thomasvdalen
Club3D Radeon 4650 screen resolution in 10.6.4
I installed Iatkos S3 V2 (10.6.3) and updated it with the combo update to 10.6.4.
I use Chameleon 2 RC4. By setup custimize i let it all standard.
My system specs are:
Asus P5QLD Pro
Club 3D 4650 1 GB, with DVI, S-video and HDMI output
Dominator 4GB 1066.
The vga card is connected by DVI2VGA adapter on my television. And with the HDMI also on my television.
Now the big qustion is: I cant change my resolution higher than 1024 x 768.
I already tried differences hext files. From differend versions. Also tried to install EFO 10.x
My system profiler says: ATI Radeon 4600 series, So thats good. but i cant change the resolution. Also i want it to work on HDMI.
Does anyone have answers for this? beacause it realy make me creazy i used to many kext files and forums.
Sorry for my bad english because in Dutch
with some other kext files my system profiler says now that if installed hd4650, so thats the good news. but the bad news is that the system profiler also says that it is only 256 mb, instead of 1024. My atisupport.text and my atiframebuffer are loaded now. Only no screen res at all :(
Thnx vampire, i fully reinstalled my iatkos s3 v2, with only efi 10.6 as bootloader and for graphics everything out. Im now updating to 10.6.4 with the combo update and then trying youre files :D hope it works!
