kyndder
[Tips] Lilu.kext and Plugins
Hello, @Poles !
Using Lilu and plugins at EFI/Clover/kexts/xxxx, will ensure that all kexts will be loaded at early boot stages and, by doing this, ensure that all needed fixes will be applied before other related system kexts get loaded...
If you choose to use L/E, is better to use also LiluFriend.kext, that is a helper kext for those using system locations for kexts, and its only purpose is ensure that the same behavior described above will happen even using this locations...
Best regards.
On 12/19/2018 at 2:05 AM, Poles said:
@kyndder
What is the actual place for installing lilu & its plugins?
Somewhere I read its EFI/Clover/Kexts/Other and somewhere its L/E ? So which one is true?
You can do in both places but better to under clover.so you dont have to patch them often.
