.533837 !!
00:00:09.533838 !! {ps2k}
00:00:09.533838 !!
00:00:09.533840 PS/2 Keyboard: scan set 2, scanning enabled
00:00:09.533841 Active command 00
00:00:09.533842 LED state 00, Num Lock off
00:00:09.533843 Typematic delay 500ms, repeat period 91ms
00:00:09.533844 Command queue: 0 items (4 max)
00:00:09.533845 Input queue : 0 items (64 max)
00:00:09.533846 !!
00:00:09.533846 !! {ps2m}
00:00:09.533847 !!
00:00:09.533848 PS/2 mouse state: normal, stream mode, reporting disabled
00:00:09.533849 Protocol: PS/2, scaling 1:1
00:00:09.533850 Active command 00
00:00:09.533851 Sampling rate 100 reports/sec, resolution 4 counts/mm
00:00:09.533852 Command queue: 0 items (8 max)
00:00:09.533853 Event queue : 0 items (256 max)
00:00:09.533883 !!
00:00:09.533884 !! {rtc}
00:00:09.533884 !!
00:00:09.533885 Time: 04:36:19 Date: 18-07-03
00:00:09.533887 REG A=26 B=02 C=00 D=80
00:00:09.533889 !!
00:00:09.533890 !! {tracebuf}
00:00:09.533890 !!
00:00:09.533891 Tracing is disabled
00:00:09.533892 !!
00:00:09.533892 !! {trpmevent}
00:00:09.533893 !!
00:00:09.533899 CPU[0]: TRPM event (None)
00:00:09.533906 CPU[1]: TRPM event (None)
00:00:09.533919 CPU[2]: TRPM event (None)
00:00:09.534013 CPU[3]: TRPM event (None)
00:00:09.534024 !!
00:00:09.534025 !! {vbe}
00:00:09.534025 !!
00:00:09.534026 LFB at 00000000e0000000
00:00:09.534028 VBE state (chip ID 0xb0c0):
00:00:09.534029 Display resolution: 1024 x 768 @ 32bpp
00:00:09.534030 Virtual resolution: 1024 x 32768
00:00:09.534031 Display start addr: 0, 0
00:00:09.534032 Linear scanline pitch: 0x1000
00:00:09.534033 Linear display start : 0x0000
00:00:09.534034 Selected bank: 0x0000
00:00:09.534035 !!
00:00:09.534035 !! {vga}
00:00:09.534035 !!
00:00:09.534036 pixel clock: 25.175 MHz
00:00:09.534037 double scanning off
00:00:09.534038 double clocking off
00:00:09.534038 htotal: 40 px (5 cclk)
00:00:09.534039 vtotal: 2 px
00:00:09.534040 hdisp : 1024 px (128 cclk)
00:00:09.534041 vdisp : 1280 px
00:00:09.534041 split : 1023 ln
00:00:09.534042 start : 0x0
00:00:09.534043 display refresh interval: 20 ms
00:00:09.534045 !!
00:00:09.534045 !! {vgaar}
00:00:09.534045 !!
00:00:09.534046 VGA Attribute Controller (3C0): index reg 20, flip-flop: 1 (data)
00:00:09.534048 Palette: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00:00:09.534052 AR10:41 AR11:00 AR12:0F AR13:00 AR14:00
00:00:09.534055 !!
00:00:09.534055 !! {vgacr}
00:00:09.534056 !!
00:00:09.534056 VGA CRTC (3D5): CRTC index 3D4:11
00:00:09.534057 CR00:00 CR01:7F CR02:00 CR03:00 CR04:00 CR05:00 CR06:00 CR07:50 CR08:00 CR09:40
00:00:09.534060 CR0A:00 CR0B:00 CR0C:00 CR0D:00 CR0E:00 CR0F:00 CR10:00 CR11:00 CR12:FF CR13:00
00:00:09.534064 CR14:00 CR15:00 CR16:00 CR17:03 CR18:FF
00:00:09.534066 !!
00:00:09.534067 !! {vgadac}
00:00:09.534067 !!
00:00:09.534068 VGA DAC contents:
00:00:09.534068 00: 00 00 00
00:00:09.534069 01: 00 00 00
00:00:09.534070 02: 00 00 00
00:00:09.534071 03: 00 00 00
00:00:09.534071 04: 00 00 00
00:00:09.534072 05: 00 00 00
00:00:09.534073 06: 00 00 00
00:00:09.534074 07: 00 00 00
00:00:09.534074 08: 00 00 00
00:00:09.534075 09: 00 00 00
00:00:09.534076 0A: 00 00 00
00:00:09.534077 0B: 00 00 00
00:00:09.534077 0C: 00 00 00
00:00:09.534078 0D: 00 00 00
00:00:09.534079 0E: 00 00 00
00:00:09.534080 0F: 00 00 00
00:00:09.534080 10: 00 00 00
00:00:09.534081 11: 00 00 00
00:00:09.534082 12: 00 00 00
00:00:09.534083 13: 00 00 00
00:00:09.534083 14: 00 00 00
00:00:09.534084 15: 00 00 00
00:00:09.534085 16: 00 00 00
00:00:09.534086 17: 00 00 00
00:00:09.534086 18: 00 00 00
00:00:09.534087 19: 00 00 00
00:00:09.534088 1A: 00 00 00
00:00:09.534089 1B: 00 00 00
00:00:09.534090 1C: 00 00 00
00:00:09.534090 1D: 00 00 00
00:00:09.534091 1E: 00 00 00
00:00:09.534092 1F: 00 00 00
00:00:09.534093 20: 00 00 00
00:00:09.534093 21: 00 00 00
00:00:09.534094 22: 00 00 00
00:00:09.534095 23: 00 00 00
00:00:09.534096 24: 00 00 00
00:00:09.534096 25: 00 00 00
00:00:09.534097 26: 00 00 00
00:00:09.534098 27: 00 00 00
00:00:09.534099 28: 00 00 00
00:00:09.534099 29: 00 00 00
00:00:09.534100 2A: 00 00 00
00:00:09.534101 2B: 00 00 00
00:00:09.534101 2C: 00 00 00
00:00:09.534102 2D: 00 00 00
00:00:09.534103 2E: 00 00 00
00:00:09.534104 2F: 00 00 00
00:00:09.534104 30: 00 00 00
00:00:09.534105 31: 00 00 00
00:00:09.534106 32: 00 00 00
00:00:09.534107 33: 00 00 00
00:00:09.534107 34: 00 00 00
00:00:09.534108 35: 00 00 00
00:00:09.534109 36: 00 00 00
00:00:09.534110 37: 00 00 00
00:00:09.534110 38: 00 00 00
00:00:09.534111 39: 00 00 00
00:00:09.534112 3A: 00 00 00
00:00:09.534113 3B: 00 00 00
00:00:09.534113 3C: 00 00 00
00:00:09.534114 3D: 00 00 00
00:00:09.534115 3E: 00 00 00
00:00:09.534115 3F: 00 00 00
00:00:09.534116 40: 00 00 00
00:00:09.534117 41: 00 00 00
00:00:09.534118 42: 00 00 00
00:00:09.534118 43: 00 00 00
00:00:09.534119 44: 00 00 00
00:00:09.534120 45: 00 00 00
00:00:09.534121 46: 00 00 00
00:00:09.534121 47: 00 00 00
00:00:09.534122 48: 00 00 00
00:00:09.534123 49: 00 00 00
00:00:09.534124 4A: 00 00 00
00:00:09.534124 4B: 00 00 00
00:00:09.534125 4C: 00 00 00
00:00:09.534126 4D: 00 00 00
00:00:09.534127 4E: 00 00 00
00:00:09.534127 4F: 00 00 00
00:00:09.534128 50: 00 00 00
00:00:09.534129 51: 00 00 00
00:00:09.534129 52: 00 00 00
00:00:09.534130 53: 00 00 00
00:00:09.534131 54: 00 00 00
00:00:09.534132 55: 00 00 00
00:00:09.534132 56: 00 00 00
00:00:09.534133 57: 00 00 00
00:00:09.534134 58: 00 00 00
00:00:09.534135 59: 00 00 00
00:00:09.534135 5A: 00 00 00
00:00:09.534136 5B: 00 00 00
00:00:09.534137 5C: 00 00 00
00:00:09.534138 5D: 00 00 00
00:00:09.534138 5E: 00 00 00
00:00:09.534139 5F: 00 00 00
00:00:09.534140 60: 00 00 00
00:00:09.534141 61: 00 00 00
00:00:09.534141 62: 00 00 00
00:00:09.534142 63: 00 00 00
00:00:09.534143 64: 00 00 00
00:00:09.534144 65: 00 00 00
00:00:09.534144 66: 00 00 00
00:00:09.534145 67: 00 00 00
00:00:09.534146 68: 00 00 00
00:00:09.534146 69: 00 00 00
00:00:09.534147 6A: 00 00 00
00:00:09.534148 6B: 00 00 00
00:00:09.534149 6C: 00 00 00
00:00:09.534149 6D: 00 00 00
00:00:09.534150 6E: 00 00 00
00:00:09.534151 6F: 00 00 00
00:00:09.534152 70: 00 00 00
00:00:09.534152 71: 00 00 00
00:00:09.534153 72: 00 00 00
00:00:09.534154 73: 00 00 00
00:00:09.534155 74: 00 00 00
00:00:09.534155 75: 00 00 00
00:00:09.534156 76: 00 00 00
00:00:09.534157 77: 00 00 00
00:00:09.534157 78: 00 00 00
00:00:09.534158 79: 00 00 00
00:00:09.534159 7A: 00 00 00
00:00:09.534160 7B: 00 00 00
00:00:09.534160 7C: 00 00 00
00:00:09.534161 7D: 00 00 00
00:00:09.534162 7E: 00 00 00
00:00:09.534163 7F: 00 00 00
00:00:09.534163 80: 00 00 00
00:00:09.534164 81: 00 00 00
00:00:09.534165 82: 00 00 00
00:00:09.534166 83: 00 00 00
00:00:09.534166 84: 00 00 00
00:00:09.534167 85: 00 00 00
00:00:09.534168 86: 00 00 00
00:00:09.534169 87: 00 00 00
00:00:09.534169 88: 00 00 00
00:00:09.534170 89: 00 00 00
00:00:09.534171 8A: 00 00 00
00:00:09.534172 8B: 00 00 00
00:00:09.534172 8C: 00 00 00
00:00:09.534173 8D: 00 00 00
00:00:09.534174 8E: 00 00 00
00:00:09.534174 8F: 00 00 00
00:00:09.534175 90: 00 00 00
00:00:09.534176 91: 00 00 00
00:00:09.534177 92: 00 00 00
00:00:09.534177 93: 00 00 00
00:00:09.534178 94: 00 00 00
00:00:09.534179 95: 00 00 00
00:00:09.534180 96: 00 00 00
00:00:09.534180 97: 00 00 00
00:00:09.534181 98: 00 00 00
00:00:09.534182 99: 00 00 00
00:00:09.534183 9A: 00 00 00
00:00:09.534183 9B: 00 00 00
00:00:09.534184 9C: 00 00 00
00:00:09.534185 9D: 00 00 00
00:00:09.534185 9E: 00 00 00
