ALiveVam
[Guide]Prepare a USB Flash Drive for installing macOS Mojave
macOS Mojave was just released in 24th September 2018. This is the major release by an Apple because the UI of Mojave is completely dark.
Requirements for this guide :
  • Intel based processor laptop/desktop
  • USB stick 8 GB or higher
  • A working mac or hackintosh
  • Internet Connection
Preparation:
Download macOS Mojave
To get a working Mojave installer onto a USB flash drive it must first be formatted into a scheme that allows for an EFI Partition. Afterwards the the Mojave Installer is ready to be placed on the USB drive using is Terminal.
Step 1:
Formatting the USB Drive.
You can format the USB flash drive using two way:
  1. Disk Utility
  2. Terminal
1.Disk Utility:
**Insert Flash Drive
**Open Disk Utility
**Select the Flash Drive on the left column
**Click Erase
Set the following settings:
  • Name: Mojave Installer
  • Format: Mac OS Extended (Journaled)
  • Scheme: GUID Partition Map
**Click Erase
**Click Done upon finish.
2.Terminal
**Open Terminal
And Type Following Command
diskutil list
Then
# repartition /dev/disk1 GPT, one partition
# EFI will be created automatically
# second partition, "install_osx", HFS+J, remainder
diskutil partitionDisk /dev/disk1 1 GPT HFS+J "install_osx" R
Note:- In my case,my sub flash drive is /dev/disk1, You can check for available drive using command diskutil list
Step 2: Transferring the Mojave Installer to usb flash drive via terminal.
If you using Disk Utility method to Formatting the USB Drive,then using this command.
In Terminal....
First edit and replace Your USB Drive Name.
sudo /Applications/Install\ macOS\ Mojave.app/Contents/Resources/createinstallmedia --volume /Volumes/Mojave Installer --applicationpath /Applications/Install\ macOS\ Mojave.app --nointeraction
Then..
After finishing the process.In Terminal [Recommended]
sudo diskutil rename "Install macOS Mojave" Mojave Installer
**If you using Terminal method to Formatting the USB Drive,then using this command.
In Terminal..
sudo "/Applications/Install macOS Mojave.app/Contents/Resources/createinstallmedia" --volume  /Volumes/install_osx --nointeraction
sudo diskutil rename "Install macOS Mojave" install_osx
Step 3:
Mount EFI Partition
Step 4:
Download Clover EFI Bootloader
Step 5:
Install Clover EFI Bootloader to usb flash drive.
  • Change Install Location and select your usb flash drive
  • select "Customize"
  • Check "Install for UEFI booting only", "Install Clover in the ESP" will automatically select
  • Check Themes
  • The defaults for Drivers64UEFI.efi are recommended
Step 6:
Moving Kext
You need to download the kext which matches with your system and copy the kext to USB EFI  /EFI/EFI/Clover/Kexts/Other/
Download:
Replace your EFI with this modified EFI<<<<<
Edited by ALiveVam
