robdawg08
how can i dual boot osx snow leopard on my system
this is my setup below! right now i am running vmware snow leopard 10.6.6 no problem but i want to be able to dual boot snow leopard or osx lion if possible i have a old amd dual core that i have setup up that dual boots osx snow leopard 10.6.2 by hazard and it runs with no problem any help or a point in the direction would be nice thanks again
motherboard
Manufacturer: Pegatron
Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
Chipset: NVIDIA GeForce 9100
Memory sockets: 4 x DDR3
Front side bus speeds: 5200MT/s (5.2 GT/s)
Processor socket: AM3
Expansion Slots:
1 PCI Express x16 slot for graphics card
2 PCI Express x1 slots
1 PCI slot
1 PCI Express x1 minicard slot
Processor
AMD Phenom II X4 820
Figure 2: AMD Phenom II X4 logo
Operating speed: Up to 2.8 GHz
Number of cores: 4
Socket: AM3/AM2+
Bus speed: 4000 MHz HT3
Memory
8 GB
Amount: 8 GB
Speed: PC3-10600 MB/sec (message as PC3-8500)
Video graphics
Integrated graphics using nVidia GeForce 9100
*Integrated graphics is not available if a graphics card is installed.
Also supports PCI Express x16 graphics cards
Sound/Audio
Integrated Realtek ALC888S Audio
*Integrated audio is not available if a sound card is installed
Audio CODEC: Realtek ALC888S
High Definition 8 channel audio
Supports one S/PDIF digital connection
Networking
LAN: 10-Base-T
Interface: Integrated into motherboard
Technology: Realtek RTL8201N
Data transfer speeds: up to 10/100 Mb/s
Transmission standards: 10-Base-T Ethernet
802.11 Wireless a/b/g/n PCI-Express x1 card
Figure 3: Wireless card - side view (embedded antenna version
Interface type: PCI
Data transfer speeds: up to 54 Mbps
Transmission standards: 802.11 a/b/g/n
Supported antenna connections: 2 (2 internal posts to connect an internal or extenal antenna)
Operating band: 2.4 GHz and 5.0 GHz dual band
Supported security protocols:
WPA
WEP
You can dualboot partitioning your HDD and installing the two OS + use a bootloader such as Chameleon, if that's what you mean.
Lion won't work on AMD :(