00:00:09.534186 9F: 00 00 00
00:00:09.534187 A0: 00 00 00
00:00:09.534188 A1: 00 00 00
00:00:09.534188 A2: 00 00 00
00:00:09.534189 A3: 00 00 00
00:00:09.534190 A4: 00 00 00
00:00:09.534191 A5: 00 00 00
00:00:09.534191 A6: 00 00 00
00:00:09.534192 A7: 00 00 00
00:00:09.534193 A8: 00 00 00
00:00:09.534194 A9: 00 00 00
00:00:09.534194 AA: 00 00 00
00:00:09.534195 AB: 00 00 00
00:00:09.534196 AC: 00 00 00
00:00:09.534196 AD: 00 00 00
00:00:09.534197 AE: 00 00 00
00:00:09.534198 AF: 00 00 00
00:00:09.534199 B0: 00 00 00
00:00:09.534199 B1: 00 00 00
00:00:09.534200 B2: 00 00 00
00:00:09.534201 B3: 00 00 00
00:00:09.534202 B4: 00 00 00
00:00:09.534202 B5: 00 00 00
00:00:09.534203 B6: 00 00 00
00:00:09.534204 B7: 00 00 00
00:00:09.534205 B8: 00 00 00
00:00:09.534205 B9: 00 00 00
00:00:09.534206 BA: 00 00 00
00:00:09.534207 BB: 00 00 00
00:00:09.534208 BC: 00 00 00
00:00:09.534208 BD: 00 00 00
00:00:09.534209 BE: 00 00 00
00:00:09.534210 BF: 00 00 00
00:00:09.534210 C0: 00 00 00
00:00:09.534211 C1: 00 00 00
00:00:09.534212 C2: 00 00 00
00:00:09.534213 C3: 00 00 00
00:00:09.534213 C4: 00 00 00
00:00:09.534214 C5: 00 00 00
00:00:09.534215 C6: 00 00 00
00:00:09.534216 C7: 00 00 00
00:00:09.534216 C8: 00 00 00
00:00:09.534217 C9: 00 00 00
00:00:09.534218 CA: 00 00 00
00:00:09.534219 CB: 00 00 00
00:00:09.534219 CC: 00 00 00
00:00:09.534220 CD: 00 00 00
00:00:09.534221 CE: 00 00 00
00:00:09.534222 CF: 00 00 00
00:00:09.534222 D0: 00 00 00
00:00:09.534223 D1: 00 00 00
00:00:09.534224 D2: 00 00 00
00:00:09.534224 D3: 00 00 00
00:00:09.534225 D4: 00 00 00
00:00:09.534226 D5: 00 00 00
00:00:09.534227 D6: 00 00 00
00:00:09.534227 D7: 00 00 00
00:00:09.534228 D8: 00 00 00
00:00:09.534229 D9: 00 00 00
00:00:09.534230 DA: 00 00 00
00:00:09.534230 DB: 00 00 00
00:00:09.534231 DC: 00 00 00
00:00:09.534232 DD: 00 00 00
00:00:09.534233 DE: 00 00 00
00:00:09.534234 DF: 00 00 00
00:00:09.534234 E0: 00 00 00
00:00:09.534235 E1: 00 00 00
00:00:09.534236 E2: 00 00 00
00:00:09.534236 E3: 00 00 00
00:00:09.534237 E4: 00 00 00
00:00:09.534238 E5: 00 00 00
00:00:09.534239 E6: 00 00 00
00:00:09.534239 E7: 00 00 00
00:00:09.534240 E8: 00 00 00
00:00:09.534241 E9: 00 00 00
00:00:09.534242 EA: 00 00 00
00:00:09.534242 EB: 00 00 00
00:00:09.534243 EC: 00 00 00
00:00:09.534244 ED: 00 00 00
00:00:09.534245 EE: 00 00 00
00:00:09.534245 EF: 00 00 00
00:00:09.534246 F0: 00 00 00
00:00:09.534247 F1: 00 00 00
00:00:09.534248 F2: 00 00 00
00:00:09.534248 F3: 00 00 00
00:00:09.534249 F4: 00 00 00
00:00:09.534250 F5: 00 00 00
00:00:09.534250 F6: 00 00 00
00:00:09.534251 F7: 00 00 00
00:00:09.534252 F8: 00 00 00
00:00:09.534253 F9: 00 00 00
00:00:09.534253 FA: 00 00 00
00:00:09.534254 FB: 00 00 00
00:00:09.534255 FC: 00 00 00
00:00:09.534256 FD: 00 00 00
00:00:09.534256 FE: 00 00 00
00:00:09.534257 FF: 00 00 00
00:00:09.534258 !!
00:00:09.534259 !! {vgagr}
00:00:09.534259 !!
00:00:09.534260 VGA Graphics Controller (3CF): GR index 3CE:08
00:00:09.534260 GR00:00 GR01:00 GR02:00 GR03:00 GR04:00 GR05:40 GR06:05 GR07:0F GR08:FF
00:00:09.534264 !!
00:00:09.534264 !! {vgapl}
00:00:09.534265 !!
00:00:09.534265 read mode : 0 write mode: 0
00:00:09.534266 set/reset data: 00 S/R enable: 00
00:00:09.534267 color compare : 00 read map : 0
00:00:09.534268 rotate : 0 function : 0
00:00:09.534269 don't care : 0F bit mask : FF
00:00:09.534270 seq plane mask: 0F chain-4 : on
00:00:09.534271 !!
00:00:09.534271 !! {vgasr}
00:00:09.534272 !!
00:00:09.534273 VGA Sequencer (3C5): SR index 3C4:00
00:00:09.534273 SR00:03 SR01:01 SR02:0F SR03:00 SR04:0A SR05:00 SR06:00 SR07:01
00:00:09.534277 !!
00:00:09.534277 !! {vgatext}
00:00:09.534278 !!
00:00:09.534278 Not in text mode!
00:00:09.534280 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
00:26:37.029206 GUI: User request to power VM off on Guru Meditation.
00:26:37.029561 GUI: Passing request to power VM off from machine-logic to UI session.
00:26:37.029587 GUI: Powering VM down on UI session power off request...
00:26:37.030273 Console: Machine state changed to 'Stopping'
00:26:37.285882 Console::powerDown(): A request to power off the VM has been issued (mMachineState=Stopping, InUninit=0)
00:26:37.285983 Display::handleDisplayResize: uScreenId=0 pvVRAM=000000000ba90000 w=1024 h=768 bpp=32 cbLine=0x1000 flags=0x0
00:26:37.286072 GUI: UIFrameBufferPrivate::NotifyChange: Screen=0, Origin=0x0, Size=1024x768, Sending to async-handler
00:26:37.286378 GUI: UIMachineView::sltHandleNotifyChange: Screen=0, Size=1024x768
00:26:37.402986 Changing the VM state from 'GURU_MEDITATION' to 'POWERING_OFF'
00:26:37.403060 ****************** Guest state at power off for VCpu 3 ******************
00:26:37.403074 Guest CPUM (VCPU 3) state:
00:26:37.403079 eax=00000000 ebx=00000000 ecx=00000000 edx=00000600 esi=00000000 edi=00000000
00:26:37.403084 eip=0000fff0 esp=00000000 ebp=00000000 iopl=0 nv up di pl zr na pe nc
00:26:37.403088 cs={f000 base=00000000ffff0000 limit=0000ffff flags=0000009b} dr0=00000000 dr1=00000000
00:26:37.403094 ds={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr2=00000000 dr3=00000000
00:26:37.403098 es={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr4=00000000 dr5=00000000
00:26:37.403101 fs={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr6=ffff0ff0 dr7=00000400
00:26:37.403104 gs={0000 base=0000000000000000 limit=0000ffff flags=00000093} cr0=60000010 cr2=00000000
00:26:37.403108 ss={0000 base=0000000000000000 limit=0000ffff flags=00000093} cr3=00000000 cr4=00000000
00:26:37.403110 gdtr=0000000000000000:ffff idtr=0000000000000000:ffff eflags=00000002
00:26:37.403114 ldtr={0000 base=00000000 limit=0000ffff flags=00000082}
00:26:37.403116 tr ={0000 base=00000000 limit=0000ffff flags=0000008b}
00:26:37.403118 SysEnter={cs=0000 eip=00000000 esp=00000000}
00:26:37.403120 xcr=0000000000000001 xcr1=0000000000000000 xss=0000000000000000 (fXStateMask=0000000000000000)
00:26:37.403124 FCW=037f FSW=0000 FTW=0000 FOP=0000 MXCSR=00001f80 MXCSR_MASK=0002ffff
00:26:37.403127 FPUIP=00000000 CS=0000 Rsrvd1=0000 FPUDP=00000000 DS=0000 Rsvrd2=0000
00:26:37.403131 ST(0)=FPR0={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403136 ST(1)=FPR1={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403142 ST(2)=FPR2={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403146 ST(3)=FPR3={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403150 ST(4)=FPR4={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403155 ST(5)=FPR5={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403159 ST(6)=FPR6={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403162 ST(7)=FPR7={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403167 XMM0 =00000000'00000000'00000000'00000000 XMM1 =00000000'00000000'00000000'00000000
00:26:37.403171 XMM2 =00000000'00000000'00000000'00000000 XMM3 =00000000'00000000'00000000'00000000
00:26:37.403175 XMM4 =00000000'00000000'00000000'00000000 XMM5 =00000000'00000000'00000000'00000000
00:26:37.403179 XMM6 =00000000'00000000'00000000'00000000 XMM7 =00000000'00000000'00000000'00000000
00:26:37.403183 XMM8 =00000000'00000000'00000000'00000000 XMM9 =00000000'00000000'00000000'00000000
00:26:37.403187 XMM10=00000000'00000000'00000000'00000000 XMM11=00000000'00000000'00000000'00000000
00:26:37.403191 XMM12=00000000'00000000'00000000'00000000 XMM13=00000000'00000000'00000000'00000000
00:26:37.403194 XMM14=00000000'00000000'00000000'00000000 XMM15=00000000'00000000'00000000'00000000
