ALiveVam
[Guide]Enable and Control Backlight | Brightness for Mojave 10.14.x
If you use Mojave 10.14.x, follow this guide to enable and control Backlight | Brightness for laptop/desktop.
NOTE: Before doing this you must need to Patch DSDT and SSDT
Requirement:
We need 4 thing for enabling and Controlling Laptop Backlight|Brightness.
  1. A Patched SSDT-PNLF.aml
  2. AppleBacklightFixup.kext
  3. Lilu.kext
  4. WhateverGreen.kext
Preparation:
Download this following elements
A Patched SSDT-PNLF.aml, AppleBacklightFixup.kext,Lilu.kext,WhateverGreen.kext
For Backlight|Brightness.zip <<<<<
Installation:
*Mount EFI Partition....
"Lilu.kext" and "WhateverGreen.kext" install to system/library or EFi/efi/clover/kext/Other
"AppleBacklightFixup.kext" install to system/library or EFi/efi/clover/kext/Other
"A Patched SSDT-PNLF.aml" install to EFi/efi/clover/Acpi/Patched
After Install:
Open Terminal and Paste this following command
In Terminal
sudo kextcache -i /
After process is complete, then reboot.
**If the Brightness | Backlight not working
Open Terminal and paste this following command one by one.
In Terminal....
sudo chmod -R 755 /System/Library/Extensions/
sudo chown -R root:wheel /System/Library/Extensions/
sudo touch /System/Library/Extensions && sudo touch /Library/Extensions && sudo kextcache -u /
After process is complete then Reboot.[Recommended]
All Done...😊😉
Edited by ALiveVam
