luizcf14
FOXCONN 45GM - No output device found!
Hi guys, i`m have one problem, my Hackintosh (iPC 10.5.6) no found my soundcard onboard, any one can help-me?
iPC:.
>Motherboard: FOXCONN 45GM 775(Link)
>Processor:Pentium 4 3.20Ghz
>Memory: 1Gb
>Video: Nvidia 7300LE 512Mb
Since I'm already grateful for the help everyone, I'm new in forum sorry if I'm posting in the wrong place.
Sorry Kynnder , but i'm not understand this fix, can you explain?
Get your codec dump by following this thread > [HOW TO] Patch AppleHDA - Knowledge Base - Project OS X Forums
And try to made the changes following the tips from the guide by adding the information below to the "info.plist" file inside of the VoodooHDA.kext... (just a example, don`t add this exact info to your kext)
<key>NodesToPatch</key>
<array>
<key>Codec</key>
<integer>2</integer>
<key>Config</key>
<string>0x90a70120</string>
<key>Node</key>
<integer>12</integer>
</array>
A little tricky but not impossible...
:D