00:26:37.403198 EFER =0000000000000000
00:26:37.403200 PAT =0007040600070406
00:26:37.403202 STAR =0000000000000000
00:26:37.403203 CSTAR =0000000000000000
00:26:37.403204 LSTAR =0000000000000000
00:26:37.403206 SFMASK =0000000000000000
00:26:37.403207 KERNELGSBASE =0000000000000000
00:26:37.403211 ***
00:26:37.403216 VCPU[3] hardware virtualization state:
00:26:37.403217 No/inactive hwvirt state
00:26:37.403220 ***
00:26:37.403229 Guest paging mode (VCPU #3): Real (changed 1 times), A20 enabled (changed 0 times)
00:26:37.403234 Shadow paging mode (VCPU #3): Nested
00:26:37.403235 Host paging mode: AMD64+G+NX
00:26:37.403238 ***
00:26:37.403239 ************** End of Guest state at power off for VCpu 3 ***************
00:26:37.403300 ****************** Guest state at power off for VCpu 2 ******************
00:26:37.403308 Guest CPUM (VCPU 2) state:
00:26:37.403311 eax=00000000 ebx=00000000 ecx=00000000 edx=00000600 esi=00000000 edi=00000000
00:26:37.403314 eip=0000fff0 esp=00000000 ebp=00000000 iopl=0 nv up di pl zr na pe nc
00:26:37.403317 cs={f000 base=00000000ffff0000 limit=0000ffff flags=0000009b} dr0=00000000 dr1=00000000
00:26:37.403321 ds={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr2=00000000 dr3=00000000
00:26:37.403324 es={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr4=00000000 dr5=00000000
00:26:37.403327 fs={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr6=ffff0ff0 dr7=00000400
00:26:37.403330 gs={0000 base=0000000000000000 limit=0000ffff flags=00000093} cr0=60000010 cr2=00000000
00:26:37.403333 ss={0000 base=0000000000000000 limit=0000ffff flags=00000093} cr3=00000000 cr4=00000000
00:26:37.403335 gdtr=0000000000000000:ffff idtr=0000000000000000:ffff eflags=00000002
00:26:37.403338 ldtr={0000 base=00000000 limit=0000ffff flags=00000082}
00:26:37.403340 tr ={0000 base=00000000 limit=0000ffff flags=0000008b}
00:26:37.403342 SysEnter={cs=0000 eip=00000000 esp=00000000}
00:26:37.403344 xcr=0000000000000001 xcr1=0000000000000000 xss=0000000000000000 (fXStateMask=0000000000000000)
00:26:37.403347 FCW=037f FSW=0000 FTW=0000 FOP=0000 MXCSR=00001f80 MXCSR_MASK=0002ffff
00:26:37.403350 FPUIP=00000000 CS=0000 Rsrvd1=0000 FPUDP=00000000 DS=0000 Rsvrd2=0000
00:26:37.403352 ST(0)=FPR0={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403357 ST(1)=FPR1={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403361 ST(2)=FPR2={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403364 ST(3)=FPR3={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403368 ST(4)=FPR4={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403371 ST(5)=FPR5={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403374 ST(6)=FPR6={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403378 ST(7)=FPR7={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403381 XMM0 =00000000'00000000'00000000'00000000 XMM1 =00000000'00000000'00000000'00000000
00:26:37.403385 XMM2 =00000000'00000000'00000000'00000000 XMM3 =00000000'00000000'00000000'00000000
00:26:37.403389 XMM4 =00000000'00000000'00000000'00000000 XMM5 =00000000'00000000'00000000'00000000
00:26:37.403393 XMM6 =00000000'00000000'00000000'00000000 XMM7 =00000000'00000000'00000000'00000000
00:26:37.403396 XMM8 =00000000'00000000'00000000'00000000 XMM9 =00000000'00000000'00000000'00000000
00:26:37.403400 XMM10=00000000'00000000'00000000'00000000 XMM11=00000000'00000000'00000000'00000000
00:26:37.403404 XMM12=00000000'00000000'00000000'00000000 XMM13=00000000'00000000'00000000'00000000
00:26:37.403408 XMM14=00000000'00000000'00000000'00000000 XMM15=00000000'00000000'00000000'00000000
00:26:37.403412 EFER =0000000000000000
00:26:37.403413 PAT =0007040600070406
00:26:37.403415 STAR =0000000000000000
00:26:37.403416 CSTAR =0000000000000000
00:26:37.403417 LSTAR =0000000000000000
00:26:37.403417 SFMASK =0000000000000000
00:26:37.403418 KERNELGSBASE =0000000000000000
00:26:37.403421 ***
00:26:37.403425 VCPU[2] hardware virtualization state:
00:26:37.403426 No/inactive hwvirt state
00:26:37.403429 ***
00:26:37.403434 Guest paging mode (VCPU #2): Real (changed 1 times), A20 enabled (changed 0 times)
00:26:37.403437 Shadow paging mode (VCPU #2): Nested
00:26:37.403439 Host paging mode: AMD64+G+NX
00:26:37.403441 ***
00:26:37.403442 ************** End of Guest state at power off for VCpu 2 ***************
00:26:37.403515 ****************** Guest state at power off for VCpu 1 ******************
00:26:37.403539 Guest CPUM (VCPU 1) state:
00:26:37.403544 eax=00000000 ebx=00000000 ecx=00000000 edx=00000600 esi=00000000 edi=00000000
00:26:37.403548 eip=0000fff0 esp=00000000 ebp=00000000 iopl=0 nv up di pl zr na pe nc
00:26:37.403551 cs={f000 base=00000000ffff0000 limit=0000ffff flags=0000009b} dr0=00000000 dr1=00000000
00:26:37.403567 ds={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr2=00000000 dr3=00000000
00:26:37.403571 es={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr4=00000000 dr5=00000000
00:26:37.403574 fs={0000 base=0000000000000000 limit=0000ffff flags=00000093} dr6=ffff0ff0 dr7=00000400
00:26:37.403578 gs={0000 base=0000000000000000 limit=0000ffff flags=00000093} cr0=60000010 cr2=00000000
00:26:37.403581 ss={0000 base=0000000000000000 limit=0000ffff flags=00000093} cr3=00000000 cr4=00000000
00:26:37.403584 gdtr=0000000000000000:ffff idtr=0000000000000000:ffff eflags=00000002
00:26:37.403587 ldtr={0000 base=00000000 limit=0000ffff flags=00000082}
00:26:37.403589 tr ={0000 base=00000000 limit=0000ffff flags=0000008b}
00:26:37.403591 SysEnter={cs=0000 eip=00000000 esp=00000000}
00:26:37.403593 xcr=0000000000000001 xcr1=0000000000000000 xss=0000000000000000 (fXStateMask=0000000000000000)
00:26:37.403597 FCW=037f FSW=0000 FTW=0000 FOP=0000 MXCSR=00001f80 MXCSR_MASK=0002ffff
00:26:37.403600 FPUIP=00000000 CS=0000 Rsrvd1=0000 FPUDP=00000000 DS=0000 Rsvrd2=0000
00:26:37.403603 ST(0)=FPR0={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403609 ST(1)=FPR1={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403614 ST(2)=FPR2={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403619 ST(3)=FPR3={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403623 ST(4)=FPR4={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403627 ST(5)=FPR5={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403631 ST(6)=FPR6={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403634 ST(7)=FPR7={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403639 XMM0 =00000000'00000000'00000000'00000000 XMM1 =00000000'00000000'00000000'00000000
00:26:37.403643 XMM2 =00000000'00000000'00000000'00000000 XMM3 =00000000'00000000'00000000'00000000
00:26:37.403648 XMM4 =00000000'00000000'00000000'00000000 XMM5 =00000000'00000000'00000000'00000000
00:26:37.403652 XMM6 =00000000'00000000'00000000'00000000 XMM7 =00000000'00000000'00000000'00000000
00:26:37.403656 XMM8 =00000000'00000000'00000000'00000000 XMM9 =00000000'00000000'00000000'00000000
00:26:37.403660 XMM10=00000000'00000000'00000000'00000000 XMM11=00000000'00000000'00000000'00000000
00:26:37.403665 XMM12=00000000'00000000'00000000'00000000 XMM13=00000000'00000000'00000000'00000000
00:26:37.403668 XMM14=00000000'00000000'00000000'00000000 XMM15=00000000'00000000'00000000'00000000
00:26:37.403673 EFER =0000000000000000
00:26:37.403674 PAT =0007040600070406
00:26:37.403676 STAR =0000000000000000
00:26:37.403677 CSTAR =0000000000000000
00:26:37.403678 LSTAR =0000000000000000
00:26:37.403679 SFMASK =0000000000000000
