prinzessin
... and again another efix switcher
Did you do an upgrade to SL or a clean install? I'm seeing a GeforcePPC.kext as part of that output, which isn't included with SL.
It is a clean install of SL on a brand new hdd, but the usbstick has also been used to start 10.5. Thanks for pointing that out.
After a complete new install using Mikes Guide ich could boot up and work, but my 9600GT wasn´t working correctly. So I tried to make it work by aquamacs guide http://aquamac.proboards.com/index.cgi?board=hack1&action=display&thread=509
The insertion of the HEX Value made both Monitors working !!!!
Thanks for that !
But now my DWA 547 isnt woking any more. I was working in the last days when I worked with the previous installations. I also tried to put the card into another PCIE slot but this did changed the behavior. So no Airport.
Someone has an Idea?
Best Regards,
prinzessin
It seems to fail on the 64bit mode.
See this link
http://www.insanelymac.com/forum/lofiversion/index.php/t186248.html
So I have to boot in 32 Bit Mode.
After editing the "arch386" command in my boot.plist unter /preferences/systempref/...
and using kext utility and several !! reboots it is now working.
I`am learning step by step. :-)
and the next one will be audio...
