camerongray
[GUIDE] Use more than 4gb RAM on AMD with 32 and 64 bit apps working
Hi guys,
I am having some difficulty in somepoint hope u share how to proceed.
my config:
Asus m4a88t-m (Integrated ATI Radeon™ HD 4250 GPU)
Amd x4 965 black edition
g skill 4gb X 2 ripjaws x
nvidia 9500 gt an old still which I use.
I am following this method How to install Mac OS X Snow Leopard on your AMD system! | osxlatitude.com
so here is my question
1.I have downloaded a mac 10.6 dmg now how can i make it boot from usb as currently I am running windows 7 or should i change the file to iso and burn it on a dual layer dvd.I want to boot from usb as it will install faster i believe and will have no issue reading files while installation.
2.In customization option should i choose amd chipset or nforce chipset as my motherboard has amd card and external I have nvidia.
3.finally since many user had 4gb ram detection so is quite obvious than i need to patch the file provided in the first post.
Sorry if i have too many queries but had confusuion so wanted it to get clear from user who had success.
I patched my OS X 10.6.8 but Final Cut Pro X doesn't run. Not sure if it was after the patch or when I switched video cards (from ATI HD5450 to nVidia GTS 450)
I guess I will shutdown and switch vid. cards and find out if it's the vid. card or the patching. Do I need to patch anything else other than what's listed on the 1st post?
EDIT: Switched back to the ATI HD5450 and got the same error... Here is part of the report:
Process: Final Cut Pro [332]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCut
Version: 10.0 (179114)
Build Info: ProEditor-179110400~1
Code Type: X86-64 (Native)
Parent Process: launchd [116]
Date/Time: 2012-07-23 22:46:53.935 -0400
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 2330971 sec
Crashes Since Last Report: 360
Per-App Interval Since Last Report: 163 sec
Per-App Crashes Since Last Report: 8
Anonymous UUID: 81584EE8-EA6D-44F1-9499-BF0B41057D66
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000018
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.apple.ProGraphics 0x000000010a9e69c3 (anonymous namespace)::PGInfoImpl::PGInfoImpl() + 1715
1 com.apple.ProGraphics 0x000000010a9e6a8f __static_initialization_and_destruction_0(int, int) + 95
2 dyld 0x00007fff5fc0d510 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 228
3 dyld 0x00007fff5fc0bcfc ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 236
4 dyld 0x00007fff5fc0bcad ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 157
5 dyld 0x00007fff5fc0bcad ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 157
6 dyld 0x00007fff5fc0bdb6 ImageLoader::runInitializers(ImageLoader::LinkContext const&) + 58
7 dyld 0x00007fff5fc08fcf dlopen + 573
8 libSystem.B.dylib 0x00007fff89ccee40 dlopen + 61
9 com.apple.CoreFoundation 0x00007fff883ebef7 _CFBundleDlfcnLoadBundle + 231
10 com.apple.CoreFoundation 0x00007fff883eae97 _CFBundleLoadExecutableAndReturnError + 1191
11 com.apple.Foundation 0x00007fff864c1355 _NSBundleLoadCode + 638
12 com.apple.Foundation 0x00007fff864c0c78 -[NSBundle loadAndReturnError:] + 742
13 com.apple.Flexo 0x000000010088b5bb +[FFPluginDirectoryScanner _scanDirectory:withExtension:scanned:delegate:didLoadSelector:] + 747
14 com.apple.Flexo 0x000000010088b295 +[FFPluginDirectoryScanner scanForPluginsInDirectory:withExtension:delegate:didLoadSelector:] + 1109
15 libobjc.A.dylib 0x00007fff802bc325 _class_initialize + 384
16 libobjc.A.dylib 0x00007fff802bc1e2 _class_initialize + 61
17 libobjc.A.dylib 0x00007fff802ca52b prepareForMethodLookup + 234
18 libobjc.A.dylib 0x00007fff802c2cb9 lookUpMethod + 73
19 libobjc.A.dylib 0x00007fff802bafaa objc_msgSend + 198
20 com.apple.Foundation 0x00007fff864c0e2a -[NSBundle loadAndReturnError:] + 1176
21 com.apple.Flexo 0x000000010088b5bb +[FFPluginDirectoryScanner _scanDirectory:withExtension:scanned:delegate:didLoadSelector:] + 747
22 com.apple.Flexo 0x000000010088b295 +[FFPluginDirectoryScanner scanForPluginsInDirectory:withExtension:delegate:didLoadSelector:] + 1109
23 com.apple.Flexo 0x0000000100708064 +[FFEffect(RuntimeBundleLoading) initialize] + 260
24 libobjc.A.dylib 0x00007fff802bc325 _class_initialize + 384
25 libobjc.A.dylib 0x00007fff802ca52b prepareForMethodLookup + 234
26 libobjc.A.dylib 0x00007fff802c2cb9 lookUpMethod + 73
27 libobjc.A.dylib 0x00007fff802bafaa objc_msgSend + 198
28 com.apple.Flexo 0x00000001006eccaa __static_initialization_and_destruction_0(int, int) + 1546
29 dyld 0x00007fff5fc0d510 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 228
30 dyld 0x00007fff5fc0bcfc ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 236
31 dyld 0x00007fff5fc0bcad ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int) + 157
32 dyld 0x00007fff5fc0bdb6 ImageLoader::runInitializers(ImageLoader::LinkContext const&) + 58
33 dyld 0x00007fff5fc0211a dyld::initializeMainExecutable() + 133
34 dyld 0x00007fff5fc06996 dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**) + 2993
35 dyld 0x00007fff5fc016de dyldbootstrap::start(macho_header const*, int, char const**, long) + 811
36 dyld 0x00007fff5fc01052 _dyld_start + 42
Edited by m4f1050
Where would I put this? In the apple.boot.plist?
Depends on what bootloader you're using. In my case I would have to put it in org.chameleon.Boot.plist
Thanks for that maxmem tip. I can get it to boot in 8GB if I type in maxmem=8192 at boot. I've tried editing the apple.boot.plist, but that doesn't work. And still can't get it to boot into 64-bit.
I have not been able to boot directly into x86 without the iB{censored} disc. I've installed Chameleon, Chimera, and just about every other boot loader here, but still cannot boot without disc.