00:26:37.403681 KERNELGSBASE =0000000000000000
00:26:37.403686 ***
00:26:37.403691 VCPU[1] hardware virtualization state:
00:26:37.403692 No/inactive hwvirt state
00:26:37.403695 ***
00:26:37.403703 Guest paging mode (VCPU #1): Real (changed 1 times), A20 enabled (changed 0 times)
00:26:37.403706 Shadow paging mode (VCPU #1): Nested
00:26:37.403708 Host paging mode: AMD64+G+NX
00:26:37.403710 ***
00:26:37.403711 ************** End of Guest state at power off for VCpu 1 ***************
00:26:37.403824 ****************** Guest state at power off for VCpu 0 ******************
00:26:37.403834 Guest CPUM (VCPU 0) state:
00:26:37.403838 rax=00000000000003fc rbx=000000000000000e rcx=0000000000000000 rdx=ffffff800e2a9570
00:26:37.403843 rsi=0000000000000008 rdi=ffffff800e10bea0 r8 =ffffff80103c602b r9 =0000000000000000
00:26:37.403847 r10=0000000000000063 r11=ffffff800e97fc78 r12=ffffff800e10bef4 r13=ffffff800eaf6038
00:26:37.403851 r14=ffffff800e10bea0 r15=ffffff800e106f40
00:26:37.403854 rip=ffffff800e2a8e1f rsp=ffffff800e106f40 rbp=ffffff800e10bf30 iopl=0 nv up di pl nz na po nc
00:26:37.403860 cs={0008 base=0000000000000000 limit=ffffffff flags=0000a09b}
00:26:37.403863 ds={0000 base=0000000000000000 limit=ffffffff flags=00000000}
00:26:37.403866 es={0000 base=0000000000000000 limit=ffffffff flags=00000000}
00:26:37.403868 fs={0000 base=0000000000000000 limit=ffffffff flags=00000000}
00:26:37.403870 gs={0000 base=ffffff800ea09040 limit=ffffffff flags=00000000}
00:26:37.403873 ss={0000 base=0000000000000000 limit=ffffffff flags=00004000}
00:26:37.403875 cr0=00000000c0010033 cr2=00000000000003fc cr3=0000000010644000 cr4=0000000000000020
00:26:37.403879 dr0=0000000000000000 dr1=0000000000000000 dr2=0000000000000000 dr3=0000000000000000
00:26:37.403881 dr4=0000000000000000 dr5=0000000000000000 dr6=00000000ffff0ff0 dr7=0000000000000400
00:26:37.403884 gdtr=ffffff8000001000:0097 idtr=ffffff8000000000:1000 eflags=00000046
00:26:37.403888 ldtr={0030 base=ffffff800ea15000 limit=00000017 flags=00000082}
00:26:37.403891 tr ={0040 base=ffffff800ea14000 limit=00000067 flags=0000008b}
00:26:37.403894 SysEnter={cs=000b eip=000000000e2a9190 esp=000000000eb35080}
00:26:37.403897 xcr=0000000000000001 xcr1=0000000000000000 xss=0000000000000000 (fXStateMask=0000000000000000)
00:26:37.403901 FCW=037f FSW=0000 FTW=0000 FOP=0000 MXCSR=00001f80 MXCSR_MASK=0002ffff
00:26:37.403904 FPUIP=00000000 CS=0000 Rsrvd1=0000 FPUDP=00000000 DS=0000 Rsvrd2=0000
00:26:37.403907 ST(0)=FPR0={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403912 ST(1)=FPR1={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403916 ST(2)=FPR2={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403920 ST(3)=FPR3={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403924 ST(4)=FPR4={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403928 ST(5)=FPR5={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403931 ST(6)=FPR6={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403935 ST(7)=FPR7={0000'00000000'00000000} t0 +0.0000000000000000000000 * 2 ^ -16383 (*)
00:26:37.403938 XMM0 =00000000'0000001f'00000000'0000001f XMM1 =00000000'0000001f'00000000'0000001e
00:26:37.403943 XMM2 =00000000'00000000'00000000'00000000 XMM3 =00000000'00000000'00000000'00000000
00:26:37.403947 XMM4 =01020304'05060708'090a0b0c'0d0e0f10 XMM5 =00010001'00010001'00010001'00010001
00:26:37.403953 XMM6 =11121314'15161718'191a1b1c'1d1e1f20 XMM7 =00000000'00000000'00000000'00000000
00:26:37.403958 XMM8 =31323334'35363738'393a3b3c'3d3e3f40 XMM9 =21222324'25262728'292a2b2c'2d2e2f30
00:26:37.403963 XMM10=00000000'00000000'00000000'00000000 XMM11=00000000'00000000'00000000'00000000
00:26:37.403967 XMM12=00000000'00000000'00000000'00000000 XMM13=00000000'00000000'00000000'00000000
00:26:37.403971 XMM14=00000000'00000000'00000000'00000000 XMM15=00000000'00000000'00000000'00000000
00:26:37.403976 EFER =0000000000000d01
00:26:37.403977 PAT =0007040600070406
00:26:37.403979 STAR =001b000800000000
00:26:37.403980 CSTAR =0000000000000000
00:26:37.403981 LSTAR =ffffff800e2a9130
00:26:37.403983 SFMASK =0000000000004700
00:26:37.403984 KERNELGSBASE =ffffff800ea09040
00:26:37.403988 ***
00:26:37.403992 VCPU[0] hardware virtualization state:
00:26:37.403993 No/inactive hwvirt state
00:26:37.403996 ***
00:26:37.404001 Guest paging mode (VCPU #0): AMD64+NX (changed 5 times), A20 enabled (changed 0 times)
00:26:37.404004 Shadow paging mode (VCPU #0): Nested
00:26:37.404006 Host paging mode: AMD64+G+NX
00:26:37.404008 ***
00:26:37.404013 Active Timers (pVM=0000000001b00000)
00:26:37.404015 pTimerR3 offNext offPrev offSched Clock Time Expire HzHint State Description
00:26:37.404022 0000000006e16f60 00069a10 00000000 00000000 Real 925305086 923717167 0 2-ACTIVE VGA Refresh Timer
00:26:37.404031 0000000006e80970 00000000 fff965f0 00000000 Real 925305086 923717858 0 2-ACTIVE CPU Load Timer
00:26:37.404038 0000000006e12870 000005e0 00000000 00000000 VrSy 5274283056 5277196060 99 2-ACTIVE i8254 Programmable Interval Timer
00:26:37.404044 0000000006e12e50 0006d260 fffffa20 00000000 VrSy 5274283056 5990000000 0 2-ACTIVE MC146818 RTC/CMOS - Second
00:26:37.404050 0000000006e800b0 00000000 fff92da0 00000000 VrSy 5274283056 599932015941 0 2-ACTIVE ACPI PM Timer
00:26:37.404057 ***
00:26:37.404063 ************** End of Guest state at power off ***************
00:26:37.490984 PDMR3PowerOff: 86 863 012 ns run time
00:26:37.491065 Changing the VM state from 'POWERING_OFF' to 'OFF'
00:26:37.495580 Changing the VM state from 'OFF' to 'DESTROYING'
00:26:37.496269 ************************* Statistics *************************
00:26:37.496507 /CPUM/MSR-Totals/Reads 14 times
00:26:37.496538 /CPUM/MSR-Totals/ReadsRaisingGP 0 times
00:26:37.496564 /CPUM/MSR-Totals/ReadsUnknown 0 times
00:26:37.496587 /CPUM/MSR-Totals/Writes 6 times
00:26:37.496611 /CPUM/MSR-Totals/WritesRaisingGP 2 times
00:26:37.496635 /CPUM/MSR-Totals/WritesToIgnoredBits 0 times
00:26:37.496655 /CPUM/MSR-Totals/WritesUnknown 0 times
00:26:37.496673 /Devices/AHCI0/Port0/QueryBufAttempts 0 count
00:26:37.496691 /Devices/AHCI0/Port0/QueryBufSuccess 0 count
00:26:37.496717 /Devices/AHCI0/Port0/ReadBytes 14012928 bytes
00:26:37.496740 /Devices/AHCI0/Port0/ReqsRead 3381 count
00:26:37.496760 /Devices/AHCI0/Port0/ReqsSubmitted 3381 count
00:26:37.496778 /Devices/AHCI0/Port0/ReqsSucceeded 3381 count
00:26:37.496798 /Devices/AHCI0/Port1/QueryBufAttempts 0 count
00:26:37.496816 /Devices/AHCI0/Port1/QueryBufSuccess 0 count
00:26:37.496840 /Devices/E1k0/ReceiveBytes 0 bytes
00:26:37.496872 /Devices/E1k0/TransmitBytes 0 bytes
00:26:37.496891 /Devices/E1k0/iStatIntLost 0 ns
00:26:37.496910 /Devices/E1k0/iStatIntLostOne 0 ns
00:26:37.496928 /Devices/E1k0/u64ArmedAt 0 ns
00:26:37.496945 /Devices/E1k0/uStatDescCtx 0 ns
00:26:37.496964 /Devices/E1k0/uStatDescDat 0 ns
00:26:37.496982 /Devices/E1k0/uStatDescLeg 0 ns
00:26:37.497000 /Devices/E1k0/uStatInt 0 ns
00:26:37.497018 /Devices/E1k0/uStatIntEarly 0 ns
00:26:37.497036 /Devices/E1k0/uStatIntICS 0 ns
00:26:37.497054 /Devices/E1k0/uStatIntIMS 0 ns
00:26:37.497072 /Devices/E1k0/uStatIntLate 0 ns
00:26:37.497091 /Devices/E1k0/uStatIntLower 0 ns
00:26:37.497108 /Devices/E1k0/uStatIntMasked 0 ns
00:26:37.497126 /Devices/E1k0/uStatIntRDTR 0 ns
00:26:37.497144 /Devices/E1k0/uStatIntRXDMT0 0 ns
00:26:37.497164 /Devices/E1k0/uStatIntRx 0 ns
00:26:37.497181 /Devices/E1k0/uStatIntSkip 0 ns
