ARMOR-original
AMD HD6450 512MB on High Sierra [HELP]
Hi There,
I have installed Hackintosh High Sierra on My Desktop Computer, the only issue I have is the GPU kext, i could not find it
I tried HD6450 1Gb not working, I tried the most tutorials with no result,
my computer specs are :
Core 2 Duo E8400 3.0Ghz
8Gb DDR3 RAM
250Gb HDD1/ 2Tb HDD2
AMD HD6450 512Mb DDR3
I have already fixed the problem already last year in Sierra just forgot the way how :/
I put my config.plist in files maybe it could help to find a solution
config.plist
Hi
HD 5xxx/6xxx graphics cards need kexts rollback from Sierra
AMDRadeonX3000.kext
AMDRadeonX3000GLDriver.bundle
IOAccelerator2D.plugin
IOAcceleratorFamily2.kext
Then use the way you want
  1. Add your device-id manually in Info.plist
  2. Clover device-id injection on the fly
  3. Clover Fake-ID
