mig81
ATI 5450 on MACPRO with 10.11.6 problem
Hello, I cannot run my ATI HD5450 on MACPRO 1,1 with 10.11.6
It run ok under 10.7 lion with the 68F91002 kext modify manually on ATI5000controller and the other ATIRADEONX3000.
I tried to do the same on 10.11.6 but nothing. I can see only black screen.
Now I have both video card on the MacPro and it works with GT7300 but in system report It says no kext loaded for the other video card....
Here the report:
Last login: Thu Sep 27 13:12:27 on console
michis-Mac-Pro:~ michi$ kextstat | grep AMD
  121    0 0xffffff7f822a7000 0x125000   0x125000   com.apple.kext.AMDSupport (1.3.6) 83090AC0-12F4-3913-875B-34864770E7AD <120 90 12 11 7 5 4 3 1>
I loaded both them manually but how can I load them at the boot? I think this is the problem....
Here the report:
Last login: Thu Sep 27 20:56:21 on ttys000
michis-Mac-Pro:~ michi$ sudo kextload /System/Library/Extensions/AMDRadeonX3000.kext
Password:
michis-Mac-Pro:~ michi$ sudo kextload /System/Library/Extensions/AMD5000Controller.kext
  111    1 0xffffff7f822d4000 0x125000   0x125000   com.apple.kext.AMDSupport (1.4.2) B1E391D3-E002-32E9-ACD4-7465DF9CCF7D <110 84 12 11 7 5 4 3 1>
  128    0 0xffffff7f8247c000 0x45b000   0x45b000   com.apple.AMDRadeonX3000 (1.4.2) 76FC78E2-43C3-35D5-8AA6-B7AFE18EE963 <127 84 12 7 5 4 3 1>
  129    0 0xffffff7f828d7000 0x5f1000   0x5f1000   com.apple.kext.AMD5000Controller (1.4.2) 483B9948-D660-3BD2-A9A6-07168CB09401 <111 84 12 11 5 4 3 1>
Now I'm not use clover boot loader, I'm just use the original boot loader to boot 10.5/ 10.7/ 10.11/ win7
thanks
Michele
7 hours ago, mig81 said:
NOW, AFTER MANY REBOOTS,  IT DEFINITELY WORKS!
Nice so its permission issue after all :)
Yes should be the permissions and the recache but anyway I did these operations from the first time I patched the kext....
thankx guys!!
thankx guys!!
Welcome, hackintosh works in mysterious ways sometimes.Make sure you have full backup of the hole system.
Use Carbon copy cloner
Enjoy
problem neverending..... After update to 10.11.6, reinstall the new patches BOTH and repair permissions with the terminal and recache many many times without good results. It repair always the same permissions....hahaha I really don't know... I do it again and again and maybe tomorrow it works again...them when it starts to work it works good....
someone knows what I could do? I think it's a permission issue....
Here the same repair permission and recache results:
Last login: Tue Oct  2 18:54:09 on ttys000
Mac-Pro-Dual-266-di-Michele:~ michi$ sudo /usr/libexec/repair_packages --repair --standard-pkgs --volume /
    Permissions differ on "System/Library/Extensions/AMD5000Controller.kext/Contents/Info.plist", should be -rw-r--r-- , they are -rwxr-xr-x .
    Repaired "System/Library/Extensions/AMD5000Controller.kext/Contents/Info.plist".
    Permissions differ on "System/Library/Extensions/AMD5000Controller.kext/Contents/_CodeSignature/CodeResources", should be -rw-r--r-- , they are -rwxr-xr-x .
    Repaired "System/Library/Extensions/AMD5000Controller.kext/Contents/_CodeSignature/CodeResources".
    Permissions differ on "System/Library/Extensions/AMD5000Controller.kext/Contents/version.plist", should be -rw-r--r-- , they are -rwxr-xr-x .
    Repaired "System/Library/Extensions/AMD5000Controller.kext/Contents/version.plist".
    Permissions differ on "System/Library/Extensions/AMDRadeonX3000.kext/Contents/Info.plist", should be -rw-r--r-- , they are -rwxr-xr-x .
    Repaired "System/Library/Extensions/AMDRadeonX3000.kext/Contents/Info.plist".
    Permissions differ on "System/Library/Extensions/AMDRadeonX3000.kext/Contents/_CodeSignature/CodeResources", should be -rw-r--r-- , they are -rwxr-xr-x .
    Repaired "System/Library/Extensions/AMDRadeonX3000.kext/Contents/_CodeSignature/CodeResources".
    Permissions differ on "System/Library/Extensions/AMDRadeonX3000.kext/Contents/version.plist", should be -rw-r--r-- , they are -rwxr-xr-x .
    Repaired "System/Library/Extensions/AMDRadeonX3000.kext/Contents/version.plist".
    User differs on "private/var/db/displaypolicyd", should be 0, user is 244.
    Group differs on "private/var/db/displaypolicyd", should be 0, group is 244.
    Repaired "private/var/db/displaypolicyd".
Mac-Pro-Dual-266-di-Michele:~ michi$ sudo touch /System/Library/Extensions && kextcache -u /
Password:
Warning: non-root can't lock the volume for /
Untrusted kexts are not allowed
AMDRadeonX3000.kext has invalid signature; omitting.
AMD5000Controller.kext has invalid signature; omitting.
Can't create /System/Library/PrelinkedKernels/prelinkedkernel.Rg1B - Permission denied.
Child process /usr/sbin/kextcache[672] exited with status 70.
Error 107 rebuilding /System/Library/PrelinkedKernels/prelinkedkernel
Please admins, let me write a beast!!!
When you edit a vanilla kext, you systematically lose its code signature, it is why you have that 'has invalid signature' error. I know there a terminal command to code sign a kext but do not remember anymore, sorry. Research for google, I guess.
OTOH, I do not remember anymore but I think you need the boot flag 'kext-dev-mode=1' under ElCapitan which allows you to boot with those 'invalid signature' kexts.
But Clover developers made the thing more better... they integrated that boot flag into the nvram.plist, so you need no more that boot flag.
So, all you have to do it is to update your clover version, if you're still using it.