00:26:37.497199 /Devices/E1k0/uStatIntTXQE 0 ns
00:26:37.497216 /Devices/E1k0/uStatIntTry 0 ns
00:26:37.497234 /Devices/E1k0/uStatIntTx 0 ns
00:26:37.497251 /Devices/E1k0/uStatMaxTxDelay 0 ns
00:26:37.497281 /Devices/E1k0/uStatNoIntICR 0 ns
00:26:37.497308 /Devices/E1k0/uStatRAD 0 ns
00:26:37.497326 /Devices/E1k0/uStatRID 0 ns
00:26:37.497344 /Devices/E1k0/uStatRxFrm 0 ns
00:26:37.497362 /Devices/E1k0/uStatTAD 0 ns
00:26:37.497380 /Devices/E1k0/uStatTID 0 ns
00:26:37.497398 /Devices/E1k0/uStatTx1514 0 ns
00:26:37.497417 /Devices/E1k0/uStatTx16384 0 ns
00:26:37.497438 /Devices/E1k0/uStatTx2962 0 ns
00:26:37.497458 /Devices/E1k0/uStatTx32768 0 ns
00:26:37.497475 /Devices/E1k0/uStatTx4410 0 ns
00:26:37.497494 /Devices/E1k0/uStatTx5858 0 ns
00:26:37.497514 /Devices/E1k0/uStatTx7306 0 ns
00:26:37.497532 /Devices/E1k0/uStatTx8754 0 ns
00:26:37.497550 /Devices/E1k0/uStatTxDelayExp 0 ns
00:26:37.497568 /Devices/E1k0/uStatTxDelayed 0 ns
00:26:37.497586 /Devices/E1k0/uStatTxFrm 0 ns
00:26:37.497607 /Devices/E1k0/uStatTxIDE 0 ns
00:26:37.497732 /Devices/E1k0/uStatTxLarge 0 ns
00:26:37.497775 /Devices/E1k0/uStatTxNoRS 0 ns
00:26:37.497796 /Devices/VMMDev/BalloonChunks 0 count
00:26:37.497816 /FT/Checkpoint/Network 0 times
00:26:37.497834 /FT/Checkpoint/Storage 0 times
00:26:37.497857 /FT/Received/Mem 0 bytes
00:26:37.497876 /FT/Received/State 0 bytes
00:26:37.497895 /FT/Sent/Mem 0 bytes
00:26:37.497914 /FT/Sent/State 0 bytes
00:26:37.497933 /FT/Sync/DeltaMem 0 times
00:26:37.497952 /FT/Sync/DeltaVM 0 times
00:26:37.497972 /FT/Sync/Full 0 times
00:26:37.497993 /GMM/VM/Allocated/cBasePages 32731 pages
00:26:37.498012 /GMM/VM/Allocated/cFixedPages 0 pages
00:26:37.498031 /GMM/VM/Allocated/cShadowPages 0 pages
00:26:37.498050 /GMM/VM/Reserved/cBasePages 1049728 pages
00:26:37.498069 /GMM/VM/Reserved/cFixedPages 33796 pages
00:26:37.498088 /GMM/VM/Reserved/cShadowPages 1 pages
00:26:37.498106 /GMM/VM/cBalloonedPages 0 pages
00:26:37.498123 /GMM/VM/cMaxBalloonedPages 0 pages
00:26:37.498143 /GMM/VM/cPrivatePages 32731 pages
00:26:37.498180 /GMM/VM/cReqActuallyBalloonedPages 0 pages
00:26:37.498240 /GMM/VM/cReqBalloonedPages 0 pages
00:26:37.498278 /GMM/VM/cReqDeflatePages 0 pages
00:26:37.498335 /GMM/VM/cShareableModules 0 count
00:26:37.498378 /GMM/VM/cSharedPages 0 pages
00:26:37.498398 /GMM/VM/enmPolicy 1
00:26:37.498417 /GMM/VM/enmPriority 2
00:26:37.498469 /GMM/VM/fBallooningEnabled false
00:26:37.498489 /GMM/VM/fMayAllocate true
00:26:37.498508 /GMM/VM/fSharedPagingEnabled false
00:26:37.498525 /GMM/cAllocatedPages 32731 pages
00:26:37.498542 /GMM/cBalloonedPages 0 pages
00:26:37.498561 /GMM/cChunks 64 count
00:26:37.498604 /GMM/cDuplicatePages 0 pages
00:26:37.498623 /GMM/cFreedChunks 0 count
00:26:37.498643 /GMM/cLeftBehindSharedPages 0 pages
00:26:37.498661 /GMM/cMaxPages 4294967295 pages
00:26:37.498679 /GMM/cOverCommittedPages 0 pages
00:26:37.498697 /GMM/cReservedPages 1083525 pages
00:26:37.498716 /GMM/cShareableModules 0 count
00:26:37.498733 /GMM/cSharedPages 0 pages
00:26:37.498761 /GVMM/EMTs 4 calls
00:26:37.498810 /GVMM/HostCPUs 4 calls
00:26:37.498852 /GVMM/HostCpus/0 0
00:26:37.498897 /GVMM/HostCpus/0/CurTimerHz 0 Hz
00:26:37.498917 /GVMM/HostCpus/0/DesiredHz 0 Hz
00:26:37.498952 /GVMM/HostCpus/0/PPTChanges 0 times
00:26:37.498978 /GVMM/HostCpus/0/PPTStarts 0 times
00:26:37.498996 /GVMM/HostCpus/0/idxCpuSet 0
00:26:37.499015 /GVMM/HostCpus/1 1
00:26:37.499033 /GVMM/HostCpus/1/CurTimerHz 0 Hz
00:26:37.499054 /GVMM/HostCpus/1/DesiredHz 0 Hz
00:26:37.499123 /GVMM/HostCpus/1/PPTChanges 0 times
00:26:37.499155 /GVMM/HostCpus/1/PPTStarts 0 times
00:26:37.499174 /GVMM/HostCpus/1/idxCpuSet 1
00:26:37.499192 /GVMM/HostCpus/2 2
00:26:37.499211 /GVMM/HostCpus/2/CurTimerHz 0 Hz
00:26:37.499229 /GVMM/HostCpus/2/DesiredHz 0 Hz
00:26:37.499247 /GVMM/HostCpus/2/PPTChanges 0 times
00:26:37.499266 /GVMM/HostCpus/2/PPTStarts 0 times
00:26:37.499283 /GVMM/HostCpus/2/idxCpuSet 2
00:26:37.499300 /GVMM/HostCpus/3 3
00:26:37.499318 /GVMM/HostCpus/3/CurTimerHz 0 Hz
00:26:37.499335 /GVMM/HostCpus/3/DesiredHz 0 Hz
00:26:37.499352 /GVMM/HostCpus/3/PPTChanges 0 times
00:26:37.499369 /GVMM/HostCpus/3/PPTStarts 0 times
00:26:37.499386 /GVMM/HostCpus/3/idxCpuSet 3
00:26:37.499406 /GVMM/Sum/HaltBlocking 1078 calls
00:26:37.499444 /GVMM/Sum/HaltCalls 1079 calls
00:26:37.499463 /GVMM/Sum/HaltNotBlocking 0 calls
00:26:37.499480 /GVMM/Sum/HaltTimeouts 969 calls
00:26:37.499498 /GVMM/Sum/HaltWakeUps 0 calls
00:26:37.499515 /GVMM/Sum/PokeCalls 36 calls
00:26:37.499533 /GVMM/Sum/PokeNotBusy 10 calls
00:26:37.499554 /GVMM/Sum/PollCalls 1 calls
00:26:37.499573 /GVMM/Sum/PollHalts 0 calls
00:26:37.499590 /GVMM/Sum/PollWakeUps 0 calls
00:26:37.499608 /GVMM/Sum/WakeUpCalls 114 calls
00:26:37.499625 /GVMM/Sum/WakeUpNotHalted 9 calls
00:26:37.499643 /GVMM/Sum/WakeUpWakeUps 0 calls
00:26:37.499661 /GVMM/VM/HaltBlocking 1078 calls
00:26:37.499680 /GVMM/VM/HaltCalls 1079 calls
00:26:37.499701 /GVMM/VM/HaltNotBlocking 0 calls
00:26:37.499721 /GVMM/VM/HaltTimeouts 969 calls
00:26:37.499740 /GVMM/VM/HaltWakeUps 0 calls
00:26:37.499758 /GVMM/VM/PokeCalls 36 calls
00:26:37.499777 /GVMM/VM/PokeNotBusy 10 calls
00:26:37.499796 /GVMM/VM/PollCalls 1 calls
00:26:37.499814 /GVMM/VM/PollHalts 0 calls
00:26:37.499832 /GVMM/VM/PollWakeUps 0 calls
00:26:37.499850 /GVMM/VM/WakeUpCalls 114 calls
00:26:37.499868 /GVMM/VM/WakeUpNotHalted 9 calls
00:26:37.499885 /GVMM/VM/WakeUpWakeUps 0 calls
00:26:37.499903 /GVMM/VMs 1 calls
00:26:37.499921 /HM/CPU0/Exit/HostNmiInGC 0 times
00:26:37.499939 /HM/CPU0/Switch/Preempting 0 times
00:26:37.499958 /HM/CPU1/Exit/HostNmiInGC 0 times
00:26:37.499975 /HM/CPU1/Switch/Preempting 0 times
00:26:37.499994 /HM/CPU2/Exit/HostNmiInGC 0 times
00:26:37.500013 /HM/CPU2/Switch/Preempting 0 times
00:26:37.500031 /HM/CPU3/Exit/HostNmiInGC 0 times
00:26:37.500048 /HM/CPU3/Switch/Preempting 0 times
00:26:37.500066 /IEM/CPU0/CodeTlb-Misses 0 count
00:26:37.500085 /IEM/CPU0/CodeTlb-PhysRev ffffffffffff9c00
00:26:37.500104 /IEM/CPU0/CodeTlb-Revision fffff38000000000
00:26:37.500123 /IEM/CPU0/CodeTlb-SlowReads 0
00:26:37.500141 /IEM/CPU0/DataTlb-Misses 0 count
00:26:37.500159 /IEM/CPU0/DataTlb-PhysRev ffffffffffff9c00
00:26:37.500178 /IEM/CPU0/DataTlb-Revision fffff38000000000
00:26:37.500212 /IEM/CPU0/cInstructions 109189 count
00:26:37.500239 /IEM/CPU0/cLongJumps 0 bytes
00:26:37.500257 /IEM/CPU0/cPendingCommit 0 bytes
00:26:37.500275 /IEM/CPU0/cPotentialExits 107890 count
00:26:37.500295 /IEM/CPU0/cRetAspectNotImplemented 0 count
00:26:37.500461 /IEM/CPU0/cRetErrStatuses 0 count
00:26:37.500483 /IEM/CPU0/cRetInfStatuses 1300 count
00:26:37.500502 /IEM/CPU0/cRetInstrNotImplemented 0 count
00:26:37.500566 /IEM/CPU0/cbWritten 139088 bytes
00:26:37.500585 /IEM/CPU1/CodeTlb-Misses 0 count
00:26:37.500604 /IEM/CPU1/CodeTlb-PhysRev ffffffffffff9c00
00:26:37.500623 /IEM/CPU1/CodeTlb-Revision fffff38000000000
00:26:37.500684 /IEM/CPU1/CodeTlb-SlowReads 0
00:26:37.500704 /IEM/CPU1/DataTlb-Misses 0 count
00:26:37.500723 /IEM/CPU1/DataTlb-PhysRev ffffffffffff9c00
00:26:37.500783 /IEM/CPU1/DataTlb-Revision fffff38000000000
00:26:37.500803 /IEM/CPU1/cInstructions 0 count
00:26:37.500822 /IEM/CPU1/cLongJumps 0 bytes
00:26:37.500841 /IEM/CPU1/cPendingCommit 0 bytes
00:26:37.500899 /IEM/CPU1/cPotentialExits 0 count
00:26:37.500918 /IEM/CPU1/cRetAspectNotImplemented 0 count
00:26:37.500936 /IEM/CPU1/cRetErrStatuses 0 count
