NicoX
10.6.4 volume control is not working <|>
Hi All I Joined today :)
I am using HAZARD SL 10.6.2 DVD.
As I am using AMD so I am using AMD patch karnel with chameleon.
I have updated to 10.6.4 successfully. Only problem is my volume control is not working .
I also updated to 10.6.5 but it slowed my XCode and Quartz Core. Caused lots of panics. Any exact process for me to update 10.6.5?
Any help for sound in 10.6.4 ?
Regards
NicoX
AMD Athlon 4000+ 64 bit dual core
Gigabyte GA-MA770UD3
3GB RAM Kingston 512 *2, CORSAIR 1 GB*2 all 667 MHZ
Weston Digital HDD 160GB SATA ( with XP SP3 )
Seagate HDD 500GB SATA (with SL 10.6.2)
hp dvd1260i (SATA DVDRW)
Palit GeForce 9800 GT 1GB
Hi John
Sound is working perfect (I used AppleAzaliaAudio.kext) no creeping. But the volume control is not functioning at all.
If I increase or decrease the sound the speaker icon comes but volume control level remains the same.
NicoX
Amd processors volume control fix= Open Marvin's Amd Utility and patch all binaries.
I try it and volume control is working now.
