AppliArt 193 Posted March 31, 2011 If it is an Update disc, it won't work. :s Share this post Link to post Share on other sites
protools 10 Posted March 31, 2011 Sorry AppliArt, I think It's not an update disc,but I don't have it yet cause I have to borrowed it from my friend. He just bought this "APPLE MacBook Pro [MC375ZA/A] Apple MacBook Intel Core 2 Duo 2.66GHz, 4GB Kit (2x2GB) DDR3, 320GB HDD, DVD±RW, GbE NIC, Wi-Fi, Bluetooth, VGA NVIDIA GeForce GT 320M 256MB, Camera, 13.3" WLED, Mac OS X 10.6 Snow Leopard". So, is it ok I use this disc 10.6 Snow Leopard ? (Is it retail one? or original one?), then later update to 10.6.6? Thank you Share this post Link to post Share on other sites
protools 10 Posted April 1, 2011 Hi AppliArt, finally I got the original/retail Snow Leopard 10.6.4 from my friend- and I follow your guide until Chapter 2 - 9) Now, you'll be prompted with the GUI of the Snow Leopard installer. You may press "Continue". And after that I got the letter say like this : "MAC OS X can't be installed on this computer . If you want to restore your system from a time machine backup, click restore from backup or restart" I took some pictures for you to see. I try to insert here, but I don't know how to do that because everytime I click insert image, there is an instruction say "Please enter the URL of your image" :-( Please brother any help with installation, I really appreciated that. Thankyou Share this post Link to post Share on other sites
protools 10 Posted April 1, 2011 [ATTACH=CONFIG]867[/ATTACH][ATTACH=CONFIG]868[/ATTACH][ATTACH=CONFIG]869[/ATTACH][ATTACH=CONFIG]870[/ATTACH] Share this post Link to post Share on other sites
protools 10 Posted April 1, 2011 When I type march_kernel and -force64 the computer just hang (see picture amd4.jpg) stiil waiting for root device, and finally I didn't type anything just push enter, It went thru Chapter 2 - 9 and stuck (see picture amd6.jpg). :-( , please help me . TQ Share this post Link to post Share on other sites
schokuhfar 10 Posted April 6, 2011 Special thanks. I tried this method on GA-MA790FXT UD5P AMD Phenom II x4 965 8G.B Ram DDR3 Corsair 1333 Nvidia 8400 GS XFX 512 M.B Retail 10.6.3 + Nawcom ModCD + Combo Update 10.6.6 + Legacy Kernel 10.6.7 + MB{censored} 3.4 for fixing restart & shutdown but only I must boot in 32bit + maxmem=4096, it doesn't work with 8G.b that caused to turned off. Also my Lan doesn't work. thanks again :-) Share this post Link to post Share on other sites