00:26:37.500994 /IEM/CPU1/cRetInfStatuses 0 count
00:26:37.501012 /IEM/CPU1/cRetInstrNotImplemented 0 count
00:26:37.501030 /IEM/CPU1/cbWritten 0 bytes
00:26:37.501087 /IEM/CPU2/CodeTlb-Misses 0 count
00:26:37.501106 /IEM/CPU2/CodeTlb-PhysRev ffffffffffff9c00
00:26:37.501125 /IEM/CPU2/CodeTlb-Revision fffff38000000000
00:26:37.501143 /IEM/CPU2/CodeTlb-SlowReads 0
00:26:37.501161 /IEM/CPU2/DataTlb-Misses 0 count
00:26:37.501217 /IEM/CPU2/DataTlb-PhysRev ffffffffffff9c00
00:26:37.501238 /IEM/CPU2/DataTlb-Revision fffff38000000000
00:26:37.501258 /IEM/CPU2/cInstructions 0 count
00:26:37.501314 /IEM/CPU2/cLongJumps 0 bytes
00:26:37.501335 /IEM/CPU2/cPendingCommit 0 bytes
00:26:37.501357 /IEM/CPU2/cPotentialExits 0 count
00:26:37.501419 /IEM/CPU2/cRetAspectNotImplemented 0 count
00:26:37.501440 /IEM/CPU2/cRetErrStatuses 0 count
00:26:37.501458 /IEM/CPU2/cRetInfStatuses 0 count
00:26:37.501477 /IEM/CPU2/cRetInstrNotImplemented 0 count
00:26:37.501535 /IEM/CPU2/cbWritten 0 bytes
00:26:37.501554 /IEM/CPU3/CodeTlb-Misses 0 count
00:26:37.501571 /IEM/CPU3/CodeTlb-PhysRev ffffffffffff9c00
00:26:37.501651 /IEM/CPU3/CodeTlb-Revision fffff38000000000
00:26:37.501671 /IEM/CPU3/CodeTlb-SlowReads 0
00:26:37.501690 /IEM/CPU3/DataTlb-Misses 0 count
00:26:37.501749 /IEM/CPU3/DataTlb-PhysRev ffffffffffff9c00
00:26:37.501770 /IEM/CPU3/DataTlb-Revision fffff38000000000
00:26:37.501789 /IEM/CPU3/cInstructions 0 count
00:26:37.501845 /IEM/CPU3/cLongJumps 0 bytes
00:26:37.501865 /IEM/CPU3/cPendingCommit 0 bytes
00:26:37.501882 /IEM/CPU3/cPotentialExits 0 count
00:26:37.501899 /IEM/CPU3/cRetAspectNotImplemented 0 count
00:26:37.501955 /IEM/CPU3/cRetErrStatuses 0 count
00:26:37.501975 /IEM/CPU3/cRetInfStatuses 0 count
00:26:37.501993 /IEM/CPU3/cRetInstrNotImplemented 0 count
00:26:37.502011 /IEM/CPU3/cbWritten 0 bytes
00:26:37.502030 /MM/HyperHeap/cbFree 1853040 bytes
00:26:37.502107 /MM/HyperHeap/cbHeap 2358976 bytes
00:26:37.502128 /PDM/BlkCache/cbCached 0 bytes
00:26:37.502147 /PDM/BlkCache/cbCachedFru 0 bytes
00:26:37.502166 /PDM/BlkCache/cbCachedMruIn 0 bytes
00:26:37.502184 /PDM/BlkCache/cbCachedMruOut 0 bytes
00:26:37.502218 /PDM/BlkCache/cbMax 5242880 bytes
00:26:37.502247 /PDM/CritSects/8237A#0Auto/ContentionR3 0 times
00:26:37.502329 /PDM/CritSects/8237A#0Auto/ContentionRZLock 0 times
00:26:37.502354 /PDM/CritSects/8237A#0Auto/ContentionRZUnlock 0 times
00:26:37.502377 /PDM/CritSects/AHCI#0/ContentionR3 0 times
00:26:37.502396 /PDM/CritSects/AHCI#0/ContentionRZLock 0 times
00:26:37.502469 /PDM/CritSects/AHCI#0/ContentionRZUnlock 0 times
00:26:37.502521 /PDM/CritSects/E1000#0/ContentionR3 0 times
00:26:37.502541 /PDM/CritSects/E1000#0/ContentionRZLock 0 times
00:26:37.502561 /PDM/CritSects/E1000#0/ContentionRZUnlock 0 times
00:26:37.502581 /PDM/CritSects/E1000#0RX/ContentionR3 0 times
00:26:37.502599 /PDM/CritSects/E1000#0RX/ContentionRZLock 0 times
00:26:37.502617 /PDM/CritSects/E1000#0RX/ContentionRZUnlock 0 times
00:26:37.502635 /PDM/CritSects/E1000#0TX/ContentionR3 0 times
00:26:37.502654 /PDM/CritSects/E1000#0TX/ContentionRZLock 0 times
00:26:37.502673 /PDM/CritSects/E1000#0TX/ContentionRZUnlock 0 times
00:26:37.502691 /PDM/CritSects/EM-REM/ContentionR3 0 times
00:26:37.502709 /PDM/CritSects/EM-REM/ContentionRZLock 0 times
00:26:37.502728 /PDM/CritSects/EM-REM/ContentionRZUnlock 0 times
00:26:37.502747 /PDM/CritSects/FTM/ContentionR3 0 times
00:26:37.502765 /PDM/CritSects/FTM/ContentionRZLock 0 times
00:26:37.502783 /PDM/CritSects/FTM/ContentionRZUnlock 0 times
00:26:37.502802 /PDM/CritSects/GIMDev#0Auto/ContentionR3 0 times
00:26:37.502835 /PDM/CritSects/GIMDev#0Auto/ContentionRZLock 0 times
00:26:37.502855 /PDM/CritSects/GIMDev#0Auto/ContentionRZUnlock 0 times
00:26:37.502874 /PDM/CritSects/HDA/ContentionR3 0 times
00:26:37.502892 /PDM/CritSects/HDA/ContentionRZLock 0 times
00:26:37.502911 /PDM/CritSects/HDA/ContentionRZUnlock 0 times
00:26:37.502929 /PDM/CritSects/HPET/ContentionR3 0 times
00:26:37.502945 /PDM/CritSects/HPET/ContentionRZLock 0 times
00:26:37.502963 /PDM/CritSects/HPET/ContentionRZUnlock 0 times
00:26:37.502980 /PDM/CritSects/MM-HYPER/ContentionR3 0 times
00:26:37.502997 /PDM/CritSects/MM-HYPER/ContentionRZLock 0 times
00:26:37.503014 /PDM/CritSects/MM-HYPER/ContentionRZUnlock 0 times
00:26:37.503035 /PDM/CritSects/NOP/ContentionR3 0 times
00:26:37.503056 /PDM/CritSects/NOP/ContentionRZLock 0 times
00:26:37.503074 /PDM/CritSects/NOP/ContentionRZUnlock 0 times
00:26:37.503091 /PDM/CritSects/OHCI#0Irq/ContentionR3 0 times
00:26:37.503108 /PDM/CritSects/OHCI#0Irq/ContentionRZLock 0 times
00:26:37.503124 /PDM/CritSects/OHCI#0Irq/ContentionRZUnlock 0 times
00:26:37.503141 /PDM/CritSects/PDM/ContentionR3 0 times
00:26:37.503159 /PDM/CritSects/PDM/ContentionRZLock 2 times
00:26:37.503177 /PDM/CritSects/PDM/ContentionRZUnlock 0 times
00:26:37.503195 /PDM/CritSects/PGM/ContentionR3 0 times
00:26:37.503213 /PDM/CritSects/PGM/ContentionRZLock 2 times
00:26:37.503230 /PDM/CritSects/PGM/ContentionRZUnlock 0 times
00:26:37.503249 /PDM/CritSects/REM-Register/ContentionR3 0 times
00:26:37.503266 /PDM/CritSects/REM-Register/ContentionRZLock 0 times
00:26:37.503284 /PDM/CritSects/REM-Register/ContentionRZUnlock 0 times
00:26:37.503303 /PDM/CritSects/TM Timer Lock/ContentionR3 1 times
00:26:37.503320 /PDM/CritSects/TM Timer Lock/ContentionRZLock 0 times
00:26:37.503339 /PDM/CritSects/TM Timer Lock/ContentionRZUnlock 0 times
00:26:37.503356 /PDM/CritSects/TM VirtualSync Lock/ContentionR3 0 times
00:26:37.503374 /PDM/CritSects/TM VirtualSync Lock/ContentionRZLock 14 times
00:26:37.503392 /PDM/CritSects/TM VirtualSync Lock/ContentionRZUnlock 0 times
00:26:37.503410 /PDM/CritSects/VGA#0/ContentionR3 0 times
00:26:37.503428 /PDM/CritSects/VGA#0/ContentionRZLock 0 times
00:26:37.503465 /PDM/CritSects/VGA#0/ContentionRZUnlock 0 times
00:26:37.503493 /PDM/CritSects/VGA#0_IRQ/ContentionR3 0 times
00:26:37.503511 /PDM/CritSects/VGA#0_IRQ/ContentionRZLock 0 times
00:26:37.503528 /PDM/CritSects/VGA#0_IRQ/ContentionRZUnlock 0 times
00:26:37.503545 /PDM/CritSects/VMMDev#0/ContentionR3 0 times
00:26:37.503561 /PDM/CritSects/VMMDev#0/ContentionRZLock 0 times
00:26:37.503578 /PDM/CritSects/VMMDev#0/ContentionRZUnlock 0 times
00:26:37.503596 /PDM/CritSects/acpi#0/ContentionR3 0 times
00:26:37.503616 /PDM/CritSects/acpi#0/ContentionRZLock 0 times
00:26:37.503637 /PDM/CritSects/acpi#0/ContentionRZUnlock 0 times
00:26:37.503654 /PDM/CritSects/efi#0Auto/ContentionR3 0 times
00:26:37.503672 /PDM/CritSects/efi#0Auto/ContentionRZLock 0 times
00:26:37.503690 /PDM/CritSects/efi#0Auto/ContentionRZUnlock 0 times
00:26:37.503707 /PDM/CritSects/ich9pci#0Auto/ContentionR3 0 times
00:26:37.503724 /PDM/CritSects/ich9pci#0Auto/ContentionRZLock 0 times
00:26:37.503741 /PDM/CritSects/ich9pci#0Auto/ContentionRZUnlock 0 times
00:26:37.503760 /PDM/CritSects/lpc#0Auto/ContentionR3 0 times
00:26:37.503778 /PDM/CritSects/lpc#0Auto/ContentionRZLock 0 times
00:26:37.503795 /PDM/CritSects/lpc#0Auto/ContentionRZUnlock 0 times
00:26:37.503812 /PDM/CritSects/mc146818#0Auto/ContentionR3 0 times
00:26:37.503830 /PDM/CritSects/mc146818#0Auto/ContentionRZLock 0 times
00:26:37.503847 /PDM/CritSects/mc146818#0Auto/ContentionRZUnlock 0 times
00:26:37.503865 /PDM/CritSects/pcarch#0Auto/ContentionR3 0 times
00:26:37.503883 /PDM/CritSects/pcarch#0Auto/ContentionRZLock 0 times
00:26:37.503900 /PDM/CritSects/pcarch#0Auto/ContentionRZUnlock 0 times
