noname
Hackintosh sound with AppleALC.kext
Short tutorial how to get hackintosh sound to work using AppleALC.kext
Ingredients:
 - Clover Configurator
 - AppleALC.kext
 - Lilu.kext
 - Supported Codecs list
 - MaciASL
So, you all may or may not know that the best solution for enabling your sound is AppleALC.kext
To get it working you’ll need obviously AppleALC.kext but also Lilu.kext
You need to install those kexts to your EFI/kexts/Other folder.
Third thing you’ll need is layout-id for your audio codec. Simply go to this page and find one that corresponds to your hardware: https://github.com/acidanthera/AppleALC/wiki/Supported-codecs
Injecting is easy, simply use Clover Configurator, mount your EFI partition and load your config.plist. From there go to Devices and go to Audio and type in on of the layout Id’s from Supported Codecs page. If there is more than one, you’ll need to test one by one to find appropriate. While at Audio tab, you can check ResetHDA box too:
So we are done! And for most of you, you’ll have sound. But for the others, sound is nowhere to be found! What’s next????
Well, there is a few thing we could do.
1. For starters, in Clover configurator, ACPISection, in the list of patches add
change HDAS to HDEF
Clover configurator will fill in Find and Replace values.
DO the restart after every change.
Still no sound???
2. Second thing we need to check is whether AppleALC.kext and AppleHDA.kext are loading.
Use these commands:
kextstat | grep -y hda
Output should look something like this:
Also for ALC:
kextstat | grep -y ALC
If you see they are loading, like in previous examples, then, probably you need to try some other layout ID and you’ll soon have sound.
But what if for example AppleHDA.kext is not loading?
3. You probably need some patches in your dsdt, namely HPET Fix and IRQ Fix
Use MaciASL for adding patches to your dsdt
Quote
#Maintained by: RehabMan for: Laptop Patches
#system_HPET.txt
# If you have panic "No HPETs available..." or have a abrubt restart
# after waking from sleep, you may need this patch.
# The patch makes sure the HPET device is always available.
# HPET fix to avoid AppleIntelCPUPowerManagement panic
into method label _STA parent_hid PNP0103 remove_entry;
into device name_hid PNP0103 code_regex Name\s\(_STA\,\s+0x0F\) remove_matched;
into device name_hid PNP0103 insert
begin
Name (_STA, 0x0F)\n
end;
into method label _CRS parent_hid PNP0103 remove_entry;
begin
Method (_CRS, 0, NotSerialized)\n
{\n
    Return (BUF0)\n
}\n
end;
Quote
#system_IRQ.txt
# This can fix non-working audio and also has an affect on HPET.
# Use this if you have issues with patched AppleHDA (required on almost all laptops)
# or if you have issues with HPET (restart after wake).
# IRQ fix
into device name_hid PNP0000 code_regex IRQNoFlags\s\(\)\n\s+\{(\d+)\} remove_matched;
into device name_hid PNP0100 code_regex IRQNoFlags\s\(\)\n\s+\{(\d+)\} remove_matched;
into device name_hid PNP0B00 code_regex IRQNoFlags\s\(\)\n\s+\{(\d+)\} remove_matched;
into device name_hid PNP0103 code_regex IRQNoFlags\s\(\)\n\s+\{.*\} removeall_matched;
into device name_hid PNP0103 code_regex Name\s\(([^,]+),\sResourceTemplate\s\(\).*\n\s+\{((?:.|\n)*)\}\) replace_matched
begin
Name (%1, ResourceTemplate()\n
{\n
    IRQNoFlags() { 0, 8, 11, 15 }\n
%2
})\n
end;
Place dsdt.aml to your EFI/ACPI/Patched Folder and restart one more time.
4. If you still have no sound you can try to check FixHDA also in ACPI Section of Clover Configurator.
After every restart and every change, of layout-id’s, or patches or fixes, you’ll need to check if AppleHDA or AppleALC is loaded.
5. Last fix to try is to remove every instance of HDEF from your dsdt.aml, as it may interfere with sound activation proces.
For that you use MaciASL, simply find HDEF, delete it and recompile it.
And you should be done!
So there you go, hopefully now you have sound on your hacintosh. Please comment below if it’s working for you!
