djsam
snow leopard
with sl going gold master and all apple developers receiving a copy, is anyone working on/having success getting it running with chameleon?
Hi all
I have installed 10A432 golden master (the one without beta mark) with the help from this post http://www.infinitemac.com/f57/guide-installing-snow-10a432-on-g31m-es2l-t3672/ . At this moment I only finished the first -x32 boot . It's too late and too tired for me, I am here only to tell you it's quite possible and practical to use Chameleon method with SL now. Details will be posted later, I was doing this slightly different from the guide post.
cheers~
a quick report:
after using SL gm for a whole morning, I got most things work, LAN, TimeMachine, all software, etc; what's non-working at this moment are : Sound(no device found), WIFI (pci D-Link DWA552 AR5416 chip) and CMOS reset problem. Maybe sleep can not work too. A very strange phenomenon is in the first "-x32" boot, the welcome guide detected my DWA552 pci wifi card, and actually I use this to connect my AP to send some reg data, but in the latter x86_64 boot AirPort utility shows no card found.
For purpose of getting the result with least time, I use almost exactly the same method described in the guide (see previous reply). And maybe using Chameleon 1.0 RC2 will be a bad idea, I have several failures which I guessed the reason is RC2.
When anything goes working, I will post the result here and other helpful hints are welcomed greatly.
Groovy Cool!!!! Fed Ex just dropped off my Snow Leopards. One of them is busily installing on my MBP ..... the other... now what do I do? I seem to remember Mike saying he was working on a guide for those of us who are somewhat noobular. Did I remember correctly? And, just for the record, this machine working just fine ... other than that DSDT problem. So, I'm in no real urgent rush...just a tad curious.
Thanks
R
Yeah, yeah, I know...I sound like I'm back on ASEM pestering Li'l Gouda for an update statement. I don't mean to ... I just like playing with my new toyz. I can't wait until the new iPodz come out!!!!
Hi Poison,
I have a quick question. The $29 upgrade DVD from Apple, is this a FULL Version? In other words, does it install on a machine with no OS on it? Is there a FULL Retail (non upgrade) version; if so is it different than the Upgrade?