00:26:37.503919 /PDM/CritSects/pckbd#0Auto/ContentionR3 0 times
00:26:37.503936 /PDM/CritSects/pckbd#0Auto/ContentionRZLock 0 times
00:26:37.503956 /PDM/CritSects/pckbd#0Auto/ContentionRZUnlock 0 times
00:26:37.503974 /PDM/CritSects/pit#0/ContentionR3 0 times
00:26:37.503991 /PDM/CritSects/pit#0/ContentionRZLock 0 times
00:26:37.504009 /PDM/CritSects/pit#0/ContentionRZUnlock 0 times
00:26:37.504027 /PDM/CritSects/smc#0Auto/ContentionR3 0 times
00:26:37.504046 /PDM/CritSects/smc#0Auto/ContentionRZLock 0 times
00:26:37.504063 /PDM/CritSects/smc#0Auto/ContentionRZUnlock 0 times
00:26:37.504081 /PDM/CritSects/usb-ohci#0Auto/ContentionR3 0 times
00:26:37.504099 /PDM/CritSects/usb-ohci#0Auto/ContentionRZLock 0 times
00:26:37.504117 /PDM/CritSects/usb-ohci#0Auto/ContentionRZUnlock 0 times
00:26:37.504135 /PDM/CritSectsRw/IOM Lock/ContentionR3EnterExcl 0 times
00:26:37.504154 /PDM/CritSectsRw/IOM Lock/ContentionR3EnterShared 0 times
00:26:37.504175 /PDM/CritSectsRw/IOM Lock/ContentionRZEnterExcl 0 times
00:26:37.504196 /PDM/CritSectsRw/IOM Lock/ContentionRZEnterShared 0 times
00:26:37.504214 /PDM/CritSectsRw/IOM Lock/ContentionRZLeaveExcl 0 times
00:26:37.504232 /PDM/CritSectsRw/IOM Lock/ContentionRZLeaveShared 0 times
00:26:37.504249 /PDM/CritSectsRw/IOM Lock/R3EnterExcl 240 times
00:26:37.504267 /PDM/CritSectsRw/IOM Lock/R3EnterShared 44607 times
00:26:37.504285 /PDM/CritSectsRw/IOM Lock/RZEnterExcl 0 times
00:26:37.504303 /PDM/CritSectsRw/IOM Lock/RZEnterShared 1354814 times
00:26:37.504322 /PDM/Queue/AHCI-Xmit/AllocFailures 0 times
00:26:37.504340 /PDM/Queue/AHCI-Xmit/Flush 0 calls
00:26:37.504359 /PDM/Queue/AHCI-Xmit/FlushLeftovers 0 times
00:26:37.504376 /PDM/Queue/AHCI-Xmit/Insert 0 calls
00:26:37.504395 /PDM/Queue/AHCI-Xmit/cItems 60 count
00:26:37.504414 /PDM/Queue/AHCI-Xmit/cbItem 32 bytes
00:26:37.504435 /PDM/Queue/DevHlp/AllocFailures 0 times
00:26:37.504472 /PDM/Queue/DevHlp/Flush 0 calls
00:26:37.504490 /PDM/Queue/DevHlp/FlushLeftovers 0 times
00:26:37.504518 /PDM/Queue/DevHlp/Insert 0 calls
00:26:37.504543 /PDM/Queue/DevHlp/cItems 8 count
00:26:37.504562 /PDM/Queue/DevHlp/cbItem 64 bytes
00:26:37.504579 /PDM/Queue/E1000-Rcv/AllocFailures 0 times
00:26:37.504597 /PDM/Queue/E1000-Rcv/Flush 0 calls
00:26:37.504616 /PDM/Queue/E1000-Rcv/FlushLeftovers 0 times
00:26:37.504635 /PDM/Queue/E1000-Rcv/Insert 0 calls
00:26:37.504652 /PDM/Queue/E1000-Rcv/cItems 1 count
00:26:37.504671 /PDM/Queue/E1000-Rcv/cbItem 24 bytes
00:26:37.504690 /PDM/Queue/E1000-Xmit/AllocFailures 0 times
00:26:37.504708 /PDM/Queue/E1000-Xmit/Flush 0 calls
00:26:37.504726 /PDM/Queue/E1000-Xmit/FlushLeftovers 0 times
00:26:37.504745 /PDM/Queue/E1000-Xmit/Insert 0 calls
00:26:37.504763 /PDM/Queue/E1000-Xmit/cItems 1 count
00:26:37.504785 /PDM/Queue/E1000-Xmit/cbItem 24 bytes
00:26:37.504807 /PDM/Queue/Keyboard/AllocFailures 0 times
00:26:37.504826 /PDM/Queue/Keyboard/Flush 0 calls
00:26:37.504844 /PDM/Queue/Keyboard/FlushLeftovers 0 times
00:26:37.504861 /PDM/Queue/Keyboard/Insert 0 calls
00:26:37.504879 /PDM/Queue/Keyboard/cItems 64 count
00:26:37.504898 /PDM/Queue/Keyboard/cbItem 32 bytes
00:26:37.504916 /PDM/Queue/Keyboard_1/AllocFailures 0 times
00:26:37.504935 /PDM/Queue/Keyboard_1/Flush 0 calls
00:26:37.504954 /PDM/Queue/Keyboard_1/FlushLeftovers 0 times
00:26:37.504973 /PDM/Queue/Keyboard_1/Insert 0 calls
00:26:37.504991 /PDM/Queue/Keyboard_1/cItems 64 count
00:26:37.505011 /PDM/Queue/Keyboard_1/cbItem 32 bytes
00:26:37.505029 /PDM/Queue/Mouse/AllocFailures 0 times
00:26:37.505046 /PDM/Queue/Mouse/Flush 0 calls
00:26:37.505064 /PDM/Queue/Mouse/FlushLeftovers 0 times
00:26:37.505081 /PDM/Queue/Mouse/Insert 0 calls
00:26:37.505099 /PDM/Queue/Mouse/cItems 128 count
00:26:37.505118 /PDM/Queue/Mouse/cbItem 48 bytes
00:26:37.505138 /PDM/Queue/Mouse_1/AllocFailures 0 times
00:26:37.505156 /PDM/Queue/Mouse_1/Flush 0 calls
00:26:37.505174 /PDM/Queue/Mouse_1/FlushLeftovers 0 times
00:26:37.505193 /PDM/Queue/Mouse_1/Insert 0 calls
00:26:37.505211 /PDM/Queue/Mouse_1/cItems 128 count
00:26:37.505228 /PDM/Queue/Mouse_1/cbItem 48 bytes
00:26:37.505248 /PDM/Queue/SCSI-Eject/AllocFailures 0 times
00:26:37.505266 /PDM/Queue/SCSI-Eject/Flush 0 calls
00:26:37.505284 /PDM/Queue/SCSI-Eject/FlushLeftovers 0 times
00:26:37.505302 /PDM/Queue/SCSI-Eject/Insert 0 calls
00:26:37.505321 /PDM/Queue/SCSI-Eject/cItems 1 count
00:26:37.505340 /PDM/Queue/SCSI-Eject/cbItem 40 bytes
00:26:37.505362 /PGM/CPU0/cA20Changes 0 times
00:26:37.505384 /PGM/CPU0/cGuestModeChanges 5 times
00:26:37.505402 /PGM/CPU1/cA20Changes 0 times
00:26:37.505419 /PGM/CPU1/cGuestModeChanges 1 times
00:26:37.505443 /PGM/CPU2/cA20Changes 0 times
00:26:37.505460 /PGM/CPU2/cGuestModeChanges 1 times
00:26:37.505477 /PGM/CPU3/cA20Changes 0 times
00:26:37.505495 /PGM/CPU3/cGuestModeChanges 1 times
00:26:37.505514 /PGM/ChunkR3Map/Mapped 64 count
00:26:37.505533 /PGM/ChunkR3Map/Unmapped 0 count
00:26:37.505551 /PGM/ChunkR3Map/c 64 count
00:26:37.505568 /PGM/ChunkR3Map/cMax 4294967295 count
00:26:37.505593 /PGM/LargePage/Recheck 0 times
00:26:37.505614 /PGM/LargePage/Refused 2 times
00:26:37.505632 /PGM/LargePage/Reused 0 times
00:26:37.505653 /PGM/Page/cAllPages 1099826 count
00:26:37.505672 /PGM/Page/cBalloonedPages 0 count
00:26:37.505704 /PGM/Page/cHandyPages 32 count
00:26:37.505730 /PGM/Page/cLargePages 9 count
00:26:37.505749 /PGM/Page/cLargePagesDisabled 0 count
00:26:37.505767 /PGM/Page/cMonitoredPages 0 count
00:26:37.505786 /PGM/Page/cPrivatePages 66495 count
00:26:37.505804 /PGM/Page/cPureMmioPages 16430 count
00:26:37.505823 /PGM/Page/cReadLockedPages 0 count
00:26:37.505840 /PGM/Page/cReusedSharedPages 0 count
00:26:37.505858 /PGM/Page/cSharedPages 0 count
00:26:37.505876 /PGM/Page/cWriteLockedPages 0 count
00:26:37.505894 /PGM/Page/cWrittenToPages 0 count
00:26:37.505911 /PGM/Page/cZeroPages 1016901 count
00:26:37.505930 /PGM/ShMod/Check 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.505951 /PGM/cRelocations 0 times
00:26:37.505972 /PROF/CPU0/EM/Capped 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.505995 /PROF/CPU0/EM/ForcedActions 773 times
00:26:37.506014 /PROF/CPU0/EM/Halted 4 times
00:26:37.506032 /PROF/CPU0/EM/RAWTotal 0 times
00:26:37.506052 /PROF/CPU0/EM/REMTotal 0 times
00:26:37.506071 /PROF/CPU0/EM/Total 17064481395 ticks/call ( 17064481395 ticks, 1 times, max 17064481395, min 17064481395)
00:26:37.506093 /PROF/CPU0/VM/Halt/Block 7781292 ns/call ( 31125170 ticks, 4 times, max 10656439, min 1104897)
00:26:37.506117 /PROF/CPU0/VM/Halt/BlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506136 /PROF/CPU0/VM/Halt/BlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506187 /PROF/CPU0/VM/Halt/BlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506210 /PROF/CPU0/VM/Halt/Timers 1190 ns/call ( 9525 ticks, 8 times, max 2399, min 102)
00:26:37.506230 /PROF/CPU0/VM/Halt/Yield 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506249 /PROF/CPU1/EM/Capped 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506275 /PROF/CPU1/EM/ForcedActions 8 times
00:26:37.506293 /PROF/CPU1/EM/Halted 8 times
00:26:37.506311 /PROF/CPU1/EM/RAWTotal 0 times
00:26:37.506329 /PROF/CPU1/EM/REMTotal 0 times
00:26:37.506347 /PROF/CPU1/EM/Total 14214140748 ticks/call ( 14214140748 ticks, 1 times, max 14214140748, min 14214140748)
00:26:37.506372 /PROF/CPU1/VM/Halt/Block 291120916 ns/call ( 5240176490 ticks, 18 times, max 501141055, min 24020)
