GNOM
Wrong Speed & Ram Bus error ! need help
Hi all Mac Guru :)
i have dell 1520 inspiron
mac 10.6.7
CPU TYPE : Intel? Core2 Duo CPU T7300 @ 2.00GHz , 800 Bus , 200 FSB , 4M Cache
i got 1813MHz Bus: 181MHz FSB: 724MHz
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 1.81 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 725 MHz
Boot ROM Version: MBP41.0073.B00
SMC Version (system): 1.30f3
Serial Number (system): SOMESRLNMBR
Hardware UUID: 9A84F69B-FEC1-5B29-B5A0-D131CB0D4C8B
rams shown as 604 MHz but its 677
Memory Slots:
ECC: Disabled
DIMM_A:
Type: DDR2 SDRAM
Speed: 604 MHz
Status: OK
Manufacturer: Hynix Semiconductor
Part Number: HYMP512S64CP8-Y5AB
Serial Number: 00007077
DIMM_B:
Type: DDR2 SDRAM
Speed: 604 MHz
Status: OK
Serial Number: 04004028
System Software Overview:
System Version: Mac OS X 10.6.7 (10J869)
Kernel Version: Darwin 10.7.0
Boot Volume: MacHD
Boot Mode: Normal
Computer Name: GNOM SYH’s MacBook Pro
User Name: GNOM SYH (gnom)
Secure Virtual Memory: Not Enabled
64-bit Kernel and Extensions: Yes
Time since boot: 34 minutes
please give me idea how to fix it
another Q from log is those errors ok ?:confused:
Mar 24 22:08:38 [1000] kCGErrorIllegalArgument: CGXSetTrackingAreaOption : Invalid tracking area
3/26/11 1:55:17 AM kernel FakeSMC: key info not found VH5Z, length - 6
3/26/11 1:54:52 AM kernel ACPI_SMC_PlatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out
3/26/11 1:54:27 AM kernel systemShutdown false
3/26/11 1:54:25 AM kernel Not loading kext com.apple.driver.AirPortBrcm43xx - not found and kextd not available in early boot.
3/26/11 1:54:25 AM kernel AppleIntelPIIXPATA: Secondary PCI IDE channel is disabled
3/26/11 1:54:25 AM kernel VoodooTSCSyn::doTsc(): stamp_tsc was called: 2 timesIOAPIC: Version 0x20 Vectors 64:87
6 answers to this question
Do you have any trouble with the laptop? crashes slowe downs ect ect if not dont make a big deal out of this.
What version of chameleon are you running? Rc5 trunk xxx ?
The system information its esthetic information, nothing is wrong there, SL is just not recognizing correctly your specs... it can be fixed by doing tweaks... i did it to my hackintosh to get all info show up correctly. could be kinda long.... but here we go:
1. Processor Name/Speed
- With these steps you will fix the information that show "about this mac" window:
a) go to System/Library/CoreServices/loginwindow (right click login window --> show contents) /Contents/Resources/English.lproj
B) there you will find there a file called AboutThisMac.strings, copy this file to your desktop, open it with text edit. once opened find a line that says:
"ABOUT_BOX_SINGLE_PROCESSOR_FIELD_FORMAT" = "PUT HERE THE INFO YOU WANT";
c) once you have edited the AboutThisMac.strings, put it back and replace it.
- With these steps you will fix the information shown on system profiler window:
a) go to system/Library/SystemProfiler look for a file called "SPPlatformReporter.spreporter" (right click SPPlatformReporter.spreporter --> show contents) /Contents/Resources/English.lproj
B) There you will find a file called "Localizable.strings", copy this file to your desktop, open it with text edit. once opened find a line that says:
copy and replace this lines:
cpu_type = "Processor Name";"Intel Core 2 Duo"="Intel? Core2 Duo CPU T7300";
current_processor_speed = "Processor Speed";"1.81 GHz"="2.00 GHz";
bus_speed = "Bus Speed";"725 MHz"="800 MHz";
c) once you have edited the "Localizable.strings", put it back and replace it.
2. Ram Frequency
-With these steps you will fix your Ram Frequency Mhz
a) go to System/Library/Extension/SMBiosResolver.kext (right click SMBiosResolver.kext --> show contents) Contents
B) you will find a file called "Info.Plist" copy this file to your desktop, open it with text edit. once opened find a line that says:
copy and replace this line.
<key>dimm-speed</key>
<string>677</string>
c) once you have edited the "Info.Plist", put it back and replace it. rebuild kext cache and restart.
For the "errors" the only one to worry about its "FakeSMC", this kext controls the temperature reading of cpu and other components.
you can look around the download area for the latest version of FakeSMC and install it with kextUtility, if you need help with that let me know.
Edited by Toltuga
Hi!
If you use Chameleon RC2, you can add smbios.plist file into your /Extra/ folder. In this file you can "show'" your Mac OS:
- Mac Model
- Processor type and frequensy
- Memory type and frequensy
You can download attached file - it's for your configuration. If you interested what I changed in it and how to change it for another configuration - white here, I'll explane.
smbios.plist.zip
Hi!
- Mac Model
thank you very much
memory is ok now
but cpu still 1.81
Hardware Overview:
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 800 MHz
Boot ROM Version: MP31.88Z.00C1.B00.0802091544
Serial Number (system): W87234JHYA4
this is my boot
<key>Default Partition</key>
<string>hd(0,1)</string>
<key>ForceHPET</key>
<key>Kernel</key>
<string>mach_kernel</string>
<key>Kernel Flags</key>
<string>arch=X86_64</string>
<key>RestartFix</key>
<string>No</string>
<key>SMBIOS</key>
<string>/extra/smbios.plist</string>
<key>SMBIOSdefaults</key>
<string>No</string>
<key>Timeout</key>
<string>5</string>
<key>blacklist</key>
About com.apple.boot.plist - try to exclude these strings from it and look at results:
<key>SMBIOS</key>
<string>No</string>
because chameleon is using smbios.plist from /EXTRA/ folder by default.
How to write in smbios.plist "proper" settings(example):
<key>SMproductname</key>
<string>MacPro1,1</string> - here you can change MacModel (it's very important to chose correct MacModel for your HackPC, because it influences on test results and stability of MacOS)
<key>SMexternalclock</key>
<string>333</string> - write here your bus frequency devided by 4 (1333/4=333)
<key>SMmaximalclock</key>
<string>2660</string> - write here your processor frequency
<key>SMmemtype</key>
<string>19</string> - write here your memory type (DDR2 - 19, DDR3 - 20)
<key>SMmemspeed</key>
<string>800</string> - write here your memory frequency
<key>SMcputype</key>
<string>769</string> - write here your processor type (257 - Intel Core Solo, 769 - Intel Core 2 Duo, 1281 - Quad-Core Intel Xeon),for my E5200 DualCore Intel I use 769
Edited by Hoarfrost