00:26:37.506393 /PROF/CPU1/VM/Halt/BlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506417 /PROF/CPU1/VM/Halt/BlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506437 /PROF/CPU1/VM/Halt/BlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506456 /PROF/CPU1/VM/Halt/Timers 911 ns/call ( 23711 ticks, 26 times, max 2214, min 196)
00:26:37.506478 /PROF/CPU1/VM/Halt/Yield 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506515 /PROF/CPU2/EM/Capped 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506538 /PROF/CPU2/EM/ForcedActions 8 times
00:26:37.506558 /PROF/CPU2/EM/Halted 7 times
00:26:37.506577 /PROF/CPU2/EM/RAWTotal 0 times
00:26:37.506595 /PROF/CPU2/EM/REMTotal 0 times
00:26:37.506614 /PROF/CPU2/EM/Total 14213868773 ticks/call ( 14213868773 ticks, 1 times, max 14213868773, min 14213868773)
00:26:37.506648 /PROF/CPU2/VM/Halt/Block 308260821 ns/call ( 5240433970 ticks, 17 times, max 501083889, min 277484)
00:26:37.506685 /PROF/CPU2/VM/Halt/BlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506709 /PROF/CPU2/VM/Halt/BlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506728 /PROF/CPU2/VM/Halt/BlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506747 /PROF/CPU2/VM/Halt/Timers 839 ns/call ( 20139 ticks, 24 times, max 2965, min 118)
00:26:37.506768 /PROF/CPU2/VM/Halt/Yield 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506788 /PROF/CPU3/EM/Capped 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506809 /PROF/CPU3/EM/ForcedActions 14 times
00:26:37.506827 /PROF/CPU3/EM/Halted 13 times
00:26:37.506845 /PROF/CPU3/EM/RAWTotal 0 times
00:26:37.506862 /PROF/CPU3/EM/REMTotal 0 times
00:26:37.506880 /PROF/CPU3/EM/Total 14214250913 ticks/call ( 14214250913 ticks, 1 times, max 14214250913, min 14214250913)
00:26:37.506920 /PROF/CPU3/VM/Halt/Block 5052736 ns/call ( 5219476713 ticks, 1033 times, max 25407212, min 5801)
00:26:37.506942 /PROF/CPU3/VM/Halt/BlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506962 /PROF/CPU3/VM/Halt/BlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.506981 /PROF/CPU3/VM/Halt/BlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:26:37.507000 /PROF/CPU3/VM/Halt/Timers 16580 ns/call ( 18520454 ticks, 1117 times, max 1607591, min 3)
00:26:37.507020 /PROF/CPU3/VM/Halt/Yield 7434 ns/call ( 7434 ticks, 1 times, max 7434, min 7434)
00:26:37.507040 /Public/Net/E1k0/BytesReceived 0 bytes
00:26:37.507058 /Public/Net/E1k0/BytesTransmitted 0 bytes
00:26:37.507077 /REM/TbFlushCount 0 times
00:26:37.507096 /REM/TbPhysInvldCount 0 times
00:26:37.507114 /REM/TlbFlushCount 2 times
00:26:37.507132 /SELM/LoadHidSel/GstReadErrors 0 times
00:26:37.507150 /SELM/LoadHidSel/NoGoodGuest 0 times
00:26:37.507169 /TM/CPU/00/cNsExecuting 2331181145 ns
00:26:37.507187 /TM/CPU/00/cNsHalted 31151962 ns
00:26:37.507260 /TM/CPU/00/cNsOther 2911072037 ns
00:26:37.507280 /TM/CPU/00/cNsTotal 5273405144 ns
00:26:37.507298 /TM/CPU/00/cPeriodsExecuting 1258716 count
00:26:37.507317 /TM/CPU/00/cPeriodsHalted 4 count
00:26:37.507335 /TM/CPU/00/pctExecuting 52 %
00:26:37.507360 /TM/CPU/00/pctHalted 0 %
00:26:37.507421 /TM/CPU/00/pctOther 47 %
00:26:37.507484 /TM/CPU/01/cNsExecuting 0 ns
00:26:37.507503 /TM/CPU/01/cNsHalted 5240245404 ns
00:26:37.507522 /TM/CPU/01/cNsOther 34195927 ns
00:26:37.507541 /TM/CPU/01/cNsTotal 5274441331 ns
00:26:37.507561 /TM/CPU/01/cPeriodsExecuting 0 count
00:26:37.507579 /TM/CPU/01/cPeriodsHalted 8 count
00:26:37.507597 /TM/CPU/01/pctExecuting 0 %
00:26:37.507615 /TM/CPU/01/pctHalted 100 %
00:26:37.507633 /TM/CPU/01/pctOther 0 %
00:26:37.507651 /TM/CPU/02/cNsExecuting 0 ns
00:26:37.507668 /TM/CPU/02/cNsHalted 5240496182 ns
00:26:37.507686 /TM/CPU/02/cNsOther 33875785 ns
00:26:37.507704 /TM/CPU/02/cNsTotal 5274371967 ns
00:26:37.507722 /TM/CPU/02/cPeriodsExecuting 0 count
00:26:37.507754 /TM/CPU/02/cPeriodsHalted 7 count
00:26:37.507779 /TM/CPU/02/pctExecuting 0 %
00:26:37.507797 /TM/CPU/02/pctHalted 100 %
00:26:37.507814 /TM/CPU/02/pctOther 0 %
00:26:37.507832 /TM/CPU/03/cNsExecuting 0 ns
00:26:37.507850 /TM/CPU/03/cNsHalted 5240436659 ns
00:26:37.507898 /TM/CPU/03/cNsOther 34009816 ns
00:26:37.507944 /TM/CPU/03/cNsTotal 5274446475 ns
00:26:37.507968 /TM/CPU/03/cPeriodsExecuting 0 count
00:26:37.507986 /TM/CPU/03/cPeriodsHalted 13 count
00:26:37.508005 /TM/CPU/03/pctExecuting 0 %
00:26:37.508022 /TM/CPU/03/pctHalted 99 %
00:26:37.508040 /TM/CPU/03/pctOther 0 %
00:26:37.508059 /TM/CPU/pctExecuting 22 %
00:26:37.508077 /TM/CPU/pctHalted 57 %
00:26:37.508098 /TM/CPU/pctOther 20 %
00:26:37.508120 /TM/MaxHzHint 0 Hz
00:26:37.508138 /TM/R0/1nsSteps 447 times
00:26:37.508157 /TM/R3/1nsSteps 493 times
00:26:37.508179 /TM/TSC/offCPU0 0 ticks
00:26:37.508198 /TM/TSC/offCPU1 0 ticks
00:26:37.508216 /TM/TSC/offCPU2 0 ticks
00:26:37.508233 /TM/TSC/offCPU3 0 ticks
00:26:37.508251 /TM/VirtualSync/CurrentOffset 144943 ns
00:26:37.508270 /VUSB/0/cUrbsInPool 0 count
00:26:37.508290 ********************* End of statistics **********************
00:26:37.508635 VUSB: Detached 'HidKeyboard' from port 1 on RootHub#0
00:26:37.508935 VUSB: Detached 'HidMouse' from port 2 on RootHub#0
00:26:37.565432 NAT: Zone(nm:mbuf_cluster, used:0)
00:26:37.567197 NAT: Zone(nm:mbuf_packet, used:0)
00:26:37.567257 NAT: Zone(nm:mbuf, used:0)
00:26:37.567732 NAT: Zone(nm:mbuf_jumbo_pagesize, used:0)
00:26:37.569366 NAT: Zone(nm:mbuf_jumbo_9k, used:0)
00:26:37.570380 NAT: Zone(nm:mbuf_jumbo_16k, used:0)
00:26:37.570990 NAT: Zone(nm:mbuf_ext_refcnt, used:0)
00:26:37.571352 E1000#0 Interrupt attempts: 0
00:26:37.571393 E1000#0 Interrupts raised : 0
00:26:37.571412 E1000#0 Interrupts lowered: 0
00:26:37.571431 E1000#0 ICR outside ISR : 0
00:26:37.571450 E1000#0 IMS raised ints : 0
00:26:37.571468 E1000#0 Interrupts skipped: 0
00:26:37.571486 E1000#0 Masked interrupts : 0
00:26:37.571504 E1000#0 Early interrupts : 0
00:26:37.571526 E1000#0 Late interrupts : 0
00:26:37.571548 E1000#0 Lost interrupts : 0
00:26:37.571566 E1000#0 Interrupts by RX : 0
00:26:37.571585 E1000#0 Interrupts by TX : 0
00:26:37.571605 E1000#0 Interrupts by ICS : 0
00:26:37.571623 E1000#0 Interrupts by RDTR: 0
00:26:37.571641 E1000#0 Interrupts by RDMT: 0
00:26:37.571658 E1000#0 Interrupts by TXQE: 0
00:26:37.571674 E1000#0 TX int delay asked: 0
00:26:37.571691 E1000#0 TX delayed: 0
00:26:37.571709 E1000#0 TX delay expired: 0
00:26:37.571726 E1000#0 TX no report asked: 0
00:26:37.571744 E1000#0 TX abs timer expd : 0
00:26:37.571761 E1000#0 TX int timer expd : 0
00:26:37.571779 E1000#0 RX abs timer expd : 0
00:26:37.571796 E1000#0 RX int timer expd : 0
00:26:37.571813 E1000#0 TX CTX descriptors: 0
00:26:37.571830 E1000#0 TX DAT descriptors: 0
00:26:37.571848 E1000#0 TX LEG descriptors: 0
00:26:37.571869 E1000#0 Received frames : 0
00:26:37.571888 E1000#0 Transmitted frames: 0
00:26:37.571907 E1000#0 TX frames up to 1514: 0
00:26:37.571924 E1000#0 TX frames up to 2962: 0
00:26:37.571943 E1000#0 TX frames up to 4410: 0
00:26:37.571987 E1000#0 TX frames up to 5858: 0
00:26:37.572006 E1000#0 TX frames up to 7306: 0
00:26:37.572023 E1000#0 TX frames up to 8754: 0
00:26:37.572044 E1000#0 TX frames up to 16384: 0
00:26:37.572062 E1000#0 TX frames up to 32768: 0
00:26:37.572079 E1000#0 Larger TX frames : 0
00:26:37.572097 E1000#0 Max TX Delay : 0
00:26:37.581953 Changing the VM state from 'DESTROYING' to 'TERMINATED'
00:26:37.601829 Console: Machine state changed to 'PoweredOff'
00:26:38.230706 GUI: Passing request to close Runtime UI from machine-logic to UI session.
